KAN4562-0501B050
KAN4562-0501B050
    GANGYUAN(港源)
    插件,4.5x4.5mm
    轻触开关 4.5*4.5*5mm 插件
KAN4562-0501B050 数据手册
ISO9001: 2015 ISO14001: 2015 APPROVAL SPECIFICATIONS Title. TACT SWITCH Product Model. KAN4562-0501B050 Customer’s Part NO. Customer’s Model: Customer’s Approval Requested. Please return this copy as a certification of your approval. Checked by: Date: Approved by: Date: 温州港源电子有限公司 Wenzhou Gangyuan Electronics Co.,Ltd Address:No.2 Yonghe Yi Road,Chengdong Street,Yueqing City,Zhejiang Province,China. Tel:0577-06571538 Fax:0577-62573066 Website:http://www.gangyuan.com APPROVE REVIEW PREPARE 黄自兵 林庆杰 林云龙 APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 Document No. Page 2/12 变更履历表: 版本 A/01 变更记录 变更存储方法 变更人 林云龙 变 更 日 期 2018.11.03 APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 Document No. Page 3/12 1、 概述 GENERAL 1.1 适用范围 APPLICATION 此规格书适用于机械式轻触开关的相关要求 This specification is applied to the requirements for tactile switch (mechanical contact) 1.2 工作温度范围 Operating Temperature Range -30℃~80℃(在标准大气压、标准湿度条件下) -30℃~80℃(Normal humidity, normal air pressure) 1.3 贮藏温度范围 Storage Temperature Range -40℃~90℃(在标准大气压、标准湿度条件下) -40℃~90℃(Normal humidity, normal air pressure) 1.4 测试条件 Test Conditions 在没有其它特定的条件下,应该在以下的条件下进行测试和测量: Unless otherwise specified, tests and measurement shall be made in the following standard conditions: 常温…………………………………5℃~35℃ Normal temperature………………5℃~35℃ 标准湿度……………………………相对湿度 25%~85% Normal humidity…………………relative humidity 25%~85% 标准大气压…………………………86Kpa~106Kpa Normal air pressure…………………86Kpa~106Kpa 在制造过程中,测试和测量应该在以下的条件下进行: If any doubt arise from the judgment, tests shall be conducted at the following conditions: 温度…………………………………20℃±2℃ Temperature………………………20℃±2℃ 相对湿度……………………………65%±5% Relative humidity…………….......…65%±5% 环境气压…………………………86Kpa~106Kpa Air pressure…………………………86Kpa~106Kpa 1.5 存储方法 Storage method 1.使用前确保包装完整无破损,无浸湿. Ensure that the product without package breaking or wetting before use. 2.存储条件 Storage conditions: 储存温度 Storage temperature:-5 ~ 35 C; 储存湿度 Storage humidity:25% ~80%; 未开封状态:6 个月内使用完毕(从发货日开始计算); 超过 6 个月后再使用的,使用前请先验证:端脚无氧化、无 发黑、塑料件无吸湿起泡,确保焊接的适宜性; Unopened status: Use up the product as soon as possible before 6 months. (calculated from shipment date).Over 6 months, please make sure below before use it: terminal without oxidation or blackening, plastic parts without moisture absorption or bubble, ensure solderability. 已开封状态:1 个月内使用完毕; Opened status: use up within 1 month; 储存注意事项:避开高湿高温和有腐蚀性气体的环境及阳光直射; Storage precautions: Please avoid the following environment: with high humidity, high temperature , corrosive gases and direct sunlight. 3.请勿超重叠放. Do not stack too many switches. APPROVAL SPECIFICATIONS GANGYUAN 2、 Product name P/N Version Tact switch KAN4562-0501B050 A/01 Document No. Page 4/12 详细说明 Detailed specification 2.1 外观:应无影响、降低产品性能的缺陷; Appearance: There should be no defects that affect the serviceability of product. 2.2 结构尺寸和安装尺寸:应符合装配图要求; Style and dimension: shall conform to the assemble drawings. 2.3 操作形式:有触觉反应的操作 Type of actuating: Tactile feedback. 2.4 开关结构:单回路单输出(具体的触点结构在装配图中已绘出); Contact arrangement: 1 pole, 1 throw (Details of contact arrangement are given in the assembly drawings.) 2.5 开关工作额定值:DC 12V 50mA(最大值) Ratings: DC 12V 50mA(Max) DC 1V 10μA(最小值) DC 1V 10μA (Min) 3.电气性能: ELECTRICAL SPECIFICATION 项 目 试 验 条 件 ITEM 3.1 TEST CONDITIONS 接触电阻 Contact Resistance 要求 REQUIREMENTS 在以 5V 10mA 的直流电源或不低于 1KHz 的交流电 源的电路中,以一个等于 2 倍按力的静负荷施加于手柄中 心 Applying a static load of 2 times operating force to the center of the stem, measurements shall be made by 5V DC ≤100mΩ 10mA or more than 1KHz AC small-current contact resistance meter. 在端子之间施加 DC 100V /min 的条件下,测量端子之 间底座、盖板的电阻值 3.2 绝缘电阻 Insulation Resistance Measurement shall be made following application of ≥100MΩ 100V DC potential, across terminals, and across terminals and cover, for one minute. 介质耐压 3.3 Dielectric voltage proof 在端子之间施加 250V AC(50Hz 或 60Hz)/min 250V AC (50Hz or 60Hz) shall be applied across terminals, for one minute. 无击穿、无飞弧 There should be no breakdown and flashover APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 Document No. Page 5/12 项目 试 验 条 件 要求 ITEM TEST CONDITIONS REQUIREMENTS 按照正常使用时的力度轻按手柄中心(每秒 3~4 次), 在导通和断开过程中测试开关抖动 Lightly striking the center of the stem at a rate encountered in normal use (3 to 4 times per second), and bounce shall be tested at “ON” and “OFF” Switch 3.4 触点抖动 Bounce DC3-5V Oscillograph 示波器 5kΩ t ON-10ms max OFF-10ms max t t 为触点抖动时间 4.机械性能: MECHANICAL SPECIFICATION 4.1 4.2 按力 Operating Force 开关垂直于操作方向放置,在开关驱动件顶端中心逐渐施力,测 量开关导通所需的最大力度。 Placing the switch such that the direction of switch operation is vertical and then gradually increasing the load applied to the center of the stem, the maximum load required for the switch to come to a stop shall be measured. 160±50 gf 最大行程 Full Travel 开关垂直于操作方向放置,以一个等于 2 倍按力的静负荷施加在 开关驱动件顶端中心,测量顶端移动的距离。 Placing the switch such that the direction of switch operation is vertical and then applying static load of 2times operating force to the center of the stem; the travel distance for the switch to come to a stop shall be measured. 0.20±0.1mm APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 Document No. 试 验 条 件 要求 ITEM TEST CONDITIONS REQUIREMENTS 回弹力 Return Force 4.4 停止强度 Stop Strength 开关垂直于操作方向放置,从操作方向向驱动件施加 30N 的静负 荷持续 1min。 Placing the switch such that the direction of switch operation is vertical, and then a static load of 30N shall be applied in the direction of stem operation for a period of 1 min. 4.5 手柄拔出 强度 Stem Strength 4.6 6/12 项目 开关垂直于操作方向放置,在开关驱动件顶端中心下降至全行程 后,测量顶端向自由位置转换的力度。 The sample switch is installed such that the direction of switch operation is vertical and upon depressing the stem in its center to the whole travel distance, the force of the stem to return to its free position shall be measured. 4.3 Page 振动 Vibration 开关垂直于操作方向放置,反方向实施最大操作力,并测量手柄 的行程范围。 Placing the switch such that the direction of switch operation is vertical, and then the maximum force to withstand a pull applied opposite to the direction of stem operation shall be measured. 根据以下给定条件进行测试: Measurement shall be made following the test set forth below: (1) 振动频率范围:10~55~10Hz Vibration frequency range: 10 to 55 to 10Hz (2) 振幅(峰-峰):1.5mm Amplitude: 1.5mm (3) 振动方向:包括手柄行程方向在内的三个相互垂直的方向 Direction of vibration:Three mutually perpendicular direction including the direction of stem travel (4) 测试时间:每次 2 小时 20gf Min 无机械和电气损坏 There shall be no sign of damage mechanically and electrically. 20N min. Item 3 Item4.1 Item4.2 Item4.3 Duration: Each 2 hours. 4.7 冲击 Shock 根据下列条件进行冲击试验 Test by following conditions (1)安装方法:正常安装 (1)installation method: normal (2)加速度:784m/s² (2)Acceleration: 784m/s² (3)作用时间:11ms (3)Acting time: 11ms (4)测试方向:6 个方向 冲击次数:每个方向 3 次,共计 18 次 (4)Test direction: 6 directions Times: 3 times/direction ,total 18 times Item3 Item4.1 Item4.2 Item4.3 APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 Document No. Page 7/12 5、环境耐久性: ENVIRONMENTAL SPECIFICATION 项目 试 验 条 件 要求 ITEM TEST CONDITIONS 样品应按照以下实验条件进行测试,实验后样品应放在常温及 标准湿度的环境中 1 小时后做性能测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:-40±2℃ Temperature : -40±2℃ (2) 时间:96h Time: 96h 样品应按照以下实验条件进行测试,实验后样品应放在常温及 标准湿度的环境中 1 小时后做性能测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:90±2℃ temperature:90±2℃ (2) 时间:96h time: 96h 根据下面的测试要求进行 5 次循环的温度周期性测试, 实验后 样品应放在常温及标准湿度的环境中 1 小时后做性能测试。测 试期间样品应保持干燥. After 5 cycles of following conditions, the sample shall be allowed to stand under normal temperature and humidity conditions for 1 h. and measurements shall be made. During the test water drops shall 温度(°C ) be removed. REQUIREMENTS 5.1 低温测试 Resistance to low temperature 5.2 高温测试 Heat resistance 5.3 温度周期性测试 Change of temperature 1个循环 A: B: C: D: E: F: A 0° C B C 5.4 湿温测试 Moisture resistance D E F +90±2° C -40±2° C 2小时 1小时 2小时 1小时 Item3 Item4.1 Item4.2 Item4.3 Item3 Item4.1 Item4.2 Item4.3 Item3 Item4.1 Item4.2 Item4.3 时间(hour) 样品应按照以下实验条件进行测试,实验后样品应放在常温及 标准湿度的环境中 1 小时后做性能测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) 温度:60±2℃ temperature: 60±2℃ (2) 相对湿度:90%~95% relative humidity:90% to 95% (3) 时间:96h time: 96h 接触电阻:≤200mΩ Contact resistance≤200mΩ 绝缘电阻:≥10MΩ Insulation Resistance≥10MΩ Item3.3 Item3.4 Item4.1 Item4.2 Item4.3 APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 5.5 5.6 5.7 Document No. Page 8/12 项目 试 验 条 件 要求 ITEM TEST CONDITIONS REQUIREMENTS 硫化试验 Sulfuration resistance 盐雾试验 Salt Mist 动作寿命 Operation life 样品应按照以下实验条件进行测试,实验后样品应放在常温及 标准湿度的环境中 1 小时后做性能测试: Following the test set forth below the sample shall be left in normal temperature and humidity conditions for 1 h before measurements are made: (1) H2S 气体浓度:3ppm±1ppm H2S gas concentration: 3ppm±1ppm (2) 时间:72h Time: 72h (3) 温度:40±2℃(90~95%RH) temperature: 40±2℃(90~95%RH) 在以下设定条件下进行测量: The switch shall be checked after following test: (1)温度:35℃±2℃ temperature: 35℃±2℃ (2)盐溶液浓度:5±1%(质量百分比) salt solution : 5±1%(solids by mass) (3)时间:8±1h Time: 8±1h 实验后的盐沉积物后水冲掉 After test, salt deposit shall be removed by running water. 根据下面的测试要求进行测试: Measurement shall be made following the test set forth below: (1) DC 12V,50mA 带负载 DC 12V, 50 mA resistive load (2) 按动速率:2 次/秒 Rate of operation: 2 times/s (3) 按力:按力的 1.5 倍 Operating Force:1.5 times as much as Operating Force (4) 无故障寿命:500,000 次 fault-free life:500,000 cycles 接触电阻:≤200mΩ Contact resistance≤200mΩ Item3.3 Item3.4 Item4.1 Item4.2 Item4.3 金属件上没有腐蚀斑点 No remarkable corrosion shall be recognized in metal part. 接触电阻≤1Ω Contact resistance≤1Ω 绝缘电阻≥10MΩ Insulation Resistance≥10MΩ 触点抖动 ON-20ms max Bounce OFF-20ms max 按力:初值的±30% Operating Force: initial value±30% Item3.3 Item4.2 APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 5.8 Document No. 9/12 项目 试 验 条 件 要求 ITEM TEST CONDITIONS REQUIREMENTS 可焊性 Solderability 在以下设定条件下进行测量: Measurements shall be made following the test set forth below: (1) 焊接温度:235±5℃ Solder temperature : 235±5℃ (2) 浸入时间:3s±0.5s Immersion time: 3s±0.5s 6.焊接条件: SOLDERING CONDITIONS: 请按以下条件进行焊接: (1) 焊锡温度:≤350℃ 6.1 Page 手工焊接 Hand soldering (2) 连续焊接时间:≤3 s Please practice according to below conditions: (1) Soldering temperature: ≤350℃ (2) Continuous soldering time: ≤3 s 除边缘外涂层应均匀覆盖 90%以上 Except for the edge, the coating should cover a minimum 90% APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 Document No. 10/12 项目 推 荐 条 件 ITEM Recommended conditions 项目 Items 助焊剂附着量 Flux built-up 预热温度 自动浸焊 6.2 Conditions for Auto-dip Preheating temperature Page 条件 Condition 不附着于零部件贴装面的程度 Mounting surface should not be coated with flax 印刷电路板焊接面的周围温度 100℃ max. Ambient temperature of the soldered surface of PC board. 100℃ max. 预热温度时间 Preheating time 焊接温度 Soldering temperature 焊接浸渍时间 Continuous dipping time 焊接次数 Number of soldering 60s max. 260℃ max. 5s max. 最多两次 2times max. 注意事项(Notes): a、印刷基板的焊盘尺寸参见产品图。 The pad size of the printed substrate is shown in the product diagram. b、在使用烙铁的情况下,焊锡温度应在 350℃以下、3 秒以内。 In the case of using soldering iron, soldering conditions shall be 350℃ max and 3 sec.max. c、防止助焊剂从开关的顶端渗入 Prevent flux penetration from the top of the switch d、开关浸焊后,注意不要用溶剂或类似品清洗开关。 After switches were soldered,please be careful not to clean switches with solvent or other similar products. e、浸焊后,注意不要在顶部施加负荷。 Right after switches were soldered;please be careful not to load to on the knobs of switches. f、注意不要施加超负荷的压力或晃动开关。 Please be cautions not to give excessive static load or shock to switches. g、开关浸焊后,印刷基板注意不要叠放。 Please be careful not to pile up P.W.B.after switches were soldered APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 1 Document No. Page 11/12 1 2 电路图 2 安装示意图 General tolerance:±0.2mm NO. NAME MATERIAL QTY. FINISHING 1 Terminal Brass 1 Silver plating 2 Case PA66 1 Black 3 Contact SUS 1 Ag plating 4 Cover SPCC 1 Cu Sn plating 5 Stem PA66 1 Black APPROVAL SPECIFICATIONS GANGYUAN Product name P/N Version Tact switch KAN4562-0501B050 A/01 Document No. 7、包装规格: 7.1:每个包装袋装 1000 只,每袋放一包干燥剂,封口要紧密 A=145mm、B=145mm 7.2:每个内盒装 4 袋,共 4000 只 包装袋 C=160mm、D=216mm、E=48mm 内盒 7.3:每个外箱装 20 盒,共 80000 只 X=350mm、Y=455、Z=280mm 外箱 Page 12/12
KAN4562-0501B050 价格&库存
很抱歉,暂时无法提供与“KAN4562-0501B050”相匹配的价格&库存,您可以联系我们找货
KAN4562-0501B050
  • 10+0.33999
  • 100+0.27260
  • 300+0.23890
库存:37
