OA3225200MEDB6SI-00
OA3225200MEDB6SI-00
    YXC(扬兴科技)
    SMD3225_6P
    有源晶振 200MHz ±20ppm 3.3V -40℃~+85℃ LVDS
OA3225200MEDB6SI-00 数据手册
PROGRAMMABLE CRYSTAL OSCILLATOR YSO210PR Applications Features ‧10 GB Ethernet, SONET, SATA, SAS, Fibre Channel ‧Freq range:10MHz-1500MHz. ‧Package Size: 3.2*2.5 , 5.0*3.2 7.0*5.0mm. ‧Quartz Crystal Programmable Differential Oscillator. ‧Output LVPECL or LVDS. Specifications Item/Type LVPECL LVDS Output Frequency Range Remarks 10MHZ~1500MHZ Supply Voltage 2.5Vdc ± 10% 3.3Vdc ± 10% Operating Temperature Range -40~+85℃,or specify Storage Temperature Range -55~+125℃ Total Stability ±50ppm Input Resistance 1Mohms Typ Current Consumption 80mA Max 50mA Max Disable Current OE=Vcc,LVPECL=(50)Ω or LVDS=(100)Ω 16mA Typ Output Voltage (LVPECL) VOH=Vcc-1.03 Min -- VOL=Vcc-1.6 Max -- Output Voltage (LVDS) Output Load Condition OE=GND DC characteristics -- VOD= 175mV VOD1, VOD2 -- dVOD=50mV Max. dVOD=|VOD1-VOD2| -- VOS= 1.25V VOS1, VOS2 dVOS=|VOD1-VOD2| DC characteristics -- dVOS=50mV Max. L_PECL=50Ω -- Terminated to Vcc-2.0V -- L_LVDS=100Ω Connected between OUT to OUT Input Voltage VIH=70% VccMin, VIL=30%Vcc Max Output Symmetry 45~55% Rise Time/Fall Time 1nS Max OE terminal LVPECL: Between 20% and 80% of (VOH-VOL), LVDS:Between 20% and 80% Differential Output peak to peak voltage Start-up time 10mS Time at minimum supply voltage to be 0 s Aging ±3ppm 25℃First year, Vcc=2.5V,3.3V 1.0ps Typ. 200MHZ~800MHZ 2.0ps Typ. 801MHZ~1500MHZ Phase Jitter(12KHZ~20MHZ) Pin Dimension Pin #1 #2 #3 #4 #5 #6 FUNCTION OE NC GND OUT+ OUT- VDD Notes: To maintain stable operation provide a 0.01uF to 0.1uF by-pass capacitor at a location as near as possible to the power source terminal of the crystal product (between Vcc-GND). www.yxc.hk 第1页共3页 PROGRAMMABLE CRYSTAL OSCILLATOR YSO210PR Dimensions and Patterns [unit:mm] Package Size – Dimensions (Unit: mm) Recommended Land Pattern (Unit: mm) 3.2*2.5mm 0.60 0.65 1 1 0.70 6 3 2 0.80 6 1 5 2 0 .8 0 Marking 0.90 3 2 0. 80 4 1.05 5 2 . 5 ± 0 .1 0 6 5 4 3 4 1. 6 0 To p V i e w 0.70 3.2±0.10 1 . 60 0.55 B ot to m V i e w 0.55 0.35 1.20 Top View Suggested Layout S id e Vie w 5.0*3.2mm 5.0±0.20 0.64 2 0.89 6 3 5 4 6 5 4 1 2 3 2. 6 0 2 1.60 1 1.20 Marking 1 1.2 7 4 0.9 5 3.2±0.20 6 3 1.27 1.27 To p V i e w 1.3±0.2 B o t t o m Vi e w S i d e Vi e w Top View Suggested Layout 7.0*5.0mm 7 . 0± 0 .2 0 * 6 5 3 4 6 5 4 1 2 3 4. 4 2. 0 2 3 To p V i ew 5 .0 8 B o tt o m Vi e w 5 .0 8 1.3±0.2 S i d e Vi e w 1 2 .0 2 1 .8 2 .5 4 2. 6 Marking 1 1.4 4 1.1 5 5.0±0.20 6 To p V i ew S u g ge s te d L a y o u t Notes: 1.A capacitor of value 0.01uf~0.1uf or higher between Vdd and GND is required. www.yxc.hk 第2页共3页 PROGRAMMABLE CRYSTAL OSCILLATOR YSO210PR Reflow Soldering Profile Temperature Pre Heating Temperature Tp1 ~ Tp2 = + 170 °C Heating Temperature TMlt = + 220 °C Peek Temperature TMax. = + 260 °C Point of measuring In case of Solder ability Terminal. In case of Resistance to soldering heat Surface. +260℃ TMax. +220℃ Tmlt Tp2 Tp1 35s 100s t(time) Test Circuit LVDS LVPECL Taping Specification(Unit: mm) Size(OSC) A B C D E F G H SMD-7050 180±2.0 16.0±0.3 7.50±0.1 5.50±0.1 8.0±0.1 2.00±0.1 61.0±1.0 16.0±1.0 SMD-5032 180±2.0 12.0±0.3 5.40±0.1 3.60±0.1 8.0±0.1 1.70±0.1 61.0±1.0 12.0±1.0 SMD-3225 180±2.0 8.0±0.3 3.40±0.1 2.70±0.1 4.0±0.1 1.50±0.1 61.0±1.0 8.0±1.0 www.yxc.hk 第3页共3页
OA3225200MEDB6SI-00 价格&库存
很抱歉,暂时无法提供与“OA3225200MEDB6SI-00”相匹配的价格&库存,您可以联系我们找货
