XL2EL89CKI-111YLC-50M
    YXC(扬兴科技)
    SMD3225_4P
    无源晶振 50MHz ±10ppm 8pF -40℃~+85℃
XL2EL89CKI-111YLC-50M 数据手册
Crystal Unit YSX321SL Applications Features ‧Smart Wearable ‧Dimensions: 3.20 x 2.50 x 0.70 mm.. ‧High precision and high frequency stability. IOT Communication ‧Standard Frequency: 8~54MHz ‧Extremely good for reducing EMI effect. Specifications(规格参数) Item Symbol Specifications f_nom 8~64MHz - AT Fundamental CL 10pF, 20pF, or specify Frequency Tolerance(频率偏差) (at 25℃ ) f_tol ±10ppm, ±20ppm, or specify Frequency Versus Temperature Characteristics(频率-温度特性) f_tem ±20ppm, or specify Operating Temperature(工作温度) T_use -40~+85℃ or specify Storage Temperature(储存温度) T_stg -55~+125℃ Shunt Capacitance(静态电容) C0 7pF Max. Level of Drive(激励电平) DL 1~200μW Max.(100μW typical) f_age ±3ppm/year Max. Nominal Frequency Range(额定频率范围) Vibration Mode(震动模式) Load Capacitance(负载电容) Aging (老化)(at 25℃ ) Equivalent Series Resistance(等效串联电阻(ESR)) YSX321SL 8 ~ 11.2892MHz 150 Ω Max. 12 ~ 16MHz 80 Ω Max. 17 ~ 64MHz 50 Ω Max. Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Dimensions (Unit: mm) Recommended land pattern(Unit: mm) www.yxc.hk 1
XL2EL89CKI-111YLC-50M 价格&库存
很抱歉,暂时无法提供与“XL2EL89CKI-111YLC-50M”相匹配的价格&库存,您可以联系我们找货
  • 5+0.84294
  • 50+0.67263
  • 150+0.58752
  • 500+0.52359
  • 3000+0.47261
  • 6000+0.44702
库存:13929
