Page 1 of 9
承认书
APPROVAL SHEET
客户代码 Customer :
产品名称 Part Number : 石英晶体谐振器
LK 料号 LK Part No. :
L538G120U11L
产品型号 Holder :
SMD5032 GLASS
标称频率 Frequency :
12.000MHZ 20PF ±10PPM
制造商 Manufacturer :
浙江蓝晶芯微电子有限公司
提交时间 Date :
2023-08-04
制作
DESIGNER
审核
Checked
批准
Approved
客户批准 Customer Approval :
审核
Checked
批准
Approved
(请批准后回签一份 PLEASE RETURN A COPY WITH APPROVAL)
Professional manufacturer of quartz crystal
Http://www.lucki.com.cn
Page 2 of 9
Revision History
No.
Revised Date
Change Content
Approved
Remark
Page 3 of 9
1.This specification applies to SMD quartz crystal unit with a frequency of 8.000MHz.
2. Electrical characteristics
PARAMETER
Normal Frequency
Range
SYMBOL
CONDITIONS
MIN
TYP
MAX
UNIT
Fn
12.000
MHz
Order of vibration
Load capacitance
Fundamental
CL
pF
FL
-10
10
ppm
RR
50
Ω
Drive level
DL
100
300
μW
Shunt capacitance
C0
5
pF
Insulation resistance
IR
DC 100V
500
MΩ
Ω
FDLD
ppm
RLD2
Ω
DLDH2
Ω
FDLDH
ppm
Initial Frequency
Accuracy
Resonance
resistance
DLD2
DLD
Motional capacitance
0.01~100 uW 10STEPS
C1
L
mH
Trim sensitivity
TS
ppm/pF
Autoeciousness
SPDB
±5300PPM of nominal Freq
-3.0
dB
-40
85
Inductance
Operating
temperature range
Storage temperature
range
Aging
T1
±30PPM
fF
-55
125
-3
3
ppm
Page 4 of 9
3. Construction
3.1 Crystal enclosure seal:
Seam seal
resistance weld
cold weld
3.2 crystal enclosure medium
nitrogen
vacuum
dry air
4.Dimension:
5. Marking specification
Page 5 of 9
6.Inside Structure
No.
Name
Material
(1)
Can
Ceramic
(2)
Base
Ceramic
(3)
Blank
Quartz
(4)
Electrode
Ag
(5)
Epoxy
Silicon based
(6)
Soldering Pads
Au plated
Page 6 of 9
7.Taping Dimension and Packing Instruction
7.1
Page 7 of 9
7.2
8.Reliability characteristic:
Item
8.1
8.2
8.3
Solderability
Condition
Specifications
Solder bath temperature:260 ℃ , dwell
A new uniform coating of solder
time:5 seconds,
shall cover a minimum of 95%
Solder: 100% tin
of the surface being immersed.
Resistance to
Solder temperature 260+/-3℃,Immersion
F≤+/-5ppm
soldering
time:10 S
R≤+/-15%+3Ω
heat
Solder bath composition:100% tin
Vibration
The entire frequency range: 10Hz
to
55Hz ,Amplitude:1.5mm
F≤+/-5ppm
R≤+/-15%+3Ω
This motion shall be applied for a period
of 2 h in each of 3 mutually perpendicular
axes(a total of 6h)
8.4
8.5
Drop test
Cold Storage
Drop from 75cm height on 3cm hard
F≤+/-5ppm
wooden board for 6 times
R≤+/-15%+3Ω
The quartz crystal unit shall be stored at a
temperature of –40+/-3℃ for 1000 h.then
it shall be subjected to standard
F≤+/-5ppm
R≤+/-15%+3Ω
atmospheric conditions for 1h after which
measurement shall be made.
Page 8 of 9
8.6
High
temperature
temperature of 40+/-2 ℃ with relative
high
humidity of 95% for 1000h, then it shall
humidity
storage
be subjected to standard atmospheric
(steady state)
conditions
for
2h
after
F≤+/-5ppm
R≤+/-15%+3Ω
which
8.7
Thermal shock
The quartz crystal unit shall be subjected
F≤+/-5ppm
to 50 successive
R≤+/-15%+3Ω
Change of temperature cycles. Each as
shown in table below ,then it shall be
subjected
to
conditions
standard
for
1h
atmospheric
after
which
Temperature
Duration
1.
-40+/-3℃
15minutes
2.
100+/-2℃
15minutes
3.
Transition time
Within 10 seconds
Helium leakage detector shall used to
8.8
Sealing
Leakage rate≤1*10-9 Pa.m3/S
measure the leakage rate of gas through
any
faulty
seal.
Pressure:500Kpa,
duration:120 minutes
8.9
High
temperature
Life test
temperature of 85+/-3℃ for 720h ,then it
shall
be
subjected
to standard
F≤+/-5ppm
R≤+/-15%+3Ω
atmospheric condition for 1h after which
9.All products are RoHs compliant
Page 9 of 9
10. Reflow Profile
High Temperature Infrared /Convection
Note:Temperature shown are applied to body of device
Ts max to TL(Ramp-up Rate)
3℃/second max
Preheat
Temperature Min(Ts Min)
150℃
Temperature Typical( Ts Typ)
175℃
Temperature Max.(Ts Max)
200℃
Time(ts)
60-180 seconds
Ram-up Rate(TL to Tp)
3℃/second Max
Time Maintained Above:
--Temperature(TL)
217℃
--Time(TL)
60-150seconds
Peak Temperature (Tp)
260℃ Max for 10 seconds
Time within 5℃ of actual peak(tp)
20-40 seconds
Ramp-down Rate
6℃/seconds Max
Tune 25℃ to Peak Temperature(t)
8 minutes Max
Moisture Sensitivity Level
Level 1
High Temperature Manual Soldering
260℃ Max for 10 seconds Max, 4 times Max
很抱歉,暂时无法提供与“L538G120U11L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.18973
- 50+0.93718
- 150+0.82893
- 1000+0.69388
- 2000+0.63375
- 5000+0.59763
