8Z25000030
8Z25000030
    TXC(台晶)
    SMD2520_4P
    25MHZ 20PF 10PPM -40TO+105 车规
8Z25000030 数据手册
TXC CORPORATION www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING X'TAL 2.5 × 2.0 NOMINAL FREQ. : 25.000000MHz TXC P/N : 8Z25000030 REVISION : S1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 RoHS Compliant 5 FMT-DOC024 VER.G TXC confidential and proprietary document TXC CORPORATION www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING X'TAL 2.5 × 2.0 NOMINAL FREQ. : 25.000000MHz TXC P/N : 8Z25000030 REVISION : S1 PE/RD QA MFG Robin Huang 17-Sep-18 NOTE: (1)The green product standard set by TXC is based upon the international standards. Related information is publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 VER.G TXC confidential and proprietary document TXC CORPORATION Rev Revise page S1 N/A FMT-DOC024 VER.G TXC P/N: Revise contents Initial released 8Z25000030 REVISION: S1 PAGE: 1 Date Ref.No. Reviser 17-Sep-18 N/A Xiaoyan Jiang TXC confidential and proprietary document TXC CORPORATION TXC P/N: 8Z25000030 REVISION: S1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 DIMENSIONS P.4 3 MARKING P.4 4 FACTORY LOCATION P.4 5 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 6 STRUCTURE ILLUSTRATION P.5 7 EMBOSS CARRIER TAPE & REEL P.6 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS&HANDING CAUTIONS FMT-DOC024 VER.G TXC confidential and proprietary document P.8~9 TXC CORPORATION 8Z25000030 TXC P/N: REVISION: S1 PAGE: 3 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±10℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.009±0.001 g/pcs Electrical Spec. Parameters Symbol Notes Min. 1 Nominal Frequency Typ. Max. Units FL 25.000000 MHz - - Fundamental - - CL 20 pF - 4 Frequency Tolerance - ±10 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±30 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 2 Oscillation Mode 3 Load Capacitance -40 ~ 105 ±2 ℃ ppm 1st Year 8 Drive Level DL - 100 - uW - 9 Equivalent Series Resistance Rr - - 50 Ω - 10 Shunt Capacitance C0 C0 - - 2 pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -55 ~ 125 ℃ FMT-DOC024 VER.G TXC confidential and proprietary document at DC 100V - TXC CORPORATION 8Z25000030 TXC P/N: S1 REVISION: PAGE: 4 2.50±0.10 ■ DIMENSIONS GND 4 4 3 3 2.00±0.10 (Unit:mm) 2 4 1.00 0.85 0.65 0.90 2 GND Connection 0.70±0.10 0.65±0.10 0.80±0.10 1 2 1 0.55MAX 1 3 0.9±0.10 *Coplanarity of solderable areas Camber 0.05 mm Max ■ MARKING T□□□ TXC Logo Frequency Code Pin 1 Location ■ □□□□ Ex.: 25.000000 MHz = 250 Lot Code Production control code Date Code Date Code: MONTH YEAR   JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 2021 A B C D E F G H J K L M 2006 2010 2014 2018 2022 N P Q R S T U V W X Y Z 2007 2011 2015 2019 2023 a b c d e f g h j k l m 2008 2012 2016 2020 2024 n p q r s t u v w x y z *This date code will be cycled every four years Production Location:Taiwan, China(Ningbo), China(Chungking) ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ Temp. (℃ ) 260 220 180 150 10 s ■ SUGGESTED MANUAL SOLDER CONDITION Temperature: 350 ± 10 ℃ Time: 3 sec. Time (sec) 120 s Re-solder times: twice FMT-DOC024 VER.G TXC confidential and proprietary document 60 s Te mp . (℃ ) 260 220 180 150 10 s Ti me 120 TXC CORPORATION TXC P/N: 8Z25000030 s 60 ( se c ) s REVISION: S1 PAGE: 5 ■ STRUCTURE ILLUSTRATION 4 5 3 1 2 NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) 2 Base(Package) Tungsten metalize Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+Pad(Au) + Ni plating + Au plating 3 Crystal blank SiO2 - 4 Conductive adhesive Resin+Ag - 5 Electrode Noble Metal - FMT-DOC024 VER.G TXC confidential and proprietary document - Te mp . (℃ ) 260 220 180 150 10 s Ti me 120 TXC CORPORATION s 8Z25000030 TXC P/N: 60 ( se c ) s REVISION: S1 PAGE: 6 ■ PACKING B E H G F INDEX MARK A DIMENSIONS C Feeding D A B C D E F G H 1.05 2.70 2.25 4.00 8.00 4.00 1.55 1.75 REMARK : Trailer Parts Empty Sealed 160mm(Min) 160mm(Min) (UNIT : mm) Leader 230mm(Min) User direction of feed DIMENSIONS FMT-DOC024 VER.G L L1 W W1 178 13 11.5 8 pcs / Reel (UNIT : mm) Standard Reel Quantity is 3,000 pcs per reel TXC confidential and proprietary document TXC CORPORATION TXC P/N: 8Z25000030 REVISION: S1 PAGE: 7 ■ PACKING Reel Quantity : 1. Reel X 6 (6 Reels) 2. Reel X 12 (12 Reels) 3. Reel X 25 (12 Reels + 13 Reels) 4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 ) Label B Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label B Label A QA Pass (Label A) Size:100 X 100mm (Lable B) Size:80 X 40mm [STORAGE] 1.Don't be caught in the rain. 2.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 3.If customers have special requirements, we can paste labels according to it. FMT-DOC024 VER.G TXC confidential and proprietary document Te mp . (℃ ) 260 220 180 150 10 s Ti me 120 TXC CORPORATION TXC P/N: s 8Z25000030 60 ( se c ) s REVISION: S1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1.1 Drop Test Test Methods Test Criteria A.C 150 cm height, 3 times on concrete floor. Device are shocked to half sine wave ( 1000 G ) three mutually 1.2 Mechanical Shock A.C perpendicular axes each 3 times. 0.5m sec. duration time 1.3 Vibration Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes perpendicular axes each test time 4 Hrs A.C (Total test time 12 Hrs) 1.4 Solder ability Temperature 240 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol E solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2.1 Resistance To Soldering Heat Test Methods Test Criteria Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for 500 ± 12 Hrs 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 500 ± 12 Hrs B.C.D B.C.D Total 100 cycles of the following temperature cycle 1 cycle 125 ± 3℃ 2.4 Temperature cycle B.C.D 25℃ -40 ± 3℃ 10 min. 10 min. 2 min. max. 2.5 High Temp&Humidity FMT-DOC024 VER.G 85℃ ± 3℃, RH 85% , 500Hrs TXC confidential and proprietary document B.C.D put F in ( ℃ ) 1000 2 6 0 2 2 0 B 2 .0 TXC CORPORATION 1 8 0 1 5 0 U se r C d i re cti o n of D W p cs Emp ty G Se a l e d W 1 1 0 Leader s e c E Pro d u cts 1 6 0 mm(Mi n ) H Tra i l e r IN D EX MAR K A L 1 160 mm ( Mi n) L 230 mm ( Mi n ) fe e d 1 2 0 TXC P/N: Tim s e c e ( s e c ) Fe e d in g 6 0 s e c 8Z25000030 REVISION: S1 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±5ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 2 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. Measurement condition Electrical characteristics measured by S&A250B or equivalent. FMT-DOC024 VER.G TXC confidential and proprietary document
8Z25000030 价格&库存
很抱歉,暂时无法提供与“8Z25000030”相匹配的价格&库存,您可以联系我们找货
8Z25000030
    • 5+1.35616
    • 50+1.05138
    • 150+0.92070
    • 500+0.75773
    库存:1245
