XRCD32-5R6M
XRCD32-5R6M
    XR(祥如)
    SMD,3.5x3mm
    5.6UH ±20%
XRCD32-5R6M 数据手册
东莞市祥如电子有限公司 SPECIFICATION FOR APPROVAL CUSTOMER ITEM CUSTOMER No. REF No. SMD POWER INDUCTOR DESCRIPTION No. XRCD32-5R6M ISSUE 0527 WLC090527027 DATE 2023.4.20 VERSION 一、DIMENSION (mm) A 3.0±0.3 B 2.1±0.3 C 3.5±0.3 D 1.0 二、ORDERING CODE XRCD32 - 5R6 M 1 2 3 1.Product type (产品类型) Size cob (尺寸) 2.Inductance value(电感值) 3.Inductance tolerance(电感公差) 4.注:图片丝印为产品尺寸示例图,实际丝印以实物为准。 三、SCHEMATIC: S F E / F / PAGE 1/3 A/0 PREPARED CHECKED APPROVED SPECIFICATION FOR APPROVAL CUSTOMER ITEM CUSTOMER No. REF No. SMD POWER INDUCTOR DESCRIPTION No. 四、ELECTRONIC XRCD32-5R6M ISSUE 0527 WLC090527027 DATE 2023.4.20 VERSION CHARACTERISTICS: ITEM SP TOLERANCE TEST FREQUENCY TEST EQUIPMENT INDUCTANCE 5.6µH ±20% 100KHz/1V VR115 DCR 0.145Ω Max / VR115 IDC 0.9A Max 100KHz TH2812C+TH1772A 五、MATERIAL LIST: No. Material Specification Supply’s name 1 2 3 4 Core Copper wire Carrier tape Cover tape JN4H DR3.5*2.1(SH) B1.5 F1.0 P180-G2Φ0.15mm*16.5TS SP32/12.00mm 9.3mm 六、DIMENSIONS FOR CARRIER TAPES (mm): Part No. A B P K W SP32 8.0±0.3 4.4±0.2 8.0±0.2 3.5±0.2 3.5±0.2 PREPARED CHECKED APPROVED PAGE 2/3 A/0 TEST CUSTOMER DATA CUSTOMER No. REF No. ITEM No. PART NO SMD POWER INDUCTOR ITEM XRCD32-5R6M COIL WLC090527027 QUANTITY DESCRIPTION SPEC 0527 10pcs DATE PAGE 3/3 2023.4.20 P180G2 Φ0.15mm CORE DR TEST FREQ 3.5*2.1 ft=100KHz/1V TEMPERATURE 25ºC HUMIDITY 75% ELECTRICAL TEST DATA Soldeyabili ty SP 5.6± 20% DCR (Ω) 0.145 max 1 5.5 0.145 OK 3.0 2.1 3.5 1.0 OK 2 5.6 0.144 OK 3.0 2.1 3.5 1.0 OK 3 5.6 0.144 OK 3.0 2.1 3.5 1.0 OK 4 5.7 0.145 OK 3.0 2.1 3.5 1.0 OK 5 5.5 0.145 OK 3.0 2.1 3.5 1.0 OK 6 5.7 0.144 OK 3.0 2.1 3.5 1.0 OK 7 5.5 0.143 OK 3.0 2.1 3.5 1.0 OK 8 5.7 0.145 OK 3.0 2.1 3.5 1.0 OK 9 5.5 0.145 OK 3.0 2.1 3.5 1.0 OK 10 5.6 0.144 OK 3.0 2.1 3.5 1.0 OK L (uH) L 0.9A –0A* 100%≥ 90% OREALL DIMENSTON (UNIT: mm) IDC (A) A B C D 0.9 max 3.0± 0.3 2.1± 0.3 3.5± 0.3 1.0 98% × R FEST EQUIPMENT: L □HM2801A □CH-1062A Q □HM2801A ■HM9481 DCR □QJ23 □CH-983 □LCR-745 IDC ■TH2815C+TH1772A ■VR102 □CJ2851 ■TH2511 PREPARED CHECKED APPROVED
XRCD32-5R6M 价格&库存
很抱歉,暂时无法提供与“XRCD32-5R6M”相匹配的价格&库存,您可以联系我们找货
XRCD32-5R6M
  • 20+0.23516
  • 200+0.18592
  • 600+0.16129
  • 3000+0.14282
  • 9000+0.12805
  • 21000+0.12056
库存:128
