JK-SMD400L-16
JK-SMD400L-16
    JK(金科)
    FUSE-2920
JK-SMD400L-16 数据手册
JK-SMD400L-16 PPTC DEVICES Edition:A1 Part Number:Q/JKTD-16-400 Page No: 1 OF 3 Terminal pad materials :Tin-Plated Nickle-copper Terminal pad solderability : Meets EIA specification RS 186-9E and ANSI/J-STD-002 Category 3. Marking : JK400L=2920(400) Table1 :DIMENTION(Unit : mm) Model Marking JK-SMD400L JK400L A B C D Min. Max. Min. Max. Min. Max Min. 6.73 7.98 4.80 5.44 0.50 1.20 0.30 Table2 :PERFORMANCE RATINGS: Model Vmax (Vdc) Imax (A) Ihold @25℃ (A) JK-SMD400L 16.0 40 4.0 Itrip @25℃ (A) Pd Typ (W) 8.00 1.500 Maximum Time To Trip Resistance Current (A) Time (Sec) Rimin (Ω) R1max (Ω) 20.00 4.00 0.010 0.040 Table3:Test Conditions and Standards Item Initial Resistance IH Ttrip .trip Trip endurance Operating Temperature:-40℃ TO Packaging:Bulk ,1500pcs per bag Test conditions 25℃ 25℃,4.00A,30min 25℃,20.00A 16V,100A,1hr 85℃ Standard 0.010~0.040Ω No Trip ≤4.0s No arcing or burning JK-SMD400L-16 PPTC DEVICES Part Number:Q/JKTD-16-400 Edition:A0 Page No: 2 OF 3 Solder reflow conditions ● Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free. ● Devices are not designed to be wave soldered to the bottom side of the board. ● Recommended maximum paste thickness is 0.25mm (0.010inch). ● Devices can be cleaned using standard industry methods and solvents. ● Soldering temprature profile meets RoHs leadfree process. Notes: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements JK-SMD400L-16 PPTC DEVICES Part Number:Q/JKTD-16-400 Edition:A0 Page No: 3 OF 3 Solder reflow conditions Storage The maximum ambient temperature shall not exceed 38 ℃ . Storage temperatures higher than 38 ℃ could result in the deformation of packaging materials. The maximum relative humidity recommended for storage is 60%. High humidity with high temperature can accelerate the oxidation of the solder plating on the termination and reduce the solderability of the components. Sealed plastic bags with desiccant shall be used to reduce the oxidation of the termination and shall only be opened prior to use. The products shall not be stored in areas where harmful gases containing sulfur or chlorine are present WARNING · Use PPTC beyond the maximum ratings or improper use may result in device damage and possible electrical arcing and flame. · PPTC are intended for protection against occasional over current or over temperature fault conditions and should not be used when repeated fault conditions or prolonged trip events are anticipated. · Device performance can be impacted negatively if devices are handled in a manner inconsistent with recommended electronic, thermal, and mechanical procedures for electronic components. · Use PPTC with a large inductance in circuit will generate a circuit voltage (L di/dt) above the rated voltage of the PPTC. · Avoid impact PPTC device its thermal expansion like placed under pressure or installed in limited space. · Contamination of the PPTC material with certain silicon based oils or some aggressive solvents can adversely impact the performance of the devices.PPTC SMD can be cleaned by standard methods. · Requests that customers comply with our recommended solder pad layouts and recommended reflow profile. Improper board layouts or reflow profilecould negatively impact solderability performance of our devices.
JK-SMD400L-16 价格&库存
很抱歉,暂时无法提供与“JK-SMD400L-16”相匹配的价格&库存,您可以联系我们找货
JK-SMD400L-16
    • 5+0.93075
    • 50+0.74931
    • 150+0.65859
    • 1500+0.56225
    • 3000+0.50782
    • 4500+0.48060
    库存:946
