H2101M063D120RL
H2101M063D120RL
    DMBJ(振宝佳)
    插件,D8xL12mm
H2101M063D120RL 数据手册
H2 Series ●Low ESR, high ripple current, high voltage ● ● Load life of 2000 hours at 105℃ RoHS Compliant Specifications Characteristics Items 漏电流 Leakage Current 损耗角正切值tanδ Dissipation Factor 温度特性 Low Temperture Characteristics (Max.Impedance Ratio) -55 ~ +105℃ 35 ~ 160V ±20%(M) (at 20℃,120Hz) 施加额定工作电压2分钟后读数,小于或等于规格值 (at 20℃) I≤0.1CV 或299μA(取大值) Less than or equal to the specified value. After 2 minutes application of rated Voltage at 20 ℃ 35~160 Rated voltage (V) (at 20℃,120Hz) tanδ (Max.) 0.12 Z(-25℃)/Z(+20℃) ≦1.25 Z(-55℃)/Z(+20℃) ≦1.25 (100KHz) 司 使用温度范围 Category Temperture Range 额定工作电压范围 Rated Voltage Range 静电容量允许偏差 Capacitance tolerance 限 公 105℃施加额定工作电压2000小时,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be satisfied when the capacitors are restored to 20℃after application of rated voltage for 2000 hours at 105℃ . Appearance No significant damage ≦±20% of the initial value Capacitance change ≦150% of the specified value D.F.(tanδ) ≦150% of the specified value ESR ≦ The specified value Leakage current 电 子 有 耐久性 Endurence 佳 宝 振 东 莞 市 耐湿负荷特性 Damp Heat (Steady State) 在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be satisfied when the capacitors are restored to 20℃after application of rated voltage for 1000 hours at 60℃,90%~ 95% RH. Appearance No significant damage ≦±20% of the initial value Capacitance change ≦150% of the specified value D.F.(tanδ) ≦150% of the specified value ESR ≦ The specified value Leakage current 浪涌电压=额定电压× 1.15(V) Surge Voltage=Rated voltage × 1.15(V) 在105℃环境中,按充电30秒;放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复后测试,应满足以下要求 The capacitors shall be subjected to 10 00 cycles each consisting of charge with the surge voltages specified at 10 5 ℃ for 30 seconds through a protective resistor (Rc=1k Ω) and discharge for 5 minutes 30 seconds Appearance No significant damage ≦±20% of the initial value Capacitance change ≦150% of the specified value D.F.(tanδ) ≦150% of the specified value ESR ≦ The specified value Leakage current 浪涌电压特性 (Surge Voltage) Dimensions (mm) ΦD P Φd α 5 2.0 0.5 6.3 2.5 0.6 8 3.5 0.6 10 5.0 0.6 (L﹤16)1.0 (16≦L﹤22)1.5 (L≧22)2.0 - 39 - www.zbjdr.com 基本特性参数表 Characteristics Part No/ Ruilong Capacitance. ( uF) Capacitance Tolerance. (%) 120Hz/+20℃ 120Hz/+20℃ 100 Surge Voltage (VDC) tanδ 120Hz/+ 63 72.5 0. 12 ±20 20℃ Leakage +20℃ ESR 100KHz +20℃ (mΩ ) Ripple Current. 100KHz ( mArms) Load Life (Hrs) 630 45 1300 2000 Current 2 min( uA) Categoty Colour Range ΦD L -55~+105℃ 8 12 公 限 有 子 电 佳 宝 振 市 莞 频 率 Frequency( Hz) 东 ◆纹波电流补正 系 数 Rated Ripple Current Coefficient 120Hz≦F ﹤ 1KHz 1KHz≦F ﹤ 10KHz 10KHz≦F ﹤ 100KHz 100KHz≦F ﹤ 500KHz 系 数 Case code 0.05 0.30 0.70 1.00 4/8 Dimensions( mm) Temperture 司 H2101M062D120RL Rated Voltage (VDC) 红色
H2101M063D120RL 价格&库存
很抱歉,暂时无法提供与“H2101M063D120RL”相匹配的价格&库存,您可以联系我们找货
