S0603-S-0.5A
S0603-S-0.5A
    SART(萨特)
    一次性保险丝(熔断) 500mA 32V
S0603-S-0.5A 数据手册
Surface Mount Fuses File No.: JS-S0603-S-00 Revision: H Page: 1/ 6 0603 Size >Slow Blow>S0603-S Series General • Slow Blow • 1.6mm× 0.8mm physical size • Thick film manufacturing method, ceramic substrate, silver fusing element • -55℃~125℃ operating temperature • Excellent environmental integrity • RoHS compliant • Halogen-free • Lead free Agency / Certificate Information Application Agency • Battery pack • PC related equipment and peripherals (Hard driver, Printer, etc.) • Digital camera (Digital still camera) • Game equipment • LCD monitor, LCD modules • Wireless base station • Power supply • Medical device File Number Ampere Range E319512 0.5A~8A Electrical Specifications * ** Typical Cold DCR* (mΩ) Typical I2T** (A2s) 63 870 0.0068 0.75 63 389 0.0177 H 1.0 32 235 0.0746 S0603-S-1.5A K 1. 5 32 93 0.1125 S0603-S-2.0A N 2.0 32 47 0.1752 S0603-S-2.5A O 2.5 32 31 0.4001 S0603-S-3.0A P 3.0 32 23 0.7329 S0603-S-3.5A R 3.5 32 19 0.9758 S0603-S-4.0A S 4.0 32 13 2.1722 8.7 3.3128 6.3 7.8480 5.8 8.5120 5.2 10.5388 Part Number Marking Current Rating (A) Voltage Rating (V) S0603-S-0.5A F 0.5 S0603-S-0.75A G S0603-S-1.0A S0603-S-5.0A T 5.0 32 S0603-S-6.0A 6 6.0 32 S0603-S-7.0A U 7.0 32 S0603-S-8.0A 8 8.0 32 Interrupting Rating (V) 50A 32V DC 35A 32V DC 50A 32V DC Measured at≤10% rated current and 25℃ 2 Melting I T at 10 times of rated current Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S0603-S-00 Revision: H Page: 2/ 6 0603 Size >Slow Blow>S0603-S Series Catalo Part Number Information S 0603—S—1.0A “1.0A” Ampere Rating: 1A “ S” Electrical Characteristic: S = Slow blow “0603” Size Number “ S” Symbol of SART Shape & Dimensions: (mm) Dimensions H Type L (mm) W (mm) T (mm) B (mm) S0603-S 1.60±0.15 0.80±0.15 0.40±0.10 0.30±0.20 Recommended Land Patterns D Materials A C Components Material Body Ceramic Terminations Silver over plated with tin (100%) Element Silver or Silver/Palladium B Dimensions A(mm) B(mm) C(mm) D(mm) Spec 1.00±0.20 3.00±0.50 1.40±0.20 1.00±0.30 Dimensions of Standard Test Board Type Ampere Rating Board Thickness (mm) Copper Layer Thickness (mm) Copper Trace Width (mm) 0.5A~6.0A 1.6 0.035 5.0 7.0A~8.0A 1.6 0.070 7.5 S0603-S Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S0603-S-00 Revision: H Page: 3/ 6 0603 Size >Slow Blow>S0603-S Series I2T VS Time Curve 1.5A 2.0A 2.5A 3.0A 3.5A 4.0A 5.0A 6.0A 7.0A 8.0A 0.5A 100 0.75A 1.0A Time Current Current Curve Time Curve: 100000 8.0A 7.0A 6.0A 5.0A 4.0A 3.5A 3.0A 2.5A 2.0A 1.5A 10000 10 1.0A 0.75A 1 100 0.5A 2 I T (A S) Time (s) 1000 10 2 0.1 1 0.01 0.1 1E-3 1 10 Current (A) 100 0.01 1E-3 0.01 0.1 1 10 Time(s) Electrical Characteristics Type S0603-S Ampere Rating % of Current Rating Opening Time 0.5A~8.0A 100 >4hours 1.0A~8.0A 200 ≤60sec 0.5A~0.75A 250 ≤20sec 0.5A~0.75A 1000 >0.1ms 1.0A~3.0A 1000 >0.3ms 3.5A~8.0A 1000 >0.6ms Temperature Derating Curve Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com 100 Surface Mount Fuses 0603 Size >Slow Blow>S0603-S Series File No.: JS-S0603-S-00 Revision: H Page: 4/ 6 Product Characteristics Recommended Solder Item TestCurve condition/ Methods Performance Standard 100% of current rating No Fusing, 4hours Min. UL248-14 200% of current rating 1.0A~8.0A:≤60sec 250% of current rating 0.5A~0.75A:≤20sec 1000% of current rating 0.5A~0.75A: >0.1ms 1.0A~3.0A: >0.3ms 3.5A~8.0A: >0.6ms Voltage Drop 100% of current rating Deviation between the mean value: <15% IEC60127-4 Temperature Rise 100% of current rating △T<75℃ IEC60127-4 Endurance Test 100 cycles of 1In for 1h “ON”, for 15min “OFF”, then following by 1h at 125%In |△R|:<10% IEC60127-4 Interrupting Ability 0.5A~3.5A: 50A 32V DC 4.0A~6.0A: 35A 32V DC 7.0A~8.0A: 50A 32V DC without permanent arcing, ignition and bursting of fuse link UL248-14 IEC60127-4 Time/Current SART SPEC. Solderability 240℃±5℃, 3sec±0.5sec 95% coverage Min. IEC60127-4 MIL-STD-202 Method 208 Resistance to Soldering 260℃±5℃, 10sec±0.5sec |△R|:<10% Legible appearance MIL-STD-202 Method 210 Bending Test Distance between holding points: 90mm Bending: 1mm, time: 10s |△R|:<10% No mechanical damages IEC60127-4 High Temperature Operating Life T=70℃±2℃, 60%In, 96hours |△R|: <10%; No fusing MIL-STD-202 Method 108 Humidity (Steady State) T=40℃±2℃, 90%~95%RH, 1000hours |△R|: <10% MIL-STD-202 Method 103 Low Temperature Storage T=-55℃±3℃,96hours |△R|: <10% IEC60068-2-1 High Temperature Storage T=125℃±2℃,96hours |△R|: <10% IEC60068-2-2 Salt Spray 5% salt solution,48hours |△R|: <10% Legible appearance MIL-STD-202 Method 101 Thermal Shock 100 cycles between -65℃/+125℃ 60 minutes, each extreme |△R|: <10% No mechanical damages MIL-STD-202 Method 107 Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses File No.: JS-S0603-S-00 Revision: H Page: 5/ 6 0603 Size >Slow Blow>S0603-S Series 1. Infrared Reflow: • Temperature: 260℃ • Time: 5sec Max. • Recommend Reflow profile 2. Wave soldering • Reservoir Temperature: 260℃ • Time in Reservoir: 10secMax. Profile Feature Average Ramp-up Rate(Tsmax to Tp) Preheat Temperature Min.(Tsmin) Temperature Max.(Tsmax) Time(Tsmin to Tsmax) Peak Temperature(Tp) Time within 5℃ of actual Peak Temperature(Tp) Pb-Free Assembly Melting tin time(TL) 20sec~30sec Ramp-down Rate 6℃/sec Max. Time 25℃ to peak Temperature 8minutes Max. 3℃/sec Max. 150℃ 200℃ 60sec~120sec 260℃ 5sec 3.Hand Soldering • Temperature: 350℃ • Time: 5secMax. Packaging • 5000 pieces of fuses in emboss taper and reeled on a 178mm(7 inch) reel. Type A(mm) B(mm) W(mm) E(mm) F(mm) Spec 1.85±0.10 1.10±0.10 8.00±0.20 1.75±0.10 3.50±0.05 Type P(mm) P0(mm) P1(mm) D0(mm) T(mm) Spec 4.00±0.10 4.00±0.10 2.00±0.05 1.50±0.10 0.60±0.10 Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com Surface Mount Fuses 0603 Size >Slow Blow>S0603-S Series File No.: JS-S0603-S-00 Revision: H Page: 6/ 6 Type M(mm) W(mm) T(mm) A(mm) B(mm) C(mm) D(mm) Spec 178.00±2.00 9.50±1.00 12.50±1.50 2.00±0.50 13.00±0.50 21.00±0.50 58.00±2.00 Storage Storage: • The ambient temperature recommended for storage shall be between 5℃~30℃ • The relative humidity recommended for storage shall be between 25%RH~60%RH • Sealed plastic bags with desiccant shall be used to reduce the oxidation of the termination and shall only be opened prior to use • The products shall not be stored in areas where harmful gases containing sulfur or chlorine are present Nanjing SART Science &Technology Development Co., ltd or ANT Technology Company Limited.(A Wholly Owned Subsidiary) ADD.:Maqun Science & Technology Park, Qingma Road 6#, Nanjing, China TEL.:086-25-84354852-8015 FAX.:086-25-83241791 Web.: www.sartfuse.com
S0603-S-0.5A 价格&库存
很抱歉,暂时无法提供与“S0603-S-0.5A”相匹配的价格&库存,您可以联系我们找货
