SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
MVH
High heat resistance, 125℃
Series
・Lower ESR, Higher ripple current
・Endurance : 1,000 to 5,000 hours at 125℃
・Suitable to fit for automotive equipment
・Solvent resistant type except 63 to 450Vdc (see PRECAUTIONS AND GUIDELINES)
・Vibration resistant structure
・RoHS2 Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
MVH
125℃
MVE
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +125℃
10 to 450Vdc
(at 20℃, 120Hz)
±20% (M)
Rated voltage (Vdc)
10 to 100Vdc
160 to 450Vdc
F60 to JA0
I=0.01CV or 3μA, whichever is greater.
I=0.04CV+100
KE0 to MN0
I=0.03CV or 4μA, whichever is greater.
Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage (Vdc)
10V 16V 25V 35V 50V 63V 80V 100V 160 to 250V 400 & 450V
F60 to JA0
0.24 0.20 0.16 0.14 0.14 0.12 0.12 0.10
tanδ (Max.)
KE0 to MN0
0.22 0.18 0.16 0.14 0.12 0.14
0.10
0.20
0.24
When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
3
2
2
2
2
2
2
2
F60 to JA0
Z(-40℃)/Z(+20℃)
6
4
4
3
3
3
3
3
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
2
3
6
KE0 to MN0
Z(-40℃)/Z(+20℃)
8
6
4
3
3
3
3
6
10
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for the specified
time at 125℃.
F60 to H63 (10 to 100Vdc) : 1,000hours
HA0 to JA0 (10 to 100Vdc) : 2,000hours
Time
KE0 to MN0 (10 to 100Vdc) : 5,000hours
KE0 to MN0 (160 to 450Vdc) : 2,000hours
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours (500 hours
for 400 to 450Vdc) at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage
according to Item 4.1 of JIS C 5101-4.
Rated voltage(Vdc)
10 to 50Vdc
63 to 450Vdc
Capacitance change
D.F. (tanδ)
Leakage current
≦500% of the initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
● Terminal
● Terminal
● Size
● Size
Vent
(Except HA0)
0.3max.
L±0.5 (Note)
φD±0.5
P
C±0.2
B±0.2
φD±0.5
W
0.3max.
L±0.5
A±0.2
W
B±0.2
Vent
(Except F60 to HA0)
Code : G(Vibration resistant structure)
code : HA0 to MN0
Size code
P
C±0.2
Code : A
code : F60 to MN0
Note : L±0.3 for F60 and F80
A±0.2
: Dummy terminals
F60
F80
H63
HA0
JA0
KE0
KG5
LH0
LN0
MH0
MN0
D
6.3
6.3
8
8
10
12.5
12.5
16
16
18
18
L
5.7
7.7
6.3
10.0
10.0
13.5
16.0
16.5
21.5
16.5
21.5
A
6.6
6.6
8.3
8.3
10.3
13.0
13.0
17.0
17.0
19.0
19.0
B
6.6
6.6
8.3
8.3
10.3
13.0
13.0
17.0
17.0
19.0
19.0
C
7.2
7.2
9.0
9.0
11.0
13.7
13.7
18.0
18.0
20.0
20.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
1.0 to 1.3
P
1.9
1.9
2.3
3.1
4.5
4.2
4.2
6.5
6.5
6.5
6.5
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E MV H AAA A AA AAA M AAA N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7,10µF:100)
Taping·Tray code
Terminal code (A, G)
Voltage code (ex. 10V:100,50V:500, 100V: 101)
Series code
Category
◆MARKING
F60 to JA0
EX) 35V47µF
74H
47
35V
KE0 to MN0
EX) 16V1,000µF
0V
MVH
1000
16V
Please refer to "Product code guide (surface mount type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
TM
AIchip
MVHSeries
◆STANDARD RATINGS
WV Cap
(Vdc) (µF)
is not solvent resistant (63 to 450Vdc).
Size
code
ESR
Rated ripple
(Ω max./
current
100kHz) (mArms/125℃)
F80
H63
F80
H63
HA0
HA0
JA0
JA0
KE0
LH0
MH0
MH0
MN0
F60
HA0
HA0
JA0
JA0
KE0
KE0
LH0
MH0
MH0
F60
F80
H63
F80
H63
HA0
HA0
JA0
JA0
KE0
KE0
LH0
LH0
MH0
MN0
F60
F60
F80
H63
F80
H63
HA0
HA0
JA0
JA0
KE0
LH0
KG5
LH0
MH0
F60
H63
F80
H63
0.90
0.90
0.90
0.90
0.40
0.40
0.30
0.30
0.14
0.10
0.10
0.10
0.058
1.6
0.40
0.40
0.30
0.30
0.14
0.14
0.10
0.10
0.10
1.6
0.90
0.90
0.90
0.90
0.40
0.40
0.30
0.30
0.14
0.14
0.10
0.10
0.10
0.058
1.6
1.6
0.90
0.90
0.90
0.90
0.40
0.40
0.30
0.30
0.14
0.10
0.11
0.10
0.10
2.8
1.6
2.0
1.6
WV Cap
(Vdc) (µF)
Part No.
Size
code
ESR
Rated ripple
(Ω max./
current
F80
H63
HA0
HA0
JA0
JA0
KE0
KE0
LH0
KG5
LH0
MH0
F80
H63
HA0
HA0
JA0
HA0
JA0
KE0
KG5
LH0
LN0
HA0
HA0
JA0
HA0
JA0
JA0
HA0
HA0
JA0
JA0
KE0
KG5
LH0
MN0
KE0
LH0
MH0
MN0
KE0
LH0
LN0
MH0
MN0
KG5
LN0
MH0
MN0
KE0
LH0
LN0
MH0
KG5
LH0
MN0
2.0
1.6
0.70
0.70
0.50
0.50
0.23
0.23
0.15
0.18
0.15
0.15
2.0
2.0
0.70
0.70
0.50
0.70
0.50
0.25
0.20
0.18
0.11
0.75
0.75
0.55
0.75
0.55
0.55
0.75
0.75
0.55
0.55
0.33
0.26
0.24
0.16
20℃ -40℃ 100kHz 120Hz
10
16
25
35
50
100
100
220
220
220
330
330
470
1,000
2,200
2,200
3,300
4,700
47
100
220
220
330
470
680
680
1,000
2,200
33
47
47
100
100
100
220
220
330
330
470
470
680
680
1,000
10
22
33
33
47
47
47
100
100
220
330
330
470
470
680
10
10
22
22
14.0
14.0
14.0
14.0
6.0
6.0
4.5
4.5
2.1
1.5
1.5
1.5
0.87
24.0
6.0
6.0
4.5
4.5
2.1
2.1
1.5
1.5
1.5
24.0
14.0
14.0
14.0
14.0
6.0
6.0
4.5
4.5
2.1
2.1
1.5
1.5
1.5
0.87
24.0
24.0
14.0
14.0
14.0
14.0
6.0
6.0
4.5
4.5
2.1
1.5
1.5
1.5
1.5
42.0
30.0
30.0
30.0
110
110
110
110
220
220
296
296
750
1,000
1,200
1,200
1,550
69
220
220
296
296
750
750
1,000
1,200
1,200
69
110
110
110
110
220
220
296
296
750
750
1,000
1,000
1,200
1,550
69
69
110
110
110
110
220
220
296
296
750
1,000
900
1,000
1,200
51
83
83
83
Part No.
EMVH100ARA101MF80G
EMVH100ARA101MH63G
EMVH100ARA221MF80G
EMVH100ARA221MH63G
EMVH100□RA221MHA0G
EMVH100□RA331MHA0G
EMVH100□RA331MJA0G
EMVH100□RA471MJA0G
EMVH100□RA102MKE0S
EMVH100□RA222MLH0S
EMVH100□RA222MMH0S
EMVH100□RA332MMH0S
EMVH100□RA472MMN0S
EMVH160ARA470MF60G
EMVH160□RA101MHA0G
EMVH160□RA221MHA0G
EMVH160□RA221MJA0G
EMVH160□RA331MJA0G
EMVH160□RA471MKE0S
EMVH160□RA681MKE0S
EMVH160□RA681MLH0S
EMVH160□RA102MMH0S
EMVH160□RA222MMH0S
EMVH250ARA330MF60G
EMVH250ARA470MF80G
EMVH250ARA470MH63G
EMVH250ARA101MF80G
EMVH250ARA101MH63G
EMVH250□RA101MHA0G
EMVH250□RA221MHA0G
EMVH250□RA221MJA0G
EMVH250□RA331MJA0G
EMVH250□RA331MKE0S
EMVH250□RA471MKE0S
EMVH250□RA471MLH0S
EMVH250□RA681MLH0S
EMVH250□RA681MMH0S
EMVH250□RA102MMN0S
EMVH350ARA100MF60G
EMVH350ARA220MF60G
EMVH350ARA330MF80G
EMVH350ARA330MH63G
EMVH350ARA470MF80G
EMVH350ARA470MH63G
EMVH350□RA470MHA0G
EMVH350□RA101MHA0G
EMVH350□RA101MJA0G
EMVH350□RA221MJA0G
EMVH350□RA331MKE0S
EMVH350□RA331MLH0S
EMVH350□RA471MKG5S
EMVH350□RA471MLH0S
EMVH350□RA681MMH0S
EMVH500ARA100MF60G
EMVH500ARA100MH63G
EMVH500ARA220MF80G
EMVH500ARA220MH63G
50
63
80
100
160
200
250
400
450
33
33
33
47
47
100
100
220
220
330
330
470
10
10
22
33
33
47
47
100
220
330
470
10
22
22
33
33
47
10
22
22
33
47
68
100
220
10
22
33
68
10
22
33
33
47
10
22
22
33
4.7
6.8
10
10
3.3
4.7
10
30.0
83
30.0
83
11.0
160
11.0
160
7.5
247
7.5
247
3.5
550
3.5
550
2.3
850
2.7
700
2.3
850
2.3
920
100
60
110
60
35.0
100
35.0
100
25.0
170
35.0
100
25.0
170
12.5
500
10.0
600
9.0
820
5.5 1,100
50.0
70
50.0
70
35.0
115
50.0
70
35.0
115
35.0
115
50.0
70
50.0
70
35.0
115
35.0
115
16.5
450
13.0
550
12.0
650
8.0
950
100
180
245
380
100
180
250
245
315
110
200
205
260
70
100
140
135
65
85
145
EMVH500ARA330MF80G
EMVH500ARA330MH63G
EMVH500□RA330MHA0G
EMVH500□RA470MHA0G
EMVH500□RA470MJA0G
EMVH500□RA101MJA0G
EMVH500□RA101MKE0S
EMVH500□RA221MKE0S
EMVH500□RA221MLH0S
EMVH500□RA331MKG5S
EMVH500□RA331MLH0S
EMVH500□RA471MMH0S
EMVH630ARA100MF80G
EMVH630ARA100MH63G
EMVH630□RA220MHA0G
EMVH630□RA330MHA0G
EMVH630□RA330MJA0G
EMVH630□RA470MHA0G
EMVH630□RA470MJA0G
EMVH630□RA101MKE0S
EMVH630□RA221MKG5S
EMVH630□RA331MLH0S
EMVH630□RA471MLN0S
EMVH800□RA100MHA0G
EMVH800□RA220MHA0G
EMVH800□RA220MJA0G
EMVH800□RA330MHA0G
EMVH800□RA330MJA0G
EMVH800□RA470MJA0G
EMVH101□RA100MHA0G
EMVH101□RA220MHA0G
EMVH101□RA220MJA0G
EMVH101□RA330MJA0G
EMVH101□RA470MKE0S
EMVH101□RA680MKG5S
EMVH101□RA101MLH0S
EMVH101□RA221MMN0S
EMVH161□RA100MKE0S
EMVH161□RA220MLH0S
EMVH161□RA330MMH0S
EMVH161□RA680MMN0S
EMVH201□RA100MKE0S
EMVH201□RA220MLH0S
EMVH201□RA330MLN0S
EMVH201□RA330MMH0S
EMVH201□RA470MMN0S
EMVH251□RA100MKG5S
EMVH251□RA220MLN0S
EMVH251□RA220MMH0S
EMVH251□RA330MMN0S
EMVH401□RA4R7MKE0S
EMVH401□RA6R8MLH0S
EMVH401□RA100MLN0S
EMVH401□RA100MMH0S
EMVH451□RA3R3MKG5S
EMVH451□RA4R7MLH0S
EMVH451□RA100MMN0S
□ : Enter the appropriate terminal code.
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Rated voltage (Vdc)
Size code
F60 to JA0
10 to 100
KE0 to MN0
160 to 450
KE0 to MN0
Capacitance(µF)
Frequency(Hz)
10
22 to 470
47 to 100
220 to 470
680 to 1,000
2,200 to 3,300
4,700
3.3 to 33
47 to 68
120
0.66
0.93
0.40
0.50
0.60
0.75
0.85
1.00
1.00
1k
0.86
0.97
0.75
0.85
0.87
0.90
0.95
1.50
1.30
10k
0.93
1.00
0.90
0.94
0.95
0.95
0.98
1.75
1.40
100k
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.80
1.50
The endurance of capacitors is reduced with internal
heating produced by ripple current at the rate of halving
the lifetime with every 5℃ rise.
When long life performance is required in actual use, the
rms ripple current has to be reduced.
CAT. No. E1001U
