HHXC500ARA121MJA0G
HHXC500ARA121MJA0G
    NCC(贵弥功)
    AEC-D10X10MM_SM
    贴片混合电解电容;额定电压:50V;额定容量:120uF;精度:20%;外形尺寸(毫米):10×10;额定纹波电流:1600mA(125℃/ 100kHz)寿命:4000小时;温度范围:-55 to ...
HHXC500ARA121MJA0G 数据手册
CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS HXC Surface Mount Upgrade! Series ・80WV model has been introduced to the product range. High ripple current model is now available for JC5 size. ・High reliability and high voltage are realized by hybrid electrolyte HXE ・Endurance with ripple current : 4,000 hours at 125℃ ・Rated voltage range : 16 to 80Vdc, Capacitance range : 6.8 to 560μF Higher temperature Higher ripple ・For high temperature and high reliability applications. (Automotive equipment, Base station equipment, etc.) HXJ HXC Downsized ・RoHS2 Compliant ・Halogen Free Higher temperature ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. HXD ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +125℃ 16 to 80Vdc ±20% (M) I=0.01CV or 3μA, whichever is greater Where, I : Max. leakage current (μA) , C: Nominal capacitance(μF), V : Rated voltage(V) Rated voltage(Vdc) 16V 25V 35V 50V 63V 80V tanδ 0.16 0.14 0.12 0.10 0.08 0.08 (Max.) Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.5 Z(-55℃)/Z(+20℃)≦2.0 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 4,000 hours at 125℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage at 85℃, 85% RH for 2,000 hours. Appearance No significant damage Capacitance change ≦ ±30% of the initial value D.F.(tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Shelf Life Bias Humidity Test ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size ● Size (Except E61 to HA0) (Except F61 to HA0) 0.3max. L±0.3 (Note) 0.3max. φD±0.5 P C±0.2 B±0.2 φD±0.5 W L±0.3 (Note) Note : L±0.5 for HA0 to JC5 A±0.2 Note : L±0.5 for HA0 to JC5 2 3 4 H HXC 5 6 7 8 9 10 RA A±0.2 Size Code E61 F61 F80 HA0 JA0 JC5 φD 5 6.3 6.3 8 10 10 L 5.8 5.8 7.7 10.0 10.0 12.5 A 5.3 6.6 6.6 8.3 10.3 10.3 B 5.3 6.6 6.6 8.3 10.3 10.3 C 5.9 7.2 7.2 9.0 11.0 11.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 0.7 to 1.1 P 1.4 1.9 1.9 3.1 4.5 4.5 : Dummy terminals ◆MARKING ◆PART NUMBERING SYSTEM 1 W P C±0.2 Vent Vent Code : G(Vibration resistant structure) code : F61 to JC5 B±0.2 Code : A code : E61 to JC5 11 12 13 14 M 15 16 17 18 G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 100µF:101) Taping code Terminal code Voltage code (ex. 35V:350, 80V:800) Series code Category EX) 35V270µF 47E 270 V HC ●Rated voltage symbol Rated voltage (Vdc) 16 25 35 50 63 80 Symbol C E V H J K Please refer to "Product code guide (conductive polymer hybrid type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V Ver.2 2021 CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXCSeries Upgrade! ◆STANDARD RATINGS WV (Vdc) 16 25 35 50 63 80 Cap (µF) Size code ESR (mΩmax./20℃, 100kHz) Rated ripple current (mArms/125℃, 100kHz) Part No. 47 82 150 270 470 560 33 47 56 68 100 150 220 270 330 470 22 27 47 47 68 100 150 150 270 330 10 15 22 33 33 47 56 68 100 120 150 6.8 10 10 22 22 33 33 47 56 82 100 22 39 47 E61 F61 F80 HA0 JA0 JC5 E61 F61 F61 F80 F80 HA0 HA0 JA0 JA0 JC5 E61 F61 F61 F80 F80 HA0 HA0 JA0 JA0 JC5 F61 F80 F61 F80 HA0 HA0 JA0 HA0 JA0 JA0 JC5 F61 F61 F80 F80 HA0 HA0 JA0 HA0 JA0 JA0 JC5 HA0 JA0 JA0 80 45 27 22 18 15 80 50 50 30 30 27 27 20 20 16 100 60 60 35 35 27 27 20 20 17 80 40 80 40 30 30 25 30 25 25 19 120 120 80 80 40 40 30 40 30 30 22 45 35 33 550 950 1,450 1,700 2,100 2,550 550 900 900 1,400 1,400 1,600 1,600 2,000 2,000 2,500 550 900 900 1,400 1,400 1,600 1,600 2,000 2,000 2,400 750 1,100 750 1,100 1,250 1,250 1,600 1,250 1,600 1,600 2,250 700 700 900 900 1,100 1,100 1,400 1,100 1,400 1,400 2,100 1,100 1,200 1,700 HHXC160ARA470ME61G HHXC160□RA820MF61G HHXC160□RA151MF80G HHXC160□RA271MHA0G HHXC160□RA471MJA0G HHXC160□RA561MJC5G HHXC250ARA330ME61G HHXC250□RA470MF61G HHXC250□RA560MF61G HHXC250□RA680MF80G HHXC250□RA101MF80G HHXC250□RA151MHA0G HHXC250□RA221MHA0G HHXC250□RA271MJA0G HHXC250□RA331MJA0G HHXC250□RA471MJC5G HHXC350ARA220ME61G HHXC350□RA270MF61G HHXC350□RA470MF61G HHXC350□RA470MF80G HHXC350□RA680MF80G HHXC350□RA101MHA0G HHXC350□RA151MHA0G HHXC350□RA151MJA0G HHXC350□RA271MJA0G HHXC350□RA331MJC5G HHXC500□RA100MF61G HHXC500□RA150MF80G HHXC500□RA220MF61G HHXC500□RA330MF80G HHXC500□RA330MHA0G HHXC500□RA470MHA0G HHXC500□RA560MJA0G HHXC500□RA680MHA0G HHXC500□RA101MJA0G HHXC500□RA121MJA0G HHXC500□RA151MJC5G HHXC630□RA6R8MF61G HHXC630□RA100MF61G HHXC630□RA100MF80G HHXC630□RA220MF80G HHXC630□RA220MHA0G HHXC630□RA330MHA0G HHXC630□RA330MJA0G HHXC630□RA470MHA0G HHXC630□RA560MJA0G HHXC630□RA820MJA0G HHXC630□RA101MJC5G HHXC800□RA220MHA0G HHXC800□RA390MJA0G HHXC800□RA470MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) to 15 to 39 to 220 to Frequency(Hz) 10 33 150 560 120 0.03 0.07 0.10 0.13 1k 0.30 0.30 0.40 0.45 5k 0.50 0.50 0.60 0.65 10k 0.60 0.60 0.70 0.75 20k 0.70 0.70 0.80 0.85 30k 0.75 0.75 0.80 0.85 100k to 500k 1.00 1.00 1.00 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V Ver.2 2021
HHXC500ARA121MJA0G 价格&库存
很抱歉,暂时无法提供与“HHXC500ARA121MJA0G”相匹配的价格&库存,您可以联系我们找货
HHXC500ARA121MJA0G
    • 1+27.785541+3.47707
    • 10+16.9681410+2.12339
    • 30+13.1250030+1.64246
    • 50+12.3529550+1.54584
    • 100+11.77819100+1.47392
    • 300+11.40074300+1.42669
    • 500+11.32353500+1.41702
    库存:328
    HHXC500ARA121MJA0G
    • 1+10.094391+1.26321
    • 10+6.4515010+0.80734
    • 50+4.9259850+0.61644
    • 100+4.44238100+0.55592
    库存:1
    HHXC500ARA121MJA0G
    • 500+3.60883500+0.45161
    • 1000+3.346201000+0.41875
    • 1500+3.213721500+0.40217
    • 2500+3.065962500+0.38368
    • 3500+2.979103500+0.37281
    • 5000+2.895195000+0.36231
    • 6000+2.855306000+0.35731
    • 12000+2.7203112000+0.34042
    • 12500+2.7131012500+0.33952
    库存:1
