EMLA350ARA221MHA0G
EMLA350ARA221MHA0G
    NCC(贵弥功)
    AEC-D8X10MM_SM
    220UF ±20% 35V
EMLA350ARA221MHA0G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM AIchip Low impedance, 105℃ MLA - Series ・Low impedance, long life ・Rated voltage 6.3 to 50V, Capacitance 10 to 1,000µF ・Case sizeφ5×5.8L to φ10×10L ・Suitable for applications requiring long life and low impedance such as equipment in continuous operation, industrial applications, etc. ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant MVY Longer life MLA ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 6.3 to 50Vdc (at 20℃, 120Hz) ±20%(M) I=0.01CV or 3μA, whichever is greater Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage(Vdc) 6.3V 10V 16V 25V 35V 50V E61 to F61 0.28 0.24 0.22 0.16 0.13 0.12 F80 0.32 0.27 0.24 0.16 0.13 0.12 tanδ (Max.) HA0 to JA0 0.28 0.24 0.22 0.16 0.13 0.12 (at 20℃, 120Hz) Rated voltage(Vdc) 6.3V 10V 16V 25V 35V 50V Z(-25℃)/Z(+20℃) 4 3 2 2 2 2 Z(-40℃)/Z(+20℃) 10 7 5 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 3,000 hours at 105℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. impedance Ratio) Endurance Shelf life ◆DIMENSIONS [mm] ●Terminal ◆MARKING Code : A Vent for JA0 Size code E61 F61 F80 HA0 JA0 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.3 (Note) D 5 6.3 6.3 8 10 C B A L 5.8 5.3 5.3 5.9 5.8 6.6 6.6 7.2 7.7 6.6 6.6 7.2 10.0 8.3 8.3 9.0 10.0 10.3 10.3 11.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 P 1.4 1.9 1.9 3.1 4.5 EX) 16V100µF 4R 100 CLA A±0.2 Note : L±0.5 for HA0 and JA0 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ●Rated 18 E MLA AAA A RA AAA M AAA G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 10µF:100,100µF:101) Taping code Terminal code Voltage code (ex. 6.3V:6R3,10V:100,50V:500) Series code Category voltage symbol Rated voltage (Vdc) Symbol j 6.3 A 10 C 16 E 25 V 35 H 50 Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V 2021 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS MLASeries TM AIchip Low impedance, 105℃ - ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 25 Cap (µF) Rated ripple Impedance current Size tanδ (Ω max./20℃, code (mArms/105℃, 100kHz) 100kHz) 47 100 150 220 330 330 470 1,000 33 47 100 150 220 220 330 470 22 33 47 100 100 150 220 220 330 470 470 10 22 22 E61 F61 F61 F80 F80 HA0 HA0 JA0 E61 F61 F61 F61 F80 HA0 HA0 HA0 E61 F61 F61 F61 F80 F80 F80 HA0 HA0 HA0 JA0 E61 E61 F61 0.28 0.28 0.28 0.32 0.32 0.28 0.28 0.28 0.24 0.24 0.24 0.24 0.27 0.24 0.24 0.24 0.22 0.22 0.22 0.22 0.24 0.24 0.24 0.22 0.22 0.22 0.22 0.16 0.16 0.16 1.30 0.70 0.70 0.70 0.70 0.16 0.16 0.08 1.30 0.70 0.70 0.70 0.70 0.16 0.16 0.16 1.30 0.70 0.70 0.70 0.70 0.70 0.70 0.16 0.16 0.16 0.08 1.30 1.30 0.70 95 140 140 230 230 600 600 850 95 140 140 140 230 600 600 600 95 140 140 140 230 230 230 600 600 600 850 95 95 140 Part No. EMLA6R3ARA470ME61G EMLA6R3ARA101MF61G EMLA6R3ARA151MF61G EMLA6R3ARA221MF80G EMLA6R3ARA331MF80G EMLA6R3ARA331MHA0G EMLA6R3ARA471MHA0G EMLA6R3ARA102MJA0G EMLA100ARA330ME61G EMLA100ARA470MF61G EMLA100ARA101MF61G EMLA100ARA151MF61G EMLA100ARA221MF80G EMLA100ARA221MHA0G EMLA100ARA331MHA0G EMLA100ARA471MHA0G EMLA160ARA220ME61G EMLA160ARA330MF61G EMLA160ARA470MF61G EMLA160ARA101MF61G EMLA160ARA101MF80G EMLA160ARA151MF80G EMLA160ARA221MF80G EMLA160ARA221MHA0G EMLA160ARA331MHA0G EMLA160ARA471MHA0G EMLA160ARA471MJA0G EMLA250ARA100ME61G EMLA250ARA220ME61G EMLA250ARA220MF61G WV (Vdc) 25 35 50 Cap (µF) 33 47 47 100 100 150 220 330 330 470 10 22 33 33 47 100 100 150 220 220 330 10 22 33 47 47 100 100 150 220 Rated ripple Impedance current Size tanδ (Ω max./20℃, code (mArms/105℃, 100kHz) 100kHz) F61 F61 F80 F80 HA0 HA0 HA0 HA0 JA0 JA0 E61 F61 F61 F80 F80 F80 HA0 HA0 HA0 JA0 JA0 F61 F61 F80 F80 HA0 HA0 JA0 JA0 JA0 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.13 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.70 0.70 0.70 0.70 0.16 0.16 0.16 0.16 0.08 0.08 1.30 0.70 0.70 0.70 0.70 0.70 0.16 0.16 0.16 0.08 0.08 2.00 2.00 1.60 1.60 0.34 0.34 0.18 0.18 0.18 140 140 230 230 600 600 600 600 850 850 95 140 140 230 230 230 600 600 600 850 850 70 70 100 100 350 350 670 670 670 Part No. EMLA250ARA330MF61G EMLA250ARA470MF61G EMLA250ARA470MF80G EMLA250ARA101MF80G EMLA250ARA101MHA0G EMLA250ARA151MHA0G EMLA250ARA221MHA0G EMLA250ARA331MHA0G EMLA250ARA331MJA0G EMLA250ARA471MJA0G EMLA350ARA100ME61G EMLA350ARA220MF61G EMLA350ARA330MF61G EMLA350ARA330MF80G EMLA350ARA470MF80G EMLA350ARA101MF80G EMLA350ARA101MHA0G EMLA350ARA151MHA0G EMLA350ARA221MHA0G EMLA350ARA221MJA0G EMLA350ARA331MJA0G EMLA500ARA100MF61G EMLA500ARA220MF61G EMLA500ARA330MF80G EMLA500ARA470MF80G EMLA500ARA470MHA0G EMLA500ARA101MHA0G EMLA500ARA101MJA0G EMLA500ARA151MJA0G EMLA500ARA221MJA0G ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 10 to 150 220 to 470 1,000 120 0.40 0.50 0.60 1k 0.75 0.85 0.87 10k 0.90 0.94 0.95 100k 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001V 2021
EMLA350ARA221MHA0G 价格&库存
很抱歉,暂时无法提供与“EMLA350ARA221MHA0G”相匹配的价格&库存,您可以联系我们找货
EMLA350ARA221MHA0G
  • 1+7.212471+0.93728
  • 10+4.5476910+0.59099
  • 50+3.4149750+0.44379
  • 100+3.05701100+0.39727
库存:752
EMLA350ARA221MHA0G
    • 1+1.759531+0.22866
    • 100+1.59432100+0.20719
    • 300+1.25563300+0.16318
    • 500+1.18129500+0.15351
    • 1000+1.131721000+0.14707
    • 4000+1.090424000+0.14171
    • 5000+1.090425000+0.14171
    库存:1666
    EMLA350ARA221MHA0G
    • 500+2.38223500+0.30958
    • 1000+2.191161000+0.28475
    • 1500+2.094571500+0.27220
    • 2500+1.986972500+0.25821
    • 3500+1.923683500+0.24999
    • 5000+1.862525000+0.24204
    库存:752
    EMLA350ARA221MHA0G
      • 1000+0.99000
      库存:3367
