SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
Low impedance, 105℃
MLA
Series
・Low impedance, long life
・Rated voltage 6.3 to 50V, Capacitance 10 to 1,000µF
・Case sizeφ5×5.8L to φ10×10L
・Suitable for applications requiring long life and low impedance such as
equipment in continuous operation, industrial applications, etc.
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
MVY
Longer life
MLA
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
6.3 to 50Vdc
(at 20℃, 120Hz)
±20%(M)
I=0.01CV or 3μA, whichever is greater
Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
(at 20℃ after 2 minutes)
Rated voltage(Vdc)
6.3V 10V 16V 25V 35V 50V
E61 to F61 0.28 0.24 0.22 0.16 0.13 0.12
F80
0.32 0.27 0.24 0.16 0.13 0.12
tanδ (Max.)
HA0 to JA0 0.28 0.24 0.22 0.16 0.13 0.12
(at 20℃, 120Hz)
Rated voltage(Vdc)
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
Z(-40℃)/Z(+20℃)
10
7
5
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 3,000 hours
at 105℃.
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. impedance Ratio)
Endurance
Shelf life
◆DIMENSIONS [mm]
●Terminal
◆MARKING
Code : A
Vent for JA0
Size code
E61
F61
F80
HA0
JA0
P
C±0.2
B±0.2
φD±0.5
W
0.3max.
L±0.3 (Note)
D
5
6.3
6.3
8
10
C
B
A
L
5.8 5.3 5.3 5.9
5.8 6.6 6.6 7.2
7.7 6.6 6.6 7.2
10.0 8.3 8.3 9.0
10.0 10.3 10.3 11.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.4
1.9
1.9
3.1
4.5
EX) 16V100µF
4R
100
CLA
A±0.2
Note : L±0.5 for HA0 and JA0
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
●Rated
18
E MLA AAA A RA AAA M AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 10µF:100,100µF:101)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100,50V:500)
Series code
Category
voltage symbol
Rated voltage (Vdc) Symbol
j
6.3
A
10
C
16
E
25
V
35
H
50
Please refer to "Product code guide (surface mount type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001V 2021
MLASeries
TM
AIchip
Low impedance, 105℃
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
Cap
(µF)
Rated ripple
Impedance
current
Size
tanδ (Ω max./20℃,
code
(mArms/105℃,
100kHz)
100kHz)
47
100
150
220
330
330
470
1,000
33
47
100
150
220
220
330
470
22
33
47
100
100
150
220
220
330
470
470
10
22
22
E61
F61
F61
F80
F80
HA0
HA0
JA0
E61
F61
F61
F61
F80
HA0
HA0
HA0
E61
F61
F61
F61
F80
F80
F80
HA0
HA0
HA0
JA0
E61
E61
F61
0.28
0.28
0.28
0.32
0.32
0.28
0.28
0.28
0.24
0.24
0.24
0.24
0.27
0.24
0.24
0.24
0.22
0.22
0.22
0.22
0.24
0.24
0.24
0.22
0.22
0.22
0.22
0.16
0.16
0.16
1.30
0.70
0.70
0.70
0.70
0.16
0.16
0.08
1.30
0.70
0.70
0.70
0.70
0.16
0.16
0.16
1.30
0.70
0.70
0.70
0.70
0.70
0.70
0.16
0.16
0.16
0.08
1.30
1.30
0.70
95
140
140
230
230
600
600
850
95
140
140
140
230
600
600
600
95
140
140
140
230
230
230
600
600
600
850
95
95
140
Part No.
EMLA6R3ARA470ME61G
EMLA6R3ARA101MF61G
EMLA6R3ARA151MF61G
EMLA6R3ARA221MF80G
EMLA6R3ARA331MF80G
EMLA6R3ARA331MHA0G
EMLA6R3ARA471MHA0G
EMLA6R3ARA102MJA0G
EMLA100ARA330ME61G
EMLA100ARA470MF61G
EMLA100ARA101MF61G
EMLA100ARA151MF61G
EMLA100ARA221MF80G
EMLA100ARA221MHA0G
EMLA100ARA331MHA0G
EMLA100ARA471MHA0G
EMLA160ARA220ME61G
EMLA160ARA330MF61G
EMLA160ARA470MF61G
EMLA160ARA101MF61G
EMLA160ARA101MF80G
EMLA160ARA151MF80G
EMLA160ARA221MF80G
EMLA160ARA221MHA0G
EMLA160ARA331MHA0G
EMLA160ARA471MHA0G
EMLA160ARA471MJA0G
EMLA250ARA100ME61G
EMLA250ARA220ME61G
EMLA250ARA220MF61G
WV
(Vdc)
25
35
50
Cap
(µF)
33
47
47
100
100
150
220
330
330
470
10
22
33
33
47
100
100
150
220
220
330
10
22
33
47
47
100
100
150
220
Rated ripple
Impedance
current
Size
tanδ (Ω max./20℃,
code
(mArms/105℃,
100kHz)
100kHz)
F61
F61
F80
F80
HA0
HA0
HA0
HA0
JA0
JA0
E61
F61
F61
F80
F80
F80
HA0
HA0
HA0
JA0
JA0
F61
F61
F80
F80
HA0
HA0
JA0
JA0
JA0
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.13
0.13
0.13
0.13
0.13
0.13
0.13
0.13
0.13
0.13
0.13
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.70
0.70
0.70
0.70
0.16
0.16
0.16
0.16
0.08
0.08
1.30
0.70
0.70
0.70
0.70
0.70
0.16
0.16
0.16
0.08
0.08
2.00
2.00
1.60
1.60
0.34
0.34
0.18
0.18
0.18
140
140
230
230
600
600
600
600
850
850
95
140
140
230
230
230
600
600
600
850
850
70
70
100
100
350
350
670
670
670
Part No.
EMLA250ARA330MF61G
EMLA250ARA470MF61G
EMLA250ARA470MF80G
EMLA250ARA101MF80G
EMLA250ARA101MHA0G
EMLA250ARA151MHA0G
EMLA250ARA221MHA0G
EMLA250ARA331MHA0G
EMLA250ARA331MJA0G
EMLA250ARA471MJA0G
EMLA350ARA100ME61G
EMLA350ARA220MF61G
EMLA350ARA330MF61G
EMLA350ARA330MF80G
EMLA350ARA470MF80G
EMLA350ARA101MF80G
EMLA350ARA101MHA0G
EMLA350ARA151MHA0G
EMLA350ARA221MHA0G
EMLA350ARA221MJA0G
EMLA350ARA331MJA0G
EMLA500ARA100MF61G
EMLA500ARA220MF61G
EMLA500ARA330MF80G
EMLA500ARA470MF80G
EMLA500ARA470MHA0G
EMLA500ARA101MHA0G
EMLA500ARA101MJA0G
EMLA500ARA151MJA0G
EMLA500ARA221MJA0G
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
10 to 150
220 to 470
1,000
120
0.40
0.50
0.60
1k
0.75
0.85
0.87
10k
0.90
0.94
0.95
100k
1.00
1.00
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
很抱歉,暂时无法提供与“EMLA250ARA221MHA0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.29482
- 50+1.03788
- 150+0.92783
- 500+0.75989
- 2500+0.69866
- 5000+0.66194
- 国内价格 香港价格
- 1+6.764221+0.84647
- 10+4.2496710+0.53180
- 50+3.1962850+0.39998
- 100+2.86094100+0.35802
- 国内价格 香港价格
- 500+2.28276500+0.28567
- 1000+2.100381000+0.26284
- 1500+2.008381500+0.25133
- 2500+1.905712500+0.23848
- 3500+1.845343500+0.23093
- 5000+1.787025000+0.22363
- 6000+1.759296000+0.22016
- 12000+1.6654212000+0.20841
- 12500+1.6604212500+0.20779
