SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
TM
AIchip
MVL
Series
3000 to 5000-hours-life, 105℃
MVL
・Endurance : 3,000 to 5,000 hours at 105℃
・Suitable for applications requiring long life such as continuously operating
equipment, industrial applications, etc
・Solvent resistant type (see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
Longer life
MVJ
◆SPECIFICATIONS
Items
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. impedance Ratio)
Endurance
Shelf Life
Characteristics
-40 to +105℃
6.3 to 50Vdc
(at 20℃,120Hz)
±20%(M)
I=0.03CV or 4μA, whichever is greater
Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V)
(at 20℃, after 2 minutes)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V
Max. tanδ
0.28 0.24 0.20 0.16 0.13 0.12
(at 20℃,120Hz)
Rated voltage(Vdc)
Z(-25℃)/Z(+20℃)
4
3
2
2
2
2
Z(-40℃)/Z(+20℃)
10
7
5
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for
specified time at 105℃.
D60 to F80:3,000 hours
Time
HA0 & JA0:5,000 hours
Capacitance change
≦±30% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
D.F. (tanδ)
Leakage current
◆DIMENSIONS [mm]
●Terminal
◆PART NUMBERING SYSTEM
Code : A
1
P
C±0.2
B±0.2
φD±0.5
W
0.3max.
L±0.3 (Note)
A±0.2
Note : L±0.5 for HA0 and JA0
A
L
D
5.7 4.3
4
5.7 5.3
5
6.3 5.7 6.6
6.3 7.7 6.6
8 10.0 8.3
10 10.0 10.3
3
4
5
6
7
8
9
10
11
12
13
14
15
16
◆MARKING
17
EX) 16V47µF
18
E MV L AAA A RA AAA M AAA G
Vent for JA0
Size code
D60
E60
F60
F80
HA0
JA0
2
B
4.3
5.3
6.6
6.6
8.3
10.3
C
5.1
5.9
7.2
7.2
9.0
11.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.0
1.4
1.9
1.9
3.1
4.5
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7,10µF:100)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100,50V:500)
Series code
Category
9hL
47
16V
Please refer to "Product code guide (surface mount type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001V 2021
TM
AIchip
MVLSeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
Cap
(µF)
Size code tanδ
22
47
100
220
330
1,000
33
220
10
22
47
100
470
33
47
100
330
D60
E60
F60
F80
HA0
JA0
E60
HA0
D60
E60
F60
F80
JA0
F60
F80
HA0
JA0
0.28
0.28
0.28
0.28
0.28
0.28
0.24
0.24
0.20
0.20
0.20
0.20
0.20
0.16
0.16
0.16
0.16
Rated ripple
current
(mArms/
105℃, 120Hz)
Part No.
22
36
60
101
160
313
35
141
18
30
50
81
254
48
63
116
238
EMVL6R3ARA220MD60G
EMVL6R3ARA470ME60G
EMVL6R3ARA101MF60G
EMVL6R3ARA221MF80G
EMVL6R3ARA331MHA0G
EMVL6R3ARA102MJA0G
EMVL100ARA330ME60G
EMVL100ARA221MHA0G
EMVL160ARA100MD60G
EMVL160ARA220ME60G
EMVL160ARA470MF60G
EMVL160ARA101MF80G
EMVL160ARA471MJA0G
EMVL250ARA330MF60G
EMVL250ARA470MF80G
EMVL250ARA101MHA0G
EMVL250ARA331MJA0G
WV
(Vdc)
35
50
Cap
(µF)
4.7
10
22
33
220
1.0
2.2
3.3
4.7
10
22
33
47
100
Size code tanδ
D60
E60
F60
F80
JA0
D60
D60
D60
E60
F60
F80
HA0
HA0
JA0
0.13
0.13
0.13
0.13
0.13
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
Rated ripple
current
(mArms/
105℃, 120Hz)
15
25
42
57
216
6.2
11
14
19
30
49
77
92
151
Part No.
EMVL350ARA4R7MD60G
EMVL350ARA100ME60G
EMVL350ARA220MF60G
EMVL350ARA330MF80G
EMVL350ARA221MJA0G
EMVL500ARA1R0MD60G
EMVL500ARA2R2MD60G
EMVL500ARA3R3MD60G
EMVL500ARA4R7ME60G
EMVL500ARA100MF60G
EMVL500ARA220MF80G
EMVL500ARA330MHA0G
EMVL500ARA470MHA0G
EMVL500ARA101MJA0G
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
Frequency(Hz)
1.0
2.2 to 10
22 to 1,000
120
1.00
1.00
1.00
1k
1.50
1.30
1.05
10k
1.75
1.40
1.08
100k
1.80
1.50
1.08
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
很抱歉,暂时无法提供与“EMVL160ARA101MF80G”相匹配的价格&库存,您可以联系我们找货
