EMVA160ARA471MHA0G
EMVA160ARA471MHA0G
    NCC(贵弥功)
    AEC-D8X10MM_SM
EMVA160ARA471MHA0G 数据手册
SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM Alchip MVA - Standard, 85℃ Upgrade! Series ・φ4 through φ18 case sizes are fully lined up ・Endurance : 2,000 hours at 85℃ ・Suitable to fit for downsized equipment ・Solvent resistant type except 100 to 450Vdc (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant MVA 105℃ MVE ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +85℃ 4 to 450Vdc (at 20℃, 120Hz) ±20% (M) Rated voltage (Vdc) 4 to 100V 160 to 450V D55 to JA0 I=0.01CV or 3μA, whichever is greater.(after 2 minutes) KE0 to MN0 I=0.03CV or 4μA, whichever is greater.(after 1 minute) I=0.04CV+100μA max.(after 1 minute) Where, I : Max. leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) (at 20℃) Dissipation Factor Rated voltage (Vdc) 4V 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 400 & 450V (tanδ) D55 to JA0 0.42 0.35 0.30 0.26 0.16 0.14 0.12 0.12 0.12 tanδ (Max.) KE0 to MN0 0.38 0.34 0.30 0.26 0.22 0.18 0.14 0.10 0.20 0.25 When nominal capacitance exceeds 1,000μF, add 0.02 to the value above for each 1,000μF increase. (at 20℃, 120Hz) Low Temperature Rated voltage (Vdc) 4V 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 400 & 450V Characteristics Z(-25℃)/Z(+20℃) 7 4 3 2 2 2 2 2 3 (Max. Impedance Ratio) D55 to JA0 Z(-40℃)/Z(+20℃) 17 10 8 6 4 3 3 3 4 Z(-25℃)/Z(+20℃) 5 4 3 2 2 2 2 2 3 6 KE0 to MN0 12 10 8 5 4 3 3 3 6 10 (at 120Hz) Z(-40℃)/Z(+20℃) Endurance The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 85℃. Size code D55 to JA0 D55 to JA0 KE0 to MN0 Rated voltage (Vdc) 4V & 6.3V 10 to 100V 6.3 to 450V Capacitance change ≦±30% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value Shelf Life The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 85℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Size code D55 to JA0 D55 to JA0 KE0 to MN0 Rated voltage 4V & 6.3V 10 to 100V 6.3 to 450V Capacitance change ≦±30% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value ◆DIMENSIONS [mm] Vent (Except D55 to HA0) (Except F80 to HA0) 0.3max. φD±0.5 P C±0.2 B±0.2 φD±0.5 W 0.3max. L±0.3(Note) Code : G (Vibration resistant structure) : F80 to MN0 Size code ●Size code Vent L±0.3 (Note) Note : L±0.5 for HA0 to MN0 A±0.2 Note : L±0.5 for HA0 to MN0 KE0 to HN0 EX) 25V1,000µF 7hA 47 16V 0V MVA 1000 25V 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 L 5.2 5.2 5.2 7.7 10.0 10.0 13.5 16.0 16.5 21.5 16.5 21.5 D 4 5 6.3 6.3 8 10 12.5 12.5 16 16 18 18 A 4.3 5.3 6.6 6.6 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 B 4.3 5.3 6.6 6.6 8.3 10.3 13.0 13.0 17.0 17.0 19.0 19.0 C 5.1 5.9 7.2 7.2 9.0 11.0 13.7 13.7 18.0 18.0 20.0 20.0 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 1.0 to 1.3 P 1.0 1.4 1.9 1.9 3.1 4.5 4.2 4.2 6.5 6.5 6.5 6.5 ◆RATED RIPPLE CURRENT MULTIPLIERS Size code 18 E MV A AAA A AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 1.0µF:1R0,100µF:101) Taping·Tray code Terminal code (A, G) Voltage code (ex. 6.3V:6R3,100V:101,450V:451) Series code Category D55 E55 F55 F80 HA0 JA0 KE0 KG5 LH0 LN0 MH0 MN0 ・Frequency Multipliers D55 to JA0 ◆PART NUMBERING SYSTEM 1 A±0.2 : Dummy terminals ◆MARKING D55 to JA0 EX) 16V47µF W P C±0.2 ●Terminal A to MN0 B±0.2 ● Terminal Code : ● Size code : D55 KE0 to MN0 Capacitance(µF) Frequency(Hz) 1.0 2.2 to 10 22 to 1,500 4.7 10 to 68 100 to 1,000 2,200 to 10,000 120 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1k 1.50 1.30 1.05 1.75 1.50 1.30 1.05 10k 1.75 1.40 1.08 2.30 1.75 1.40 1.08 100k 1.80 1.50 1.08 2.50 1.80 1.50 1.08 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Please refer to "Product code guide (surface mount type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U Ver.3 SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS TM Alchip - Standard, 85℃ MVASeries Upgrade! ◆STANDARD RATINGS WV (Vdc) 4 6.3 10 16 25 35 is not solvent resistant. Cap (µF) Size code tanδ Rated ripple current (mArms/ 85℃, 120Hz) Part No. 33 47 100 220 330 470 1,000 33 47 100 220 330 470 680 820 1,000 1,500 2,200 3,300 3,300 4,700 6,800 6,800 10,000 22 33 47 100 150 220 330 470 1,000 2,200 3,300 4,700 4,700 6,800 22 33 47 100 150 220 330 470 680 1,000 2,200 3,300 3,300 4,700 10 22 33 47 56 100 150 220 330 470 1,000 2,200 2,200 3,300 4.7 10 22 D55 D55 E55 F55 F80 F80 HA0 D55 D55 E55 F55 F80 HA0 HA0 HA0 JA0 JA0 KE0 KG5 LH0 LH0 LN0 MH0 MN0 D55 D55 E55 F55 F55 F80 HA0 HA0 JA0 KE0 LH0 LN0 MH0 MN0 D55 E55 E55 F55 F80 F80 HA0 HA0 JA0 KE0 LH0 LN0 MH0 MN0 D55 E55 E55 F55 F55 F80 HA0 HA0 HA0 JA0 KE0 LN0 MH0 MN0 D55 D55 E55 0.42 0.42 0.42 0.42 0.42 0.42 0.42 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.40 0.42 0.42 0.44 0.48 0.48 0.56 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.36 0.38 0.40 0.40 0.44 0.26 0.26 0.26 0.26 0.26 0.26 0.26 0.26 0.26 0.30 0.32 0.34 0.34 0.36 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.26 0.28 0.28 0.30 0.14 0.14 0.14 25 30 50 80 135 150 320 30 33 55 88 135 280 290 320 430 480 890 1,000 1,200 1,400 1,750 1,700 2,000 26 30 44 70 79 130 270 280 430 960 1,300 1,550 1,600 1,850 26 37 44 70 110 130 270 280 380 710 1,150 1,450 1,450 1,750 24 41 47 60 66 120 210 260 300 400 820 1,450 1,400 1,800 18 24 41 EMVA4R0ARA330MD55G EMVA4R0ARA470MD55G EMVA4R0ARA101ME55G EMVA4R0ARA221MF55G EMVA4R0□RA331MF80G EMVA4R0□RA471MF80G EMVA4R0□RA102MHA0G EMVA6R3ARA330MD55G EMVA6R3ARA470MD55G EMVA6R3ARA101ME55G EMVA6R3ARA221MF55G EMVA6R3□RA331MF80G EMVA6R3□RA471MHA0G EMVA6R3□RA681MHA0G EMVA6R3□RA821MHA0G EMVA6R3□RA102MJA0G EMVA6R3□RA152MJA0G EMVA6R3□RA222MKE0S EMVA6R3□RA332MKG5S EMVA6R3□RA332MLH0S EMVA6R3□RA472MLH0S EMVA6R3□RA682MLN0S EMVA6R3□RA682MMH0S EMVA6R3□RA103MMN0S EMVA100ARA220MD55G EMVA100ARA330MD55G EMVA100ARA470ME55G EMVA100ARA101MF55G EMVA100ARA151MF55G EMVA100□RA221MF80G EMVA100□RA331MHA0G EMVA100□RA471MHA0G EMVA100□RA102MJA0G EMVA100□RA222MKE0S EMVA100□RA332MLH0S EMVA100□RA472MLN0S EMVA100□RA472MMH0S EMVA100□RA682MMN0S EMVA160ARA220MD55G EMVA160ARA330ME55G EMVA160ARA470ME55G EMVA160ARA101MF55G EMVA160□RA151MF80G EMVA160□RA221MF80G EMVA160□RA331MHA0G EMVA160□RA471MHA0G EMVA160□RA681MJA0G EMVA160□RA102MKE0S EMVA160□RA222MLH0S EMVA160□RA332MLN0S EMVA160□RA332MMH0S EMVA160□RA472MMN0S EMVA250ARA100MD55G EMVA250ARA220ME55G EMVA250ARA330ME55G EMVA250ARA470MF55G EMVA250ARA560MF55G EMVA250□RA101MF80G EMVA250□RA151MHA0G EMVA250□RA221MHA0G EMVA250□RA331MHA0G EMVA250□RA471MJA0G EMVA250□RA102MKE0S EMVA250□RA222MLN0S EMVA250□RA222MMH0S EMVA250□RA332MMN0S EMVA350ARA4R7MD55G EMVA350ARA100MD55G EMVA350ARA220ME55G WV (Vdc) 35 50 63 100 160 200 250 400 450 Cap (µF) Size code tanδ 33 100 150 220 330 470 1,000 2,200 3.3 4.7 10 22 33 47 100 220 330 470 470 1,000 1,000 1.0 2.2 3.3 4.7 10 22 33 47 56 68 100 220 330 330 470 470 22 33 68 100 220 220 330 47 68 100 100 22 33 47 68 68 100 10 22 33 47 47 68 4.7 10 22 22 33 4.7 10 22 33 F55 F80 HA0 HA0 JA0 KE0 LH0 MN0 D55 D55 E55 F55 F80 F80 HA0 JA0 KE0 KG5 LH0 LN0 MN0 D55 D55 E55 E55 F55 F80 HA0 HA0 JA0 JA0 KE0 KE0 KG5 LH0 LH0 MH0 HA0 JA0 KE0 KE0 LN0 MH0 MN0 KG5 LH0 LN0 MH0 KE0 KG5 LH0 LN0 MH0 MN0 KE0 KG5 LH0 LN0 MH0 MN0 KE0 LH0 LN0 MH0 MN0 KE0 LH0 LN0 MN0 0.14 0.14 0.14 0.14 0.14 0.22 0.22 0.24 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.18 0.18 0.18 0.18 0.18 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.14 0.14 0.14 0.14 0.14 0.12 0.12 0.10 0.10 0.10 0.10 0.10 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 Rated ripple current (mArms/ 85℃, 120Hz) 54 120 210 260 360 600 1,100 1,700 15 18 30 47 70 85 190 320 600 740 850 1,300 1,400 8.0 12 17 20 32 60 110 130 160 170 380 580 720 820 950 1,000 90 120 380 440 850 800 1,000 370 500 590 590 240 310 420 510 510 590 150 240 340 420 420 490 120 140 280 280 350 120 140 280 350 Part No. EMVA350ARA330MF55G EMVA350□RA101MF80G EMVA350□RA151MHA0G EMVA350□RA221MHA0G EMVA350□RA331MJA0G EMVA350□RA471MKE0S EMVA350□RA102MLH0S EMVA350□RA222MMN0S EMVA500ARA3R3MD55G EMVA500ARA4R7MD55G EMVA500ARA100ME55G EMVA500ARA220MF55G EMVA500□RA330MF80G EMVA500□RA470MF80G EMVA500□RA101MHA0G EMVA500□RA221MJA0G EMVA500□RA331MKE0S EMVA500□RA471MKG5S EMVA500□RA471MLH0S EMVA500□RA102MLN0S EMVA500□RA102MMN0S EMVA630ARA1R0MD55G EMVA630ARA2R2MD55G EMVA630ARA3R3ME55G EMVA630ARA4R7ME55G EMVA630ARA100MF55G EMVA630□RA220MF80G EMVA630□RA330MHA0G EMVA630□RA470MHA0G EMVA630□RA560MJA0G EMVA630□RA680MJA0G EMVA630□RA101MKE0S EMVA630□RA221MKE0S EMVA630□RA331MKG5S EMVA630□RA331MLH0S EMVA630□RA471MLH0S EMVA630□RA471MMH0S EMVA101□RA220MHA0G EMVA101□RA330MJA0G EMVA101□RA680MKE0S EMVA101□RA101MKE0S EMVA101□RA221MLN0S EMVA101□RA221MMH0S EMVA101□RA331MMN0S EMVA161□RA470MKG5S EMVA161□RA680MLH0S EMVA161□RA101MLN0S EMVA161□RA101MMH0S EMVA201□RA220MKE0S EMVA201□RA330MKG5S EMVA201□RA470MLH0S EMVA201□RA680MLN0S EMVA201□RA680MMH0S EMVA201□RA101MMN0S EMVA251□RA100MKE0S EMVA251□RA220MKG5S EMVA251□RA330MLH0S EMVA251□RA470MLN0S EMVA251□RA470MMH0S EMVA251□RA680MMN0S EMVA401□RA4R7MKE0S EMVA401□RA100MLH0S EMVA401□RA220MLN0S EMVA401□RA220MMH0S EMVA401□RA330MMN0S EMVA451□RA4R7MKE0S EMVA451□RA100MLH0S EMVA451□RA220MLN0S EMVA451□RA330MMN0S □ : Enter the appropriate terminal code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U Ver.3
EMVA160ARA471MHA0G 价格&库存
很抱歉,暂时无法提供与“EMVA160ARA471MHA0G”相匹配的价格&库存,您可以联系我们找货
EMVA160ARA471MHA0G
    • 500+0.78590500+0.09835
    • 1500+0.763721500+0.09558
    • 2500+0.753962500+0.09435
    • 10000+0.7273510000+0.09102
    • 15000+0.7096115000+0.08880
    EMVA160ARA471MHA0G
    • 5+4.11764
    • 125+4.02599
    • 250+3.94268
    库存:10
