EKMS551VSN471MA60S
EKMS551VSN471MA60S
    NCC(贵弥功)
    AEC-2P_D35X60MM_TM
EKMS551VSN471MA60S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS KMS Downsized snap-ins, 105℃ Upgrade! Series KHS ・The lower temperature range of the category temperature range has been expanded. ・For solar power generation ・Endurance with ripple current : 105℃ 3,000 hours ・Rated voltage range : 160 to 600V ・Capacitance range : 47 to 3,300µF ・Non solvent resistant type ・RoHS2 Compliant Downsizing KMS LXS Longer life Downsizing KMM ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃(160 to 500Vdc)   -25 to +105℃(550 to 600Vdc) 160 to 600Vdc ±20% (M) I≦3 CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 160 to 400V 420 to 600V tanδ (Max.) 0.15 0.20 Rated voltage (Vdc) 160 to 400V 420 to 600V Z(-25℃)/Z(+20℃) 4 8 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 5 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 3,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value (600Vdc:≦300%) Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±15% of the initial value D.F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] Sleeve (PET : Brown) ●Terminal PC board pin-out (View from Solder side) Negative mark φD+1max. 10 2-φ2 4.0±0.5 L±2.5 Vent Code : LI (φ35) Sleeve (PET : Brown) Negative mark Vent PC board pin-out (View from Solder side) 4.2±0.5 Code : VS (φ22 to φ35) : Standard 2-1.2×6 φD+1max. ●Terminal 5±0.5 L±2.5 4.5±1 14.2±1 The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KMS A A A V S N A A A M A A A S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 100µF:101, 1,000µF:102) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 160V:161, 400V:401) Series code Category Please refer to "Product code guide (snap-in type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Downsized snap-ins, 105℃ KMSSeries ◆STANDARD RATINGS WV (Vdc) 160 180 200 Cap (µF) 470 680 680 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,200 1,500 1,500 1,800 1,800 1,800 2,200 2,200 2,700 2,700 2,700 3,300 390 560 560 680 820 820 820 1,000 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,800 1,800 2,200 2,200 2,700 2,700 390 470 560 560 680 680 820 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,200 1,500 1,500 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 22 ×25 22 ×30 25.4 ×25 22 ×35 25.4 ×30 22 ×40 22× 45 25.4× 35 30× 25 22× 50 25.4× 40 30× 30 35× 25 25.4× 45 30× 35 25.4× 50 30× 40 35× 30 30× 45 35× 35 30× 50 35× 40 35× 45 35× 50 22× 25 22 × 30 25.4×25 22×35 22×40 25.4×30 30×25 22×45 22 ×50 25.4×35 25.4×40 30×30 25.4 ×45 30×35 35 ×25 25.4×50 30×40 35 ×30 30×45 35 ×35 30×50 35 ×40 35×45 35 ×50 22 ×25 22 ×30 22 ×35 25.4×25 22 ×40 25.4×30 22 ×45 25.4×35 30 ×25 22 ×50 25.4×40 30 ×30 35 ×25 25.4×45 25.4×50 30 ×35 35 ×30 30 ×40 35 ×35 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.47 1.86 1.84 2.09 2.08 2.35 2.40 2.40 2.50 2.69 2.68 2.77 2.91 3.05 3.17 3.40 3.57 3.62 4.05 4.07 4.56 4.67 4.78 5.40 1.34 1.68 1.67 1.90 2.13 2.08 2.26 2.40 2.45 2.40 2.45 2.52 2.73 2.83 2.91 3.10 3.26 3.31 3.66 3.68 4.11 4.22 4.78 4.88 1.34 1.54 1.72 1.67 1.94 1.89 2.17 2.17 2.26 2.45 2.45 2.52 2.66 2.73 2.78 2.83 2.96 3.26 3.36 Part No. EKMS161VSN471MP25S EKMS161VSN681MP30S EKMS161VSN681MQ25S EKMS161VSN821MP35S EKMS161VSN821MQ30S EKMS161VSN102MP40S EKMS161VSN102MP45S EKMS161VSN102MQ35S EKMS161VSN102MR25S EKMS161VSN122MP50S EKMS161VSN122MQ40S EKMS161VSN122MR30S EKMS161VSN122MA25S EKMS161VSN152MQ45S EKMS161VSN152MR35S EKMS161VSN182MQ50S EKMS161VSN182MR40S EKMS161VSN182MA30S EKMS161VSN222MR45S EKMS161VSN222MA35S EKMS161VSN272MR50S EKMS161VSN272MA40S EKMS161VSN272MA45S EKMS161VSN332MA50S EKMS181VSN391MP25S EKMS181VSN561MP30S EKMS181VSN561MQ25S EKMS181VSN681MP35S EKMS181VSN821MP40S EKMS181VSN821MQ30S EKMS181VSN821MR25S EKMS181VSN102MP45S EKMS181VSN102MP50S EKMS181VSN102MQ35S EKMS181VSN102MQ40S EKMS181VSN102MR30S EKMS181VSN122MQ45S EKMS181VSN122MR35S EKMS181VSN122MA25S EKMS181VSN152MQ50S EKMS181VSN152MR40S EKMS181VSN152MA30S EKMS181VSN182MR45S EKMS181VSN182MA35S EKMS181VSN222MR50S EKMS181VSN222MA40S EKMS181VSN272MA45S EKMS181VSN272MA50S EKMS201VSN391MP25S EKMS201VSN471MP30S EKMS201VSN561MP35S EKMS201VSN561MQ25S EKMS201VSN681MP40S EKMS201VSN681MQ30S EKMS201VSN821MP45S EKMS201VSN821MQ35S EKMS201VSN821MR25S EKMS201VSN102MP50S EKMS201VSN102MQ40S EKMS201VSN102MR30S EKMS201VSN102MA25S EKMS201VSN122MQ45S EKMS201VSN122MQ50S EKMS201VSN122MR35S EKMS201VSN122MA30S EKMS201VSN152MR40S EKMS201VSN152MA35S WV (Vdc) 200 250 315 400 Cap (µF) 1,800 1,800 1,800 2,200 2,700 270 330 390 390 470 470 560 560 560 680 680 680 680 820 820 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,800 180 220 220 270 330 330 330 390 390 390 470 470 470 560 560 560 560 680 680 820 820 820 1,000 1,200 120 150 180 180 220 220 270 270 270 330 330 330 330 390 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 30 × 45 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 25.4 × 50 30 × 40 35 × 30 30 × 45 30 × 50 35 × 35 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 25.4 × 25 22 × 35 22 × 40 25.4 × 30 30 × 25 22 × 45 22 × 50 25.4 × 35 25.4 × 40 30 × 30 35 × 25 25.4 × 45 25.4 × 50 30 × 35 35 × 30 30 × 40 35 × 35 30 × 45 30 × 50 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 3.66 3.72 3.81 4.32 4.88 1.11 1.29 1.44 1.40 1.61 1.57 1.79 1.79 1.87 2.02 2.02 2.08 2.19 2.26 2.34 2.53 2.66 2.70 2.99 3.04 3.00 3.48 3.56 3.98 0.95 1.10 1.10 1.24 1.40 1.38 1.43 1.56 1.59 1.57 1.76 1.73 1.82 1.96 1.99 1.93 2.02 2.19 2.26 2.47 2.51 2.57 2.91 3.25 0.77 0.90 1.02 0.99 1.15 1.13 1.29 1.30 1.29 1.47 1.47 1.45 1.52 1.63 Part No. EKMS201VSN182MR45S EKMS201VSN182MR50S EKMS201VSN182MA40S EKMS201VSN222MA45S EKMS201VSN272MA50S EKMS251VSN271MP25S EKMS251VSN331MP30S EKMS251VSN391MP35S EKMS251VSN391MQ25S EKMS251VSN471MP40S EKMS251VSN471MQ30S EKMS251VSN561MP45S EKMS251VSN561MQ35S EKMS251VSN561MR25S EKMS251VSN681MP50S EKMS251VSN681MQ40S EKMS251VSN681MR30S EKMS251VSN681MA25S EKMS251VSN821MQ45S EKMS251VSN821MR35S EKMS251VSN102MQ50S EKMS251VSN102MR40S EKMS251VSN102MA30S EKMS251VSN122MR45S EKMS251VSN122MR50S EKMS251VSN122MA35S EKMS251VSN152MA40S EKMS251VSN152MA45S EKMS251VSN182MA50S EKMS3B1VSN181MP25S EKMS3B1VSN221MP30S EKMS3B1VSN221MQ25S EKMS3B1VSN271MP35S EKMS3B1VSN331MP40S EKMS3B1VSN331MQ30S EKMS3B1VSN331MR25S EKMS3B1VSN391MP45S EKMS3B1VSN391MP50S EKMS3B1VSN391MQ35S EKMS3B1VSN471MQ40S EKMS3B1VSN471MR30S EKMS3B1VSN471MA25S EKMS3B1VSN561MQ45S EKMS3B1VSN561MQ50S EKMS3B1VSN561MR35S EKMS3B1VSN561MA30S EKMS3B1VSN681MR40S EKMS3B1VSN681MA35S EKMS3B1VSN821MR45S EKMS3B1VSN821MR50S EKMS3B1VSN821MA40S EKMS3B1VSN102MA45S EKMS3B1VSN122MA50S EKMS401VSN121MP25S EKMS401VSN151MP30S EKMS401VSN181MP35S EKMS401VSN181MQ25S EKMS401VSN221MP40S EKMS401VSN221MQ30S EKMS401VSN271MP45S EKMS401VSN271MQ35S EKMS401VSN271MR25S EKMS401VSN331MP50S EKMS401VSN331MQ40S EKMS401VSN331MR30S EKMS401VSN331MA25S EKMS401VSN391MQ45S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Downsized snap-ins, 105℃ KMSSeries ◆STANDARD RATINGS WV (Vdc) 400 420 450 Cap (µF) 390 390 470 470 560 560 560 680 680 820 100 120 120 150 180 180 180 220 220 220 220 270 270 270 330 330 330 330 390 390 470 470 560 680 82 120 120 120 150 150 180 180 180 220 220 220 220 270 270 270 270 330 390 390 390 470 470 560 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 25.4×50 30 ×35 30 ×40 35 ×30 30× 45 30× 50 35 × 35 35 × 40 35 ×45 35 ×50 22 ×25 22 ×30 25.4 ×25 22 ×35 22× 40 25.4× 30 30 × 25 22 × 45 22 × 50 25.4× 35 30 ×30 25.4×40 25.4×45 35 ×25 25.4×50 30 ×35 30×40 35×30 30×45 35×35 30×50 35×40 35×45 35×50 22 ×25 22×30 22×35 25.4×25 22×40 25.4×30 22×45 25.4×35 30×25 22×50 25.4×40 30×30 35×25 25.4×45 25.4×50 30×35 35×30 30×40 30×45 30×50 35 × 35 35 ×40 35 ×45 35× 50 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 1.66 1.61 1.82 1.85 2.04 2.07 2.05 2.34 2.40 2.69 0.70 0.81 0.81 0.93 1.04 1.02 1.06 1.17 1.20 1.18 1.18 1.33 1.36 1.38 1.52 1.48 1.52 1.55 1.70 1.71 1.90 1.95 2.17 2.45 0.64 0.81 0.83 0.81 0.94 0.93 1.06 1.06 1.06 1.20 1.20 1.18 1.24 1.36 1.38 1.34 1.40 1.52 1.70 1.73 1.71 1.95 1.99 2.22 Part No. EKMS401VSN391MQ50S EKMS401VSN391MR35S EKMS401VSN471MR40S EKMS401VSN471MA30S EKMS401VSN561MR45S EKMS401VSN561MR50S EKMS401VSN561MA35S EKMS401VSN681MA40S EKMS401VSN681MA45S EKMS401VSN821MA50S EKMS421VSN101MP25S EKMS421VSN121MP30S EKMS421VSN121MQ25S EKMS421VSN151MP35S EKMS421VSN181MP40S EKMS421VSN181MQ30S EKMS421VSN181MR25S EKMS421VSN221MP45S EKMS421VSN221MP50S EKMS421VSN221MQ35S EKMS421VSN221MR30S EKMS421VSN271MQ40S EKMS421VSN271MQ45S EKMS421VSN271MA25S EKMS421VSN331MQ50S EKMS421VSN331MR35S EKMS421VSN331MR40S EKMS421VSN331MA30S EKMS421VSN391MR45S EKMS421VSN391MA35S EKMS421VSN471MR50S EKMS421VSN471MA40S EKMS421VSN561MA45S EKMS421VSN681MA50S EKMS451VSN820MP25S EKMS451VSN121MP30S EKMS451VSN121MP35S EKMS451VSN121MQ25S EKMS451VSN151MP40S EKMS451VSN151MQ30S EKMS451VSN181MP45S EKMS451VSN181MQ35S EKMS451VSN181MR25S EKMS451VSN221MP50S EKMS451VSN221MQ40S EKMS451VSN221MR30S EKMS451VSN221MA25S EKMS451VSN271MQ45S EKMS451VSN271MQ50S EKMS451VSN271MR35S EKMS451VSN271MA30S EKMS451VSN331MR40S EKMS451VSN391MR45S EKMS451VSN391MR50S EKMS451VSN391MA35S EKMS451VSN471MA40S EKMS451VSN471MA45S EKMS451VSN561MA50S WV (Vdc) 500 550 600 Cap (µF) 47 56 68 82 82 100 100 120 120 120 150 150 150 180 180 180 220 220 270 270 330 390 470 82 82 100 100 100 120 120 120 120 150 150 180 180 180 220 220 270 270 330 330 470 100 100 120 150 150 180 180 180 220 220 220 270 330 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 22 × 25 22 × 30 25.4 × 25 22 × 35 25.4 × 30 22 × 45 30 × 25 22 × 50 25.4 × 35 30 × 30 25.4 × 45 30 × 35 35 × 25 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 35 × 60 22 × 35 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 35 × 60 30 × 30 35 × 25 30 × 35 30 × 40 35 × 30 30 × 45 30 × 50 35 × 35 30 × 60 35 × 40 35 × 45 35 × 50 35 × 60 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.51 0.58 0.65 0.72 0.74 0.83 0.82 0.93 0.93 0.91 1.08 1.04 0.99 1.20 1.17 1.10 1.33 1.23 1.50 1.42 1.60 1.78 2.03 0.72 0.74 0.83 0.85 0.82 0.93 0.95 0.91 0.88 1.08 1.04 1.20 1.17 1.10 1.33 1.23 1.50 1.42 1.60 1.64 2.03 0.83 0.85 0.93 1.07 1.06 1.20 1.22 1.18 1.40 1.35 1.38 1.56 1.79 Part No. EKMS501VSN470MP25S EKMS501VSN560MP30S EKMS501VSN680MQ25S EKMS501VSN820MP35S EKMS501VSN820MQ30S EKMS501VSN101MP45S EKMS501VSN101MR25S EKMS501VSN121MP50S EKMS501VSN121MQ35S EKMS501VSN121MR30S EKMS501VSN151MQ45S EKMS501VSN151MR35S EKMS501VSN151MA25S EKMS501VSN181MQ50S EKMS501VSN181MR40S EKMS501VSN181MA30S EKMS501VSN221MR45S EKMS501VSN221MA35S EKMS501VSN271MR50S EKMS501VSN271MA40S EKMS501VSN331MA45S EKMS501VSN391MA50S EKMS501VSN471MA60S EKMS551VSN820MP35S EKMS551VSN820MQ30S EKMS551VSN101MP45S EKMS551VSN101MQ35S EKMS551VSN101MR25S EKMS551VSN121MP50S EKMS551VSN121MQ40S EKMS551VSN121MR30S EKMS551VSN121MA25S EKMS551VSN151MQ45S EKMS551VSN151MR35S EKMS551VSN181MQ50S EKMS551VSN181MR40S EKMS551VSN181MA30S EKMS551VSN221MR45S EKMS551VSN221MA35S EKMS551VSN271MR50S EKMS551VSN271MA40S EKMS551VSN331MA45S EKMS551VSN331MA50S EKMS551VSN471MA60S EKMS601VSN101MR30S EKMS601VSN101MA25S EKMS601VSN121MR35S EKMS601VSN151MR40S EKMS601VSN151MA30S EKMS601VSN181MR45S EKMS601VSN181MR50S EKMS601VSN181MA35S EKMS601VSN221MR60S EKMS601VSN221MA40S EKMS601VSN221MA45S EKMS601VSN271MA50S EKMS601VSN331MA60S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 160 to 250Vdc 315 to 450Vdc 500 to 600Vdc 50 0.81 0.77 0.70 120 1.00 1.00 1.00 300 1.17 1.16 1.16 1k 1.32 1.30 1.30 10k 1.45 1.41 1.41 50k 1.50 1.43 1.43 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EKMS551VSN471MA60S 价格&库存
很抱歉,暂时无法提供与“EKMS551VSN471MA60S”相匹配的价格&库存,您可以联系我们找货
