SWPCBV33EF-74.250000D
    STARWAVE(思大)
    SMD3225_4P
    74.25MHZ ±30PPM CMOS 3.3V
SWPCBV33EF-74.250000D 数据手册
PC Type Crystal Oscillator Programmable 3.2 x 2.5 mm Frequency 1MHz to 200MHz FEATURE - Typical 3.2 x 2.5 x 0.95 mm ceramic SMD package Operation supply voltage: 1.8V, 2.5V and 3.3V FASTXO series, Fast delivery at any frequency Tri-State Enable/Disable Frequency Stability ±25ppm over -40 oC to 105 oC Pb-free/RoHS compliant TYPICAL APPLICATION - Computer Peripherals - Set-top Box , HDTV - DSC, PDA DIMENSION (mm) SOLDER PAD LAYOUT (mm) 2.10 ± 0.15 #3 #1 0.90 ± 0.15 Pin# 0.95 ± 0.15 0.35 0.65 ± 0.15 2.50 ± 0.15 #2 #2 [ SIDE VIEW ] 1 2 3 4 1.60 #4 1.65 ± 0.15 #3 #4 1.10 3.20 ± 0.15 #1 0.1 μF [ BO TTO M VIEW ] [ TOP VIEW ] 2.10 Function 1.20 Tri-state GND Output VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3V Parameter Supply Voltage Variation Frequency Range Supply Current (@15pf Loading) Output Level Transition Time 2.5V 1.8V Unit Min. Max. Min. Max. Min. Max. VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% V 1 200 1 200 1 125 MHz mA - 35 - 30 - 20 Output High 90%VDD - 90%VDD - 90%VDD - V Output Low - 10%VDD - 10%VDD - 10%VDD V nSec Rise Time / Fall Time Duty Cycle Startup Time - 2 - 2 - 3 45 55 45 55 45 55 % - 8 - 8 - 8 mSec V Output Enable 0.7 x VDD - 0.7 x VDD - 0.7 x VDD - Output Disable - 0.3 x VDD - 0.3 x VDD - 0.3 x VDD V Stand by Current (@PD Mode) - 400 - 400 - 400 uA Stand by Current (@OE Mode) - 20 - 20 - 20 mA 2 pSec Tri-State Output Loading 15 RMS Phase Jitter (12KHz to 20MHz) 2 - Aging (@ 25oC, First Year) Storage Temp. Range 15 - 15 2 - pf - 3 - 3 - 3 ppm -50 +125 -50 +125 -50 +125 oC Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. + Transition times are measured between 10% and 90% of VDD, with an output load of 15pF. FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±15 -20~+70 -40~+85 -40~+105 ± 20 ±25 ± 50 *O: Available △: Conditional X: Not available *Inclusive of calibration @ 25 oC ,operating temperature rrange,input Voltage variation,load variation,aging (1st year),shock,and vibration Note: not all combination of options are available. Other specifications may be available upon request. www.starwavecorp.com info@starwavecorp.com PC Type Crystal Oscillator Programmable 3.2 x 2.5 mm Frequency 1MHz to 200MHz Ordering Information Output Drive Strength SW P C B V 25 E F - 125.000000 Y Brand SW:Starwave Part Series P: Programmable Oscillator Packing “D”: 8 mm Tape & Reel, 3ku reel “E”: 8 mm Tape & Reel, 1ku reel “T”: 12/16 mm Tape & Reel, 3ku reel “Y”: 12/16 mm Tape & Reel, 1ku reel Blank for Bulk Frequency 1.000000 to 200.000000 MHz Output Drive Strength 4 :4 mA 8 :8 mA F :16 mA Feature Pin “E” for Output Enable “S” for Standby Package Size “E” “D” “C” “B” “A” 2.0 x 1.6 mm 2.5 x 2.0 mm 3.2 x 2.5 mm 5.0 x 3.2 mm 7.0 x 5.0 mm Supply Voltage “18” for 1.8V ±10% “25” for 2.5V ±10% “33” for 3.3V ±10% Frequency Stability Temperature Range “A” for ±15 ppm “B” for ±20 ppm “C” for ±25 ppm “D” for ±50 ppm “U” Commercial, -20ºC to 70ºC “V” Industrial, - 40ºC to 85ºC W:High Temp, -40 ºC to 105 ºC Table 13. Ordering Codes for Supported Tape & Reel Packing Method Device Size (mm x mm) 16 mm T&R (3ku) 16 mm T&R (1ku) 12 mm T&R (3ku) 12 mm T&R (1ku) 8 mm T&R (3ku) 8 mm T&R (1ku) 2.0 x 1.6 – – – – D E 2.5 x 2.0 – – – – D E 3.2 x 2.5 – – – – D E 5.0 x 3.2 – – T Y – – 7.0 x 5.0 T Y – – – – www.starwavecorp.com info@starwavecorp.com
SWPCBV33EF-74.250000D 价格&库存
很抱歉,暂时无法提供与“SWPCBV33EF-74.250000D”相匹配的价格&库存,您可以联系我们找货
