JK60-110
JK60-110
    JKSEMI(金开盛)
    PTC-2P_D13XT3MM_TM
JK60-110 数据手册
JK60 Series Surface Mount PTC Devices Performance Specification Maximum Time Vmax Model Imax Ihold Itrip Pd To Trip Resistance Typ. Current Time Rimin Rimax (Vdc) (A) (A) (A) (W) (A) (Sec) () () 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 60 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 0.05 0.10 0.17 0.2 0.25 0.30 0.40 0.50 0.65 0.75 0.90 1.10 1.35 1.60 1.85 2.00 2.50 3.00 3.75 0.15 0.3 0.34 0.4 0.5 0.6 0.8 1.0 1.3 1.5 1.8 2.2 2.7 3.2 3.7 4.0 5.0 6.0 7.5 0.26 0.38 0.48 0.41 0.45 0.49 0.56 0.77 0.88 0.92 0.99 1.5 1.7 1.9 2.1 2.3 2.5 2.8 3.2 0.25 0.5 0.85 1.0 1.25 1.5 2.0 2.5 3.25 3.75 4.5 5.5 6.75 8.0 9.25 10.0 12.5 15.0 18.75 8.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 24.0 7.3 2.5 2 1.5 1.0 0.76 0.45 0.40 0.31 0.25 0.20 0.15 0.12 0.09 0.08 0.07 0.05 0.04 0.03 20 7.5 5.21 2.84 1.95 1.38 0.88 0.79 0.50 0.42 0.33 0.27 0.21 0.16 0.14 0.14 0.10 0.08 0.06 5.00 10 3.5 25.0 24.0 0.02 0.06 JK60-005 JK60-010 JK60-017 JK60-020 JK60-025 JK60-030 JK60-040 JK60-050 JK60-065 JK60-075 JK60-090 JK60-110 JK60-135 JK60-160 JK60-185 JK60-200 JK60-250 JK60-300 JK60-375 JK60-500 V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (Vmax). I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at25°C. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Test Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C http:// www.jksemi.com 2021-10-21 版次: c JK60 Series Surface Mount PTC Devices Agency Approval and Environmental Complianc Agency File Number Regulation UL pending 2002/95/EC TUV pending EN14582 Thermal Derating Curve Standard Average Time-Current Curve Derating Curves for D60 Series Average TimeCurrent Curves 0.100A 180 0.170A 1000 0.200A 0.250A 140 0.300A 100 120 100 80 60 0.400A 0.500A T IME IN SECO N P e rc enta ge of D erated C urrent 160 0.650A 10 0.750A 0.900A 1.10A 1 1.35A 1.60A 40 1.85A 0.1 20 2.50A 3.00A 0 -40 -20 0 20 40 60 80 3.75A 0.01 0.1 1 Temperature (°C) 10 100 CURRENTINAMPERES Ihold Versus Temperature Model Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) -40°C -20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C JK60-010 0.16 0.14 0.12 0.10 0.08 0.07 0.06 0.05 0.04 JK60-017 0.26 0.23 0.20 0.17 0.14 0.12 0.11 0.09 0.07 JK60-020 0.31 0.27 0.24 0.20 0.16 0.14 0.13 0.11 0.08 JK60-025 0.39 0.34 0.30 0.25 0.20 0.18 0.16 0.14 0.10 JK60-030 0.47 0.41 0.36 0.30 0.24 0.22 0.19 0.16 0.12 JK60-040 0.62 0.54 0.48 0.40 0.32 0.29 0.25 0.22 0.16 JK60-050 0.78 0.68 0.60 0.50 0.41 0.36 0.32 0.27 0.20 JK60-065 1.01 0.88 0.77 0.65 0.53 0.47 0.41 0.35 0.26 JK60-075 1.16 1.02 0.89 0.75 0.61 0.54 0.47 0.41 0.30 JK60-090 1.40 1.22 1.07 0.90 0.73 0.65 0.57 0.49 0.36 JK60-110 1.71 1.50 1.31 1.10 0.89 0.79 0.69 0.59 0.44 JK60-135 2.09 1.84 1.61 1.35 1.09 0.97 0.85 0.73 0.54 JK60-160 2.48 2.18 1.90 1.60 1.30 1.15 1.01 0.86 0.64 JK60-185 2.87 2.52 2.20 1.85 1.50 1.33 1.17 1.00 0.74 JK60-250 3.88 3.40 2.98 2.50 2.03 1.80 1.58 1.35 1.00 JK60-300 4.65 4.08 3.57 3.00 2.43 2.16 1.89 1.62 1.20 JK60-375 5.81 5.10 4.46 3.75 3.04 2.70 2.36 2.03 1.50 http:// www.jksemi.com 2021-10-21 版次: c JK60 Series Surface Mount PTC Devices Soldering Parameters TP 260 Soldering 5Sea.MAX Pre-Heating 1 Minute Min. Gradual Cooling 100 25 Time WAVE SOLDERING INFORMATIONS Pre-Heating Zone Max. ramping rate should not exceed 4℃/Sec. Soldering Zone Max. solder temperature should not exceed 260℃ Cooling Zone Cooling by natural convection in air. ◎ Specifications are subject to change without notice. Physical Dimensions(mm.) A B C Max. Max. Max. JK60-005 JK60-010 JK60-017 JK60-020 JK60-025 JK60-030 JK60-040 JK60-050 JK60-065 JK60-075 JK60-090 JK60-110 JK60-135 JK60-160 JK60-185 JK60-200 JK60-250 JK60-300 JK60-375 5.5 5.5 7.4 7.4 7.4 7.4 7.8 7.8 9.7 10.4 11.7 13.0 14.5 16.3 17.8 17.8 21.3 21.3 28.5 9.5 9.5 12.7 12.7 12.7 13.0 16.2 16.2 17.8 18.4 18.4 18.0 19.6 21.3 22.9 22.9 26.4 26.4 33.5 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 JK60-500 28.5 33.5 3.0 Model http:// www.jksemi.com D 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 5.1±0.75 10.2±0.75 10.2±0.75 10.2±0.75 10.2±0.75 E Lead Min. Style 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 4.6 Kink Kink Kink Kink Kink Kink Kink Kink Kink Kink Kinkt Straight Straight Straight Straight Straight Straight Straight Straight Straight 2021-10-21 版次: c JK60 Series Surface Mount PTC Devices PHYSICAL SPECIFICATIONS : Materials : JK60-005-~050: 24 AWG/Φ0.5. JK60-065 ~ 075:22 AWG/Φ0.5. JK60-090: 22 AWG/Φ0.8. JK60-110 ~ 500: 20 AWG/Φ0.8. Lead Solderability : MIL-STD-202, Method 208E. Packaging Quantity JK60-005~JK60-110 1000pcs/pag or 2000pcs/pag JK60-135~JK60-200 500pcs/pag JK60-250~JK60-500 200pcs/pag Tape & Reel packaging per EIA468-B standard. Cross Reference Cross Reference JKSEMI Tyco / Raychem Bourns / Multifuse® Polytronics / EVERFUSE® SEA-LAND JK60-010 RXEF010 MF-R010 RLD60P010UF R60-010 JK60-017 RXEF017 MF-R017 RLD60P017UF R60-017 JK60-020 RXEF020 MF-R020 RLD60P020UF R60-020 JK60-025 RXEF025 MF-R025 RLD60P025UF R60-025 JK60-030 RXEF030 MF-R030 RLD60P030UF R60-030 JK60-040 RXEF040 MF-R040 RLD60P040UF R60-040 JK60-050 RXEF050 MF-R050 RLD60P050UF R60-050 JK60-065 RXEF065 MF-R065 RLD60P065UF R60-065 JK60-075 RXEF075 MF-R075 RLD60P075UF R60-075 JK60-090 RXEF090 MF-R090 RLD60P090UF R60-090 JK60-110 RXEF110 MF-RX110 RLD60P110UF R60-110 JK60-135 RXEF135 MF-RX135 RLD60P135UF R60-135 JK60-160 RXEF160 MF-RX160 RLD60P160UF R60-160 JK60-185 RXEF185 MF-RX185 RLD60P185UF R60-185 JK60-250 RXEF250 MF-RX250 RLD60P250UF R60-250 JK60-300 RXEF300 MF-RX300 RLD60P300UF R60-300 JK60-375 RXEF375 MF-RX375 RLD60P375UF R60-375 “Raychem” is a registered trademark of Tyco Electronics. “Multifuse” is a registered trademark of bourns,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. “SEA-LAND” is a registered trademark of Sea-Land electronic corp. Website: http://www.jksemi.com For additional information, please contact your local Sales Representative. ©Copyright 2021, jksemi is a registered trademark of jksemi All rights arereserved http:// www.jksemi.com 2021-10-21 版次: c
JK60-110 价格&库存
很抱歉,暂时无法提供与“JK60-110”相匹配的价格&库存,您可以联系我们找货
