TXC CORPORATION
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING X'TAL 2.0 × 1.6
NOMINAL FREQ.
26.000000MHz
TXC P/N
8Y26000053
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
Attachment: Product Specification Sheet
1
2
3
4
5
FMT-DOC024 VER.G
RoHS Compliant
TXC confidential and proprietary document
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
26.000000MHz
TXC P/N
8Y26000053
REVISION
S1
PE/RD
QA
MFG
Robin Huang
28-Feb-19
NOTE:
(1)The green product standard set by TXC is based upon the international standards. Related information is
publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green
product quality system directives at the time.
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
RoHS Compliant
FMT-DOC024 VER.G
TXC CORPORATION
Rev
Revise page
S1
N/A
FMT-DOC024 VER.G
TXC P/N:
Revise contents
Initial released
8Y26000053
REVISION:
S1
PAGE: 1
Date
Ref.No.
Reviser
28-Feb-19
N/A
Xiaoyan Jiang
TXC CORPORATION
TXC P/N:
8Y26000053
REVISION:
S1
PAGE:
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
DIMENSIONS
P.4
3
MARKING
P.4
4
FACTORY LOCATION
P.4
5
SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS&HANDING CAUTIONS
FMT-DOC024 VER.G
P.8~9
2
TXC CORPORATION
TXC P/N:
8Y26000053
REVISION:
S1
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature
25±10℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
Ambient temperature
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.005±0.002 g/pcs
Parameters
1 Nominal Frequency
Symbol
Electrical Spec.
Min.
Typ.
Max.
Notes
Units
FL
26.000000
MHz
Fundamental
CL
8
pF
4 Frequency Tolerance
±10
ppm
at 25 ℃ ± 3 ℃
5 Frequency Stability
±10
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
7 Aging
2 Oscillation Mode
3 Load Capacitance
-30
85
±3
ppm
1st Year
8 Drive Level
DL
100
uW
9 Equivalent Series Resistance
Rr
80
Ω
10 Shunt Capacitance C0
C0
0.55
2
pF
11 Pulling Sensitivity
TS
12
ppm/pF
12 Insulation Resistance
500
MΩ
13 Storage Temperature Range
-40
125
FMT-DOC024 VER.G
at DC 100V
TXC CORPORATION
TXC P/N:
8Y26000053
S1
REVISION:
PAGE: 4
■ DIMENSIONS
(Unit:mm)
2.00 ± 0.10
Connection
3
GND
1
2
GND
0.50Max
1
0.5
0.9
0.8
0.9
0.8
0.3
2
2
Suggested Layout
0.475 ± 0.10
0.7 ± 0.10
0.5 ± 0.10
0.575 ± 0.10
1
3
4
1.60 ± 0.10
4
4
3
*Coplanarity of solderable areas Camber 0.05 mm Max
■ MARKING
T□□□
TXC Logo
Frequency Code
Pin 1 Location
MHz = 260
Ex.: 26.000000
Lot Code
Date Code
Production control code
Date Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG
SEP
OCT NOV DEC
2005
2009
2013
2017
2021
A
B
C
D
E
F
G
H
J
K
L
2006
2010
2014
2018
2022
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
2023
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
2024
n
p
q
r
s
t
u
v
w
x
y
z
*This date code will be cycled every four years
Production Location:Taiwan, China(Ningbo), China(Chungking).
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
Solder melting point :220 ℃
■ SUGGESTED MANUAL SOLDER CONDITION
Temperature: 350 ± 10 ℃
Time: 3 sec.
Re-solder times: twice
FMT-DOC024 VER.G
M
TXC CORPORATION
TXC P/N:
8Y26000053
REVISION:
S1
PAGE: 5
■ STRUCTURE ILLUSTRATION
4
5
3
1
2
NO
COMPONENTS
MATERIALS
FINISH/SPECIFICATIONS
1 Lid
Kovar (Fe/Co/Ni)
2 Base(Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+Pad(Au)
Tungsten metalize
+ Ni plating
+ Au plating
3 Crystal blank
SiO2
4 Conductive adhesive
Resin+Ag
5 Electrode
Noble Metal
FMT-DOC024 VER.G
TXC CORPORATION
TXC P/N:
8Y26000053
S1
REVISION:
PAGE: 6
■ PACKING
2.0±0.05
4.0±0.1
0.25±0.05
5o(max)
5o(max)
4.0±0.1
1.9±0.1
2.3±0.1
1.75±0.1
3.5±0.05
8.0±0.2
1.55±0.05
0.65±0.1
1.1±0.05
Unit:mm
REMARK :
Trailer
160 mm (Min)
Products put in 3000 pcs
Empty Sealed
Leader
160 mm (Min)
User direction of feed
230 mm (Min)
11±0.5
Ø178±1
Ø60.2±0.5
120
Ø13±0.5
2.5 +0.5
8
-0
ENLARGE
11.5±0.2
Standard Reel Quantity is 3,000 pcs per reel
FMT-DOC024 VER.G
TXC CORPORATION
TXC P/N:
8Y26000053
REVISION:
S1
PAGE:
7
■ PACKING
Reel Quantity :
1. Reel X 6 (6 Reels)
2. Reel X 12 (12 Reels)
3. Reel X 25 (12 Reels + 13 Reels)
4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 )
Label B
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label A
Label B
QA Pass
(Label A) Size:100 X 100mm
(Lable B) Size:80 X 40mm
[STORAGE]
1.Don't be caught in the rain.
2.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
3.If customers have special requirements, we can paste labels according to it.
FMT-DOC024 VER.G
TXC CORPORATION
TXC P/N:
8Y26000053
REVISION:
S1
PAGE: 8
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
1 Drop Test
Test Methods
150 cm height, 3 times on concrete floor.
1 Mechanical Shock
1 Vibration
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minutes
perpendicular axes each test time
4 Hrs
Test Criteria
A.C
A.C
A.C
(Total test time 12 Hrs)
1 Gross Leak
Standard Sample For Automatic Gross Leak Detector, Test Pressure:
2kg / cm2
F
2 Fine Leak
Helium Bombing 4.5 kg/ cm2 for 2 Hrs
G
2 Solder ability
Temperature
240 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
E
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
2 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 500 ± 12 Hrs
2 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 500 ± 12 Hrs
Test Criteria
B.C.D
B.C.D
Total 100 cycles of the following temperature cycle
2 Temperature cycle
3 High Temp&Humidity
FMT-DOC024 VER.G
B.C.D
85℃ ± 3℃, RH 85% , 500Hrs
B.C.D
TXC CORPORATION
TXC P/N:
8Y26000053
REVISION:
S1
PAGE:
Specifications
A
Frequency change: Within ±5ppm or in customer's specification.
B
Frequency change: Within ±10ppm or in customer's specification.
C
Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value).
D
After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 2 hour, and
measured.
E
Minimum 95% of immersed terminal shall be covered with new uniform solder.
F
Leak rate< 1×10 -5 Pa*m3/Sec
G
Leak rate< 4×10-9 Pa*m3/Sec
Measurement condition
FMT-DOC024 VER.G
9
很抱歉,暂时无法提供与“8Y26000053”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.27527
- 50+1.00311
- 150+0.88647
- 500+0.74099
