DS1037-01-09FNAKT74
DS1037-01-09FNAKT74
    CONNFLY(晨翔)
    弯插
    D-SUB RA 90度9pin,外壳镀镍锁螺丝,黑色,半金锡
DS1037-01-09FNAKT74 数据手册
[Female] Dimension C B D Position A±0.2 B±0.2 C±0.3 D 9 17.90 24.99 30.80 16.33 15 26.50 33.32 39.14 24.66 25 40.00 47.04 53.04 38.38 37 56.50 63.50 69.32 54.84 7.9 12.5 2.84 2.77 NOTES: 1. Electrical characteristics: 1.1 Contact resistance: 20mΩ Max. Initial. 1.2 Dielectric withstanding voltage: 500V AC(rms) for 1 minute. 1.3 Insulation resistance: 1000MΩ Min. 2. Environment characteristics: 2.1.Temperature range: -40°C~+105°C. 3. Materials: 3.1 Insulator:PBT+Glass fiber 3.2 Shell:Steel 3.3 Contact:Copper alloy 4. Product number code: #4-40 18.3 9.52 8.10 10.94 5.9 E F With screw type 3.2 4.4 Screws [Male] E 2.77 9.2 12.5 With rivet type Inside screw thread E #4-40 6.1 With screw and rivet type 3. Ø 2.77 .00 2.84 Ø1 20 Outside screw thread Screw figure 18.5 8.10 3.2 4.4 Insulator materials 0: PBT UL94 V-0 Screw DIM. E 4: 4.80mm 5: 5.80mm 6: 4.80mm(Inside thread M2.6*0.45p, outside thread unc#4-40) M3: 4.80mm(Inside thread M3.0, outside thread unc#4-40) Board lock DIM. F 7: 3.70mm Contact plating T: Selective gold flash Si: Full gold flash F 10.94 9.52 2.84 C B A Screw materials F: Steel C: Copper alloy Board lock materials F: Steel C: Copper alloy 1.385 B Recommend PCB layout (Tolerance:±0.05) Color of housing K: Black Screw type A: With screw type B: With rivet type C: With screw and rivet type D: Rivet type with screws in bulk package E: With rivet type(N/A Thread) Shell plating N: Nickel Connector type M: Male F: Female No. of contact 09,15,25,37 D-SUB Standard Right Angle(7.2mm) Type 晨翔电子有限公司 (Series Image-Reference Only) CONNFLY ELECTRONIC CO. LTD
DS1037-01-09FNAKT74 价格&库存
很抱歉,暂时无法提供与“DS1037-01-09FNAKT74”相匹配的价格&库存,您可以联系我们找货
DS1037-01-09FNAKT74
    • 1+3.16470
    • 10+2.44860
    • 30+2.14830
    • 100+1.76720
    • 500+1.60550
    库存:507
    DS1037-01-09FNAKT74
    • 1+2.95920
    • 10+2.28960
    • 30+2.00880
    • 100+1.65240
    • 500+1.50120
    库存:470
