LTST-C19HRGYW
LTST-C19HRGYW
    LITE-ON(光宝)
    SMD-4P,1.6x1.6mm
    发光二极管/LED 红色,黄色,翠绿色 SMD-4P,1.6x1.6mm
LTST-C19HRGYW 数据手册
SMD LED Product Data Sheet LTST-C19HRGYW Spec No.: DS22-2014-0387 Effective Date: 11/15/2014 Revision: - LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto SMD LED LTST-C19HRGYW Ali 20140806 1. Description SMD LED lamps from Lite-On are available in miniature sizes and special configurations for automated PC board assembly and space-sensitive applications. These SMD LED lamps are suitable for use in a wide variety of electronic equipment, including cordless and cellular phones, notebook computers, network systems, home appliances, and indoor signboard applications. 1.1 Features         1.2 Applications Meet ROHS Extra Thin (0.35Hmm) Full Color SMD Chip LED. Ultra InGaN /AlInGaP Chip LED Package In 8mm Tape On 7" Diameter Reels. EIA STD Package. I.C. Compatible. Compatible With Automatic Placement Equipment. Compatible With Infrared Reflow Solder Process.      Telecommunication, Office automation, home appliances, industrial equipment Keypad/Keyboard Backlighting Status indicator Micro-displays Signal and Symbol Luminary 2. Package Dimensions Part No. Lens Color LTST-C19HRGYW White Diffused Source Color Pin Assignment AlInGaP Red 1 InGaN Green 2 AlInGaP Yellow 3 Notes: 1. All dimensions are in millimeters. 2. Tolerance is ±0.1 mm (.004") unless otherwise noted. 1/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 3. Rating and Characteristics 3.1 Absolute Maximum Ratings at Ta=25°C LTST-C19HRGYW Parameter Power Dissipation Unit Red Green Yellow 75 80 75 mW 80 100 80 mA 30 20 30 mA Peak Forward Current (1/10 Duty Cycle, 0.1ms Pulse Width) DC Forward Current Operating Temperature Range -20 ºC to + 80 ºC Storage Temperature Range -30 ºC to + 85 ºC Infrared Soldering Condition 260 °C For 10 Seconds 3.2 Suggest IR Reflow Condition For Pb Free Process: 2/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 3.3 Electrical / Optical Characteristics at Ta=25°C Parameter Luminous Intensity LTST-C19HRGYW Symbol IV Unit Red Green Yellow MIN. 45.0 71.0 71.0 TYP. - - - MAX. 180.0 450.0 280.0 mcd Test Condition IF = 20mA Note 1 Viewing Angle Peak Emission Wavelength 21/2 TYP. 130.0 λP TYP 632.0 520.0 595.0 MIN. 617.0 520.0 587.0 TYP. - - - MAX. 631.0 530.0 602.0 TYP 17.0 35.0 16.0 MIN. 1.8 2.9 1.8 TYP. - - - MAX. 2.4 3.5 2.4 MAX. 10 10 10 deg Note 1(Fig.5) nm Measurement @Peak (Fig.1) IF = 20mA Dominant Wavelength λd nm Note 3 Spectral Line Half-Width Forward Voltage Reverse Current Δλ VF IR nm V μA IF = 20mA VR=5V Notes: 1. 1. Luminous intensity is measured with a light sensor and filter combination that approximates the CIE eye-response curve. 2. θ1/2 is the off-axis angle at which the luminous intensity is half the axial luminous intensity. 3. The dominant wavelength, λd is derived from the CIE chromaticity diagram and represents the single wavelength which defines the color of the device. 4. Caution in ESD: Static Electricity and surge damages the LED. It is recommend to use a wrist band or anti-electrostatic glove when handling the LED. All devices, equipment and machinery must be properly grounded. 5. Reverse voltage (VR) condition is applied to IR test only. The device is not designed for reverse operation. 3/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 4. Bin Rank 4.1 Bin code list  IV Rank Luminous Intensity Color : Red , Unit : mcd @20mA Bin Code Min. Max. P 45.0 71.0 Q 71.0 112.0 R 112.0 180.0 Tolerance on each Luminous Intensity bin is +/- 15% Luminous Intensity Color : Green , Unit : mcd @20mA Bin Code Min. Max. Q 71.0 112.0 R 112.0 180.0 S 180.0 280.0 T 280.0 450.0 Tolerance on each Luminous Intensity bin is +/- 15% Luminous Intensity Color : yellow, Unit : mcd @20mA Bin Code Min. Max. Q 71.0 112.0 R 112.0 180.0 S 180.0 280.0 Tolerance on each Luminous Intensity bin is +/- 15% Tolerance on each Luminous Intensity bin is +/- 15% 4/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 5. Typical Electrical / Optical Characteristics Curves. (25°C Ambient Temperature Unless Otherwise Noted) 5/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 6. User Guide 6.1 Cleaning Do not use unspecified chemical liquid to clean LED they could harm the package. If clean is necessary, immerse the LED in ethyl alcohol or in isopropyl alcohol at normal temperature for less one minute. 6.2 Recommend Printed Circuit Board Attachment Pad 6.3 Package Dimensions Of Tape And Reel Note: 1. All dimensions are in millimeters (inches). 6/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 6.4 Package Dimensions of Reel Notes: 1. Empty component pockets sealed with top cover tape. 2. 7 inch reel-3000 pieces per reel. 3. Minimum packing quantity is 500 pieces for remainders. 4. The maximum number of consecutive missing lamps is two. 5. In accordance with ANSI/EIA 481 specifications. 7/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 7. Cautions 7.1 Application The LEDs described here are intended to be used for ordinary electronic equipment (such as office equipment, communication equipment and household applications).Consult Liteon’s Sales in advance for information on applications in which exceptional reliability is required, particularly when the failure or malfunction of the LEDs may directly jeopardize life or health (such as in aviation, transportation, traffic control equipment, medical and life support systems and safety devices). 7.2 Storage The package is sealed: The LEDs should be stored at 30°C or less and 90%RH or less. And the LEDs are limited to use within one year, while the LEDs is packed in moisture-proof package with the desiccants inside. The package is opened: The storage ambient for the LEDs should not exceed 30°C temperature or 60% relative humidity. It is recommended that LEDs out of their original packaging are IR-reflowed within one week.(MSL 3) For extended storage out of their original packaging, it is recommended that the LEDs be stored in a sealed container with appropriate desiccant, or in a desiccators with nitrogen ambient. LEDs stored out of their original packaging for more than one week should be baked at about 60 deg C for at least 20 hours before solder assembly. 7.3 Cleaning Use alcohol-based cleaning solvents such as isopropyl alcohol to clean the LED if necessary. 7.4 Soldering Recommended soldering conditions: Reflow soldering Pre-heat Pre-heat time Peak temperature Soldering time 150~200°C 120 sec. Max. 260°C Max. 10 sec. Max.(Max. two times) Soldering iron Temperature Soldering time 300°C Max. 3 sec. Max. (one time only) Notes: Because different board designs use different number and types of devices, solder pastes, reflow ovens, and circuit boards, no single temperature profile works for all possible combinations. However, you can successfully mount your packages to the PCB by following the proper guidelines and PCB-specific characterization. LITE-ON Runs both component-level verification using in-house KYRAMX98 reflow chambers and board-level assembly. The results of this testing are verified through post-reflow reliability testing. Profiles used at LITE-ON are based on JEDEC standards to ensure that all packages can be successfully and reliably surface mounted. Figure on page3 shows a sample temperature profile compliant to JEDEC standards. You can use this example as a generic target to set up your reflow process. You should adhere to the JEDEC profile limits as well as specifications and recommendations from the solder paste manufacturer to avoid damaging the device and create a reliable solder joint. 8/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 7.5 Drive Method A LED is a current-operated device. In order to ensure intensity uniformity on multiple LEDs connected in parallel in an application, it is recommended that a current limiting resistor be incorporated in the drive circuit, in series with each LED as shown in Circuit A below. Circuit model A LED Circuit model B LED (A) Recommended circuit. (B) The brightness of each LED might appear different due to the differences in the I-V characteristics of those LEDs. 7.6 ESD (Electrostatic Discharge) Static Electricity or power surge will damage the LED. Suggestions to prevent ESD damage:     Use of a conductive wrist band or anti-electrostatic glove when handling these LEDs. All devices, equipment, and machinery must be properly grounded. Work tables, storage racks, etc. should be properly grounded. Use ion blower to neutralize the static charge which might have built up on surface of the LED’s plastic lens as a result of friction between LEDs during storage and handling. ESD-damaged LEDs will exhibit abnormal characteristics such as high reverse leakage current, low forward voltage, or “ no lightup ” at low currents. To verify for ESD damage, check for “ lightup ” and Vf of the suspect LEDs at low currents. The Vf of “ good ” LEDs should be >2.0V@0.1mA for InGaN product and >1.4V@0.1mA for AlInGaP product. 9/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 SMD LED LTST-C19HRGYW Ali 20140806 8. Reliability Test Classification Test Item Test Condition Operation Life Ta= Under Room Temperature As Per Data Sheet Maximum Rating *Test Time= 1000HRS (-24HRS,+72HRS) High Temperature High Humidity Endurance Storage Reference Standard MIL-STD-750D:1026 MIL-STD-883D:1005 JIS C 7021:B-1 IR-Reflow In-Board, 2 Times MIL-STD-202F:103B JIS C 7021:B-11 Ta= 65±5℃,RH= 90~95% *Test Time= 240HRS±2HRS Test High Temperature Storage Low Temperature Ta= 105±5℃ *Test Time= 1000HRS (-24HRS,+72HRS) MIL-STD-883D:1008 JIS C 7021:B-10 Ta= -55±5℃ JIS C 7021:B-12 Storage Temperature *Test Time=1000HRS (-24HRS,+72H RS) MIL-STD-202F:107D MIL-STD-750D:1051 MIL-STD-883D:1010 JIS C 7021:A-4 105 ºC ~ 25 ºC ~ -55 ºC ~ 25 ºC Cycling 30mins 5mins 10 Cycles 30mins Thermal IR-Reflow In-Board, 2 Times 85 ± 5℃ ~ -40℃ ± 5℃ 5mins MIL-STD-202F:107D MIL-STD-750D:1051 MIL-STD-883D:1011 Shock 10mins Solder T.sol= 260 ± 5 ºC Dwell Time= 10 ± 1secs MIL-STD-202F:210A MIL-STD-750D:2031 JIS C 7021:A-1 Ramp-up rate(217 ºC to Peak) +3 ºC / second max Temp. maintain at 175(±25) ºC 180 seconds max Temp. maintain above 217 ºC 60-150 seconds Peak temperature range 260 ºC +0/-5 ºC Time within 5°C of actual Peak Temperature (tp) 10-30 seconds Ramp-down rate +6 ºC /second max MIL-STD-750D:2031.2 J-STD-020D T.sol= 235 ± 5 ºC Immersion time 2±0.5 sec Immersion rate 25±2.5 mm/sec Coverage ≧95% of the dipped surface MIL-STD-202F:208D MIL-STD-750D:2026 MIL-STD-883D:2003 IEC 68 Part 2-20 JIS C 7021:A-2 Resistance 10mins 10 Cycles Environmental Test IR-Reflow Solder ability 10/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4 Ali 20140806 SMD LED LTST-C19HRGYW 9. Others The appearance and specifications of the product may be modified for improvement without prior notice. 10. Suggested Checking List Training and Certification 1. Everyone working in a static-safe area is ESD-certified? 2. Training records kept and re-certification dates monitored? Static-Safe Workstation & Work Areas 1. Static-safe workstation or work-areas have ESD signs? 2. All surfaces and objects at all static-safe workstation and within 1 ft measure less than 100V? 3. All ionizer activated, positioned towards the units? 4. Each work surface mats grounding is good? Personnel Grounding 1. Every person (including visitors) handling ESD sensitive(ESDS) items wears wrist strap, heel strap or conductive shoes with conductive flooring? 2. If conductive footwear used, conductive flooring also present where operator stand or walk? 3. Garments, hairs or anything closer than 1 ft to ESD items measure less than 100V*? 4. Every wrist strap or heel strap/conductive shoes checked daily and result recorded for all DLs? 5. All wrist strap or heel strap checkers calibration up to date? Note: *50V for InGaN LED. Device Handling 1. Every ESDS items identified by EIA-471 labels on item or packaging? 2. All ESDS items completely inside properly closed static-shielding containers when not at static-safe workstation? 3. No static charge generators (e.g. plastics) inside shielding containers with ESDS items? 4. All flexible conductive and dissipative package materials inspected before reuse or recycles? Others 1. Audit result reported to entity ESD control coordinator? 2. Corrective action from previous audits completed? 3. Are audit records complete and on file? 11/11 Part No. : LTST-C19HRGYW BNS-OD-FC002/A4
LTST-C19HRGYW 价格&库存
很抱歉,暂时无法提供与“LTST-C19HRGYW”相匹配的价格&库存,您可以联系我们找货
