JK30-600
JK30-600
    JKSEMI(金开盛)
    PTC-17.2X3MM_TM
JK30-600 数据手册
JK30 Series Surface Mount PTC Devices Performance Specification Maximum Time Vmax Model Imax Ihold Itrip Pd Resistance To Trip Typ. Current Time Rimin Rimax R1max (Vdc) (A) (A) (A) (W) (A) (Sec) () () () JK30-030 30 40 0.30 0.60 0.44 8.00 0.3 0.370 0.720 1.080 JK30-040 30 40 0.40 0.80 0.45 8.00 0.3 0.250 0.645 1.100 JK30-050 30 40 0.50 1.00 0.46 8.00 0.3 0.250 0.600 1.200 JK30-065 30 40 0.65 1.30 0.47 8.00 0.4 0.120 0.450 0.500 JK30-075 30 40 0.75 1.50 0.48 8.0 0.4 0.200 0.370 0.420 JK30-090 30 40 0.90 1.80 0.6 4.50 5.9 0.100 0.220 0.300 JK30-110 30 40 1.10 2.20 0.7 5.50 6.6 0.070 0.200 0.260 JK30-135 30 40 1.35 2.70 0.8 6.75 7.3 0.070 0.160 0.200 JK30-160 30 40 1.60 3.20 0.9 8.00 8.0 0.060 0.140 0.180 JK30-185 30 40 1.85 3.70 1.0 9.25 8.7 0.050 0.120 0.150 JK30-250 30 40 2.50 5.00 1.2 12.5 10.3 0.030 0.080 0.100 JK30-300 30 40 3.00 6.00 2.0 15.0 10.8 0.030 0.070 0.095 JK30-400 30 40 4.00 8.00 2.5 20.0 12.7 0.010 0.060 0.090 JK30-500 30 40 5.00 10.00 3.0 25.0 14.5 0.010 0.050 0.080 JK30-600 30 40 6.00 12.00 3.5 30.0 16.0 0.005 0.040 0.060 JK30-700 30 40 7.00 14.00 3.8 35.0 17.5 0.005 0.030 0.050 JK30-800 30 40 8.00 16.00 4.0 40.0 18.8 0.005 0.025 0.030 JK30-900 30 40 9.00 18.00 4.2 40.0 20.0 0.005 0.020 0.025 V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (Vmax). I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Test Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C http:// www.jksemi.com 2019-12-01 版次: c JK30 Series Surface Mount PTC Devices Agency Approval and Environmental Complianc Agency File Number Regulation UL pending 2002/95/EC TUV pending EN14582 Thermal Derating Curve Average Time-Current Curve Derating Curves for D30 Series Average Time Current Curves 180 1000 0.90A 100 1.60A 1.85A 1.10A 1.35A 160 140 120 TIME IN SECOND Percentage of Derated Current Standard 100 80 60 2.50A 3.00A 10 4.00A 5.00A 6.00A 7.00A 1 40 8.00A 9.00A 0.75A 0.65A 0.1 20 0 -40 -20 0 20 40 60 0.50A 0.40A 0.01 80 0.30A 1 Temperature (°C) 10 CURRENT IN AMPERES 100 Ihold Versus Temperature Model Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) -40°C -20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C JK30-030 0.44 0.39 0.35 0.30 0.25 0.23 0.20 0.18 0.16 JK30-040 0.58 0.52 0.46 0.40 0.33 0.31 0.27 0.24 0.21 JK30-050 0.73 0.65 0.58 0.50 0.42 0.38 0.34 0.31 0.26 JK30-065 0.95 0.85 0.75 0.65 0.54 0.50 0.44 0.40 0.34 JK30-075 0.00 0.00 0.00 0.75 0.00 0.00 0.00 0.00 0.00 JK30-090 1.31 1.17 1.04 0.90 0.75 0.69 0.61 0.55 0.47 JK30-110 1.60 1.43 1.27 1.10 0.91 0.85 0.75 0.67 0.57 JK30-135 1.96 1.76 1.55 1.35 1.12 1.04 0.92 0.82 0.70 JK30-160 2.32 2.08 1.84 1.60 1.33 1.23 1.09 0.98 0.83 JK30-185 2.68 2.41 2.13 1.85 1.54 1.42 1.26 1.13 0.96 JK30-250 3.63 3.25 2.88 2.50 2.08 1.93 1.70 1.53 1.30 JK30-300 4.35 3.90 3.45 3.00 2.49 2.31 2.04 1.83 1.56 JK30-400 5.80 5.20 4.60 4.00 3.32 3.08 2.72 2.44 2.08 JK30-500 7.25 6.50 5.75 5.00 4.15 3.85 3.40 3.05 2.60 JK30-600 8.70 7.80 6.90 6.00 4.98 4.62 4.08 3.66 3.12 JK30-700 10.15 9.10 8.05 7.00 5.81 5.39 4.76 4.27 3.64 JK30-800 11.60 10.40 9.20 8.00 6.64 6.16 5.44 4.88 4.16 JK30-900 13.05 11.70 10.35 9.00 7.47 6.93 6.12 5.49 4.68 http:// www.jksemi.com 2019-12-01 版次: c JK30 Series Surface Mount PTC Devices Soldering Parameters TP 260 Gradual Cooling Soldering 5Sea.MAX Pre-Heating 1 Minute Min. 100 25 WAVE SOLDERING INFORMATIONS Time Pre-Heating Zone Max. ramping rate should not exceed 4℃/Sec. Soldering Zone Max. solder temperature should not exceed 260℃ Cooling Zone Cooling by natural convection in air. ◎ Specifications are subject to change without notice. Physical Dimensions(mm.) E A A C B E JK = JKSEMI mark 30= Radial type 30 Vrms 135 = 1.35A hold current JK 30-135 B F D D C C Model A B C D E F Lead Max. Max. Typ. Min. Max. Max. Style JK30-030 7.4/0.29 10.2/0.4 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-040 7.4/0.29 11.4/0.45 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-050 7.4/0.29 11.4/0.45 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-065 7.4/0.29 11.4/0.45 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-075 7.4/0.29 11.4/0.45 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-090 7.4/0.29 12.2/0.48 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink JK30-110 7.4/0.29 14.2/0.56 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink JK30-135 8.9/0.35 13.5/0.53 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink JK30-160 8.9/0.35 15.2/0.60 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink JK30-185 10.2/0.40 15.7/0.62 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink JK30-250 11.4/0.45 18.3/0.72 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink JK30-300 11.4/0.45 17.3/0.68 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-400 14.0/0.55 20.1/0.79 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-500 14.0/0.55 24.9/0.98 10.2/0.40 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-600 16.5/0.65 24.9/0.98 10.2/0.40 7.6/0.3 3.0/0.12 1.2/0.05 Straight JK30-700 19.1/0.75 26.7/1.05 10.2/0.40 7.6/0.3 3.0/0.12 2.0/0.08 Straight JK30-800 21.6/0.85 29.2/1.15 10.2/0.40 7.6/0.3 3.0/0.12 2.0/0.08 Straight JK30-900 24.1/0.95 29.7/1.17 10.2/0.40 7.6/0.3 3.0/0.12 2.0/0.08 Straight http:// www.jksemi.com 2019-12-01 版次: c JK30 Series Surface Mount PTC Devices PHYSICAL SPECIFICATIONS : Materials : Leads JK30-030 ~ 250: Tin-platedcopper-cladsteel,0.205mm2(24AWG),Φ0.51mm(0.020in). JK30-300 ~ 900: Tin-plated copper, 0.52mm2 (20AWG), Φ0.81mm(0.032 in). Lead Solderability : MIL-STD-202, Method 208E. Packaging Quantity 30 135 Radial type Hold K or S Model Reel Q'ty Bag Q'ty JK30-030 ~ JK30-075 - 500 JK30-090 ~ JK30-250 3000 500 U= Bulk JK30-300 ~ JK30-400 1500 500 packaged JK30-500 ~ JK30-900 - 500 K= Kink leads Current (A) R or U R=Tape&reel S=Straight 30 V leads Tape & Reel packaging per EIA468-B standard. Cross Reference Cross Reference JKSEMI Tyco /Raychem Bourns / Multifuse® Polytronics / EVERFUSE® SEA-LAND JK30-030 - - - R30-030 JK30-040 - - - R30-040 JK30-050 - - - R30-050 JK30-065 - - - R30-065 JK30-075 - - - R30-075 JK30-090 RUEF090 MF-R090-0-009 RLD30P090UF R30-090 JK30-110 RUEF110 MF-R110 RLD30P110UF R30-110 JK30-135 RUEF135 MF-R135 RLD30P135UF R30-135 JK30-160 RUEF160 MF-R160 RLD30P160UF R30-160 JK30-185 RUEF185 MF-R185 RLD30P185UF R30-185 JK30-250 RUEF250 MF-R250 RLD30P250UF R30-250 JK30-300 RUEF300 MF-R300 RLD30P300UF R30-300 JK30-400 RUEF400 MF-R400 RLD30P400UF R30-400 JK30-500 RUEF500 MF-R500 RLD30P500UF R30-500 JK30-600 RUEF600 MF-R600 RLD30P600UF R30-600 JK30-700 RUEF700 MF-R700 RLD30P700UF R30-700 JK30-800 RUEF800 MF-R800 RLD30P800UF R30-800 JK30-900 RUEF900 MF-R900 RLD30P900UF R30-900 “Raychem” is a registered trademark of Tyco Electronics. “Multifuse” is a registered trademark of bourns,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. “SEA-LAND” is a registered trademark of Sea-Land electronic corp. Website: http://www.jksemi.com For additional information, please contact your local Sales Representative. ©Copyright 2016, jksemi is a registered trademark of jksemi All rights arereserved http:// www.jksemi.com 2019-12-01 版次: c
JK30-600 价格&库存
很抱歉,暂时无法提供与“JK30-600”相匹配的价格&库存,您可以联系我们找货
