NV040C
NV040C
    N-EC(九芯电子)
    SOP-8
    语音芯片
NV040C 数据手册
广州市九芯电子科技有限公司 GUANGZHOU NINE CHIP ELECTRON TECHNOLOGY CO,. LTD. NVC 系列语音芯片 目 录 1 概述............................................................................................................................................................................. 3 2 功能特点..................................................................................................................................................................... 3 3 选型指南..................................................................................................................................................................... 4 4 芯片内部结构图与应用范围....................................................................................................................................4 4.1 芯片应用范围.................................................................................................................................................4 4.2 芯片内部结构图.............................................................................................................................................4 5 芯片管脚图及封装引脚对应表.................................................................................................................................5 5.1 芯片管脚图......................................................................................................................................................5 5.2 封装引脚对应表.............................................................................................................................................5 6 电气参数及环境极限绝对系数.................................................................................................................................6 6.1 电气参数......................................................................................................................................................... 6 6.2 环境极限参数.................................................................................................................................................7 6.3 芯片电压与频率变化的对应图表.................................................................................................................7 7 控制模式.................................................................................................................................................................... 8 7.1 按键控制模组.................................................................................................................................................8 7.2 MCU 一线串口控制........................................................................................................................................9 7.3 MCU 二线串口控制......................................................................................................................................12 8 芯片典型应用电路图..............................................................................................................................................13 8.1 按键应用图, PWM 直推喇叭,VDD4.5V 电路图.................................................................................14 8.3 PWM 输出,VDD200us 高电平:低电平=1:3 表示0 高电平:低电平=3:1 表示1 * 多条指令连续发送的时候,检测到忙信号变高后,先延时 50~100ms 在发送下一条指令,以避免因为处理 未完成导致丢失某段语音。 7.2.4 程序范例(MCU:PIC16F57 sda=0; wait(300); for(i=0;i>=1; } sda=1; 晶振:4MHz) /*>2ms*/ /*>2400us*/ /*>800us*/ /*>800us*/ /*>2400us*/ /*地址值右移一位*/ 11 NVC 系列语音芯片 广州市九芯电子科技有限公司 GUANGZHOU NINE CHIP ELECTRON TECHNOLOGY CO,. LTD. 7.3 MCU 二线串口控制 MCU 二线串口控制是指主控 MCU 通过 DATA 数据线来控制任意一段语音的触发播放及停止。时序采 用下列时序。 7.2.1 端口的分配 管脚 封装形式 SSOP20/SOP8 ---- ---- ---- --- --- PB0 PA1 PA0 ---- --- BUSY SDA CLK 7.2.2 数据与语音的对应关系 可支持 223 段声音以及命令的发送。语音地址发送和命令发送格式是一样的,发送之间相互独立。 一线串口 功能 00H 播放第 1 段语音 01H 播放第 2 段语音 . XXH . . 播放第 N 段语音 . DFH 播放第 223 段语音 E0H~E7H 控制 8 级音量,E0 音量最小,E7 音量最大,默认最大 F2H 循环指令,播放时发此指令循环该段语音。 FEH 停止播放 7.2.3 二线串口时序图 二线串口一共占用 2 个 IO 端口,一个是 CLK 时钟信号,一个是 SDA 数据信号。头码为 4ms 到 6ms 之间。 单个 bit 时钟周期为 80us~1320us 之间,建议单个 bit 时钟周期为 680us 比较稳定。特殊要求需要更快时序的 请联系厂家定制。在上升沿收码,收码为收低位。一个完整的数据为 1byte。CLK 和 SDA 非收码状态下为 高电平。 * 多条指令连续发送的时候,检测到忙信号变高后,先延时 50~100ms 在发送下一条指令,以避免因为处理 12 NVC 系列语音芯片 广州市九芯电子科技有限公司 GUANGZHOU NINE CHIP ELECTRON TECHNOLOGY CO,. LTD. 未完成导致丢失某段语音。 7.2.4 参考程序范例(MCU:PIC16F57 clk=0; delay(200); for(i=0;i>=1; } sda=1; 晶振:4MHz) /*时钟口拉低*/ /*延时>4ms*/ sda=1; /*addr 为待发数据*/ /*延时大于 500us*/ /*地址值右移一位*/ 8 芯片典型应用电路图 8.1 按键应用图, PWM 直推喇叭,VDD4.5V,PWM直推喇 叭时的应用 电路图 VDD LED 1 2 SW-P B 3 SW-P B 4 PB0 VPP PA0 GND PA1 VDD PWM 1/DAC 8 电容靠 近ic 0.1UF 7 VDD 6 5 PWM 2 IN400 7 NVC语音芯 片 SPEA KER 8.3 PWM 输出,VDD2ms*/ /*>2400us*/ /*>800us*/ /*>800us*/ /*>2400us*/ /*地址值右移一位*/ 11 NVC 系列语音芯片 广州市九芯电子科技有限公司 GUANGZHOU NINE CHIP ELECTRON TECHNOLOGY CO,. LTD. 7.3 MCU 二线串口控制 MCU 二线串口控制是指主控 MCU 通过 DATA 数据线来控制任意一段语音的触发播放及停止。时序采 用下列时序。 7.2.1 端口的分配 管脚 封装形式 SSOP20/SOP8 ---- ---- ---- --- --- PB0 PA1 PA0 ---- --- BUSY SDA CLK 7.2.2 数据与语音的对应关系 可支持 223 段声音以及命令的发送。语音地址发送和命令发送格式是一样的,发送之间相互独立。 一线串口 功能 00H 播放第 1 段语音 01H 播放第 2 段语音 . XXH . . 播放第 N 段语音 . DFH 播放第 223 段语音 E0H~E7H 控制 8 级音量,E0 音量最小,E7 音量最大,默认最大 F2H 循环指令,播放时发此指令循环该段语音。 FEH 停止播放 7.2.3 二线串口时序图 二线串口一共占用 2 个 IO 端口,一个是 CLK 时钟信号,一个是 SDA 数据信号。头码为 4ms 到 6ms 之间。 单个 bit 时钟周期为 80us~1320us 之间,建议单个 bit 时钟周期为 680us 比较稳定。特殊要求需要更快时序的 请联系厂家定制。在上升沿收码,收码为收低位。一个完整的数据为 1byte。CLK 和 SDA 非收码状态下为 高电平。 * 多条指令连续发送的时候,检测到忙信号变高后,先延时 50~100ms 在发送下一条指令,以避免因为处理 12 NVC 系列语音芯片 广州市九芯电子科技有限公司 GUANGZHOU NINE CHIP ELECTRON TECHNOLOGY CO,. LTD. 未完成导致丢失某段语音。 7.2.4 参考程序范例(MCU:PIC16F57 clk=0; delay(200); for(i=0;i>=1; } sda=1; 晶振:4MHz) /*时钟口拉低*/ /*延时>4ms*/ sda=1; /*addr 为待发数据*/ /*延时大于 500us*/ /*地址值右移一位*/ 8 芯片典型应用电路图 8.1 按键应用图, PWM 直推喇叭,VDD4.5V,PWM直推喇 叭时的应用 电路图 VDD LED 1 2 SW-P B 3 SW-P B 4 PB0 VPP PA0 GND PA1 VDD PWM 1/DAC 8 电容靠 近ic 0.1UF 7 VDD 6 5 PWM 2 IN400 7 NVC语音芯 片 SPEA KER 8.3 PWM 输出,VDD
NV040C 价格&库存
很抱歉,暂时无法提供与“NV040C”相匹配的价格&库存,您可以联系我们找货
