DOCUMENT:M20153
REV LETTER: C
PAGE NO: 1 OF 1
REV DATE: 2013-10-30
PART NUMBER:
Polymer
PTC Devices
CYG
Wayon Circuit Protection Co.,Ltd.
No.1001, Shiwan Qi Road, Shanghai 201207,China
Tel: 86-21-50968309
Fax: 86-21-50968310
Surface mount fuses
E-mail: market@way-on.com
Http://www.way-on.com
LP-NSM012
Features
Small size of 1206
Lead-free and compliant with the European Union RoHS Directive 2011/65/EU
Fast tripping resettable circuit protection
Surface mount packaging for automated assembly
Agency Recognition: UL、CSA、TUV
Product Dimensions (mm)
A
Max.
3.50
Part number
LP-NSM012
B
Max.
1.80
Top View
C
Max.
0.85
D
Min.
0.25
E
Min.
0.10
Part marking
P
Side View
Electrical Characteristics
IH
IT
Vmax
Imax
Ttrip
Pd typ
Rmin
(A)
(A)
(V)
(A)
Current(A)
Time(S)
(W)
(Ω)
LP-NSM012
0.125
0.29
30
0.20
0.6
1.50
IH=Hold current: maximum current at which the device will not trip at 25℃ still air.
IT=Trip current: minimum current at which the device will always trip at 25℃ still air.
Vmax=Maximum voltage device can withstand without damage at rated current.
Imax=Maximum fault current device can withstand without damage at rated voltage.
Ttrip=Maximum time to trip(s) at assigned current.
Pdtyp=Typical power dissipation: typical amount of power dissipated by the device when in state air environment.
Rmin=Minimum device resistance at 25℃ prior to tripping.
R1max=Maximum device resistance measured in the nontripped state 1 hour post reflow.
Part number
R1max
(Ω)
6.00
Thermal Derating
Maximum ambient operating temperature(℃)
LP-NSM012
Hold Current (A)
-40
0.19
-20
0.16
25
0.125
40
0.10
50
0.09
60
0.08
70
0.07
85
0.04
Solder Reflow Recommendations
C
Solder Pad Layouts
B
A
B
A
B
C
(mm)
(mm)
(mm)
LP-NSM012
1.80
1.00
1.80
* Recommended reflow methods: IR, Vapor phase, hot air oven.
* Devices can be cleaned using standard industry methods and
solvents.
Notes:
If reflow temperatures exceed the recommended profile, devices
may not meet the performance requirements.
Devices are not designed to be wave soldered to the bottom side
of the board.
Part number
Package Information
Tape & Reel: 4000pcs per reel.
Effectivity: Reference documents shall be the issue in effect on the
date of invitation for bid.
Caution: Operation beyond the rated voltage or current may result in
rupture electrical arcing or flame.
Specifications are subject to change without notice
page 1 of 1
很抱歉,暂时无法提供与“LP-NSM012”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.80234
- 50+0.64941
- 150+0.57294
- 500+0.51560
- 2500+0.42077
- 4000+0.39788
