BK13C06-32DS/2-0.35V(868)
    HRS(广濑)
    CONN-32P_7.85X1.9MM_SM
    板对板连接器 SMT 针脚数:38Pin
BK13C06-32DS/2-0.35V(868) 数据手册
COUNT DESCRIPTION OF REVISIONS RE-6-1422 8 APPLICABLE STANDARD 1 OPERATING TEMPERATURE RANGE BY CHKD DATE JSH JHW 19.06.10 STORAGE TEMPERATURE RANGE APPLICABLE CONNECTOR -55℃ TO +85℃(note1) 30 V AC/DC RATING VOLTAGE DESCRIPTION OF REVISIONS COUNT BY CHKD DATE -10℃ TO +60℃ BK13C06-32DP2-0.35V(**) SIGNAL CONTACT 0.3A POWER CONTACT 5.0A CURRENT SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT CONSTRUCTION GENERAL EXAMINATION CONFIRMED VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ACCORDING TO DRAWING. X X X X X - ELECTRICAL CHARACTERISTICS CONTACT RESISTANCE SIGNAL CONTACT : 50mΩ MAX POWER CONTACT : 15mΩ MAX 20mV AC OR LESS 1kHz, 1mA 1 1 INSULATION RESISTANCE 100V DC 50MΩ MIN X VOLTAGE PROOF 100V AC FOR 1min. NO FLASHOVER OR BREAKDOWN X - X - X - X - X - X - X - X - MECHANICAL CHARACTERISTICS INSERTION AND WITHDRAWAL FORCE 1 MEASURED BY APPLICABLE CONNECTOR. 30TIMES INSERTION AND WITHDRAWAL. TEST SPEED 10mm/min ① INSERTION FORCE : 40N MAX (INITIAL AND AFTER TEST) ② WITHDRAWAL FORCE INITIAL : 8N MIN (0.25N * PIN) AFTERT TEST : 6.4N MIN (0.2N * PIN) MECHANICAL OPERATION VIBRATION SHOCK 30 TIMES INSERTIONS AND EXTRACTIONS. ① CONTACT RESISTANCE: 1 SIGNAL CONTACT : 70mΩ MAX POWER CONTACT : 30mΩ MAX ② NO DAMAGE, CRACK OR LOOSENESS OF PATRS. ① NO ELECTRICAL DISCONTINUITY OF 1μs. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. ① NO ELECTRICAL DISCONTINUITY OF 1μs. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. 1 FREQUENCY 10 TO 55 TO 10 Hz, APPROX 5min SINGLE AMPLITUDE 0.75mm, 10CYCLES, FOR 3 DIRECTIONS. 490 m/s² DURATION OF PULSE 11ms AT 3 TIMES FOR 3 DIRECTIONS. ENVIRONMENTAL CHARACTERISTICS RAPID CHANGE OF TEMPERATURE DAMP HEAT (STEADY STATE) SULPHUR DIOXIDE TEMPERATURE -55 → +85℃ TIME 30 → 30 min UNDER 5 CYCLES. (RELOCATION TIME TO CHAMBER: WITHIN2~3 MIN) ① CONTACT RESISTANCE: SIGNAL CONTACT : 70mΩ MAX 1 POWER CONTACT : 30mΩ MAX ② INSULATION RESISTANCE: 50MΩ MIN ③ NO DAMAGE, CRACK OR LOOSENESS OF PARTS. ① CONTACT RESISTANCE: 1 SIGNAL CONTACT : 70mΩ MAX EXPOSED AT 40±2℃, 90 TO 95%, 96h. POWER CONTACT : 30mΩ MAX ② INSULATION RESISTANCE: 25MΩ MIN ③ NO DAMAGE, CRACK OR LOOSENESS OF PARTS. ① CONTACT RESISTANCE: SIGNAL CONTACT : 70mΩ MAX 1 POWER CONTACT : 30mΩ MAX ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. EXPOSED IN 25 PPM FOR 96h, 25℃, 75±5%RH. (Test standard : JIS C 60068) REMARKS Note 1 : INCLUDE THE TEMPERATURE RISING BY CURRENT. DRAWN DESIGNED CHECKED APPROVED S.H.JUNG S.H.JUNG H.W.JO H.W.JO RELEASED ENG 19.06.10 Unless otherwise specified, refer to JIS C 5402 and IEC 60512 Note QT: QUALIFICATION TEST AT: ASSURANCE TEST HIROSE KOREA CO.,LTD. CODE NO.(OLD) 19.02.25 19.02.25 19.02.25 19.02.25 DEPT X: APPLICABLE TEST SPECIFICATION SHEET DRAWING NO. SLC4-632775-68 PART NO. BK13C06-32DS/2-0.35V(868) 1 CODE NO. CL 6665-0012-4-868 1
BK13C06-32DS/2-0.35V(868) 价格&库存
很抱歉,暂时无法提供与“BK13C06-32DS/2-0.35V(868)”相匹配的价格&库存,您可以联系我们找货
