TMBF410
TMBF410
    BAOCHENG(宝乘)
    DBS-4P_6.6X7.3MM_SM
    耐压:1000V 电流:4A
TMBF410 数据手册
TMBF4005 thru TMBF410 4.0 A Single-Phase Glass Passivated Bridge Rectifiers Rectifier Reverse Voltage 50 to 1000V .264(6.70) .256(6.50) .049(1.25) .037(0.95) Features .339(8.60) .311(7.90) .291(7.40) .283(7.20) .049(1.25) .037(0.95) ● Rating to 1000V PRV ● Compact, thin profile package design ● Ideal for SMT manufacturing .045(1.15) .037(0.95) (depth:0.02~0.08) (? 0.8±0.03) (Pin1) (1) .041(1.05) .026(0.65) (3) .205(5.20) .197(5.00) ● Reliable robust construction ● UL recognized file#E364304 (4) (2) Bottom View Top Viev Mechanical Data (1) (3) - ●Molding compound meets UL 94 V-0 flammability rating, + .122(3.10) .016(0.40) .011(0.27) .059(1.5) .051(1.3) ●Weight: 216 mg .003(0.08) .002(0.04) Halogen-free, RoHS-compliant, and commercial grade ●Polarity indicator: As marked on body .114(2.90) ~ ~ (4) Side View (2) Dimensions in millimeters ( 1mm =0.0394" ) Maximum Ratings & Thermal Characteristics Rating at 25 C ambient temperature unless otherwise specified, Resistive or Inductive load, 60 Hz. For Capacitive load derate current by 20%. TMBF TMBF TMBF TMBF TMBF TMBF TMBF Parameter Symbol 4005 408 404 410 unit 406 401 402 VRRM 600 50 100 200 400 800 1000 V Maximum repetitive peak reverse voltage Maximum RMS bridge input voltage Maximum DC blocking voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified output current at TA=40 C IF(AV) 4.0 A Peak forward surge current single sine-wave superimposed on rated load (JEDEC Method) IFSM 110 A I t 50.2 A sec ReJA 55 Rating for fusing ( t
TMBF410 价格&库存
很抱歉,暂时无法提供与“TMBF410”相匹配的价格&库存,您可以联系我们找货
