OR-M611-TP-G
OR-M611-TP-G
    ORIENT(奥伦德)
    SOP-5_4.4X3.85MM
    DC输入 隔离电压(RMS):3750V
OR-M611-TP-G 数据手册
Shenzhen Orient Components Co ., Ltd OR-M6XX ORIENT Photo coupler Product Data Sheet Name: OR-M6XX Customer: Date: SHENZHEN ORIENT COMPONENTS CO ., LTD Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2020 Orient .All rights Reserved 1 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 1. Features (1) (2) (3) (4) (5) (6) (7) Compliance Halogens Free (Br < 900ppm, Cl < 900ppm, Br+Cl 13mA Input Capacitance CIN — 34 — pF f = 1MHz, VF = 0V High Level Supply Current ICCH — 6 10 mA VCC=5.5V,IF=0mA Low Level Supply Current ICCL — 8 13 mA VCC= 5.5V,IF=10mA High Level Output Current IOH — 3 100 μA VCC=5.5V, VO=5.5V,IF=250μA V VCC=5.5V, IF=5mA, IOL (sinking) = 13mA Forward Voltage Temperature Coefficient OF Forward Voltage Input Symbol Min OR-M6XX Detector Low Level Output Voltage VOL — 0.4 0.6 Recommended temperature range(TA= -40℃—+85℃,4.5V≤VCC≤5.5V),IF= 7.5mA Unless otherwise stated. Typical values TA =25℃,VCC = 5.0V. Copyright© 2020 Orient .All rights Reserved 5 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 8. Switching Characteristics Parameter Symbol Min Typ Max Unit Propagation delay time to output High level tPLH — 60 90 ns Propagation delay time to output Low level tPHL — 25 75 ns |tPLH-tPHL| — 35 45 ns Output Rise Time (10 to 90%) tr — 27 — ns Output Fall Time (90 to 10%) tf — 6.6 — ns tPSK — — 40 ns Pulse Width Distortion Propagation Delay Skew Condition RL=350Ω CL=15pF Recommended temperature range (TA= -40℃—+85℃,2.7V≤VCC≤3.6 V),IF= 7.5mA Unless otherwise stated. Typical values TA =25℃,VCC = 3.3 V。 Parameter Symbol Min Typ Max Propagation delay time to output High level tPLH Propagation delay time to output Low level tPHL — 45 75 — — 100 — 25 75 — — 100 |tPLH-tPHL| — 10 35 ns Output Rise Time (10 to 90%) tr — 22 — ns Output Fall Time (90 to 10%) tf — 6.9 — ns tPSK — — 40 ns Pulse Width Distortion Propagation Delay Skew Unit Condition ns RL=50Ω, CL=15pF, TA=25℃ ns RL=350Ω , CL=15pF, TA=25℃ RL=350Ω, CL=15pF Recommended temperature range (TA= -40℃—+85℃,4.5V≤VCC≤5.5V),IF= 7.5mA Unless otherwise stated. Typical values TA =25℃,VCC = 5.0 V。 Copyright© 2020 Orient .All rights Reserved 6 V3 Shenzhen Orient Components Co ., Ltd Parameter Symbol Part Number M600 Logic High Common Mode Transient Immunity |CMH| M601 M611 M600 Logic Low Common Mode Transient Immunity |CML| M601 M611 Min Typ — — 5000 — 20000 — — — 5000 — Max Unit OR-M6XX Condition — IF = 7.5mA , VOH=2.0V, RL=350Ω, TA=25°C VCM=10Vp-p — IF = 7.5mA , VOH=2.0V, RL=350Ω, TA=25°C VCM=50Vp-p V/μs — IF = 7.5mA , VOH=2.0V, RL=350Ω, TA=25°C VCM=1000Vp-p — IF = 0mA , VOL=0.8V, RL=350Ω, TA=25°C VCM=10Vp-p — IF = 0mA , VOL=0.8V, RL=350Ω, TA=25°C VCM=50Vp-p V/μs IF = 0mA , VOL=0.8V, RL=350Ω, TA=25°C VCM=1000Vp-p 20000 — Symbol Min Typ Max Unit Condition Input-Output Insulation Leakage Current II-O — — 1 μA 45% RH,t=5s, VI-O = 3kV DC,TA =25 C Withstand Insulation Test Voltage VISO 3750 — — VRMS RH ≤ 50%, t =1min,TA=25℃ Input-Output Resistance RI-O — 1012 — Ω VI-O = 500V DC Input-Output Capacitance CI-O — 1 — p f = 1MHz, TA = 25 C Parameter — Recommended temperature range (TA=40℃-85℃) Unless otherwise stated. Typical values TA =25℃. Copyright© 2020 Orient .All rights Reserved 7 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 9. Order Information Part Number OR-M6XX-W-Y-Z Note XX = Type code. ( ‘00’, ‘01’, ‘11’) W = Tape and reel option. (TP or TP1). Y = ‘V’ code for VDE safety (This options is not necessary). Z = ‘G’ code for Halogen free. * VDE Code can be selected. Option Description Packing quantity TP Surface mount lead form (low profile) + TP tape & reel option 3000 units per reel TP1 Surface mount lead form (low profile) + TP1 tape & reel option 3000 units per reel Copyright© 2020 Orient .All rights Reserved 8 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 10. Naming Rule 1. Manufacturer : ORIENT. 2. Part Number : M600, M601 or M611. 3. Year Code : '21' means '2021' and so on. 4. Week Code : 01 means the first week, 02 means the second week and so on. 5. VDE Code . (Optional) 6. HF Code ‘G’: Halogen Free. 7. Anode. * VDE Code can be selected. Copyright© 2020 Orient .All rights Reserved 9 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 11. Outer Dimension 12. Recommended Foot Print Patterns (Mount Pad) Copyright© 2020 Orient .All rights Reserved 10 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 13. Taping Dimensions (1)OR-M6XX-TP (2)OR-M6XX-TP1 Description Symbol Tape wide W 12±0.3(0.472) Pitch of sprocket holes P0 4±0.1(0.157) F 5.5±0.1(0.217) P2 2±0.1(0.079) P1 8±0.1(0.315) Distance of compartment Distance of compartment to compartment Encapsulation type amount (pcs) Copyright© 2020 Orient .All rights Reserved Dimension in mm(inch) TP/TP1 3000 11 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 14. Package Dimension (1) package dimension Packing Information Packing type Reel type Tape Width 12mm Qty per Reel 3,000pcs Small box (inner) Dimension 345*345*45mm Large box (Outer) Dimension 480x360x360mm Max qty per small box 6,000pcs Max qty per large box 60,000pcs (2) Packing Label Sample Note: 1.Material Code :Product ID. 2.P/N :Contents with "Order Information" in the specification. 3.Lot No. :Product data. 4.D/C :Product weeks. 5.Quantity :Packaging quantity. Copyright© 2020 Orient .All rights Reserved 12 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 15. Reliability Test Reliability Testing NO. ITEMS QTY. (Pcs) 1 RSH 耐焊接热 22 Condition 260±5℃ Process 5s/3 次 Device Standard 锡炉 JESD22-A106 高温烤 箱 测试仪 JESD22-A103 低温箱 测试仪 JESD22-A119 168 hrs 2 HTSL 高温存储 77 125℃ 500 hrs 1000 hrs 168 hrs 3 LTSL 低温存储 77 -40℃ 500 hrs 1000 hrs 4 TC 温度循环 77 H:125℃ 15min ∫5min L:-55℃ 15min 300 cycle 冷热冲 击机 JESD22-A104 5 TS 温度冲击 77 H:100℃ 5min ∫15s L:-40℃ 5min 300 cycle 冷热冲 击机 JESD22-A106 168 hrs 6 HTOL 高温操作 77 100°C IF=10mA Vcc=5V 500 hrs 1000 hrs 7 ESD-HB M 人体模式 22 ≥8KV 1Cycle 1次 8 SD 可焊性 22 Pb-free 245±5℃ 5s/1 次 9 HTHB 温湿寿命 试验 168 hrs 77 85℃,85%RH IF=10mA,Vcc=5V 500 hrs 1000 hrs 10 Autoclave 压力锅 77 Ta=121 ℃,100%RH,2atm Copyright© 2020 Orient .All rights Reserved 96hrs 13 高温烤 箱 测试仪、 JESD22-A108 老化电 路板 ESD 静 电测试 仪 JESD22-A114 锡炉 JESD22-B102 恒温恒湿 机,测试 仪 JESD22-A101 压力锅 JESD22-A102 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 16. Temperature Profile Of Soldering (1)IR Reflow soldering (JEDEC-STD-020C compliant) Note: one solder backflow is recommended under the conditions described below in the temperature and time profile. Do not weld more than three times. Profile item Conditions Preheat 150˚C - Temperature Min (T Smin ) 200˚C - Temperature Max (T Smax ) 90±30 sec - Time (min to max) (ts) Soldering zone - Temperature (TL ) 217˚C - Time (t L ) 60 sec Peak Temperature 260˚C Peak Temperature time 20 sec Ramp-up rate 3˚C / sec max. Ramp-down rate from peak temperature 3~6˚C / sec Reflow times Copyright© 2020 Orient .All rights Reserved ≤3 14 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX (2)Wave soldering (JEDEC22A111 compliant) One-time welding is recommended under the temperature condition. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 5 to 140˚C 30 to 80 sec Preheat time (3)Hand soldering by soldering iron Single lead welding is allowed in each process and one-time welding is recommended. Copyright© 2020 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 15 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 17. Switching time test circuit Figure 1:Test Circuit for TPHL and TPLH Figure 2:Single Channel Test Circuit for Common Mode Transient Immunity Copyright© 2020 Orient .All rights Reserved 16 V3 Shenzhen Orient Components Co ., Ltd OR-M6XX 18. Characteristics Curve Copyright© 2020 Orient .All rights Reserved 17 V3 Shenzhen Orient Components Co ., Ltd Copyright© 2020 Orient .All rights Reserved 18 OR-M6XX V3 Shenzhen Orient Components Co ., Ltd Copyright© 2020 Orient .All rights Reserved 19 OR-M6XX V3
OR-M611-TP-G 价格&库存
很抱歉,暂时无法提供与“OR-M611-TP-G”相匹配的价格&库存,您可以联系我们找货
