RC100M331LO13*25TH-2A1E
    BERYL(绿宝石)
    AEC-D13X25MM_TM
RC100M331LO13*25TH-2A1E 数据手册
ALUMINUM ELECTROLYTIC CAPACITORS 规 格书 SPECIFICATION SHEET Customer name: BERYL SERIES: RC DESCRIPTION: 330uF/100V Apply 2022-04-11 date : TYPE: RADIAL Φ13*25 BERYL CUSTOMER P/N:RC100M331LO13*25TH-2A1E P/N: PREPARED CHECKED APPROVAL 董桂茹 廖梅君 张业维 PREPARED CHECKED APPROVAL After approved, please sign back 1 Approval Sheet before order. If not, we will treat it as tacitly acknowledged and accepted our relative standard and technical index. Zhao Qing Beryl Electronic Technology Co., Ltd. TEL: (0758) 13428556686 E-mail: master@zq-beryl.com FAX: (0758) 2862870 http://www.zq-beryl.com NO.8 DUANZHOU ROAD, ZHAOQING CITY. GUANGDONG. CHINA Sheet NO.:20220411 Page : 1 / 12 ALUMINUM ELECTROLYTIC CAPACITORS Revise record NO. Date Revise reason Revise content Prepared 01 2022.04.11 First issue First issue 董桂茹 Sheet NO.:20220411 Page : 2 / 12 ALUMINUM ELECTROLYTIC CAPACITORS 1、Application This specification applies to Aluminum electrolytic capacitor (foil type) used in electronic equipment. Designed capacitor’s quality meets IEC 60384. 2、Table of specification and characteristics Series Cap(uF) 120Hz/20℃ WV(V) 330 100 RC Size(mm) D L 13 25 Temperature (℃) Capacitance Life(hours) -40~+105 ±20% 3000 Tolerance @105(℃) DF (%)(MAX) 120Hz/20℃ LC(μA)(MAX) 2min/20℃ ESR(Ω)(MAX) 100KHz/25℃ RC (mA rms) (MAX)105℃/100KHz Surge voltage(V) ≤8 ≤330 ≤0.12 1240 115 Other:/ 3、Product Dimensions Type ФD 5 6.3 8 10 13 16 18 22 P 2 2.5 3.5 5 5 7.5 7.5 10 Фd 0.5 0.5 0.5/0.6 0.6 0.6 0.8 0.8 0.8 a Sheet NO.:20220411 (L< 20) ± 1.5 (L≥20) ± 2.0 Page : 3 / 12 ALUMINUM ELECTROLYTIC CAPACITORS 4、Part Number RC 100 M 331 LO 1 3* 2 5 TH - 2 B 1 E t t=date code(week) Material PET Sleeve colour Size:D*L TYPE CODE DESCRIPTION: LO Long Lead RATED CAPACITANCE: 331=330uF CAPACITANCE TOLERANCE:M=±20% RATED VOLTAGE: 100=100V SERIES NAME 5、Construction Sheet NO.:20220411 Material name Composition Supplier name Lead Al and (Fe+Cu+Sn) NM、JX Rubber EPT / IIR LHX、LA、TH、LM2 Case Aluminum OX、YJ、HL、LY2 Paper Wood / Fibrous plant materials KE、DF Anode foil Al + Al2O3 HY1、HY2、HF、HY3、 LD、FQ Cathode foil Aluminum GY、LY1 Electrolyte Glycol + Water +Ammonium salt XZB、LM1、JZ2、FS Sleeve PET YL、CY Page : 4 / 12 ALUMINUM ELECTROLYTIC CAPACITORS 6、Product Marking Marking Sample: Front Reverse ④ BERYL ① ⑤ RC(M) RG(M) 100V 50V 100V ② ⑥ E105℃ 330uF 10uF ③ ⑦ 1916 2216 ④ Marking Details: Capacitor shall be marked the following items: 1) Trademark (BERYL) 2) working voltage(100V) 3) Nominal capacitance(330uF) 4) Cathode marked 5) Series symbol & Nominal capacitance tolerance (M: -20% ~ +20%) 6) Sleeve material(E:PET) Maximum operating temperature(105℃) 7) Date code (2216) 22:Manufactured year 2022 Code 20 21 22 23 24 25 26 27 …… Year 2020 2021 2022 2023 2024 2025 2026 2027 …… Page : 5 / 12 16:Manufactured week (01、02、03、04……52、53) Sheet NO.:20220411 ALUMINUM ELECTROLYTIC CAPACITORS 7、Characteristics Standard atmospheric conditions Unless other specified, the standard range of atmospheric conditions for making measurements and tests is as follows: Ambient temperature :15C to 35C Relative humidity :45% to 85% Air pressure :86kPa to 106kPa If there is any doubt about the results, measurement shall be made within the following conditions: Ambient temperature :20C  2C Relative humidity :60% to 70% Air pressure : 86kPa to 106kPa Operating temperature range The ambient temperature range at which the capacitor can be operated continuously at rated voltage is (6.3~450WV) -40C to +105C . Table ITEM 1 2 3 Nominal capacitance (Tolerance) Leakage current Dissipation factor PERFORMANCE Measuring Frequency: 120Hz±12Hz Measuring Voltage: Not more than 0.5Vrms +1.5~2.0V.DC Measuring Temperature: 20±2℃ Shall be within the specified capacitance tolerance. Connecting the capacitor with a protective resistor (1kΩ±10Ω) in series for 2 minutes, and then, measure leakage current. I: Leakage current (μA) I (μA) ≤0.01CVor 3 (μA) whichever is greater, measurement circuit refer to right drawing. C: Capacitance (μF) V: Rated DC working voltage (V) Nominal capacitance, for measuring frequency, voltage and temperature. Must be within the parameters (See page 3) Sheet NO.:20220411 Page : 6 / 12 ALUMINUM ELECTROLYTIC CAPACITORS ITEM 4 5 6 7 Impedance Load life test Shelf life test Maximum permissible (ripple current, temperature coefficient) PERFORMANCE Measuring frequency:100kHz; Measuring temperature:20±2℃ Measuring point: 2mm max. from the surface of a sealing rubber on the lead wire. (20℃) Must be within the parameters (See page 3) According to IEC60384-4No. 4.13 methods, the capacitor is stored at a temperature of Maximum operating temperature ±2°C with DC bias voltage plus the rated ripple current for Rated life +48/0hours. (The sum of DC and ripple peak voltage shall not exceed the rated working voltage) Then the product should be tested after 16 hours recovering time at atmospheric conditions. The result should meet the following table: The characteristic shall meet the following requirements. Leakage current Not more than the specified value. Capacitance Change Within ±20% of initial value. Dissipation Factor Not more than 200%of the specified value. Appearance There shall be no leakage of electrolyte. The capacitors are then stored with no voltage applied at a temperature of Maximum operating temperature±2℃ for1000+48/0 hours. Following this period, the capacitors shall be removed from the test chamber and be allowed to stabilized at room temperature for16 hours. measure leakage current The characteristic shall meet the following requirements. Leakage current Not more than 200%of the specified value. Capacitance Change Within ±20% of initial value. Dissipation Factor Not more than 200%of the specified value. Appearance There shall be no leakage of electrolyte. The maximum permissible ripple current is the maximum A.C current at 100kHz and can be applied at maximum operating temperature Table-3 The combined value of D.C voltage and the peak A.C voltage shall not exceed the rated voltage and shall not reverse voltage. Frequency Multipliers: Freq (Hz) 120 1k 10k 50~100k Cap. (μF) 330 0.55 0.77 0.94 1.00 Temperature Coefficient: Sheet NO.:20220411 Temperature (°C) 60 85 95 105 Factor 2.23 1.73 1.41 1.00 Page : 7 / 12 ALUMINUM ELECTROLYTIC CAPACITORS ITEM 8 Terminal strength PERFORMANCE Tensile strength of terminals Fixed the capacitor, applied force to the terminal in lead out direction for30+5-0 seconds. Bending strength of terminals. Fixed the capacitor, applied force to bent the terminal (1~4 mm from the rubber) for 90o within 2~3 seconds, and then bent it for 90o to its original position within 2~3 seconds. Tensile force N Diameter of lead wire Bending force N (kgf) (kgf) 0.5mm and less 5 (0.51) 2.5 (0.25) 10(1.02) 0.6~0.8 mm 5(0.51) No noticeable changes shall be found, no breakage or looseness at the terminal. STEP 1 9 Temperature characteristics Testing temperature (℃) 20±2 Time Time to reach thermal equilibrium 2 -40 -25±3 Time to reach thermal equilibrium 3 20±2 Time to reach thermal equilibrium 4 105±2 Time to reach thermal equilibrium 5 20±2 Time to reach thermal equilibrium Capacitance, DF, and impedance shall be measured at 120Hz. a. At +105℃, capacitance measured at +20℃ shall be within ±25% of its original value. Dissipation factor shall be within the limit of Item 7.3 The leakage current measured shall not more than 10 times of its specified value. b. In step 5, capacitance measured at +20℃ shall be within ±10% of its original value. Dissipation factor shall be within the limit of Item 7. 3 The leakage current shall not more than the specified value. c. At- 40℃ Impedance (Z) ratio shall not exceed the value of the following table. Voltage (V) 6.3 10 16 25 35 50 63 100 160 200~400 450 Z-40℃/Z+20℃ 8 6 4 4 4 4 4 4 4 7 8 Applied a surge voltage to the capacitor connected with a (100 ±50)/CR (kΩ) resistor in series for 30±5 seconds in every 5±0.5 minutes at 15~35℃.Procedure shall be repeated 1000 times. Then the capacitors shall be left under normal humidity for 1-2 hours before measurement CR :Nominal Capacitance (μF) 10 Surge test Leakage current Not more than the specified value. Capacitance Change Within ±15% of initial value. Dissipation Factor Not more than the specified value. Appearance There shall be no leakage of electrolyte. Attention: This test simulates over voltage at abnormal situation only. It is not applicable to such over voltage as often applied. Sheet NO.:20220411 Page : 8 / 12 ALUMINUM ELECTROLYTIC CAPACITORS ITEM PERFORMANCE Temperature cycle: According to IEC60384-4 No.4.7 methods, capacitor shall be placed in an oven, the condition according as below: Temperature 11 Change of temperature test Time (1) +20℃ 3 Minutes (2) Rated low temperature (- 40℃)(-25℃) 30±2 Minutes (3) Rated high temperature (+105℃) 30±2 Minutes (1) to (3) =1 cycle, total 5 cycle The characteristic shall meet the following requirement. Leakage current Not more than the specified value. 12 13 Damp heat test Solderability test Dissipation Factor Not more than the specified value. Appearance There shall be no leakage of electrolyte. Humidity test: According to IEC60384-4 No.4.12 methods, capacitor shall be exposed for 500±8 hours in an atmosphere of 90~95%R H .at 40±2℃, the characteristic change shall meet the following requirement. Leakage current Not more than the specified value. Capacitance Change Within ±10% of initial value. Dissipation Factor Not more than 120% of the specified value. Appearance There shall be no leakage of electrolyte. The capacitor shall be tested under the following conditions: Soldering temperature :245 5C Dipping depth : 2mm Dipping speed : 252.5mm/s Dipping time :30.5s Soldering wetting time Less than 3s Coating quality Sheet NO.:20220411 A minimum of 95% of the surface being immersed Page : 9 / 12 ALUMINUM ELECTROLYTIC CAPACITORS ITEM PERFORMANCE The following conditions shall be applied for 2 hours in each 3 mutually perpendicular directions. Vibration frequency range :10Hz ~ 55Hz each to peak amplitude :1.5mm Sweep rate :10Hz ~ 55Hz ~ 10Hz in about 1 minute Mounting method:The capacitor with diameter greater than 12.5mm or longer than 25mm must be fixed in place with a bracket. Within 30 4mm or less 14 Vibration test To be soldered After the test, the following items shall be tested: No intermittent contacts, open or short circuiting. Inner construction No damage of tab terminals or electrodes. No mechanical damage in terminal. No leakage of electrolyte or swelling of the case. The Appearance markings shall be legible. 15 Resistance to solder heat test Terminals of the capacitor shall be immersed into solder bath at 260±5℃for10±1seconds 1 or400±10℃for3  0 seconds to 1.5~2.0 mm from the body of capacitor. Then the capacitor shall be left under the normal temperature and normal humidity for 1~2 hours before measurement. Leakage current Not more than the specified value. Capacitance Change Within ±5% of initial value. Dissipation Factor Not more than the specified value. Appearance There shall be no leakage of electrolyte. 16 Vent test The following test only apply to those products with vent products at diameter 6.3 with vent. D.C. test The capacitor is connected with its polarity reversed to a DC power source. Then a current selected from Table 2 is applied. Diameter (mm) DC Current (A) 22.4 or less 1 The vent shall operate with no dangerous conditions such as flames or dispersion of pieces of the capacitor and/or case. Sheet NO.:20220411 Page : 10 / 12 ALUMINUM ELECTROLYTIC CAPACITORS 8、 Packing Information Packing Label Marked (the following items shall be marked on the label) (Inside box or bag) ⑴Clint order number ⑵Client part number ⑶Beryl part number ⑷Capacitance ⑸Voltage ⑹Dimension ⑺Packaging quantity ⑻Capacitance tolerance ⑼ QC Marking ⑽ Lot number ⑾ Series LOT Number : 1)Bulk Packing: 3)Outer box Sheet NO.:20220411 2)Taped Packing: 4) Outer box label: Page : 11 / 12 ALUMINUM ELECTROLYTIC CAPACITORS 9、Prohibition to Use Environment- related Substances We are hereby to certify the followings: Our company hereby warrants and guarantees that all or part of products, including, but not limited to, the peripherals, accessories or package, delivered to your company (including your subsidiaries and affiliated companies) directly or indirectly by our company are free from any of the substances listed below. The latest version of
