SCW2012-901Y
SCW2012-901Y
    LINEKEY(立凯电控)
    SMD-4P,2x1.2mm
    两路 0805共模滤波器 阻抗900Ω@100MHZ
SCW2012-901Y 数据手册
www.Linekey.cn SMD Wire Wound Common Mode Choke---SCW Series Feature     Winding type realizes small size and low profile. Prevention of common mode noise at high frequency. RoHS compliant and halogen free. Operating temperature range -40℃~125℃. Application    EMI suppression for data and signal lines. Communications, Computers, Noise suppression, etc. Consumer electronics. Production identification SCW ① 2012 ② - 181 ③ Y ④ ① Series name: SMD Common Mode Choke ② Size:2.0×1.2×1.2mm ③ Impedance:180Ω ④ Tolerance:±25% Series Shape and Dimensions (Unit:mm) Series A B C DTyp ETyp FTyp GTyp HTyp I Typ SPQ SCW1608 1.6±0.1 0.8±0.1 1.1±0.1 0.25 0.33 0.3 1.0 0.7 2.1 2000 SCW2012 2.0±0.2 1.2±0.2 1.2±0.2 0.46 0.55 0.45 1.25 1.1 2.6 2000 SCW3216 3.2±0.2 1.6±0.2 2.0±0.2 0.5 0.5 0.4 1.6 1.9 3.7 2000 SCW4532 4.5±0.2 3.2±0.2 2.8±0.2 1.2 1.0 0.9 3.6 3.0 5.2 2000 SCW4532A 4.5±0.2 3.2±0.2 2.8±0.2 1.2 1.0 0.9 3.6 3.0 5.2 500 www.Linekey.cn SMD Wire Wound Common Mode Choke---SCW Series SCW1608 Electrical Characteristics Impedance Rated Withstanding Insulation DCR Voltage Voltage Resistance Max Max (Ω) Toleranc e (±%) (Vdc) (Vdc) (MΩ) Min (Ω) (mA) SCW1608-670Y 67 25 50 125 10 0.30 300 SCW1608-900Y 90 25 50 125 10 0.30 300 SCW1608-121Y 120 25 50 125 10 0.36 250 SCW1608-161Y 160 25 50 125 10 0.40 200 SCW1608-221Y 220 25 50 125 10 0.42 200 Part Number @100MHz IDC Typical Impedance vs. Frequency Curves SCW1608-670Y 100 10 1 0.1 1 10 100 100 10 1 0.1 1000 Frequency(MHz) 1000 10 100 1 1 10 100 1000 1000 10 1 10 100 Frequency(MHz) 1 1 10 100 Frequency(MHz) 100 1 10 0.1 SCW1608-221Y 1000 Impedance(OHM) Impedance(Ω) 100 SCW1608-161Y Frequency(MHz) Impedance(Ω) 10 Frequency(MHz) 100 0.1 1 SCW1608-121Y 1000 0.1 SCW1608-900Y 1000 Impedance(Ω) Impedance(OHM) 1000 1000 1000 www.Linekey.cn SMD Wire Wound Common Mode Choke---SCW Series SCW2012 Electrical Characteristics Impedance Rated Withstanding Insulation DCR IDC Voltage Voltage Resistance Max Max (Ω) Toleranc e (±%) (Vdc) (Vdc) (MΩ) Min (Ω) (mA) SCW2012-300Y 30 25 50 250 10 0.20 400 SCW2012-670Y 67 25 50 250 10 0.25 400 SCW2012-900Y 90 25 50 250 10 0.30 400 SCW2012-121Y 120 25 50 250 10 0.30 400 SCW2012-161Y 160 25 50 250 10 0.35 350 SCW2012-181Y 180 25 50 250 10 0.35 350 SCW2012-201Y 200 25 50 250 10 0.40 300 SCW2012-221Y 220 25 50 250 10 0.40 300 SCW2012-261Y 260 25 50 250 10 0.40 300 SCW2012-301Y 300 25 50 250 10 0.50 300 SCW2012-361Y 360 25 50 250 10 0.50 300 SCW2012-371Y 370 25 50 250 10 0.50 300 SCW2012-501Y 500 25 50 250 10 0.50 300 SCW2012-671Y 670 25 50 250 10 0.60 140 SCW2012-901Y 900 25 50 250 10 0.88 100 SCW2012-102Y 1000 25 50 250 10 0.85 100 Part Number @100MHz Typical Impedance vs. Frequency Curves SCW2012-300Y SCW2012-900Y SCW2012-670Y SCW2012-121Y www.Linekey.cn SMD Wire Wound Common Mode Choke---SCW Series Typical Impedance vs. Frequency Curves SCW2012-161Y SCW2012-181Y SCW2012-201Y SCW2012-221Y SCW2012-261Y SCW2012-301Y SCW2012-361Y SCW2012-371Y www.Linekey.cn SMD Wire Wound Common Mode Choke---SCW Series Typical Impedance vs. Frequency Curves SCW2012-501Y SCW2012-901Y SCW2012-671Y SCW2012-102Y www.Linekey.cn SMD Wire Wound Common Mode Choke---SCW Series SCW3216 Electrical Characteristics Impedance Rated Withstanding Insulation DCR Voltage Voltage Resistance Max Max (Ω) Toleranc e (±%) (Vdc) (Vdc) (MΩ) Min (Ω) (mA) SCW3216-900Y 90 25 50 125 10 0.30 400 SCW3216-161Y 160 25 50 125 10 0.35 350 SCW3216-221Y 220 25 50 125 10 0.45 300 SCW3216-261Y 260 25 50 125 10 0.45 300 SCW3216-601Y 600 25 50 125 10 0.80 300 SCW3216-102Y 1000 25 50 125 10 1.00 230 Part Number @100MHz Typical Impedance vs. Frequency Curves SCW3216-900Y SCW3216-161Y SCW3216-221Y SCW3216-261Y SCW3216-601Y SCW3216-102Y IDC www.Linekey.cn SMD Wire Wound Common Mode Choke---SCW Series SCW4532 Electrical Characteristics Impedance Rated Min Insulation DCR Max IDC Max @100MHz(Ω) Tolerance (±%) Voltage (Vdc) Resistance (MΩ) (Ω) (mA) SCW4532-331Y 330 25 50 10 0.11 1100 SCW4532-601Y 600 25 50 10 0.12 1000 SCW4532-801Y 800 25 50 10 0.16 900 SCW4532-102Y 1000 25 50 10 0.18 800 SCW4532-142Y 1400 25 50 10 0.20 700 Part Number SCW4532A Electrical Characteristics Inductance(uH) Rated Voltage Common Mode Toleranc e (±%) SCW4532A-110Y 11 +50/-30 SCW4532A-220Y 22 SCW4532A-510Y SCW4532A-101Y Part Number @100KHz Impedance@10MHz DCR Max Max (Ω) (mA) 700 0.80 300 500 1000 2.65 200 50 1000 2000 3.50 200 50 2000 5000 8.90 200 Min.(Ω) Typ.(Ω) 50 300 +50/-30 50 51 +50/-30 100 +50/-30 (Vdc) Typical Impedance vs. Frequency Curves SCW4532A-110Y SCW4532A-510Y IDC SCW4532A-220Y SCW4532A-101Y
