AMCW4532B-2-110T
AMCW4532B-2-110T
    SUNLORD(顺络)
    SMD-4P,4.5x3.2mm
    AMCW4532B-2-110T
AMCW4532B-2-110T 数据手册
Wire Wound Chip Common Mode Choke AMCW-B Series Operating Temp. : -40℃~+150℃ FEATURES     Winding type realizes small size and low profile Suppression of common mode noise at high frequency Excellent solderability AEC-Q200 verified APPLICATIONS  Common mode noise filtering for automotive CAN-BUS and signal line. PRODUCT IDENTIFICATION AMCW ① 3225 B -2 ② ③ ④ ① -110 T ⑤ ⑥ ③ ② AMCW Type Winding Type Common Mode Choke Code External Dimensions (L× W) (mm) 3225 [1210] 3.2× 2.5 4532 [1812] 4.5× 3.2 B for CAN-BUS ⑤ Example 110 220 510 101 ④ Number of Lines 2 Inductance(uH) Nominal Value 11 22 51 100 ⑥ Packing T Tape & Reel SHAPE AND DIMENSIONS AMCW3225B TYPE Recommended Land Pattern Unit:mm Sunlord Part Number A AMCW3225B-2-110T/220T 0.80mm AMCW3225B-2-510T/101T 0.70mm Specifications subject to change without notice. Please check our website for latest information. Revised 2021/09/30 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SHAPE AND DIMENSIONS AMCW4532B TYPE Recommended Land Pattern Unit: mm SPECIFICATIONS AMCW3225B TYPE Inductance Part Number Units Symbol AMCW3225B-2-110T AMCW3225B-2-220T AMCW3225B-2-510T AMCW3225B-2-101T +50%/-30% uH L 11(@100KHz/0.1V) 22(@100KHz/0.1V) 51(@100KHz/0.1V) 100(@100KHz/0.1V) DC Resistance Max. DCR 0.3 0.5 1.5 1.8 Rated Current Rated Voltage Max. mA Ir 400 300 200 150 Max. Volts VDC 80 80 80 80 Insulation Resistance Min. IR 10 10 10 10 AMCW4532B TYPE Inductance Part Number Units Symbol AMCW4532B-2-110T AMCW4532B-2-220T AMCW4532B-2-510T AMCW4532B-2-101T +50%/-30% uH L 11(@ 100KHz/0.1V) 22(@ 100KHz/0.1V) 51(@ 1.0MHz/0.1V) 100(@ 1.0MHz/0.1V) DC Resistance Max. DCR 0.5 0.8 1.0 2.0 Rated Current Rated Voltage Max. mA Ir 360 310 230 200 Max. Volts VDC 50 50 50 50 Insulation Resistance Min. IR 10 10 10 10 ※: Products wit EQUIVALENT CIRCUIT Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/09/30 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com TYPICAL ELECTRICAL CHARACTERISTICS AMCW3225B TYPE Impedance vs. Frequency AMCW4532B TYPE Impedance vs. Frequency Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/09/30 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
AMCW4532B-2-110T 价格&库存
很抱歉,暂时无法提供与“AMCW4532B-2-110T”相匹配的价格&库存,您可以联系我们找货
AMCW4532B-2-110T
  • 1+3.27920
  • 10+2.45940
  • 30+1.96760
  • 100+1.78870
  • 500+1.63970
  • 1000+1.51360
库存:2370
