SMBJ5344B
SMBJ5344B
    LGE(鲁光)
    SMB(DO-214AA)
    独立式 耐压:8.2V 电流:10UA@5.9V
SMBJ5344B 数据手册
SMBJ5333A-SMBJ5388A Surface Mount Silicon Zener Diodes VZ : 3.3 - 200 Volts PD : 5 Watts Features SMB/DO-214AA  Complete Voltage Range 3.3 to 200 Volts  High peak reverse power dissipation  High reliability  Low leakage current  Pb / RoHS Free 0.180(4.57) 0.160(4.06) 0.086(2.20) 0.077(1.95) 0.209(5.30) 0.201(5.10) Mechanical Data      0.155(3.94) 0.130(3.30) 0.012(0.30) 0.006(0.15) Case : SMB (DO-214AA) Molded plastic Epoxy : UL94V-O rate flame retardant Lead : Lead formed for Surface mount Polarity : Color band denotes cathode end Mounting position : Any 0.096(2.44) 0.084(2.13) 0.059(1.50) 0.035(0.90) 0.008(0.20) 0.002(0.05) Dimensions in inches and(millimeters) MAXIMUM RATINGS Rating at 25 °C ambient temperature unless otherwise specified Rating Symbol Value Unit Power Dissipation at T L = 25 °C PD 5 W Maximum Forward Voltage at I F = 1.0 A VF 1.2 V Thermal Resistance, Junction to Ambient (Note 1) RӨJA 90 °C/W Thermal Resistance, Junction to Lead (Note 1) RӨJL 25 °C/W TJ, TSTG - 65 to + 150 °C Operating and Storage Temperature Range Note : (1) When mounted on FR4 PC board (1 oz Cu) with recommended footprint. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SMBJ5333A-SMBJ5388A Surface Mount Silicon Zener Diodes ELECTRICAL CHARACTERISTICS Rating at 25 °C ambient temperature unless otherwise specified Nominal Zener Maximum Zener Voltage Impedance TYPE VZ @ IZT IZT ZZT @ IZT ZZK @ IZK (V) (mA) (Ω) (Ω) SMBJ5333A SMBJ5334A SMBJ5335A SMBJ5336A SMBJ5337A SMBJ5338A SMBJ5339A SMBJ5340A SMBJ5341A SMBJ5342A SMBJ5343A SMBJ5344A SMBJ5345A SMBJ5346A SMBJ5347A SMBJ5348A SMBJ5349A SMBJ5350A SMBJ5351A SMBJ5352A SMBJ5353A SMBJ5354A SMBJ5355A SMBJ5356A SMBJ5357A SMBJ5358A SMBJ5359A SMBJ5360A SMBJ5361A SMBJ5362A SMBJ5363A SMBJ5364A SMBJ5365A SMBJ5366A SMBJ5367A SMBJ5368A SMBJ5369A SMBJ5370A SMBJ5371A SMBJ5372A SMBJ5373A SMBJ5374A SMBJ5375A SMBJ5376A SMBJ5377A SMBJ5378A SMBJ5379A SMBJ5380A SMBJ5381A SMBJ5382A SMBJ5383A SMBJ5384A SMBJ5385A SMBJ5386A SMBJ5387A SMBJ5388A 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.0 6.2 6.8 7.5 8.2 8.7 9.1 10 11 12 13 14 15 16 17 18 19 20 22 24 25 27 28 30 33 36 39 43 47 51 56 60 62 68 75 82 87 91 100 110 120 130 140 150 160 170 180 190 200 380 350 320 290 260 240 220 200 200 175 175 150 150 150 125 125 100 100 100 75 75 70 65 65 65 50 50 50 50 50 40 40 30 30 30 25 25 20 20 20 20 20 15 15 15 12 12 10 10 8.0 8.0 8.0 8.0 5.0 5.0 5.0 3.0 2.5 2.0 2.0 2.0 1.5 1.0 1.0 1.0 1.0 1.0 1.0 1.0 2.0 2.0 2.0 2.5 2.5 2.5 2.5 2.5 2.5 2.5 3.0 3.0 3.5 3.5 4.0 5.0 6.0 8.0 10 11 14 20 25 27 35 40 42 44 45 65 75 75 90 125 170 190 230 330 350 380 430 450 480 400 500 500 500 450 400 400 300 200 200 200 200 200 150 125 125 125 100 75 75 75 75 75 75 75 75 100 110 120 130 140 150 160 170 190 210 230 280 350 400 500 620 720 760 760 800 1000 1150 1250 1500 1500 1650 1750 1750 1850 1850 IZK (mA) 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 Maximum Reverse Leakage Current IR @ VR (V) (μA) 300 150 50 10 5.0 1.0 1.0 1.0 1.0 10 10 10 10 7.5 5.0 5.0 2.0 1.0 1.0 1.0 1.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 1.0 1.0 2.0 3.0 4.0 4.9 5.4 5.9 6.3 6.6 7.2 8.0 8.6 9.4 10.1 10.8 11.5 12.2 13.0 13.7 14.4 15.8 17.3 18.0 19.4 20.1 21.6 23.8 25.9 28.1 31.0 33.8 36.7 40.3 43.0 44.6 49.0 54.0 59.0 63.0 65.5 72.0 79.2 86.4 93.2 101 108 115 122 130 137 144 Maximum DC Zener Current IZM (mA) 1440 1320 1220 1100 1010 930 856 790 765 700 630 580 545 520 475 430 395 365 340 315 295 280 265 250 237 216 198 190 176 170 158 144 132 122 110 100 93.0 86.0 79.0 76.0 70.0 63.0 58.0 54.5 52.5 47.5 43.0 39.5 36.6 34.0 31.6 29.4 28.0 26.4 25.0 23.6 Note : ( 1 ) Suffix " A " indicates ± 10% tolerance, suffix " B " indicates± 5% tolerance. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SMBJ5333A-SMBJ5388A Surface Mount Silicon Zener Diodes RATING AND CHARACTERISTIC CURVES ( SMBJ5333B - SMBJ5388B ) Fig. 1 POWER DERATING CURVE PD, MAXIMUM DISSIPATION (WATTS) 5.0 4.0 3.0 2.0 1.0 0 0 25 50 75 100 125 150 TL, LEAD TEMPERATURE (°C) Ir, PEAK SURGE CURRENT (AMPS) Fig.2 Maximum Non-Repetitive Surg Current versus Nominal Zener Voltage 40 PW=1 ms* 20 10 PW=8.3 ms* 4 2 1 PW=100 ms* 0.4 PW=1000 ms* 0.2 *SQURE WAVE 0.1 3 4 6 8 10 20 30 40 80 100 200 NORMINAL Vz (V) PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMB 3000/REEL 48000 36X35.8X36.5 12.00 11.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
SMBJ5344B 价格&库存
很抱歉,暂时无法提供与“SMBJ5344B”相匹配的价格&库存,您可以联系我们找货
SMBJ5344B
  • 5+1.53353
  • 50+1.21510
  • 150+1.07863
  • 500+0.90834
  • 3000+0.79452
  • 6000+0.74903
库存:2408
