DCS 型半导体圆片瓷介电容器
TYPE DCS SEMI-CONDUCTIVE DISC CERAMIC CAPACITORS
特性 Feature
■容量范围 Wide capacitance range from 100pF to 1000000pF
■工作温度 Operating Temperature: -40℃~125℃
■存储温度 Storage Temperature: -10℃~40℃
应用 Applications
DCS 型半导体圆片瓷介电容器的陶瓷芯片属于表面层半导体结构,其电容器具有大容量、小
体积等特点,适用于滤波、旁路、耦合等电路中。
This disc ceramic capacitors belong to surface layer semi-conductive construction,have characteristics
such as higher capacitance,small size etc.,They are best suited for use in filter circuit,bypass circuit
and coupling circuit etc..
产品型号Part Number
DCS
104 M
26
Y5V
F
6
B
L
5
型号 Type:
DCS:半导体圆片瓷介电容器
电容量(Capacitance):
470:47pF
内部管理代码
Interior
managing
471:470pF
472:2200pF
103:10000pF
电 容 量 允 许 偏 差
Capacitance Tolerance:
M=20%
Z=+80%-20%
K=±10%
J=±5%
尺寸代码 Size:
见规格详情
See the specification
温度特性
temperature characteristic:
Y5P,Y5U,Y5V
额定电压 Rated voltage:
F=50VDC
H=100VDC
位引线间距 Lead spacing:
5=5.0mm
7=7.5mm 0=10mm
引线式样 Lead style:
L、J、
见引线形状 see the lead style
Figure1-2 and figure 1-3
位引线长度/包装方法/
Lead length/package:
B=20min.mm, 6=6.0±0.5mm
0=10.0±0.5mm,8=8.0±0.5mm,
W=3.4±0.3mm, A=7.0±0.5mm, 3=3.0±0.3mm
F=12.7mm 编带/扇折,V=15.0mm 编带/扇折
引线直径 Lead diameter:
CP 线:
6=0.55±0.05mm =0.48±0.05mm
脚型 Lead style
规格Specification
产品尺寸(mm)
额定电
压
Rated
voltage
(KV)
标称容量
Nominal
capacitance
(pF)
电容量允
许偏差范
围
Tolerance
温度特性
Temperature
Characteristic
DCS103K20Y5PF6FJ5A0
50VDC
10000
±10%
Y5P
5.0
4.0
5.0
0.55±0.05
DCS103M20Y5UF5AL5A0
50VDC
10000
±20%
Y5U
5.0
4.0
5.0
0.48±0.05
DCS103M20Y5VF6FL5A0
50VDC
10000
±20%
Y5V
5.0
4.0
5.0
0.55±0.05
DCS104M26Y5UF50L5A0
50VDC
100000
±20%
Y5U
6.5
4.0
5.0
0.48±0.05
DCS104M26Y5UF5BL5A0
50VDC
100000
±20%
Y5U
6.5
4.0
5.0
0.48±0.05
DCS104M26Y5UF5WL5A0
50VDC
100000
±20%
Y5U
6.5
4.0
5.0
0.48±0.05
DCS104M26Y5UF6AJ5A0
50VDC
100000
±20%
Y5U
6.5
4.0
5.0
0.55±0.05
DCS104M26Y5UF6FJ5A0
50VDC
100000
±20%
Y5U
6.5
4.0
5.0
0.55±0.05
DCS104M26Y5UH6FJ5A0
100VDC
100000
±20%
Y5U
6.5
4.0
5.0
0.55±0.05
DCS104M26Y5VF6FJ5A0
50VDC
100000
±20%
Y5V
6.5
4.0
5.0
0.55±0.05
DCS104M26Y5VFEFL5A0
50VDC
100000
±20%
Y5V
6.5
4.0
5.0
0.58±0.05
镀锡铜线
DCS104Z26Y5VF56L5A0
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.48±0.05
DCS104Z26Y5VF58L5A0
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.48±0.05
DCS104Z26Y5VF5BL5A0
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.48±0.05
SHM 产品代码
SHM Part No.
直径 厚度 引线
引线直径
Dmax. Tmax 间距
d (mm)
(mm) (mm) F(mm)
散
件/
编
带
编
带
散
件
编
带
散
件
散
件
散
件
散
件
散
件
编
带
编
带
编
带
散
件
散
件
散
件
DCS104Z26Y5VF6BL5A0
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.55±0.05
DCS104Z26Y5VF6FJ5A0
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.55±0.05
DCS104Z26Y5VF6FJ5BQ
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.55±0.05
DCS104Z26Y5VF6FJ5ER
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.55±0.05
DCS104Z26Y5VF6FL5BQ
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.55±0.05
DCS104Z26Y5VFEFJ5A0
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
DCS104Z26Y5VFEFL5A0
50VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.58±0.05
镀锡铜线
0.58±0.05
镀锡铜线
DCS104Z26Y5VH63L5A0
100VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.55±0.05
DCS104Z26Y5VH6FJ5A0
100VDC
100000
+80% to
-20%
Y5V
6.5
4.0
5.0
0.55±0.05
散
件
编
带
编
带
编
带
编
带
编
带
编
带
散
件
编
带
电性能指标 Electrical Performance
序号
No.
项目名称 Item
1
容量和误差 C
@25℃,1 kHz and 0.1 Vrms
参照规格表
2
损耗系数 DF
5% max.( Ⅲ类瓷 Y5V & Y5U)
3.5% max.( Ⅲ类瓷 Y5P)
3
绝缘电阻 IR
@额定电压 VDC,60S
1000MΩmin
150%额定电压
无击穿或飞弧。
No visible damage
50V
耐电压
Rate
Voltage
4
技术要求 Specification
100V
温度特性
temperature
characteristic
5
Y5P
±10%
Y5U
+22% to -56%
Y5V
+22% to -82%
标志 Marking
例如 e. g
22#号产品以下
≤ 22#
正面
Front
B
221
反面
Back
空白
Blank
26#号产品以下
=26#
F
104 M
空白
Blank
30#产品以上
≥30#
B
472 K
SHM
空白
Blank
编带样式 Taping style
备注 1 DCS104Z26Y5VF6FL5BQ 的标志:
正面
Front
104
DCS104M26Y5UF5BL5A0 价格&库存
很抱歉,暂时无法提供与“DCS104M26Y5UF5BL5A0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17313
- 200+0.13652
- 1000+0.11621
- 2000+0.10401
- 10000+0.09342
- 20000+0.08770
