20D561KJ
20D561KJ
    SURGING(绍鑫)
    VAR-D23X6.7MM_TM
    钳位电压925V 380焦耳 插件压敏电阻
20D561KJ 数据手册
Voltage Dependent Resistor 压敏电阻 20D Series http://www.szshaoxin.com/ 绍 鑫 实 业 Metal Oxide Varistors - 20D Series Features 1. Wide operating voltage (V1mA) range from 8V to 1800V. 2. Fast responding to transient over-voltage. 3. Large absorbing transient energy capability. 4. Low clamping ratio and no following-on current. General Information The MOV-20DxxxK Series of 20mm radial leaded varistor devices protects against overvoltage transients such as lightning, power contact and power induction. The metal oxide varistors offer a choice of varistor voltages from 18 V to 1800 V and Vrms voltages from 11 V to 1000 V. The devices have a high current handling, high energy absorption capability and fast response times to protect against transient faults up to rated limits. General Characteristics No Radioactive Material Storage Temperature: -55ºC to +125ºC Operating Temperature: -55ºC to +85ºC Body: Nickel Plated Leads: Surface-mount, Axial Devices: Tin Plated Devices with No Leads: Nickel Plated Product Name 2 0 D 4 7 1 K Disc Diameter Type Nominal Varistor Voltage Varistor Voltage Tolerance 20=20MM D: Disk 471=47*101V K = 10 % S: Square http://www.szshaoxin.com/ 绍 鑫 实 业 Metal Oxide Varistors - 20D Series Electriacl Characteristics Type Number Maximum Allowable Voltage Varistor Voltage Maximum Clamping Voltage VAC(V) VDC(V) V1mA(V) IP(A) VC(V) Standard High Surge 20D180K 20D180KJ 11 20D220K 20D220KJ 20D270K 20D270KJ 20 36 Withstanding Surge Current (J) Typical Capacitance (Reference) Standard High Surge Standard High Surge (J) (W) @1KHz(pf) 2000 3000 11 13 0.2 28500 I(A) I(A) Maximum Energy Rated (10/1000μs) Power 14 18(15~21.6) 14 18 22(19.5~26) 20 43 2000 3000 14 16 0.2 18500 17 22 27(24~30) 20 53 2000 3000 16 19 0.2 13000 20K330K 20K330KJ 20 26 33(29.5~36.5) 20 65 2000 3000 23 24 0.2 11500 20D390K 20D390KJ 25 31 39(35~43) 20 77 2000 3000 26 28 0.2 8500 20D470K 20D470KJ 30 38 47(42~54) 20 93 2000 3000 30 34 0.2 7400 20D560K 20D560KJ 35 45 56(50~62) 20 100 2000 3000 41 41 0.2 6500 20D680K 20D680KJ 40 56 68(61~75) 20 135 2000 3000 46 49 0.2 5800 20D820K 20D820KJ 50 65 82(74~90) 100 135 6500 10000 38 56 1.0 4900 20D101K 20D101KJ 60 85 100(90~110) 100 165 6500 10000 45 70 1.0 4000 20D121K 20D121KJ 75 100 120(108~132) 100 200 6500 10000 55 85 1.0 3300 20D151K 20D151KJ 95 125 150(135~165) 100 250 6500 10000 70 106 1.0 2700 20D181K 20D181KJ 115 150 180(162~198) 100 300 6500 10000 85 130 1.0 2200 20D201K 20D201KJ 130 170 200(180~220) 100 340 6500 10000 95 140 1.0 2000 20D221K 20D221KJ 140 180 220(198~242) 100 360 6500 10000 100 155 1.0 1800 20D241K 20D241KJ 150 200 240(216~264) 100 395 6500 10000 108 168 1.0 1650 20D271K 20D271KJ 175 225 270(243~297) 100 455 6500 10000 127 190 1.0 1500 20D301K 20D301KJ 190 250 300(270~330) 100 500 6500 10000 136 210 1.0 1300 20D331K 20D331KJ 210 275 330(297~363) 100 550 6500 10000 150 228 1.0 1200 20D361K 20D361KJ 230 300 360(324~396) 100 595 6500 10000 163 255 1.0 1100 20D391K 20D391KJ 250 320 390(351~429) 100 650 6500 10000 180 275 1.0 1000 20D431K 20D431KJ 275 350 430(387~473) 100 710 6500 10000 190 305 1.0 930 20D471K 20D471KJ 300 385 470(423~517) 100 775 6500 10000 220 350 1.0 850 20D511K 20D511KJ 320 415 510(459~561) 100 845 6500 10000 220 360 1.0 780 20D561K 20D561KJ 350 460 560(504~616) 100 925 6500 10000 220 380 1.0 710 20D621K 20D621KJ 385 505 620(558~682) 100 1025 6500 10000 220 390 1.0 650 20D681K 20D681KJ 420 560 680(612~748) 100 1120 6500 10000 230 400 1.0 600 20D751K 20D751KJ 460 615 750(675~825) 100 1240 6500 10000 255 420 1.0 580 20D781K 20D781KJ 485 640 780(702~858) 100 1290 6500 10000 265 440 1.0 560 20D821K 20D821KJ 510 670 820(738~902) 100 1355 6500 10000 282 460 1.0 525 20D911K 20D911KJ 550 745 910(819~1001) 100 1500 6500 10000 310 510 1.0 495 20D102K 20D102KJ 625 825 1000(900~1100) 100 1650 6500 10000 342 565 1.0 480 20D112K 20D112KJ 680 895 1100(990~1210) 100 1815 6500 10000 383 620 1.0 460 20D122K 20D122KJ 740 975 1200(1080~1320) 100 2010 6500 10000 412 660 1.0 440 20D142K 20D142K 850 1100 1400(1260~1540) 100 2255 6500 10000 470 725 1.0 415 20D152K 20D152K 900 1220 1500(135~1650) 100 2475 6500 10000 529 815 1.0 400 20D162K 20D162KJ 1000 1280 1600(1440~1760) 100 2640 6500 10000 606 896 1.0 330 20D182K 20D182KJ 1000 1465 1800(1620~1980) 100 2970 6500 10000 625 660 1.0 320 http://www.szshaoxin.com/ 绍 鑫 实 业 Metal Oxide Varistors - 20D Series Electrical Rating ltem Varistor Voltage Test Condition / Description Requirement The voltage between two terminals with the specified measuring current 1mA. DC applied is call Vb. Maximum Allowable The recommended maximum sine wave voltage (RMS) or the maximum DC Voltage voltage can be applied continuously. Rated Wattaget IEnergy The maximum average power that can be applied within the specified ambient temperature. To meet the specified value The maximum energy within the varistor voltage change of ±10% when one impulse of10/1000μsec. or 2 msec. is applied. Withstanding Surge The maximum current within the varistor voltage change of ±10% with the standard Current impulse current (8/20μsec.) applied one time. The change of Vb shall be measured after the impulse listed below is applied 10,000 times continuously with the interval of ten seconds at room temperature. 180K to 680K 10A (8/20μsec.) 820K to 751K 20A (8/20μsec.) 180K to 680K 25A (8/20μsec.) 820K to 821K 50A (8/20μsec.) 180K to 680K 50A (8/20μsec.) 820K to 182K 100A (8/20μsec.) 180K to 680K 75A (8/20μsec.) 820K to 182K 150A (8/20μsec.) 180K to 680K 100A (8/20μsec.) 820K to 182K 200A (8/20μsec.) 5D series 7Dseries Surge Life Vb Vb _
20D561KJ 价格&库存
很抱歉,暂时无法提供与“20D561KJ”相匹配的价格&库存,您可以联系我们找货
20D561KJ
    • 5+1.82250
    • 50+1.45239
    • 250+1.29374
    • 500+1.09577
    库存:493
