ELE-500ETD101MHB5D
ELE-500ETD101MHB5D
    NCC(贵弥功)
    AEC-D8X11.5MM_TM
ELE-500ETD101MHB5D 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Long life forφ5 toφ8 product, 105℃ LE Series ・Suitable for long life products ・Downsize and long life ・Endurance with ripple current:10,000 hours at 105℃ ・Case size range:φ5×11L to φ8×11.5L ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant ◆SPECIFICATION Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 10 to 100Vdc ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 100V tanδ (Max.) 0.45 0.35 0.30 0.22 0.19 0.17 0.15 Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 100V Z(-25℃)/Z(20℃) 8 6 4 4 3 3 3 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃,120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 10,000 hours at 105℃. Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦300% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] Code : E φd Sleeve (PET : Brown) F±0.5 ●Terminal φD φd φD' F φD' L' L' 15min. 5 0.5 2.0 8 6.3 0.6 0.5 3.5 2.5 φD+0.5max. L+1.5max. 4min. Gas escape end seal Vent (Except φ5) ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E L E- AAA E AA AAA M AAA D Supplement code Size code Capacitance tolerance code Capacitance code (ex. 4.7µF:4R7, 10µF:100,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 16V:160, 100V:101) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Long life forφ5 toφ8 product, 105℃ LESeries ◆STANDARD RATINGS WV (Vdc) 10 16 25 35 50 63 100 Cap (µF) Case size φD×L(mm) tanδ Rated ripple current (mArms/105℃, 100kHz) Part No. 100 220 330 47 100 220 33 47 100 33 47 100 1.0 2.2 3.3 4.7 10 22 33 47 100 10 22 33 47 1.0 2.2 3.3 4.7 10 22 5 ×11 6.3 × 11 8 × 11.5 5×11 6.3 ×11 8 ×11.5 5× 11 5 × 11 6.3×11 5× 11 6.3 ×11 8×11.5 5× 11 5× 11 5× 11 5× 11 5 ×11 5 ×11 6.3 ×11 6.3 ×11 8×11.5 5 × 11 6.3 ×11 6.3 ×11 8 ×11.5 5 × 11 5× 11 5× 11 5× 11 6.3 ×11 8 ×11.5 0.45 0.45 0.45 0.35 0.35 0.35 0.30 0.30 0.30 0.22 0.22 0.22 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.17 0.17 0.17 0.17 0.15 0.15 0.15 0.15 0.15 0.15 130 210 330 130 210 330 130 130 210 130 210 330 25 35 70 80 90 110 190 190 270 80 170 170 240 40 50 60 70 150 230 ELE-100E□□101ME11D ELE-100E□□221MF11D ELE-100E□□331MHB5D ELE-160E□□470ME11D ELE-160E□□101MF11D ELE-160E□□221MHB5D ELE-250E□□330ME11D ELE-250E□□470ME11D ELE-250E□□101MF11D ELE-350E□□330ME11D ELE-350E□□470MF11D ELE-350E□□101MHB5D ELE-500E□□1R0ME11D ELE-500E□□2R2ME11D ELE-500E□□3R3ME11D ELE-500E□□4R7ME11D ELE-500E□□100ME11D ELE-500E□□220ME11D ELE-500E□□330MF11D ELE-500E□□470MF11D ELE-500E□□101MHB5D ELE-630E□□100ME11D ELE-630E□□220MF11D ELE-630E□□330MF11D ELE-630E□□470MHB5D ELE-101E□□1R0ME11D ELE-101E□□2R2ME11D ELE-101E□□3R3ME11D ELE-101E□□4R7ME11D ELE-101E□□100MF11D ELE-101E□□220MHB5D □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 1.0 to 10 22 to 33 47 to 330 120 0.42 0.55 0.70 1k 0.60 0.75 0.85 10k 0.80 0.90 0.95 100k 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
ELE-500ETD101MHB5D 价格&库存
很抱歉,暂时无法提供与“ELE-500ETD101MHB5D”相匹配的价格&库存,您可以联系我们找货
