EKY-630ETD331MK20S
EKY-630ETD331MK20S
    NCC(贵弥功)
    AEC-D12.5X20MM_TM
    330UF ±20% 63V
EKY-630ETD331MK20S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS KY Low impedance, 105℃ KZH Series Lower Z KZE ・Newly innovative electrolyte is employed to minimize ESR ・Endurance with ripple current : 4,000 to 10,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant Lower Z KY ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 6.3 to 100Vdc (at 20℃, 120Hz) ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V tanδ (Max.) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.09 0.08 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V Z(-25℃)/Z(+20℃) 4 3 2 2 2 2 2 2 2 Z(-40℃)/Z(+20℃) 8 6 4 3 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃. 6.3 to 10Vdc φ5 & 6.3 : 4,000hours φ8 & 10 : 6,000hours φ12.5 to 18 : 8,000hours Time 16 to 100Vdc φ5 & 6.3 : 5,000hours φ8 & 10 : 7,000hours φ12.5 to 18 : 10,000hours Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] φd Sleeve (PET : Brown) F±0.5 Code : E F±0.5 ●Terminal φD φd φD' F φD' L' Vent (Exceptφ5 &φ6.3) 15min. 4min. (φ5 to φ10) (φ12.5 to φ18) L' 5 0.5 2.0 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max. L+1.5max. 16 0.8 7.5 18 0.8 7.5 Gas escape end seal ◆PART NUMBERING SYSTEM 1 2 3 4 E KY- 5 6 7 8 E 9 10 11 12 13 14 M 15 16 17 18 Supplement code Size code Capacitance tolerance code Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3,50V:500) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KYSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 150 330 680 820 1,000 1,200 1,200 1,500 1,800 2,200 2,700 2,700 3,300 3,900 6.3 3,900 4,700 5,600 5,600 6,800 6,800 6,800 8,200 10,000 10,000 12,000 12,000 15,000 18,000 100 220 470 680 680 1,000 1,000 1,200 1,500 1,500 2,200 2,200 2,200 2,700 10 3,300 3,900 3,900 4,700 5,600 5,600 5,600 6,800 6,800 8,200 8,200 10,000 10,000 12,000 56 120 330 470 470 16 680 680 1,000 1,000 1,200 1,500 5×11 6.3×11 8×11.5 10×12.5 8×15 8×20 10×16 10×20 12.5×15 10×25 10×30 16×15 12.5×20 12.5×25 18×15 12.5×30 12.5×35 16×20 12.5×40 16×25 18×20 16×31.5 16×35.5 18×25 16×40 18×31.5 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×15 10×30 12.5×20 16×15 18×15 12.5×25 12.5×30 16×20 12.5×35 12.5×40 16×25 18×20 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×15 10×25 10×30 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.58 0.22 0.13 0.080 0.087 0.069 0.060 0.046 0.049 0.042 0.031 0.042 0.035 0.027 0.043 0.024 0.020 0.027 0.017 0.021 0.026 0.017 0.015 0.019 0.013 0.015 0.014 0.012 0.58 0.22 0.13 0.087 0.080 0.069 0.060 0.046 0.042 0.049 0.031 0.035 0.042 0.043 0.027 0.024 0.027 0.020 0.017 0.021 0.026 0.017 0.019 0.015 0.015 0.013 0.014 0.012 0.58 0.22 0.13 0.087 0.080 0.069 0.060 0.046 0.049 0.042 0.031 2.3 0.87 0.52 0.32 0.35 0.27 0.24 0.18 0.16 0.17 0.12 0.12 0.12 0.089 0.11 0.078 0.065 0.078 0.056 0.060 0.067 0.050 0.044 0.049 0.038 0.040 0.038 0.032 2.3 0.87 0.52 0.35 0.32 0.27 0.24 0.18 0.17 0.16 0.12 0.12 0.12 0.11 0.089 0.078 0.078 0.065 0.056 0.060 0.067 0.050 0.049 0.044 0.040 0.038 0.038 0.032 2.3 0.87 0.52 0.35 0.32 0.27 0.24 0.18 0.16 0.17 0.12 210 340 640 865 840 1,050 1,210 1,400 1,450 1,650 1,910 1,940 1,900 2,230 2,210 2,650 2,880 2,530 3,350 2,930 2,860 3,450 3,610 3,140 4,080 4,170 4,220 4,280 210 340 640 840 865 1,050 1,210 1,400 1,650 1,450 1,910 1,900 1,940 2,210 2,230 2,650 2,530 2,880 3,350 2,930 2,860 3,450 3,140 3,610 4,170 4,080 4,220 4,280 210 340 640 840 865 1,050 1,210 1,400 1,450 1,650 1,910 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ EKY-6R3E□□151ME11D EKY-6R3E□□331MF11D EKY-6R3E□□681MHB5D EKY-6R3E□□821MJC5S EKY-6R3E□□102MH15D EKY-6R3E□□122MH20D EKY-6R3E□□122MJ16S EKY-6R3E□□152MJ20S EKY-6R3E□□182MK15S EKY-6R3E□□222MJ25S EKY-6R3E□□272MJ30S EKY-6R3E□□272ML15S EKY-6R3E□□332MK20S EKY-6R3E□□392MK25S EKY-6R3E□□392MM15S EKY-6R3E□□472MK30S EKY-6R3E□□562MK35S EKY-6R3E□□562ML20S EKY-6R3E□□682MK40S EKY-6R3E□□682ML25S EKY-6R3E□□682MM20S EKY-6R3E□□822MLN3S EKY-6R3E□□103MLP1S EKY-6R3E□□103MM25S EKY-6R3E□□123ML40S EKY-6R3E□□123MMN3S EKY-6R3E□□153MMP1S EKY-6R3E□□183MM40S EKY-100E□□101ME11D EKY-100E□□221MF11D EKY-100E□□471MHB5D EKY-100E□□681MH15D EKY-100E□□681MJC5S EKY-100E□□102MH20D EKY-100E□□102MJ16S EKY-100E□□122MJ20S EKY-100E□□152MJ25S EKY-100E□□152MK15S EKY-100E□□222MJ30S EKY-100E□□222MK20S EKY-100E□□222ML15S EKY-100E□□272MM15S EKY-100E□□332MK25S EKY-100E□□392MK30S EKY-100E□□392ML20S EKY-100E□□472MK35S EKY-100E□□562MK40S EKY-100E□□562ML25S EKY-100E□□562MM20S EKY-100E□□682MLN3S EKY-100E□□682MM25S EKY-100E□□822MLP1S EKY-100E□□822MMN3S EKY-100E□□103ML40S EKY-100E□□103MMP1S EKY-100E□□123MM40S EKY-160E□□560ME11D EKY-160E□□121MF11D EKY-160E□□331MHB5D EKY-160E□□471MH15D EKY-160E□□471MJC5S EKY-160E□□681MH20D EKY-160E□□681MJ16S EKY-160E□□102MJ20S EKY-160E□□102MK15S EKY-160E□□122MJ25S EKY-160E□□152MJ30S 1,500 1,500 2,200 2,200 2,700 2,700 3,300 3,900 16 3,900 3,900 4,700 4,700 5,600 5,600 6,800 8,200 10,000 47 100 220 330 330 470 470 680 680 820 1,000 1,000 1,000 1,200 25 1,500 1,800 1,800 2,200 2,200 2,700 2,700 3,300 3,300 3,900 3,900 4,700 4,700 5,600 33 56 150 220 220 270 330 470 470 560 680 35 680 680 1,000 1,000 1,200 1,200 1,500 1,800 1,800 1,800 2,200 12.5×20 16×15 12.5×25 18×15 12.5×30 16×20 12.5×35 12.5×40 16×25 18×20 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×15 10×25 10×30 12.5×20 16×15 18×15 12.5×25 12.5×30 16×20 12.5×35 18×20 12.5×40 16×25 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×15 10×25 10×30 12.5×20 16×15 12.5×25 18×15 12.5×30 16×20 12.5×35 12.5×40 16×25 18×20 16×31.5 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.035 0.042 0.027 0.043 0.024 0.027 0.020 0.017 0.021 0.026 0.017 0.019 0.015 0.015 0.013 0.014 0.012 0.58 0.22 0.13 0.087 0.080 0.069 0.060 0.046 0.049 0.042 0.031 0.035 0.042 0.043 0.027 0.024 0.027 0.020 0.026 0.017 0.021 0.017 0.019 0.015 0.015 0.013 0.014 0.012 0.58 0.22 0.13 0.087 0.080 0.069 0.060 0.046 0.049 0.042 0.031 0.035 0.042 0.027 0.043 0.024 0.027 0.020 0.017 0.021 0.026 0.017 0.12 0.12 0.089 0.11 0.078 0.078 0.065 0.056 0.060 0.067 0.050 0.049 0.044 0.040 0.038 0.038 0.032 2.3 0.87 0.52 0.35 0.32 0.27 0.24 0.18 0.16 0.17 0.12 0.12 0.12 0.11 0.089 0.078 0.078 0.065 0.067 0.056 0.060 0.050 0.049 0.044 0.040 0.038 0.038 0.032 2.3 0.87 0.52 0.35 0.32 0.27 0.24 0.18 0.16 0.17 0.12 0.12 0.12 0.089 0.11 0.078 0.078 0.065 0.056 0.060 0.067 0.050 1,900 1,940 2,230 2,210 2,650 2,530 2,880 3,350 2,930 2,860 3,450 3,140 3,610 4,170 4,080 4,220 4,280 210 340 640 840 865 1,050 1,210 1,400 1,450 1,650 1,910 1,900 1,940 2,210 2,230 2,650 2,530 2,880 2,860 3,350 2,930 3,450 3,140 3,610 4,170 4,080 4,220 4,280 210 340 640 840 865 1,050 1,210 1,400 1,450 1,650 1,910 1,900 1,940 2,230 2,210 2,650 2,530 2,880 3,350 2,930 2,860 3,450 Part No. EKY-160E□□152MK20S EKY-160E□□152ML15S EKY-160E□□222MK25S EKY-160E□□222MM15S EKY-160E□□272MK30S EKY-160E□□272ML20S EKY-160E□□332MK35S EKY-160E□□392MK40S EKY-160E□□392ML25S EKY-160E□□392MM20S EKY-160E□□472MLN3S EKY-160E□□472MM25S EKY-160E□□562MLP1S EKY-160E□□562MMN3S EKY-160E□□682ML40S EKY-160E□□822MMP1S EKY-160E□□103MM40S EKY-250E□□470ME11D EKY-250E□□101MF11D EKY-250E□□221MHB5D EKY-250E□□331MH15D EKY-250E□□331MJC5S EKY-250E□□471MH20D EKY-250E□□471MJ16S EKY-250E□□681MJ20S EKY-250E□□681MK15S EKY-250E□□821MJ25S EKY-250E□□102MJ30S EKY-250E□□102MK20S EKY-250E□□102ML15S EKY-250E□□122MM15S EKY-250E□□152MK25S EKY-250E□□182MK30S EKY-250E□□182ML20S EKY-250E□□222MK35S EKY-250E□□222MM20S EKY-250E□□272MK40S EKY-250E□□272ML25S EKY-250E□□332MLN3S EKY-250E□□332MM25S EKY-250E□□392MLP1S EKY-250E□□392MMN3S EKY-250E□□472ML40S EKY-250E□□472MMP1S EKY-250E□□562MM40S EKY-350E□□330ME11D EKY-350E□□560MF11D EKY-350E□□151MHB5D EKY-350E□□221MH15D EKY-350E□□221MJC5S EKY-350E□□271MH20D EKY-350E□□331MJ16S EKY-350E□□471MJ20S EKY-350E□□471MK15S EKY-350E□□561MJ25S EKY-350E□□681MJ30S EKY-350E□□681MK20S EKY-350E□□681ML15S EKY-350E□□102MK25S EKY-350E□□102MM15S EKY-350E□□122MK30S EKY-350E□□122ML20S EKY-350E□□152MK35S EKY-350E□□182MK40S EKY-350E□□182ML25S EKY-350E□□182MM20S EKY-350E□□222MLN3S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KYSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 2,200 2,700 2,700 35 3,300 3,300 3,900 1.0 2.2 3.3 4.7 10 22 56 100 120 150 180 220 270 270 330 470 50 470 470 560 560 680 820 820 1,000 1,000 1,000 1,200 1,200 1,500 1,800 1,800 2,200 2,700 15 33 56 82 82 120 120 180 63 180 220 270 390 470 470 560 680 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 5×11 5×11 5×11 5×11 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×15 10×25 10×30 12.5×20 16×15 12.5×25 18×15 12.5×30 12.5×35 16×20 12.5×40 16×25 18×20 16×31.5 18×25 16×35.5 16×40 18×31.5 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 12.5×40 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.019 0.049 0.015 0.044 0.015 0.040 0.013 0.038 0.014 0.038 0.012 0.032 4.0 16.0 2.5 10.0 2.2 8.8 1.9 7.6 1.5 6.0 0.70 2.8 0.30 1.2 0.17 0.68 0.12 0.48 0.12 0.48 0.091 0.36 0.084 0.34 0.060 0.24 0.061 0.20 0.055 0.22 0.043 0.17 0.045 0.15 0.055 0.17 0.034 0.11 0.054 0.15 0.030 0.10 0.025 0.083 0.034 0.10 0.021 0.069 0.025 0.075 0.036 0.097 0.022 0.066 0.026 0.070 0.019 0.057 0.016 0.048 0.021 0.057 0.017 0.046 0.014 0.038 0.88 3.5 0.35 1.4 0.22 0.88 0.16 0.64 0.11 0.44 0.12 0.48 0.076 0.31 0.056 0.23 0.072 0.29 0.046 0.19 0.041 0.13 0.031 0.093 0.028 0.084 0.032 0.096 0.024 0.072 0.021 0.063 3,140 3,610 4,170 4,080 4,220 4,280 30 43 53 88 100 180 295 555 730 760 910 1,050 1,220 1,260 1,440 1,690 1,660 1,690 1,950 1,930 2,310 2,510 2,210 2,920 2,555 2,490 3,010 2,740 3,150 3,710 3,635 3,680 3,800 165 265 500 665 690 820 950 1,150 1,150 1,350 1,500 1,900 2,300 2,000 2,500 2,800 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ EKY-350E□□222MM25S EKY-350E□□272MLP1S EKY-350E□□272MMN3S EKY-350E□□332ML40S EKY-350E□□332MMP1S EKY-350E□□392MM40S EKY-500E□□1R0ME11D EKY-500E□□2R2ME11D EKY-500E□□3R3ME11D EKY-500E□□4R7ME11D EKY-500E□□100ME11D EKY-500E□□220ME11D EKY-500E□□560MF11D EKY-500E□□101MHB5D EKY-500E□□121MH15D EKY-500E□□151MJC5S EKY-500E□□181MH20D EKY-500E□□221MJ16S EKY-500E□□271MJ20S EKY-500E□□271MK15S EKY-500E□□331MJ25S EKY-500E□□471MJ30S EKY-500E□□471MK20S EKY-500E□□471ML15S EKY-500E□□561MK25S EKY-500E□□561MM15S EKY-500E□□681MK30S EKY-500E□□821MK35S EKY-500E□□821ML20S EKY-500E□□102MK40S EKY-500E□□102ML25S EKY-500E□□102MM20S EKY-500E□□122MLN3S EKY-500E□□122MM25S EKY-500E□□152MLP1S EKY-500E□□182ML40S EKY-500E□□182MMN3S EKY-500E□□222MMP1S EKY-500E□□272MM40S EKY-630E□□150ME11D EKY-630E□□330MF11D EKY-630E□□560MHB5D EKY-630E□□820MH15D EKY-630E□□820MJC5S EKY-630E□□121MH20D EKY-630E□□121MJ16S EKY-630E□□181MJ20S EKY-630E□□181MK16S EKY-630E□□221MJ25S EKY-630E□□271MK20S EKY-630E□□391MK25S EKY-630E□□471MK30S EKY-630E□□471ML20S EKY-630E□□561MK35S EKY-630E□□681MK40S 680 680 820 820 63 1,000 1,200 1,200 1,500 1,800 68 100 120 150 150 220 330 330 390 470 80 470 470 560 680 680 820 820 1,000 1,000 1,200 6.8 15 27 39 47 56 68 82 100 120 150 220 100 220 270 330 330 330 390 470 470 560 560 680 680 820 16×25 18×20 16×31.5 18×25 16×35.5 16×40 18×31.5 18×35.5 18×40 10×12.5 10×16 10×20 10×25 12.5×16 12.5×20 12.5×25 16×20 12.5×30 12.5×35 16×25 18×20 12.5×40 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 16×20 12.5×30 12.5×35 16×25 18×20 12.5×40 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.025 0.030 0.021 0.024 0.019 0.018 0.020 0.018 0.017 0.17 0.11 0.084 0.069 0.11 0.062 0.047 0.048 0.042 0.036 0.038 0.045 0.032 0.032 0.036 0.029 0.030 0.027 0.027 0.026 1.4 0.57 0.36 0.25 0.17 0.19 0.11 0.084 0.11 0.069 0.062 0.047 0.048 0.042 0.036 0.038 0.045 0.032 0.032 0.036 0.029 0.030 0.027 0.027 0.026 0.075 0.090 0.063 0.072 0.057 0.054 0.060 0.054 0.051 0.66 0.47 0.34 0.28 0.34 0.18 0.14 0.15 0.13 0.11 0.12 0.14 0.095 0.095 0.11 0.086 0.090 0.081 0.081 0.077 5.6 2.3 1.4 1.0 0.66 0.76 0.47 0.34 0.34 0.28 0.18 0.14 0.15 0.13 0.11 0.12 0.14 0.095 0.095 0.11 0.086 0.090 0.081 0.081 0.077 2,600 2,500 2,850 2,800 2,900 3,400 3,300 3,400 3,500 480 600 800 900 750 1,100 1,250 1,350 1,500 1,650 1,700 1,500 1,800 1,850 1,750 2,000 1,900 2,200 2,200 2,700 125 205 355 450 480 565 600 800 750 900 1,100 1,250 1,350 1,500 1,650 1,700 1,500 1,800 1,850 1,750 2,000 1,900 2,200 2,200 2,700 Part No. EKY-630E□□681ML25S EKY-630E□□681MM20S EKY-630E□□821MLN3S EKY-630E□□821MM25S EKY-630E□□102MLP1S EKY-630E□□122ML40S EKY-630E□□122MMN3S EKY-630E□□152MMP1S EKY-630E□□182MM40S EKY-800E□□680MJC5S EKY-800E□□101MJ16S EKY-800E□□121MJ20S EKY-800E□□151MJ25S EKY-800E□□151MK16S EKY-800E□□221MK20S EKY-800E□□331MK25S EKY-800E□□331ML20S EKY-800E□□391MK30S EKY-800E□□471MK35S EKY-800E□□471ML25S EKY-800E□□471MM20S EKY-800E□□561MK40S EKY-800E□□681MLN3S EKY-800E□□681MM25S EKY-800E□□821MLP1S EKY-800E□□821MMN3S EKY-800E□□102ML40S EKY-800E□□102MMP1S EKY-800E□□122MM40S EKY-101E□□6R8ME11D EKY-101E□□150MF11D EKY-101E□□270MHB5D EKY-101E□□390MH15D EKY-101E□□470MJC5S EKY-101E□□560MH20D EKY-101E□□680MJ16S EKY-101E□□820MJ20S EKY-101E□□101MK16S EKY-101E□□121MJ25S EKY-101E□□151MK20S EKY-101E□□221MK25S EKY-101E□□221ML20S EKY-101E□□271MK30S EKY-101E□□331MK35S EKY-101E□□331ML25S EKY-101E□□331MM20S EKY-101E□□391MK40S EKY-101E□□471MLN3S EKY-101E□□471MM25S EKY-101E□□561MLP1S EKY-101E□□561MMN3S EKY-101E□□681ML40S EKY-101E□□681MMP1S EKY-101E□□821MM40S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Capacitance(µF) 1.0 220 680 2,200 4,700 to to to to to 180 560 1,800 3,900 120 0.40 0.50 0.60 0.75 0.85 1k 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T
EKY-630ETD331MK20S 价格&库存
很抱歉,暂时无法提供与“EKY-630ETD331MK20S”相匹配的价格&库存,您可以联系我们找货
EKY-630ETD331MK20S
    • 10+1.24960
    库存:500
