FTC322520S4R7MBCA
FTC322520S4R7MBCA
    CJIANG(长江微电)
    SMD,3.2x2.5mm
    4.7UH ±20% 4A
FTC322520S4R7MBCA 数据手册
深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD Specification for Approval Customer Product Name Wire Wound Molded SMD Power Inductors Customer P/N: Cjiang P/N: [ FTC Series New Released, Revised] SPEC No.: REMARK: Customer Approval Feedback ●深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD ADD:11F, International Science and Technology Building, Fuhong Road, Futian District, Shenzhen Factory ADD:No. shanyang RD CJIANG Industrial Park HUAi'AN Section HUAI'AN City Jiangsu Province TEL: 0755-82529562 FAX:0755-83977004 http://www.CJING.COM.CN E-mail: BOND@Cjiang.com.cn;ann@cjiang.com.cn Version change history Rev Date 1.0 2022/8/9 Description 文件制定 APPROVED CHECKED DRAWN Bond Charles 王云燕 更多资讯,请点击长江微电官网 more information,Please click:WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZ CJIANG TECHNOLOGY CO.,LTD Caution : All products listed in this specification are developed, designed and intended for use in general electronics equipment. The products are not designed or Warranted to meet the requirements of the applications listed below, whose performance and/or quality require especially high reliability, or whose failure, malfunction or trouble might directly cause damage to society, person, or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below. Please contact us for more details if you intend to use our products in the following applications. 1. Aircraft equipment. 2. Aerospace equipment. 3. Undersea equipment. 4. nuclear control equipment. 5. military equipment. 6. Power plant equipment. 7. Medical equipment. 8. Transportation equipment (automobiles, trains, ships,etc.) 9. Traffic signal equipment. 10. Disaster prevention / crime prevention equipment. 11. Data-processing equipment. 12. Applications of similar complexity or with reliability requirements comparable to the applications listed in the above. 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD 1. Scope Featurs 1.1 1.2 1.3 1.4 1.5 1.6 Metal material for large current and low loss. High performance (Isat) realized by metal dust core. Low loss realized with low Rdc. Closed magnetic circuit design reduces leakage flux. Vinyl thermal spray, better surface compactness. 100% lead (Pb) free meet RoHS standard. Application 2.1 2.2 2.3 2.4 2.5 2.6 DC/DC converters. Pad,Smart phone. Portable gaming devices, Smart wear, Wi-Fi module. Notebooks, VR, AR. LCD displays, HDDs, DVCs, DSCs, etc. Baseband power supply, Amplifier, Power management, Module power supply, Camera power manageme. 2. Ordering Procedure FTC ① 2016 ② 10 ③ S ④ 1R0 ⑤ M ⑥ B ⑦ C ⑧ * ⑨ ①Series Name: Mini Molding Power Inductors ②External Dimensions(L×W):2016=2.0*1.6 mm ③External Dimensions(H):10=1.0 mm ④Size Tolerance:S=±0.2mm D=±0.1mm ⑤Inductance value:1R0=1.0uH ⑥Tolerance:K=±10% M=±20% N=±30% ⑦Coating color:B=Black G=Grey ⑧Product type:C=Common ⑨Special define:A=Routine B~Z=Special For special characteristics, please refer to the specific values in Item 5 "Specifications". 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD . SHAPE AND DIMENSIONS Outline Dimensions Recommend Land Pattern Dimensions Units: mm Series L G(TYP) W T A B C FTC100765D 1.0±0. 1 0.3 0.7±0. 1 0.65Max. 1.00 0.20 0.70 FTC121065S 1.2±0.2 0.4 1.0±0.2 0.65Max. 1.30 0.30 1. 10 FTC160865D 1.6±0. 1 0.5 0.8±0. 1 0.65Max. 1.70 0.40 0.90 FTC160865S 1.6±0.2 0.5 0.8±0.2 0.65Max. 1.60 0.40 0.80 FTC160808S 1.6±0.2 0.5 0.8±0.2 0.80Max. 1.70 0.40 0.90 FTC160810S 1.6±0.2 0.5 0.8±0.2 1.00Max. 1.70 0.40 0.90 FTC141265S 1.4±0.2 0.5 1.2±0.2 0.65Max. 1.50 0.45 1.30 FTC141208S 1.4±0.2 0.5 1.2±0.2 0.80Max. 1.50 0.45 1.30 FTC201265S 2.0±0.2 0.5 1.2±0.2 0.65Max. 2. 10 0.50 1.30 FTC201208S 2.0±0.2 0.5 1.2±0.2 0.80Max. 2. 10 0.50 1.30 FTC201210S 2.0±0.2 0.5 1.2±0.2 1.00Max. 2. 10 0.50 1.30 FTC201608S 2.0±0.2 0.6 1.6±0.2 0.80Max. 2. 10 0.50 1.70 FTC201610S 2.0±0.2 0.6 1.6±0.2 1.00Max. 2. 10 0.50 1.70 FTC201610D 2.0±0. 1 0.6 1.6±0. 1 1.00Max. 2.00 0.50 1.60 FTC201612S 2.0±0.2 0.6 1.6±0.2 1.20Max. 2. 10 0.50 1.70 FTC252010S 2.5±0.2 0.7 2.0±0.2 1.00Max. 2.60 0.70 2. 10 FTC252012S 2.5±0.2 0.7 2.0±0.2 1.20Max. 2.60 0.70 2. 10 FTC322512S 3.2±0.2 0.9 2.5±0.2 1.20Max. 3.25 0.90 2.55 FTC322520S 3.2±0.2 0.9 2.5±0.2 2.00Max 3.25 0.90 2.55 FTC303020D 3.0±0. 1 1.0 3.0±0. 1 2.00Max. 2.90 0.90 2.90 5. Marking No Marking 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD 5. Specifications ①1007 Series FTC100765(1.0*0.7*0.65mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC100765D1R5MBCA 1.5 400 500 0.4 0.3 1.1 0.9 FTC100765D2R6MGCA 2.6 750 900 0.55 0.4 1.0 0.8 ②1210 Series FTC121065(1.2*1.0*0.65mm) P/N @ (0A) 1MHz FTC121065S2R2MBCA 2.2 Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max 280 340 1.0 0.9 1.3 1.2 ③1608 Series FTC160865(1.6*0.8*0.65mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC160865DR22MGCA 0.22 35 43 3.8 3.5 4.7 4.3 FTC160865SR47MGCA 0.47 66 82 2.3 2.0 3.3 3.0 FTC160808(1.6*0.8*0.8mm) @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) P/N Saturation current Isat(A) Typical Max Typical Max Typical Max FTC160808SR22MBCA 0.22 33 40 3.4 3.0 5.5 5.0 FTC160808SR24MBCA 0.24 34 41 3.3 2.9 5.3 4.8 FTC160808SR47MBCA 0.47 80 100 2.6 2.3 4.1 3.7 FTC160808SR47MBCD 0.47 48 55 3.8 3.4 4.0 3.5 FTC160808SR56MBCA 0.56 85 110 2.2 1.9 4.0 3.5 FTC160808SR68MBCA 0.68 110 130 2.1 1.9 3.3 3.0 FTC160808S1R0MBCA 1.0 180 200 2.1 1.8 3.0 2.6 FTC160808S1R0MGCD 1.0 105 115 2.1 1.8 2.3 2.1 FTC160808S2R2MGCA 2.2 220 260 1.4 1.2 1.5 1.3 FTC160810(1.6*0.8*1.0mm) @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) P/N Saturation current Isat(A) Typical Max Typical Max Typical Max FTC160810SR22MBCA 0.22 28 35 4.5 4.0 6.5 6.0 FTC160810SR24MBCA 0.24 28 35 4.4 3.9 6.3 5.8 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC160810SR47MBCA 0.47 65 80 4.0 3.5 4.8 4.4 FTC160810SR56MBCA 0.56 70 95 3.5 3.0 4.2 3.7 FTC160810SR68MBCA 0.68 90 115 3.0 2.5 3.6 3.2 ④1412 Series FTC141265(1.4*1.2*0.65mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC141265SR33MBCA 0.33 26 32 4.4 4.2 4.4 4.0 FTC141265SR33MGCA 0.33 26 32 4.4 4.2 4.4 4.0 FTC141265SR47MBCA 0.47 37 45 3.0 2.7 3.4 3.0 FTC141265SR47MGCA 0.47 37 45 3.0 2.7 3.4 3.0 FTC141207(1.4*1.2*0.7mm) @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) P/N Saturation current Isat(A) Typical Max Typical Max Typical Max FTC141207SR24MBCA 0.24 22 28 4.0 3.6 4.6 4.3 FTC141207SR47MBCA 0.47 34 38 3.8 3.3 3.8 3.5 FTC141208(1.4*1.2*0.8mm) @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) P/N Saturation current Isat(A) Typical Max Typical Max Typical Max FTC141208SR24MBCA 0.24 22 27 4.1 3.7 6.0 5.7 FTC141208SR33MBCA 0.33 23 28 4.0 3.5 5.3 5.0 FTC141208SR33MGCA 0.33 23 28 4.0 3.5 5.3 5.0 FTC141208SR47MBCA 0.47 29 35 3.8 3.3 4.6 4.2 FTC141208SR47MGCA 0.47 29 35 3.8 3.3 4.6 4.2 ⑤2012 Series FTC201265(2.0*1.2*0.65mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC201265S1R0MBCA 1.0 78 86 2.6 2.3 2.8 2.5 FTC201265D1R0MGCA 1.0 95 110 2.5 2.2 2.7 2.4 FTC201265S2R2MBCA 2.2 215 230 1.7 1.4 1.8 1.5 FTC201265S2R2MBCB 2.2 230 245 1.7 1.4 1.8 1.5 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC201208(2.0*1.2*0.8mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC201208SR24MBCA 0.24 18 23 6.5 5.9 6.5 6.0 FTC201208SR24MGCA 0.24 18 23 6.5 5.9 6.5 6.0 FTC201208SR33MBCA 0.33 33 45 4.3 4.0 5.2 4.8 FTC201208SR47MBCA 0.47 34 50 3.5 3.3 5.0 4.6 FTC201208SR47MGCA 0.47 34 50 3.5 3.3 5.0 4.6 FTC201208SR47MBCD 0.47 24 28 4.7 4.5 5.2 4.8 FTC201208DR47MGCA 0.47 34 42 4.3 3.9 5.2 4.8 FTC201208SR68MBCA 0.68 50 60 3.7 3.3 4.2 3.7 FTC201208S1R0MBCA 1.0 55 70 3.3 2.9 4.0 3.5 FTC201208S1R0MBCD 1.0 48 55 3.2 2.8 3.2 2.8 FTC201208S1R0MGCD 1.0 48 55 3.2 2.8 3.2 2.8 FTC201208S1R5MBCA 1.5 118 135 2.2 1.9 3.0 2.5 FTC201208S2R2MBCA 2.2 160 185 2.2 1.8 2.6 2.3 FTC201210(2.0*1.2*1.0mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC201210SR10MBCA 0.1 8.0 13 7.5 7.0 8.5 8.0 FTC201210SR22MBCA 0.22 16 22 7.1 6.5 7.3 6.8 FTC201210SR24MBCA 0.24 17 23 7.0 6.4 7.2 6.7 FTC201210SR24MGCD 0.24 13 17 7.0 6.4 7.2 6.7 FTC201210SR33MBCA 0.33 24 32 5.5 5.0 6.5 6.0 FTC201210SR47MBCA 0.47 29 36 4.7 4.3 5.5 5.0 FTC201210SR68MBCA 0.68 37 43 4.3 4.0 5.0 4.5 FTC201210S1R0MBCA 1.0 55 63 3.9 3.5 4.0 3.5 FTC201210S1R5MBCA 1.5 76 85 3.1 2.6 3.2 2.7 FTC201210S2R2MBCA 2.2 135 150 2.0 1.7 2.7 2.4 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD ⑥2016 Series FTC201608(2.0*1.6*0.8mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC201608SR22MBCA 0.22 14 19 6.6 5.9 6.1 5.6 FTC201608SR24MBCA 0.24 14 20 6.5 5.8 6.0 5.5 FTC201608SR33MBCA 0.33 18 24 5.5 4.8 5.8 5.3 FTC201608SR47MBCA 0.47 24 27 4.6 4.4 5.5 5.0 FTC201608SR47MGCA 0.47 24 27 4.6 4.4 5.5 5.0 FTC201608SR68MBCA 0.68 39 44 3.8 3.5 4.6 4.2 FTC201608S1R0MBCA 1.0 53 60 3.6 3.3 3.3 3.1 FTC201608S1R0MGCD 1.0 45 52 3.6 3.3 3.8 3.5 FTC201608S1R5MBCA 1.5 73 85 3.1 2.8 3.0 2.8 FTC201608S2R2MBCA 2.2 123 140 2.2 2.0 2.5 2.3 FTC201608S3R3MBCA 3.3 200 220 1.8 1.5 2.1 1.8 FTC201608S4R7MBCA 4.7 260 290 1.6 1.4 1.7 1.5 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC201610(2.0*1.6*1.0mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC201610SR10MBCA 0.1 7.0 12 8.5 8.0 9.0 8.4 FTC201610SR15MBCA 0.15 8.0 14 7.6 7.0 8.7 8.0 FTC201610SR22MBCA 0.22 11 18 6.9 6.3 8.2 7.5 FTC201610SR24MBCA 0.24 10.5 19 6.8 6.2 8.2 7.4 FTC201610SR33MBCA 0.33 16.5 22 5.7 5.8 7.0 6.0 FTC201610SR33MGCA 0.33 16.5 22 5.7 5.8 7.0 6.0 FTC201610SR47MBCA 0.47 19.5 25 6.0 5.0 6.3 5.5 FTC201610SR47MGCA 0.47 19.5 25 6.0 5.0 6.3 5.5 FTC201610SR68MBCA 0.68 25 32 5.3 4.3 5.2 4.5 FTC201610S1R0MBCA 1.0 35 43 4.5 4.1 4.6 3.8 FTC201610S1R0MGCA 1.0 35 43 4.5 4.1 4.6 3.8 FTC201610S1R0MBCD 1.0 31 36 4.6 4.2 4.7 4.2 FTC201610S1R0MGCD 1.0 31 36 4.6 4.2 4.7 4.2 FTC201610S1R5MBCA 1.5 58 100 3.3 2.3 3.2 2.9 FTC201610S2R2MBCA 2.2 100 130 2.5 2.1 3.0 2.45 FTC201610S2R2MGCA 2.2 100 130 2.5 2.1 3.0 2.45 FTC201610D2R2MBCA 2.2 115 125 2.5 2.2 3.3 3.0 FTC201610S3R3MBCA 3.3 140 170 1.7 1.5 2.3 2.0 FTC201610S4R7MBCA 4.7 190 220 1.6 1.4 2.0 1.8 FTC201610S4R7MGCA 4.7 190 220 1.6 1.4 2.0 1.8 FTC201612(2.0*1.6*1.2mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC201612SR10MBCA 0.1 4.0 6.0 12 10 13 11.5 FTC201612SR24MBCA 0.24 9.0 11 9.1 8.6 9.2 8.7 FTC201612SR33MBCA 0.33 10 15 7.7 7.2 7.8 7.3 FTC201612SR47MBCA 0.47 13 17 6.7 6.0 6.7 6.0 FTC201612S1R5MBCA 1.5 40 50 4.0 3.5 4.0 3.5 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD ⑦2520 Series FTC252010S(2.5*2.0*1.0mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC252010SR22MBCA 0.22 12 17 6.8 6.5 8.6 7.9 FTC252010SR22MGCA 0.22 12 17 6.8 6.5 8.6 7.9 FTC252010SR24MBCA 0.24 12 17.5 6.7 6.4 8.5 7.8 FTC252010SR33MBCA 0.33 13 19 6.5 6.2 7.6 7.2 FTC252010SR33MGCA 0.33 13 19 6.5 6.2 7.6 7.2 FTC252010SR47MBCA 0.47 15 22 6.1 5.6 7.0 6.5 FTC252010SR47MGCA 0.47 15 22 6.1 5.6 7.0 6.5 FTC252010SR68MBCA 0.68 23 27 5.6 5.0 5.9 5.5 FTC252010S1R0MBCA 1.0 22.5 30 5.4 4.1 5.3 4.8 FTC252010S1R0MGCA 1.0 22.5 30 5.4 4.1 5.3 4.8 FTC252010S1R5MBCA 1.5 45 55 3.4 3.0 4.3 3.9 FTC252010S1R5MGCA 1.5 45 55 3.4 3.0 4.3 3.9 FTC252010S2R2MBCA 2.2 60.5 70 2.5 2.1 3.5 3.0 FTC252010S2R2MGCA 2.2 60.5 70 2.5 2.1 3.5 3.0 FTC252010S3R3MBCA 3.3 86 100 2.5 2.1 2.8 2.5 FTC252010S3R3MGCA 3.3 86 100 2.5 2.1 2.8 2.5 FTC252010S4R7MBCA 4.7 160 180 2.0 1.6 2.6 2.0 FTC252010S4R7MGCA 4.7 160 180 2.0 1.6 2.6 2.0 FTC252010S4R7MBCD 4.7 145 160 2.0 1.6 2.6 2.0 FTC252010S6R8MBCA 6.8 270 320 1.6 1.4 2.4 1.9 FTC252010S100MBCA 10.0 500 560 1.05 0.95 1.55 1.4 FTC252010S100MGCA 10.0 500 560 1.05 0.95 1.55 1.4 FTC252010S220MGCA 22.0 1100 1300 0.85 0.6 1.1 0.9 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC252012S(2.5*2.0*1.2mm) P/N @ (0A) 1MHz Saturation current Isat(A) Heat rating current Irms(A) Rdc(mΩ) L0(µH) Typical Max Typical Max Typical Max FTC252012SR10MBCA 0.1 6 10 12 10.5 13.5 12.5 FTC252012SR15MBCA 0.15 7 11 11.5 10 13.0 12.0 FTC252012SR22MBCA 0.22 9 14 8.2 7.6 9.6 9.0 FTC252012SR24MBCA 0.24 10 15 8.0 6.4 9.5 8.8 FTC252012SR24MGCA 0.24 10 15 8.0 6.4 9.5 8.8 FTC252012SR33MBCA 0.33 11 17 6.8 6.1 8.6 7.8 FTC252012SR47MBCA 0.47 13 19 6.5 6.0 7.5 6.8 FTC252012SR47MBCD 0.47 11 13 8.0 7.5 8.5 8.0 FTC252012SR47MGCD 0.47 11 13 8.0 7.5 8.5 8.0 FTC252012SR68MBCA 0.68 17 23 6.3 5.0 6.5 6.0 FTC252012S1R0MBCA 1.0 33 42 4.4 3.6 5.6 4.5 FTC252012S1R0MBCD 1.0 16 22 5.2 4.5 6.5 6.0 FTC252012S1R0MGCD 1.0 16 22 5.2 4.5 6.5 6.0 FTC252012S1R5MBCA 1.5 44 56 3.7 3.2 4.5 3.8 FTC252012S1R5MBCD 1.5 27 32 4.6 4.2 4.7 4.4 FTC252012S1R5MBCE 1.5 48 55 4.4 4.0 4.3 3.9 FTC252012S1R5MGCA 1.5 44 56 3.7 3.2 4.5 3.8 FTC252012S2R2MBCA 2.2 55 79 3.2 2.7 3.8 3.3 FTC252012S2R2MGCA 2.2 55 79 3.2 2.7 3.8 3.3 FTC252012S3R3MBCA 3.3 80 125 2.3 1.8 3.0 2.5 FTC252012S4R7MBCA 4.7 145 180 1.8 1.5 2.4 2.1 FTC252012S4R7MGCA 4.7 145 180 1.8 1.5 2.4 2.1 FTC252012S6R8MBCA 6.8 225 270 1.6 1.3 2.2 1.7 FTC252012S100MBCA 10.0 330 400 1.2 1.05 1.6 1.45 FTC252012S100MGCA 10.0 330 400 1.2 1.05 1.6 1.45 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD ⑧3225 Series FTC322510S(3.2*2.5*1.0mm) @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) P/N Saturation current Isat(A) Typical Max Typical Max Typical Max FTC322510SR47MBCA 0.47 17 22 6.4 5.9 8.3 7.6 FTC322510SR68MBCA 0.68 22 28 6.2 5.7 7.5 7.0 FTC322510S1R0MBCA 1.0 25 30 5.4 4.9 6.0 5.3 FTC322510S1R5MBCA 1.5 34 42 4.0 3.6 5.0 4.4 FTC322510S2R2MBCA 2.2 55 66 3.7 3.4 4.0 3.5 FTC322510S3R3MBCA 3.3 105 120 2.7 2.3 3.7 3.3 FTC322510S4R7MBCA 4.7 125 140 2.3 1.9 2.8 2.5 FTC322512S(3.2*2.5*1.2mm) L0(µH) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC322512SR10MBCA 0.10 5.2 7.0 12 11 18 16.5 FTC322512SR22MBCA 0.22 6.6 10 9..2 8.7 11.5 11 FTC322512SR22MGCA 0.22 6.6 10 9..2 8.7 11.5 11 FTC322512SR24MBCA 0.24 7.0 12 9.0 8.5 11 10.5 FTC322512SR33MBCA 0.33 9.0 14 8.4 8.1 10 9.5 FTC322512SR47MBCA 0.47 14 19 7.5 7.2 8.6 8.2 FTC322512SR47MGCA 0.47 14 19 7.5 7.2 8.6 8.2 FTC322512SR47MBCD 0.47 11 14 7.5 7.2 8.6 8.2 FTC322512SR68MBCA 0.68 18 23 7.3 6.8 8.1 7.7 FTC322512SR68MBCD 0.68 12 15 7.0 6.5 8.0 7.5 FTC322512S1R0MBCA 1.0 26 30 5.3 4.8 6.6 5.8 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC322512S1R0MGCA 1.0 26 30 5.3 4.8 6.6 5.8 FTC322512S1R0MBCD 1.0 18 21 5.5 5.0 7.7 7.0 FTC322512S1R5MBCA 1.5 37 44 4.7 4.3 5.1 4.7 FTC322512S2R2MBCA 2.2 58 70 3.6 3.0 4.6 4.2 FTC322512S2R2MBCD 2.2 42 50 3.8 3.5 5.0 4.5 FTC322512S2R2MGCD 2.2 42 50 3.8 3.5 5.0 4.5 FTC322512S3R3MBCA 3.3 75 95 2.9 2.5 3.7 3.2 FTC322512S3R3MGCA 3.3 75 95 2.9 2.5 3.7 3.2 FTC322512S4R7MBCA 4.7 115 135 2.3 2.0 2.9 2.6 FTC322520S(3.2*2.5*2.0mm) @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ ) L0(µH) P/N Saturation current Isat( A) Typical Max Typical Max Typical Max FTC322520SR33MBCA 0.33 8.0 9.6 8.5 8.0 11.0 10 FTC322520SR47MBCA 0.47 9.0 10.5 8.0 7.5 10.0 9.0 FTC322520SR68MBCA 0.68 12.5 14.5 7.0 6.5 8.6 7.5 FTC322520S1R0MBCA 1.0 15.0 17.5 6.5 6.0 7.5 6.5 FTC322520S1R5MBCA 1.5 24.5 28.0 5.5 5.0 6.3 5.5 FTC322520S2R2MBCA 2.2 36.5 44.0 5.0 4.5 5.4 4.8 FTC322520S3R3MBCA 3.3 54.0 63.0 3.2 2.7 4.5 4.0 FTC322520S4R7MBCA 4.7 82.0 95.0 2.8 2.4 3.5 3.0 ⑨3030 Series FTC303018(3.0*3.0*1.8mm) P/N @ (0A) 1MHz Heat rating current Irms(A) Rdc(mΩ) L0(µH) Saturation current Isat(A) Typical Max Typical Max Typical Max FTC303018DR22MBCA 0.22 5.5 7.0 10.0 9.0 17 16 FTC303018D4R7MBCA 4.7 72 87 3.4 3.0 4.7 4.2 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC303020(3.0*3.0*2.0mm) P/N Heat rating current Irms ( A ) Rdc(mΩ ) L0 (µH) Saturation current Isat ( A ) @ (0A) 1MHz Typical Max Typical Max Typical Max FTC303020DR33MBCA 0.33 9 13 7.8 7.2 9.5 9.0 FTC303020DR47MBCA 0.47 11 15 7.3 6.7 9.0 8.3 FTC303020DR68MBCA 0.68 14 19 6.8 6.2 8.3 7.6 FTC303020D1R0MBCA 1.0 14 20 6.5 6.0 8.0 7.3 FTC303020D1R5MBCA 1.5 22 30 5.0 4.5 5.5 5.0 FTC303020D2R2MBCA 2.2 37 45 4.7 4.3 6.0 5.5 FTC303020D3R3MBCA 3.3 54 70 3.7 3.4 4.3 3.8 FTC303020D4R7MBCA 4.7 75 100 3.2 2.8 3.5 3.2 FTC303020D6R8MBCA 6.8 90 115 2.7 2.3 3.0 2.5 FTC303020D100MBCA 10 140 170 2.4 2.0 2.6 2.2 Test remarks Note 1.:All test data is referenced to 25 ℃ ambient. Note 2.:Test Condition:1MHz, 1.0Vrms. Note 3.:Irms:DC current (A) that will cause an approximate △T of 40 ℃. Note 4.: Isat:DC current (A) that will cause L0 to drop approximately 30%. Note 5.: Operating Temperature Range -55℃ to + 125℃. Note 6.:The part temperature (ambient + temp rise) should not exceed 125 under ℃ the worst case operating conditions. Circuit design, Note 7.:The rated current as listed is either the saturation current or the heating current depending on which value is lower. Note 8 :For FTC series inductors,absolute maximum voltage: DC 20V 6 . Structure component placement, PCB trace size and thickness, airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the end application. 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD 7. Current Characteristic FTC100765D1R5MBCA FTC100765D2R6MGCA FTC160865DR22MGCA FTC160865DR47MGCA FTC160808SR24MBCA  FTC160808SR24MBCA FTC160808SR47MBCD FTC160808SR24MBCA FTC160810SR22MBCA FTC160808SR56MBCA  FTC121065S2R2MBCA FTC160808SR22MBCA FTC160808SR47MBCA FTC160808SR68MBCA  FTC160808S1R0MGCD FTC160808S2R2MGCA FTC160810SR24MBCA FTC160810SR47MBCA 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC160810SR56MBCA FTC160810SR68MBCA FTC141265SR33MBCA FTC141265SR33MGCA FTC141265SR47MBCA FTC141265SR47MGCA FTC141208SR24MBCA FTC141208SR33MBCA FTC141208SR33MGCA FTC141208SR47MBCA FTC141208SR47MGCA FTC201265S1R0MBCA FTC201265D1R0MGCA FTC201208SR24MGCA FTC201265S2R2MBCA FTC201208SR33MBCA FTC201208SR24MBCA FTC201208SR47MBCA 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC201208SR47MGCA FTC201208SR47MBCD FTC201208S1R0MBCA FTC201208S1R0MBCD FTC201208S1R0MGCD FTC201208S2R1MBCA FTC201210SR10MBCA FTC201210SR22MBCA FTC201210SR24MBCA FTC201210SR24MGCD FTC201210SR33MBCA FTC201210SR47MBCA FTC201210SR68MBCA FTC201210S1R0MBCA FTC201210S1R5MBCA FTC201210S2R2MBCA FTC201608SR22MBCA FTC201608SR24MBCA 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC201608SR33MBCA FTC201608SR47MBCA FTC201608SR47MGCA FTC201608SR68MBCA FTC201608S1R0MBCA FTC201608S1R0MGCD FTC201608S1R5MBCA FTC201608S4R7MBCA FTC201610SR22MBCA FTC201610SR33MGCA FTC201608S2R2MBCA FTC201610SR10MBCA FTC201610SR24MBCA FTC201610SR47MBCA FTC201608S3R3MBCA FTC201610SR15MBCA FTC201610SR33MBCA FTC201610SR47MGCA 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC201610SR68MBCA FTC201610S1R0MBCD FTC201610S2R2MBCA FTC201610S3R3MBCA FTC201612SR10MBCA FTC201612S1R5MBCA FTC201610S1R0MBCA FTC201610S1R0MGCD FTC201610S2R2MGCA FTC201610S4R7MBCA FTC201610S1R0MGCA FTC201610S1R5MBCA FTC201610D2R2MBCA FTC201610S4R7MGCA FTC201612SR24MBCA FTC201612SR33MBCA FTC252010SR22MBCA FTC252010SR22MGCA 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC252010SR24MBCA FTC252010SR47MBCA FTC252010S1R0MBCA FTC252010S1R5MGCA FTC252010S3R3MBCA FTC252010S4R7MGCA FTC252010SR33MBCA FTC252010SR47MGCA FTC252010S1R0MGCA FTC252010S2R2MBCA FTC252010S3R3MGCA FTC252010S4R7MBCD FTC252010SR33MGCA FTC252010SR68MBCA FTC252010S1R5MBCA FTC252010S2R2MGCA FTC252010S4R7MBCA FTC252010S6R8MBCA 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC252010S100MBCA FTC252010S100MGCA FTC252010SR10MBCA FTC252012SR15MBCA FTC252012SR24MBCA FTC252012SR24MGCA FTC252010S220MBCA FTC252012SR22MBCA FTC252012SR33MBCA FTC252012SR47MBCA FTC252012SR47MBCD FTC252012SR47MGCD FTC252012SR68MBCA FTC252012S1R0MBCA FTC252012S1R0MBCD FTC252012S1R0MGCD FTC252012S1R5MBCA FTC252012S1R5MBCD 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC252012S1R5MBCE FTC252012S1R5MGCA FTC252012S2R1MGCA FTC252012S3R3MBCA FTC252012S4R7MGCA FTC252012S6R8MBCA FTC252012S100MGCA FTC322512SR22MBCA FTC322512SR24MBCA FTC322510S2R2MBCA FTC322510SR22MGCA FTC322512SR33MBCA FTC252012S2R2MBCA FTC252012S4R7MBCA FTC252012S100MBCA FTC322510S3R3MBCA FTC322510S4R7MBCA FTC322512SR47MBCA 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD FTC322512SR47MGCA FTC322512SR47MBCD FTC322512SR68MBCD FTC322512S1R0MBCA FTC322512S1R0MBCD FTC322512S1R5MBCA FTC322512S2R2MBCD FTC322512S3R3MGCA FTC303020D1R0MBCA FTC322512S2R2MGCD FTC322512S4R7MBCA FTC303020D2R2MBCA FTC322512SR68MBCA FTC322512S1R0MGCA FTC322512S2R2MBCA FTC322512S3R3MBCA FTC303018D4R7MBCA FTC303020D1R5MBCA 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD 8. Reliability Item Requirements Insulation Resistance ≥100MΩ Test Methods and Remarks 100 VDC between inductor coil and The middle of the top surface of the body for 60 seconds. Dip pads in flux . Solderability 90% or more of electrode area shall Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free). be coated by new solde. Solder Temperature: 245±5℃. Immersion Time: (5±1) s. Dip pads in flux. Resistance to Soldering Heat No visible mechanical damage. Inductance change: Within ±10. Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free). Solder Temperature: 260±5℃. Immersion Time: 10±1sec. Adhesion of teral electrode High temperature Strong bond between the pad and the core, without come off PCB. No case deformation or change in appearance. Inductance change: Within ±10% Low temperature No visible mechanical damage. Inductance change: Within ±10% Inductors shall be subjected to (260±5)℃ for (20±5)s Soldering in the base whit 0.3mm solder. And then aplombelectrode way plus tax 10 N for (10±1) seconds. Temperature: 125±2℃. Time : 1000 hours. Measurement at 24±4 hours after test conclusion. Temperature: -40±2℃. Time : 1000 hours. Measurement at 24±4 hours after test conclusion. The test sample shall be placed at (-55±3)℃ and Thermal shock Temperature characteristic No visible mechanical damage. Inductance change: Within ±10% Inductance change Pc-b,Pc-d: Within ±20% Static Humidity No visible mechanical damage. Inductance change: Within ±10% Life No visible mechanical damage. Inductance change: Within ±10% (125±3)℃ for (30±3) , different temperature conversion time is 2~3 utes. The temperature cycle shall be repeated 32 cycles. Placed at room temperature for 2 hours, within 48±4 hours of testing. a:+20 ℃ (30~45) → b: -40 ℃ (30~45) → c: +20 ℃ (30~45) → d: +125 ℃ (30~45) → e: +20 ℃ (30~45) Lb  Lc Ld  Lc Pc-b  100% Pc-d  100% Lc Lc ; Inductors shall be subjected to (95±3)%RH . at(60±2)℃ for (1000±4) h. Placed at room temperature for 2 hours, within 48 hours of testing. Inductors shall be store at (85±2)℃ for (1000±4) hours with Irms applied. Placed at room temperature for 2 hours, within 48 hours of testing 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD 9. Soldering Condition (This is for recommendation, please customer perform adjustment according to actual application) Recommend Reflow Soldering Profile:(solder : Sn96.5 / Ag3 / Cu0.5) Profile Feature Lead (Pb)-Free solder Preheat: Temperature Min (Tsmin) 150℃ Temperature Max (Tsmax) 200℃ Time (Tsmin to Tsmax ) (ts) 60 -120 seconds Average ramp-up rate: (Ts max to Tp) 3℃ / second max. Time maintained above : Temperature (TL ) 217℃ Time (tL) 60-150 seconds Peak Temperature (Tp) 260℃ Time within +0 ℃ of actual peak Temperature (tp)2 −5 10 seconds Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature 8minutes max. Allowed Re-flow times : 2 times Remark : To avoid discoloration phenomena of chip on terminal electrodes, please use N2 Re-flow furnace . 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD 10. Packing 10.1 Dimension of plastic taping: (Unit: mm) Series W ±0.30 A0 ±0.05 B0 +0.1/-0 D +0.1/-0 D1 Min E ±0.10 F ±0.10 K0 ±0.05 P0 ±0.10 P2 ±0.10 P ±0.10 T ±0.05 Qty/Reel 100765 8.00 0.90 1.20 1.50 1.0 1.75 3.50 0.80 4.00 2.00 4.00 0.23 5K 121065 8.00 1.30 1.50 1.50 1.0 1.75 3.50 0.80 4.00 2.00 4.00 0.23 160865 8.00 1.10 1.90 1.50 1.0 1.75 3.50 0.80 4.00 2.00 4.00 0.23 160808 8.00 1.10 1.90 1.50 1.0 1.75 3.50 1.00 4.00 2.00 4.00 0.23 160810 8.00 1.10 1.90 1.50 1.0 1.75 3.50 1.20 4.00 2.00 4.00 0.23 141265 8.00 1.50 1.70 1.50 1.0 1.75 3.50 0.80 4.00 2.00 4.00 0.23 141208 8.00 1.50 1.70 1.50 1.0 1.75 3.50 1.00 4.00 2.00 4.00 0.23 201265 8.00 1.50 2.30 1.50 1.0 1.75 3.50 0.8 4.00 2.00 4.00 0.23 201208 8.00 1.50 2.30 1.50 1.0 1.75 3.50 1.00 4.00 2.00 4.00 0.23 201210 8.00 1.50 2.30 1.50 1.0 1.75 3.50 1.20 4.00 2.00 4.00 0.23 201608 8.00 1.90 2.30 1.50 1.0 1.75 3.50 1.00 4.00 2.00 4.00 0.23 201610 8.00 1.90 2.30 1.50 1.0 1.75 3.50 1.20 4.00 2.00 4.00 0.23 201612 8.00 1.90 2.30 1.50 1.0 1.75 3.50 1.40 4.00 2.00 4.00 0.23 252010 8.00 2.40 2.80 1.50 1.0 1.75 3.50 1.20 4.00 2.00 4.00 0.23 252012 8.00 2.40 2.80 1.50 1.0 1.75 3.50 1.40 4.00 2.00 4.00 0.23 322510 8.00 2.90 3.50 1.50 1.0 1.75 3.50 1.20 4.00 2.00 4.00 0.23 322512 8.00 2.90 3.50 1.50 1.0 1.75 3.50 1.40 4.00 2.00 4.00 0.23 303018 12.0 3.40 3.40 1.50 1.0 1.75 5.50 2.00 4.00 2.00 8.00 0.35 303020 12.0 3.40 3.40 1.50 1.0 1.75 5.50 2.20 4.00 2.00 8.00 0.35 3K 10.2 Dimension of Reel:(Unit: mm) Type A 0.5 B 0.5 C 0.5 D 1 All 178 60 12 1.5 11. Note 11.1 recommend products store in warehouse with temperature between 15 to 35℃ under humidity between 25 to 75%RH. Even under storage conditions recommended above, solder ability of products will be degraded stored over 1 year old. 11.2 Cartons must be placed in correct direction which indicated on carton, otherwise the reel or wire will be deformed. 11.3 Storage conditions as below are inappropriate: a. Stored in high electrostatic environment b. Stored in direct sunshine, rain, snow or condensation. c. Exposed to sea wind or corrosive gases, such as Cl2, H2S, NH3, SO2, NO2, etc. 11.4 The products are used in circuit board thickness greater than 1.6mm. If customers use less than the thickness of the circuit board that you should confirm with the company, in order to recommend a more suitable product. 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN 深圳市长江微电科技有限公司 SZCJIANGTECHNOLOGYCO.,LTD 12. Record Version Description Page Date Amended by Checked by A0 First version 1~23 Nov.21.2022 Xi Rui.Niu Dirk.Wang 1~23 Dec.14.2022 Xi Rui.Niu Dirk.Wang 1~23 Dec.29.2022 Xi Rui.Niu Dirk.Wang A1 A2 newly increased: FTC303020D1R5MBCA FTC252010S6R8MBCA FTC252010S220MBCA FTC322510S2R2MBCA FTC201208SR47MBCD newly increased: FTC303018D4R7MBCA FTC322510S3R3MBCA FTC322510S4R7MBCA . All rights reserved. Specification herein will be changed at any time without prior notice. 更 多 资 讯 ,请 点 击 长 江 微 电 官 网 more information, Please click: WWW.CJIANG.COM.CN
FTC322520S4R7MBCA 价格&库存
很抱歉,暂时无法提供与“FTC322520S4R7MBCA”相匹配的价格&库存,您可以联系我们找货
FTC322520S4R7MBCA
  • 1+1.07030
  • 50+0.82390
  • 2000+0.75900
库存:1973
FTC322520S4R7MBCA
  • 5+1.66690
  • 50+1.28780
  • 150+1.11330
  • 500+0.91560
  • 2000+0.82750
  • 4000+0.77480
库存:490
FTC322520S4R7MBCA
    • 5+1.51635
    • 50+1.17551
    • 400+0.84721
    • 800+0.83450
    库存:740
    FTC322520S4R7MBCA
    • 5+1.67109
    • 50+1.29546
    • 150+1.13454
    • 500+0.93366
    • 2000+0.84424
    • 4000+0.79056
    库存:5251
    FTC322520S4R7MBCA
    • 5+1.66420
    • 50+1.28480
    • 150+1.12330
    • 500+0.92450
    • 2000+0.83600
    • 4000+0.78270
    库存:234
