RS706
Supply Voltage Supervisor with Watchdog and Manual
Reset
1 FEATURES
3 DESCRIPTIONS
Operating Voltage Range:1.0V to 5.5V
Low Power Consumption:40µA (Max)
Precision Supply-Voltage Monitor:
2.63V, 2.93V, 3.08V, 4.00V
Debounced TTL/CMOS Compatible
Manual-Reset Input
Guaranteed ̅̅̅̅̅̅̅̅̅
𝐑𝐄𝐒𝐄𝐓 Valid at VCC=1.0V
160ms Reset Pulse Width
Independent Watchdog Timer (1.6sec TYP)
Timeout
Voltage Monitor for Power-Fail or LowBattery Warning
Operating Temperature Range:
-40°C to +125°C
Available in Green Package: SOIC-8(SOP8)
The RS706 microprocessor (µP) supervisory circuits
reduce the complexity and number of components
required to monitor power-supply and battery function
in µP systems. This device significantly improves
system reliability and accuracy compared to separate
ICs or discrete components.
2 APPLICATIONS
Computers
SOC、DSP or Micro Controllers
Embedded Systems
Industrial Equipment
Intelligent Instruments
Critical µP Power Monitoring
Wireless Communications Systems
The RS706 provide four functions:
1) A reset output during power-up, power-down, and
brownout conditions. The reset output remains
operational with VCC as low as 1.0V.
2) An independent watchdog output that goes low if the
watchdog input has not been toggled within 1.6
seconds (TYP).
3) A 1.2V threshold detector for power-fail warning, lowbattery detection, or for monitoring a power supply.
4) An active-low manual-reset input.
The RS706 is available in Green SOIC-8 (SOP8)
package. It operates over an ambient temperature
range of -40°C to +125°C.
Device Information (1)
PART
NUMBER
RS706
(1)
PACKAGE
BODY SIZE (NOM)
SOIC-8(SOP8)
4.90mm x 3.90mm
For all available packages, see the orderable addendum at the
end of the data sheet.
4 TYPICAL APPLICATION
Unregulator
DC Voltage
RS3005
Linear Regulator
μP
Vcc
Vcc
PFI
RESET
RS706
WDI
WDO
MR
PFO
Pushbutton
REV A.3
1 / 17
RESET
I/O LINE
NMI
INTERRUPT
www.run-ic.com
RS706
Table of Contents
1 FEATURES .......................................................................................................................................................1
2 APPLICATIONS ................................................................................................................................................1
3 DESCRIPTION ..................................................................................................................................................1
4 TYPICAL APPLICATION ..................................................................................................................................1
5 Revision History ..............................................................................................................................................3
6 PACKAGE/ORDERING INFORMATION (1) ......................................................................................................4
7 PIN CONFIGURATIONS ...................................................................................................................................5
8 Specifications ..................................................................................................................................................6
8.1 Absolute Maximum Ratings (1) ....................................................................................................................6
8.2 ESD Ratings................................................................................................................................................6
8.3 Thermal Information: ...................................................................................................................................6
8.4 ELECTRICAL CHARACTERISTICS ...........................................................................................................7
8.5 Typical Operating Characteristics ...............................................................................................................8
9 Function Block Diagram .............................................................................................................................. 11
10 Detailed Description ................................................................................................................................... 12
10.1 Reset Output .......................................................................................................................................... 12
10.2 Watchdog Timer ..................................................................................................................................... 12
10.3 Manual Reset ......................................................................................................................................... 12
10.4 Power-Fail Comparator .......................................................................................................................... 12
11 Applications Information ........................................................................................................................... 13
11.1 Ensuring a Valid RESET Output Down to VCC=0V ................................................................................ 13
11.2 Monitoring Voltages Other Than the Unregulated DC Input .................................................................. 13
11.3 Interfacing to µPs with Bidirectional Reset Pins .................................................................................... 13
12 PACKAGE OUTLINE DIMENSIONS ........................................................................................................... 15
13 TAPE AND REEL INFORMATION .............................................................................................................. 16
2 / 17
www.run-ic.com
RS706
5 Revision History
Note: Page numbers for previous revisions may different from page numbers in the current version.
Version
Change Date
A.1
2020/12/13
A.2
2022/02/22
A.3
2022/06/27
Change Item
Initial version completed
1.Added the maximum value of tMD on Page 6@RevA.1
2.Modify ELECTRICAL CHARACTERISTICS
1. Update Operating Temperature Range: -40°C to +125°C
2. Update Typical Operating Characteristics
3. Update Reset Pulse Width typical value
4. Update VCC to ̅̅̅̅̅̅̅̅̅
RESET delay typical value
3 / 17
www.run-ic.com
RS706
PRODUCT
ORDERING
NUMBER
TEMPERATURE
RANGE
PACKAGE
LEAD
PACKAGE
MARKING (2/3)
PACKAGE OPTION
RS706-2.63YK
-40°C ~+125°C
SOIC-8(SOP8)
RS706B
Tape and Reel,4000
RS706-2.93YK
-40°C ~+125°C
SOIC-8(SOP8)
RS706C
Tape and Reel,4000
RS706-3.08YK
-40°C ~+125°C
SOIC-8(SOP8)
RS706D
Tape and Reel,4000
RS706-4.00YK
-40°C ~+125°C
SOIC-8(SOP8)
RS706E
Tape and Reel,4000
RS706
NOTE:
(1) This information is the most current data available for the designated devices. This data is subject to change without notice and revision
of this document. For browser-based versions of this data sheet, refer to the right-hand navigation.
(2) There may be additional marking, which relates to the lot trace code information(data code and vendor code),the logo or the
environmental category on the device.
(3) B, C, D, E, represents different Reset Thresholds.
4 / 17
www.run-ic.com
RS706
(TOP VIEW)
MR
1
VCC
2
8
WDO
7
RESET
RS706
GND
3
6
WDI
PFI
4
5
PFO
SOIC-8(SOP8)
PIN DESCRIPTION
PIN
NAME
FUNCTION
SOIC-8(SOP8)
1
MR
2
VCC
3
GND
4
PFI
5
PFO
6
WDI
7
RESET
8
WDO
Manual-Reset Input triggers a reset pulse when pulled below 0.8V. This active-low
input has an internal pull-up resistance. It can be driven from a TTL or CMOS logic
line as well as shorted to ground with a switch.
Power Supply Voltage that is monitored.
Ground, reference for all signals.
Power-Fail Volta Monitor Input. When PFI is less than 1.2V, ̅̅̅̅̅̅
PFO goes low.
Connect PFI to GND or VCC if not used.
Power-Fail Output goes low and sinks current when PFI is less than 1.2V;
Otherwise ̅̅̅̅̅
PFO stays high.
Watchdog Input. If WDI remains high or low 1.6sec, the internal watchdog timer
runs out and WDO goes low. Floating WDI or connecting WDI to a high-impedance
three-state buffer disables the watchdog feature. The internal watchdog timer
clears whenever reset is asserted, WDI is three-stated, or WDI sees a rising or
falling edge.
Active-Low Reset Output pulses low for 160ms when triggered, and stays low
whenever VCC is below the reset threshold. It remains low for 160ms after VCC
rises above the reset threshold or̅̅̅̅̅
MR goes from low to high. A watchdog timeout
̅̅̅̅̅̅̅ is connected to MR
will not trigger ̅̅̅̅̅̅̅̅̅
RESET unless WDO
Watchdog Output pulls low when the internal watchdog timer finishes, its 1.6sec
̅̅̅̅̅̅̅ also goes
count and does not go high again until the watchdog is cleared. WDO
low during low-line conditions. Whenever VCC is below the reset threshold, WDO
stays low; WDO does not have a minimum pulse width. As soon as VCC rises above
̅̅̅̅̅̅̅ goes high with no delay.
5 / 17
www.run-ic.com
RS706
8 Specifications
over operating free-air temperature range (unless otherwise noted) (1)(2)
VCC
Supply voltage range
(2)
VI
(2)
(3)
(4)
MAX
UNIT
-0.5
6.0
V
-0.5
6.0
V
-0.5
6.0
V
-0.5
VCC+0.5
V
Vo
Input voltage range
Voltage range applied to any output in the high-impedance or power-off
state(2)
Voltage range applied to any output in the high or low state (2)(3)
IIK
Input clamp current
VI
很抱歉,暂时无法提供与“RS706-2.93YK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.51704
- 50+1.07251
- 150+0.88200
- 国内价格
- 5+1.67184
- 50+1.18196
- 150+0.97200
