DC/DC Converter
VRB_S-10WR3 Series
FEATURES
10W isolated DC-DC converter in SIP package
Wide input and regulated single output
Wide 2:1 input voltage range
High efficiency up to 88%
I/O isolation test voltage 1.5k VDC
Input under-voltage protection, output short-circuit,
over-current protection
Operating ambient temperature range: -40℃ to
+85℃
Patent Protection
Compact SIP package
Industry standard pin-out
RoHS
EN62368-1
BS EN62368-1
VRB_S-10WR3 series are isolated 10W DC-DC converter products with 2:1 input voltage range. They feature efficiencies of up to 88%,
1500VDC input to output isolation, operating ambient temperature of -40℃ to +85℃, input under-voltage protection, output short-circuit,
over-current protection and they are widely used in applications such as medical care, industrial control, electric power, instruments,
communications and other industries.
Selection Guide
Input Voltage (VDC)
Voltage(VDC)
Current (mA)
Max./Min.
Full Load
②
Efficiency
(%) Min./Typ.
Capacitive
Load
(µF)Max.
VRB1203S-10WR3
3.3
2400/0
80/82
2200
VRB1205S-10WR3
5
2000/0
83/85
2200
VRB1209S-10WR3
9
1111/0
84/86
680
12
833/0
84/86
470
15
667/0
84/86
330
Certification
Part No.
Nominal
(Range)
VRB1212S-10WR3
Max.
12
(9-18)
①
Output
VRB1215S-10WR3
EN/BS EN
VRB1224S-10WR3
24
417/0
84/86
220
VRB2403S-10WR3
3.3
2400/0
82/84
2200
VRB2405S-10WR3
5
2000/0
85/87
2200
VRB2409S-10WR3
9
1111/0
86/88
680
12
833/0
86/88
470
VRB2415S-10WR3
15
667/0
86/88
330
VRB2424S-10WR3
24
417/0
85/87
220
VRB2412S-10WR3
24
(18-36)
40
Notes:
①Exceeding the maximum input voltage may cause permanent damage;
②Efficiency is measured at nominal input voltage and rated output load.
Input Specifications
Item
Operating Conditions
Min.
Typ.
Max.
3.3V output
795/35
815/50
5V output
969/35
992/50
Others
969/9
992/18
3.3V output
389/25
398/45
5V output
474/25
485/45
Others
474/9
485/18
50
12VDC nominal input voltage
-0.7
25
24VDC nominal input voltage
-0.7
50
9
18
12VDC nominal input series,
Input Current (full load / no-load)
24VDC nominal input series,
Reflected Ripple Current
Surge Voltage (1sec. max.)
Start-up Voltage
2022.05.17-A/6
Unit
mA
VDC
Page 1 of 5
MORNSUN Guangzhou Science & Technology Co., Ltd. reserves the copyright and right of final interpretation
DC/DC Converter
VRB_S-10WR3 Series
Input Under-voltage Protection
5.5
6.5
24VDC nominai input voltage
12
15.5
Input Filter
Capacitance filter
Hot Plug
Unavailable
Module on
Ctrl pin open or pulled high (3.5-12VDC)
Module off
Ctrl *
Ctrl pin pulled low to GND (0-1.2VDC)
Input current when off
6
10
mA
Unit
Note: *The Ctrl pin voltage is referenced to input GND.
Output Specifications
Item
Min.
Typ.
Max.
Voltage Accuracy
5%-100% load
±1.5
±2
Linear Regulation
Input voltage variation from low to high at full load
±0.25
±0.5
Load Regulation
5%-100% load
±0.5
±1
300
500
3.3V/ 5V output
±5
±8
Others
±3
±5
①
②
Transient Recovery Time
Transient Response Deviation
25% load step change
µs
Temperature Coefficient
Full load
±0.03
Ripple & Noise
20MHz bandwidth, 5%-100% load
75
150
mV p-p
160
230
%Io
③
Over-current Protection
Short-circuit Protection
110
Input voltage range
Continuous, self-recovery
Note: ① Under 0%-5% load conditions, the maximum output voltage accuracy is ±3%;
② Load regulation for 0%-100% load is ±3%;
③ Under 0% -5% load conditions, ripple & noise does not exceed 300mV, please refer to Fig.2 for testing method.
General Specification
Item
Min.
Typ.
Max.
Unit
Isolation
Input-output electric strength test for 1 minute
with a leakage current of 1mA max.
1500
VDC
Insulation Resistance
Input-output resistance at 500VDC
1000
MΩ
Isolation Capacitance
Input-output capacitance at 100kHz/0.1V
1000
pF
Operating Temperature
See Fig. 1
-40
+85
Storage Humidity
Non-condensing
%RH
Storage Temperature
Pin Soldering Resistance
Temperature
Soldering spot is 1.5mm away from case for 10
seconds
Vibration
5
95
-55
+125
+300
10-150Hz, 5G, 0.75mm. along X, Y and Z
Switching Frequency *
PWM mode
MTBF
MIL-HDBK-217F@25℃
500
kHz
1000
k hours
Note: *Switching frequency is measured at full load. The module reduces the switching frequency for light load (below 50%) efficiency improvement.
Mechanical Specifications
Case Material
Black plastic, flame-retardant and heat-resistant (UL94 V-0)
Dimension
22.00 x 9.50 x 12.00 mm
Weight
5.5g (Typ.)
Cooling Method
Free air convection (20LFM)
Electromagnetic Compatibility (EMC)
Emissions
CE
CISPR32/EN55032
CLASS B (see Fig.4-② for recommended circuit)
RE
CISPR32/EN55032
2022.05.17-A/6
Page 2 of 5
DC/DC Converter
VRB_S-10WR3 Series
Immunity
ESD
IEC/EN61000-4-2
Contact ±6kV
perf. Criteria B
RS
IEC/EN61000-4-3
10V/m
perf. Criteria A
EFT
IEC/EN61000-4-4
±2kV (see Fig.4-① for recommended circuit)
perf. Criteria B
Surge
IEC/EN61000-4-5
line to line ±2kV (see Fig.4-① for recommended circuit)
perf. Criteria B
CS
IEC/EN61000-4-6
3 Vr.m.s
perf. Criteria A
Typical Characteristic Curves
Safe Operating Area
Fig. 1
12
Output Current Percentage(%)
Design Reference
1. Ripple & Noise
All the DC/DC converters of this series are tested before delivery using the recommended circuit shown in Fig. 2. Please keep the wire of
probe to copper as short as possible.
Fig. 2
2022.05.17-A/6
Page 3 of 5
DC/DC Converter
VRB_S-10WR3 Series
2. Typical application
Input and/or output ripple can be further reduced by appropriately increasing the input & output capacitor values Cin and Cout and/or by
selecting capacitors with a low ESR (equivalent series resistance). Also make sure that the capacitance is not exceeding the specified max.
capacitive load value of the product.
Cin
Vin: 12VDC
Vin: 24VDC
47µF/50V
47µF/100V
Vout(VDC)
Cout
3.3/5/9
22µF/16V
12/15
22µF/25V
24
22µF/50V
Fig. 3
3. EMC solution-recommended circuit
Parameter description:
Model
FUSE
C0/C4
C1/C2
Fig. 4
Notes: We use Part ① in Fig. 3 for Immunity test and part ② for Emissions test.
Selecting based on needs.
Vin: 12VDC
Vin: 24VDC
Choose according to actual input current
330µF/35V
330µF/50V
10µF/50V
C3
Refer to the Cout in Fig2
LCM1
470µH, recommended to use
MORNSUN’s FL2D-13-471R3
CY1/CY2
1nF/2000VDC
4. The products do not support parallel connection of their output
5. For additional information please refer to DC-DC converter application notes on
www.mornsun-power.com
Dimensions and Recommended Layout
2022.05.17-A/6
Page 4 of 5
DC/DC Converter
VRB_S-10WR3 Series
Note:
1. For additional information on Product Packaging please refer to www.mornsun-power.com. Packaging bag number: 58210004;
2. The maximum capacitive load offered were tested at input voltage range and full load;
3. Unless otherwise specified, parameters in this datasheet were measured under the conditions of Ta=25℃, humidity
很抱歉,暂时无法提供与“VRB2424S-10WR3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+36.38800
- 22+35.31000
- 国内价格
- 1+38.47500
- 10+37.05000
- 100+33.63000
- 500+31.92000
- 国内价格
- 1+46.30392
- 10+40.26348
- 22+36.58230
- 110+33.50700
