OT8EL89CJI-111YLC-25M 数据手册
Suply
CRYSTAL OSCILLATOR
YSO110TR
Wide Voltage
Applications
Features
‧Consumer Electronics
Industrial Control
IOT
‧Frequency range:1MHz-54MHz
‧Ultra Small SMD seam sealed
‧Package Size: 1.6*1.2 , 2.0*1.6
2.5*2.0 , 3.2*2.5 , 5.0*3.2 , 7.0*5.0mm
crystal oscillator units.
Specifications
Frequency Range
1MHz to 54MHz,or specify
Supply Voltage
1.8V~3.3V
Output Type
CMOS
Frequency Tolerance(at 25℃)
±10ppm,±20ppm,or specify
Output Load
15pF
Operating Temperature Range
-40~+85℃,-40~+125℃,or specify
Storage Temperature Range
-55~+125℃
Frequency Versus Temperature Characteristics
± 20ppm, ± 30ppm, ± 50ppm, or specify
Voltage Vol ( Max. ) / Vol ( Min. )
VOH = 90%Vdd/VOL = 10%Vdd
Duty Cycle
45~55%
Start-up Time
3ms Max.
Rise Time/Fall Time
4nS Max
Supply Current
See Below
Frequency Aging (at 25℃)
±3 ppm / year Max.
Current Consumption
Power Dissipation Vcc=1.8~3.3V 15pF only
1.000~40.000MHZ
Supply Voltage (V)
7050/5032/3225
1.8V
4mA max
2.5V
3.3V
4.5mA max
5mA max
2520/2016/1612
4mA max
Pin Dimension
41.000~54.000MHZ
7050/5032/3225/2520
9mA max
10mA max
12mA max
2016/1612
10mA max
Pin Assignments
Pin
#1
#2
#3
#4
FUNCTION
Tri-state
GND
OUTPUT
VDD
www.yxc.hk
第1页共4页
CRYSTAL OSCILLATOR
YSO110TR
Wide Voltage
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
Recommended Land Pattern (Unit: mm)
1.6*1.2mm
#2
#4
0.80max
#1
Bottom
View
0.775 0.5 0.775
#2
1.25±0.1
MARKING
#1
#3
0.6 0.2 0.6
#3
0.395 0.3 0.395
1.65±0.1
#4
0.08
0.495 0.5
#3
#4
#2
0.1
0.775 0.5 0.775
#3
#2
0.9 0.95 0.9
#4
#2
#3
0.95
0.8±0.1
0.8 0.65 0.8
MARKING
#1
#1
0.65
#4
0.68
2.5±0.1
2.0±0.1
2.5*2.0mm
#2
#3
0.57±0.1 0.7±0.1
0.80max
#1
Bottom
View
1.65±0.1
MARKING
#1
0.675 0.3 0.675
2.05±0.1
#4
0.475±0.1 0.5±0.1 0.475±0.1
2.0*1.6mm
0.78
0.4
3.2*2.5mm
3.2±0.1
1.1 0.8 1.1
1.0
4
2
3
Bottom View
1.0±0.1
Top View
1.3
2
1
2.5±0.1
MARKING
1
1.3 1.0
1.2
3
4
Side View
www.yxc.hk
第2页共4页
CRYSTAL OSCILLATOR
YSO110TR
Wide Voltage
5.0*3.2mm
#2
#1
1.0
MARKING
2.2
3.2±0.1
1.2
#3
#4
#2
#4
#3
1.2
1.2±0.1
#1
1.4
2.54±0.1
5.0±0.2
2.54
7.0*5.0mm
7.00±0.15
#2
2.6±0.1
5.08±0.15
2.0
#4
#3
3.28
1.4±0.1
MARKING
#1
#2
5.0±0.1
#3
1.4±0.15
0.6±0.15
2.2
#4
#1
1.8
Notes:
1.A capacitor of value 0.01uf~0.1uf or higher between Vdd and GND is required.
Reflow Soldering Profile
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
Temperature
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability Terminal.
In case of Resistance to soldering heat Surface.
Tp2
Tp1
35s
100s
t(time)
www.yxc.hk
第3页共4页
CRYSTAL OSCILLATOR
YSO110TR
Wide Voltage
Test Circuit
Taping Specification(Unit: mm)
Size(OSC)
A
B
C
D
E
F
G
H
SMD-7050
180±2.0
16.0±0.3
7.50±0.1
5.50±0.1
8.0±0.1
2.00±0.1
61.0±1.0
16.0±1.0
SMD-5032
180±2.0
12.0±0.3
5.40±0.1
3.60±0.1
8.0±0.1
1.70±0.1
61.0±1.0
12.0±1.0
SMD-3225
180±2.0
8.0±0.3
3.40±0.1
2.70±0.1
4.0±0.1
1.50±0.1
61.0±1.0
8.0±1.0
SMD-2520
180±2.0
8.0±0.3
2.90±0.1
2.40±0.1
4.0±0.1
1.20±0.1
61.0±1.0
8.0±1.0
SMD-2016
180±2.0
8.0±0.3
2.30±0.1
1.90±0.1
4.0±0.1
0.95±0.1
61.0±1.0
8.0±1.0
SMD-1612
180±2.0
8.0±0.3
1.80±0.1
1.40±0.1
4.0±0.1
0.80±0.1
61.0±1.0
8.0±1.0
www.yxc.hk
第4页共4页
OT8EL89CJI-111YLC-25M 价格&库存
很抱歉,暂时无法提供与“OT8EL89CJI-111YLC-25M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.99840
- 10+5.73351
- 30+5.09069
- 100+4.46861
- 500+4.02279
- 1000+3.82580
