ANR3015T220M
ANR3015T220M
    APV(爱普微)
    SMD,3x3mm
    22UH ±20% 0.68A 3X3X1.5MM
ANR3015T220M 数据手册
Wire Wound SMD Power Inductors - ANR Series ▉ FEATURES ● Various high power inductors are superior to be high saturation. ● Suitable for surface mounting equipment . ● Takes up less PCB real estate and save more power. ● Operating Temperature: -40℃~+125℃ . ● Magnetic-resin shielded construction reduces buzz noise to ultra-low levels . ● Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference . ● Packing:Tape Carrier Package. ▉ APPLICATIONS ● Smart phone, smart TV,set top box, notebook. ● Car navigation systems, telecomm basestations. ● RoHS, REACH Compliance. ● VR, AR. ● LED lighting. ▉ PART NUMBERING A NR 252012 T 4R7 M □□ ① Grade ② Series Name ③ Dimensions Code ④ Feature Type ⑤ Nominal inductance ⑥ Inductance tolerance ⑦ Design Code ①Grade A Grade Code ② Series Name NR Wire Wound Power Inductor ④Feature Type T Standard ⑤Nominal inductance Code Nominal inductance[μH] (example) 4R7 4.7 100 10 101 100 ⑦Design Code Standard □□ product is blank ⑥Inductance tolerance Code (example) Inductance tolerance K M N ±10% ±20% ±30% Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM ③Dimensions Code Dimensions Code (L×W×H)[mm] 252010 2.5×2.0×1.0 252012 2.5×2.0×1.2 3010 3.0×3.0×1.0 3012 3.0×3.0×1.2 3015 3.0×3.0×1.5 4010 4.0×4.0×1.0 4012 4.0×4.0×1.2 4018 4.0×4.0×1.8 4020 4.0×4.0×2.0 4026 4.0×4.0×2.6 4030 4.0×4.0×3.0 5012 5.0×5.0×1.2 5020 5.0×5.0×2.0 5040 5.0×5.0×4.0 5045 5.0×5.0×4.5 6020 6.0×6.0×2.0 6028 6.0×6.0×2.8 6045 6.0×6.0×4.5 8040 8.0×8.0×4.0 8060 8.0×8.0×6.0 8065 8.0×8.0×6.5 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Dimensions & Recommended Land Pattern Recommended Land Pattern Unit: mm Dimensions Series Recommended Land Pattern A B C D Typ. E Typ. F Typ. a Typ. b Typ. c Typ. ANR252010 2.5±0.2 2.0±0.2 1.0 Max. 2 0.75 1.0 0.8 0.85 2.2 ANR252012 2.5±0.2 2.0±0.2 1.2 Max. 2 0.75 1.0 0.8 0.85 2.2 ANR3010 3.0±0.2 3.0±0.2 1.0 ±0.2 2.5 0.75 1.5 1.5 0.8 2.7 ANR3012 3.0±0.2 3.0±0.2 1.2 Max. 2.5 0.75 1.5 1.5 0.8 2.7 ANR3015 3.0±0.2 3.0±0.2 1.5 Max. 2.5 0.75 1.5 1.5 0.8 2.7 ANR4010 4.0±0.2 4.0±0.2 1.0 ±0.2 3.3 1.1 1.8 1.9 1.1 3.7 ANR4012 4.0±0.2 4.0±0.2 1.2 Max. 3.3 1.1 1.8 1.9 1.1 3.7 ANR4018 4.0±0.2 4.0±0.2 1.8 Max. 3.3 1.1 1.8 1.9 1.1 3.7 ANR4020 4.0±0.2 4.0±0.2 2.0 Max. 3.3 1.1 1.8 1.9 1.1 3.7 ANR4026 4.0±0.2 4.0±0.2 2.6 Max. 3.3 1.1 1.8 1.9 1.1 3.7 ANR4030 4.0±0.2 4.0±0.2 3.0 Max. 3.3 1.1 1.8 1.9 1.1 3.7 ANR5012 5.0±0.2 5.0±0.2 1.2 Max. 4.0 1.4 2.2 2.3 1.4 4.2 ANR5020 5.0±0.2 5.0±0.2 2.0 Max. 4.0 1.4 2.2 2.3 1.4 4.2 ANR5040 5.0±0.2 5.0±0.2 4.0 Max. 4.0 1.4 2.2 2.3 1.4 4.2 ANR5045 5.0±0.2 5.0±0.2 4.5 Max. 4.0 1.4 2.2 2.3 1.4 4.2 ANR6020 6.0±0.3 6.0±0.3 2.0 Max. 4.9 1.7 2.6 2.8 1.7 5.7 ANR6028 6.0±0.3 6.0±0.3 2.8 Max. 4.9 1.7 2.6 2.8 1.7 5.7 ANR6045 6.0±0.3 6.0±0.3 4.5 Max. 4.9 1.7 2.6 2.8 1.7 5.7 ANR8040 8.0±0.3 8.0±0.3 4.2 Max. 6.3 2 4 3.8 2.2 7.5 ANR8065 8.0±0.3 8.0±0.3 6.5 Max. 6.3 2 4 3.8 2.2 7.5 ● All products are printed with Marking except the 252010 & 252012 series. Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR252010 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A L M=±20% N=±30% 0.47 N/M 2.39 2.56 2.54 3.35 ANR252010TR56□ 0.56 N/M 2.03 2.18 2.94 3.20 0.071 ANR252010TR68□ 0.68 N/M 2.03 2.18 2.23 2.75 0.073 ANR252010T1R0□ 1 N/M 1.67 1.80 1.88 2.20 0.107 ANR252010T1R5□ 1.5 N/M 1.32 1.42 1.83 2.10 0.18 ANR252010T2R2□ 2.2 N/M 1.22 1.31 1.22 1.60 0.207 ANR252010T3R3M 3.3 M 0.91 0.98 1.07 1.30 0.325 ANR252010T4R7M 4.7 M 0.71 0.76 0.96 1.15 0.557 ANR252010T5R6M 5.6 M 0.74 0.80 0.81 0.95 0.557 ANR252010T6R8M 6.8 M 0.60 0.64 0.79 0.92 0.887 ANR252010T100M 10 M 0.51 0.55 0.66 0.78 1.081 ANR252010T220M 22 M 0.45 0.50 0.40 0.48 1.625 Symbol ANR252010TR47□ Irms Isat DCR 0.055 ● ANR252012 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR252012TR47□ 0.47 N/M 2.18 2.34 3.88 4.27 0.06 ANR252012TR68□ 0.68 N/M 1.98 2.13 3.33 3.68 0.073 ANR252012T1R0□ 1 N/M 1.96 2.10 2.63 2.90 0.089 ANR252012T1R2□ 1.2 N/M 1.48 1.59 2.42 2.67 0.128 ANR252012T1R5□ 1.5 N/M 1.42 1.53 2.27 2.51 0.146 ANR252012T2R2□ 2.2 N/M 1.17 1.25 1.88 2.07 0.214 ANR252012T2R7M 2.7 M 1.11 1.19 1.75 1.92 0.237 ANR252012T3R3M 3.3 M 1.06 1.13 1.63 1.80 0.261 ANR252012T3R6M 3.6 M 0.91 0.98 1.48 1.64 0.345 ANR252012T4R3M 4.3 M 0.88 0.95 1.39 1.53 0.373 ANR252012T4R7M 4.7 M 0.85 0.92 1.14 1.25 0.373 ANR252012T5R1M 5.1 M 0.76 0.82 1.25 1.37 0.495 ANR252012T5R6M 5.6 M 0.74 0.80 1.13 1.25 0.533 ANR252012T6R2M 6.2 M 0.74 0.80 1.05 1.16 0.537 ANR252012T6R8M 6.8 M 0.70 0.75 0.99 1.09 0.575 ANR252012T7R5M 7.5 M 0.69 0.74 0.98 1.09 0.605 ANR252012T8R2M 8.2 M 0.66 0.71 0.99 1.10 0.651 ANR252012T9R1M 9.1 M 0.63 0.68 0.92 1.02 0.683 ANR252012T100M 10 M 0.63 0.68 0.80 0.88 0.683 ANR252012T120M 12 M 0.52 0.56 0.79 0.88 1.064 ANR252012T150M 15 M 0.43 0.46 0.69 0.77 1.575 ANR252012T220M 22 M 0.39 0.41 0.54 0.59 1.956 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR3010 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR3010T1R0□ 1 N/M 1.47 1.80 ANR3010T1R2□ 1.2 N/M 1.47 ANR3010T1R5□ 1.5 N/M 1.32 ANR3010T2R2□ 2.2 N/M 1.11 ANR3010T2R7□ 2.7 N/M 1.04 ANR3010T3R3□ 3.3 N/M ANR3010T3R6M 3.6 M ANR3010T4R7M 4.7 M 0.78 1.10 0.76 1.05 0.29 ANR3010T5R6M 5.6 M 0.71 1.05 0.59 0.65 0.319 ANR3010T6R8M 6.8 M 0.67 0.96 0.56 0.72 0.393 ANR3010T8R2M 8.2 M 0.59 0.70 0.56 0.70 0.515 ANR3010T100M 10 M 0.59 0.70 0.56 0.75 0.515 ANR3010T120M 12 M 0.53 0.67 0.44 0.65 0.65 ANR3010T150M 15 M 0.48 0.57 0.43 0.57 0.785 ANR3010T220M 22 M 0.39 0.52 0.36 0.48 1.197 ANR3010T270M 27 M 0.36 0.50 0.30 0.45 1.39 ANR3010T330M 33 M 0.30 0.55 0.29 0.42 1.995 ANR3010T390M 39 M 0.28 0.53 0.28 0.38 2.252 ANR3010T430M 43 M 0.27 0.52 0.23 0.36 2.317 ANR3010T470M 47 M 0.26 0.52 0.22 0.35 2.51 ANR3010T510M 51 M 0.25 0.48 0.21 0.33 2.831 ANR3010T560M 56 M 0.24 0.35 0.21 0.28 2.986 Irms Isat DCR 1.42 2.10 0.084 1.80 1.27 1.70 0.084 1.60 1.29 1.70 0.103 1.40 1.17 1.50 0.142 1.40 1.02 1.20 0.167 0.97 1.20 0.98 1.20 0.187 0.91 1.10 0.96 1.20 0.213 ● ANR3012 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH L M=±20% N=±30% ANR3012TR22□ 0.22 N/M ANR3012TR82□ 0.82 ANR3012T1R0□ 1 ANR3012T1R2□ ANR3012T1R5□ ANR3012T1R8□ 1.8 ANR3012T2R2□ 2.2 ANR3012T2R4□ 2.4 N/M ANR3012T2R7M 2.7 M ANR3012T3R3M 3.3 M ANR3012T3R6M 3.6 M Symbol Heat Rating Current Max. Typ. Saturation Current Max. A Ω A Irms Isat DCR 3.05 3.30 5.38 6.00 N/M 2.51 3.00 2.08 2.80 0.039 N/M 2.23 2.70 1.90 2.80 0.052 1.2 N/M 2.04 2.20 2.25 2.50 0.058 1.5 N/M 2.04 2.20 1.64 1.90 0.078 N/M 1.67 1.80 1.32 1.90 0.081 N/M 1.57 1.70 1.22 1.90 0.098 1.62 1.70 1.17 1.50 0.087 1.50 1.50 1.16 1.50 0.109 1.38 1.40 1.07 1.50 0.13 1.38 1.40 1.07 1.50 0.129 Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM Typ. DC Resistance Typ. 0.022 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR3012 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH L M=±20% N=±30% ANR3012T3R9M 3.9 M ANR3012T4R7M 4.7 ANR3012T6R8M 6.8 ANR3012T100M ANR3012T120M Symbol Heat Rating Current Max. Typ. Saturation Current Max. A Typ. Ω A Irms Isat 1.02 DC Resistance Typ. DCR 1.26 1.30 1.30 0.187 M 1.26 1.30 0.91 1.00 0.156 M 0.99 1.10 0.76 0.90 0.247 10 M 0.84 0.90 0.61 0.88 0.345 12 M 0.74 0.84 0.49 0.67 0.445 ANR3012T150M 15 M 0.72 0.77 0.46 0.62 0.468 ANR3012T180M 18 M 0.59 0.65 0.44 0.59 0.702 ANR3012T220M 22 M 0.54 0.59 0.43 0.52 0.839 ANR3012T270M 27 M 0.48 0.51 0.36 0.48 1.12 ANR3012T330M 33 M 0.47 0.50 0.37 0.46 1.138 ANR3012T360M 36 M 0.45 0.48 0.35 0.44 1.223 ANR3012T390M 39 M 0.38 0.41 0.30 0.39 1.712 ANR3012T470M 47 M 0.36 0.40 0.27 0.35 1.885 ANR3012T560M 56 M 0.28 0.40 0.26 0.33 1.776 ANR3012T680M 68 M 0.33 0.37 0.24 0.29 2.149 ANR3012T820M 82 M 0.27 0.31 0.17 0.27 3.269 ANR3012T101M 100 M 0.25 0.29 0.21 0.23 3.681 ● ANR3015 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR3015TR50□ 0.5 N/M 2.64 2.80 3.96 4.20 0.039 ANR3015T1R0□ 1 N/M 2.39 2.50 2.35 2.80 0.039 ANR3015T1R2□ 1.2 N/M 1.98 2.30 2.24 3.10 0.051 ANR3015T1R5□ 1.5 N/M 1.73 2.20 2.33 2.70 0.065 ANR3015T1R8□ 1.8 N/M 1.73 2.20 1.78 2.20 0.065 ANR3015T2R2□ 2.2 N/M 1.62 2.00 1.62 2.00 0.078 ANR3015T2R7□ 2.7 N/M 1.45 1.90 1.54 1.90 0.097 ANR3015T3R3M 3.3 M 1.38 1.60 1.34 1.81 0.104 ANR3015T3R6M 3.6 M 1.22 1.50 1.30 1.60 0.136 ANR3015T3R9M 3.9 M 1.22 1.50 1.22 1.40 0.136 ANR3015T4R3M 4.3 M 1.16 1.30 1.22 1.40 0.149 ANR3015T4R7M 4.7 M 1.11 1.30 1.12 1.40 0.163 ANR3015T5R1M 5.1 M 1.07 1.20 1.02 1.20 0.171 ANR3015T5R6M 5.6 M 0.87 1.05 1.02 1.15 0.245 ANR3015T6R2M 6.2 M 0.87 1.00 1.02 1.20 0.251 ANR3015T6R8M 6.8 M 0.86 1.10 0.86 1.10 0.26 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR3015 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR3015T100M 10 M 0.78 0.90 ANR3015T120M 12 M 0.69 0.89 0.71 0.90 0.412 ANR3015T150M 15 M 0.66 0.72 0.67 0.88 0.455 ANR3015T180M 18 M 0.60 0.72 0.57 0.72 0.553 ANR3015T220M 22 M 0.58 0.69 0.53 0.68 0.598 ANR3015T270M 27 M 0.46 0.56 0.49 0.56 0.94 ANR3015T330M 33 M 0.44 0.51 0.45 0.53 1.066 ANR3015T390M 39 M 0.40 0.44 0.42 0.55 1.281 ANR3015T430M 43 M 0.38 0.48 0.38 0.43 1.364 ANR3015T470M 47 M 0.36 0.44 0.36 0.43 1.625 ANR3015T560M 56 M 0.35 0.41 0.33 0.42 1.664 ANR3015T620M 62 M 0.30 0.41 0.30 0.40 2.072 ANR3015T680M 68 M 0.23 0.31 0.28 0.37 3.475 ANR3015T101M 100 M 0.21 0.25 0.23 0.25 4.003 ANR3015T151M 150 M 0.19 0.23 0.18 0.22 4.891 ANR3015T221M 220 M 0.35 0.40 0.16 0.20 5.81 Irms Isat 0.73 DCR 0.92 0.325 ● ANR4010 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Symbol L M=±20% N=±30% ANR4010T1R0□ 1 N/M ANR4010T1R5□ 1.5 ANR4010T2R2M 2.2 ANR4010T3R3M ANR4010T4R7M Heat Rating Current Max. Typ. Saturation Current Max. A Typ. Ω A Irms DC Resistance Typ. Isat DCR 1.93 2.40 2.03 2.30 0.066 N/M 1.73 M 1.52 2.00 1.71 2.00 0.083 2.00 1.22 1.50 0.101 3.3 M 1.42 4.7 M 1.22 1.80 1.12 1.40 0.119 1.50 0.96 1.10 0.166 ANR4010T6R8M 6.8 M 1.02 ANR4010T100M 10 M 0.76 1.20 0.81 0.95 0.238 1.00 0.63 0.75 0.356 ANR4010T150M 15 M 0.61 0.85 0.55 0.61 0.511 ANR4010T220M 22 M 0.51 0.75 0.46 0.52 0.677 Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR4012 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A L M=±20% N=±30% 0.82 N/M ANR4012T1R0□ 1 ANR4012T1R5□ 1.5 ANR4012T1R8□ ANR4012T2R2□ ANR4012T2R7□ ANR4012T3R3□ ANR4012T3R6□ 3.6 N/M 1.14 ANR4012T4R3□ 4.3 N/M 1.02 ANR4012T4R7□ 4.7 N/M 1.07 ANR4012T5R1□ 5.1 N/M 0.96 ANR4012T5R6□ 5.6 N/M 1.02 1.20 1.02 1.60 0.182 ANR4012T6R8M 6.8 M 0.85 1.20 0.86 1.40 0.257 ANR4012T100M 10 M 0.78 1.00 0.81 1.10 0.345 ANR4012T120M 12 M 0.71 0.95 0.67 1.00 0.373 ANR4012T150M 15 M 0.65 0.85 0.57 0.80 0.442 ANR4012T180M 18 M 0.56 0.80 0.56 0.75 0.605 ANR4012T220M 22 M 0.50 0.75 0.47 0.70 0.763 ANR4012T270M 27 M 0.46 0.60 0.51 0.70 0.927 ANR4012T330M 33 M 0.43 0.58 0.43 0.60 1.053 ANR4012T360M 36 M 0.41 0.56 0.41 0.50 1.158 ANR4012T390M 39 M 0.38 0.50 0.56 0.66 1.416 ANR4012T470M 47 M 0.38 0.50 0.36 0.50 1.43 ANR4012T560M 56 M 0.33 0.46 0.33 0.45 1.609 ANR4012T680M 68 M 0.27 0.45 0.39 0.45 2.51 ANR4012T820M 82 M 0.26 0.36 0.28 0.40 2.754 ANR4012T101M 100 M 0.25 0.35 0.25 0.30 2.844 Symbol ANR4012TR82□ Irms Isat DCR 1.67 2.50 3.07 3.30 0.064 N/M 1.67 2.50 2.65 3.20 0.065 N/M 1.48 2.20 2.13 2.70 0.085 1.8 N/M 1.34 1.90 2.15 2.60 0.104 2.2 N/M 1.34 1.90 1.79 2.30 0.104 2.7 N/M 1.27 1.70 1.93 2.30 0.116 3.3 N/M 1.14 1.60 1.75 2.10 0.143 1.60 1.22 1.70 0.142 1.50 1.60 1.70 0.18 1.50 1.17 1.80 0.163 1.50 1.57 1.60 0.199 ● ANR4018 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR4018TR47□ 0.47 N/M 4.06 4.50 4.36 5.20 0.018 ANR4018TR68□ 0.68 N/M 3.35 3.80 4.97 5.60 0.026 ANR4018T1R0□ 1 N/M 2.03 3.30 4.87 5.20 0.033 ANR4018T1R5□ 1.5 N/M 1.83 3.20 3.40 4.00 0.042 ANR4018T1R8□ 1.8 N/M 2.03 2.80 3.05 3.40 0.044 ANR4018T2R2□ 2.2 N/M 1.67 2.60 2.74 3.20 0.058 ANR4018T3R3M 3.3 M 1.25 2.10 2.49 2.90 0.09 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR4018 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A L M=±20% N=±30% ANR4018T4R7M 4.7 M ANR4018T6R8M 6.8 ANR4018T100M 10 ANR4018T150M 15 M ANR4018T220M 22 M ANR4018T330M 33 M 0.50 ANR4018T470M 47 M 0.43 ANR4018T680M 68 M 0.32 0.52 0.48 0.51 1.287 ANR4018T101M 100 M 0.25 0.41 0.41 0.44 2.252 ANR4018T151M 150 M 0.22 0.36 0.31 0.34 3.218 ANR4018T221M 220 M 0.17 0.27 0.27 0.30 5.148 Symbol Irms Isat DCR 1.22 1.80 1.73 2.20 0.116 M 1.08 1.50 1.47 2.00 0.142 M 0.85 1.20 1.32 1.60 0.232 0.66 1.00 0.95 1.10 0.322 0.60 0.85 0.81 0.88 0.463 0.72 0.57 0.75 0.682 0.65 0.58 0.70 0.837 ● ANR4020 Series Part Number Units Symbol Inductance Tolerance @100kHz,1V Inductance μH L Heat Rating Current Max. M=±20% N=±30% Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR ANR4020TR24□ 0.24 N/M 4.57 5.20 10.66 12.50 0.014 ANR4020TR33□ 0.33 N/M 3.35 4.90 7.61 8.50 0.016 ANR4020TR47□ 0.47 N/M 3.35 3.70 7.11 7.50 0.029 ANR4020TR68□ 0.68 N/M 2.84 3.30 6.50 6.60 0.036 ANR4020T1R0□ 1 N/M 2.18 3.20 4.85 5.20 0.038 ANR4020T1R2□ 1.2 N/M 2.18 3.20 5.18 5.60 0.038 ANR4020T1R5□ 1.5 N/M 2.01 3.00 4.52 4.90 0.046 ANR4020T2R2□ 2.2 N/M 1.88 2.80 3.45 3.70 0.051 ANR4020T3R3□ 3.3 N/M 1.42 2.50 3.25 3.50 0.09 ANR4020T3R6□ 3.6 N/M 1.56 2.50 2.84 3.00 0.091 ANR4020T4R7□ 4.7 N/M 1.36 2.00 2.39 2.50 0.097 ANR4020T5R1M 5.1 M 1.29 1.80 2.33 2.50 0.11 ANR4020T5R6M 5.6 M 1.24 1.80 2.23 2.40 0.116 ANR4020T6R2M 6.2 M 1.10 1.60 2.18 2.30 0.149 ANR4020T6R8M 6.8 M 1.06 1.60 2.23 2.40 0.161 ANR4020T7R5M 7.5 M 1.10 1.50 1.88 2.00 0.149 ANR4020T8R2M 8.2 M 1.06 1.40 1.78 1.90 0.181 ANR4020T100M 10 M 0.91 1.20 1.62 1.70 0.213 ANR4020T120M 12 M 0.89 1.20 1.52 1.60 0.226 ANR4020T150M 15 M 0.78 1.10 1.37 1.50 0.296 ANR4020T220M 22 M 0.63 0.87 1.07 1.10 0.45 ANR4020T270M 27 M 0.51 0.70 1.04 1.10 0.702 ANR4020T330M 33 M 0.50 0.68 0.86 0.93 0.708 Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR4020 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR4020T390M 39 M 0.47 0.64 0.83 0.90 0.837 ANR4020T430M 43 M 0.46 0.63 0.78 0.85 0.849 ANR4020T470M 47 M 0.45 0.61 0.75 0.81 0.914 ANR4020T510M 51 M 0.43 0.59 0.71 0.77 0.965 ANR4020T560M 56 M 0.42 0.57 0.67 0.72 1.03 ANR4020T620M 62 M 0.40 0.52 0.66 0.71 1.158 ANR4020T680M 68 M 0.37 0.50 0.62 0.67 1.366 ANR4020T750M 75 M 0.36 0.49 0.71 0.77 1.495 ANR4020T820M 82 M 0.35 0.47 0.51 0.55 1.505 ANR4020T101M 100 M 0.31 0.43 0.49 0.53 2 Irms Isat DCR ● ANR4026 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR4026T1R0□ 1 N/M 3.05 3.66 ANR4026T1R2□ 1.2 N/M 2.33 ANR4026T1R5□ 1.5 N/M 2.33 ANR4026T2R2M 2.2 M 2.03 2.44 2.13 2.36 0.051 ANR4026T3R3M 3.3 M 1.73 2.08 1.83 2.03 0.064 ANR4026T4R7M 4.7 M 1.62 1.94 1.47 1.63 0.071 ANR4026T6R8M 6.8 M 1.52 1.82 1.32 1.47 0.084 ANR4026T100M 10 M 1.32 1.58 1.02 1.13 0.109 ANR4026T150M 15 M 1.12 1.34 0.91 1.01 0.142 ANR4026T220M 22 M 0.91 1.09 0.61 0.68 0.212 ANR4026T330M 33 M 0.71 0.85 0.56 0.62 0.347 ANR4026T470M 47 M 0.66 0.79 0.41 0.46 0.386 Irms Isat DCR 3.35 3.72 0.031 2.80 3.15 3.50 0.039 2.80 2.44 2.71 0.039 ● ANR4030 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Max. A L M=±20% N=±30% ANR4030TR47□ 0.47 M 5.20 ANR4030TR68□ 0.68 N/M 4.63 ANR4030TR91□ 0.91 N/M 4.21 ANR4030T1R0□ 1 N/M 4.21 ANR4030T1R2□ 1.2 N/M 3.88 Symbol Typ. Saturation Current Ω A Irms Isat 5.90 DCR 7.80 9.80 0.015 5.10 6.90 8.00 0.018 4.70 6.34 6.80 0.017 4.70 5.34 5.70 0.018 4.20 5.89 6.30 0.02 Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM Typ. DC Resistance Typ. 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR4030 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR4030T1R5□ 1.5 N/M 3.39 3.60 4.91 5.30 0.026 ANR4030T1R8□ 1.8 N/M 3.25 3.30 4.57 5.00 0.033 ANR4030T2R2□ 2.2 N/M 2.99 3.20 4.97 5.80 0.039 ANR4030T3R3M 3.3 M 2.44 2.60 3.35 3.60 0.051 ANR4030T3R9M 3.9 M 2.13 2.30 3.05 3.30 0.073 ANR4030T4R3M 4.3 M 2.13 2.30 2.99 3.20 0.071 ANR4030T4R7M 4.7 M 2.03 2.30 2.94 3.20 0.077 ANR4030T5R6M 5.6 M 1.98 2.10 2.64 2.80 0.084 ANR4030T6R8M 6.8 M 1.62 1.70 2.79 3.00 0.116 ANR4030T7R5M 7.5 M 1.67 1.80 2.23 2.40 0.11 ANR4030T8R2M 8.2 M 1.62 1.70 2.13 2.30 0.116 ANR4030T100M 10 M 1.52 1.60 1.98 2.40 0.129 ANR4030T120M 12 M 1.32 1.40 1.73 1.80 0.174 ANR4030T150M 15 M 1.13 1.20 1.67 1.80 0.245 ANR4030T180M 18 M 1.12 1.20 1.42 1.50 0.257 ANR4030T220M 22 M 1.02 1.20 1.32 1.40 0.29 ANR4030T330M 33 M 0.85 0.92 1.12 1.20 0.425 ANR4030T360M 36 M 0.84 0.91 1.07 1.10 0.432 ANR4030T390M 39 M 0.74 0.80 1.05 1.10 0.56 ANR4030T470M 47 M 0.73 0.80 0.96 1.00 0.573 ANR4030T510M 51 M 0.71 0.80 0.91 1.13 0.605 ANR4030T560M 56 M 0.66 0.71 0.86 0.94 0.715 ANR4030T620M 62 M 0.64 0.70 0.81 0.99 0.752 ANR4030T680M 68 M 0.53 0.57 0.73 0.80 1.117 ANR4030T750M 75 M 0.49 0.53 0.71 0.88 1.313 ANR4030T820M 82 M 0.48 0.52 0.67 0.72 1.364 ANR4030T910M 91 M 0.47 0.50 0.66 0.71 1.416 ANR4030T101M 100 M 0.46 0.49 0.61 0.73 1.48 ANR4030T121M 120 M 0.43 0.46 0.56 0.60 1.737 ANR4030T151M 150 M 0.30 0.35 0.51 0.55 2.317 ANR4030T221M 220 M 0.35 0.40 0.40 0.50 3.25 ANR4030T331M 330 M 0.25 0.26 0.30 0.40 5.2 ANR4030T471□ 470 K/M 0.20 0.23 0.30 0.35 9.36 ANR4030T501M 500 M 0.15 0.20 0.28 0.30 8.937 ANR4030T681M 680 M 0.14 0.18 0.19 0.20 9.755 Irms Isat Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM DCR 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR5012 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR5012T1R0□ 1 N/M 2.03 ANR5012T1R5□ 1.5 N/M ANR5012T2R2□ 2.2 N/M ANR5012T3R3□ 3.3 N/M ANR5012T4R7□ 4.7 N/M ANR5012T6R8M 6.8 M 1.02 1.20 1.73 1.90 0.291 ANR5012T100M 10 M 0.86 1.00 1.42 1.50 0.409 ANR5012T150M 15 M 0.81 0.92 1.22 1.30 0.518 ANR5012T220M 22 M 0.61 0.68 0.89 0.98 0.849 Irms Isat DCR 2.40 4.47 4.70 0.067 1.93 2.20 3.76 3.80 0.085 1.73 2.00 3.15 3.20 0.107 1.42 1.70 2.44 2.60 0.149 1.32 1.50 2.23 2.30 0.195 ● ANR5020 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR5020TR22□ 0.22 N/M 5.38 6.00 9.14 12.00 0.011 ANR5020TR24□ 0.24 N/M 5.38 6.00 8.12 10.00 0.011 ANR5020TR47□ 0.47 N/M 4.67 5.00 6.24 6.70 0.017 ANR5020TR56□ 0.56 N/M 3.86 4.20 8.63 9.60 0.022 ANR5020TR68□ 0.68 N/M 4.06 4.40 5.58 6.00 0.022 ANR5020TR75□ 0.75 N/M 4.06 4.40 5.58 6.00 0.022 ANR5020T1R0□ 1 N/M 3.86 4.10 4.16 5.00 0.026 ANR5020T1R2□ 1.2 N/M 3.60 3.90 4.57 4.90 0.033 ANR5020T1R5□ 1.5 N/M 3.25 3.50 4.16 4.50 0.034 ANR5020T2R2□ 2.2 N/M 2.94 3.10 3.25 4.00 0.042 ANR5020T2R7□ 2.7 N/M 2.74 2.90 2.94 3.50 0.049 ANR5020T3R0□ 3 N/M 2.74 2.90 2.59 2.80 0.049 ANR5020T3R3□ 3.3 N/M 2.54 2.70 2.59 3.00 0.056 ANR5020T3R6□ 3.6 N/M 2.54 2.70 2.84 3.00 0.055 ANR5020T3R9□ 3.9 N/M 2.54 2.70 2.33 2.80 0.071 ANR5020T4R3M 4.3 M 2.23 2.40 2.54 3.00 0.073 ANR5020T4R7M 4.7 M 2.23 2.40 2.54 2.70 0.074 ANR5020T5R1M 5.1 M 2.08 2.20 2.28 2.60 0.082 ANR5020T5R6M 5.6 M 2.08 2.20 2.33 2.50 0.083 ANR5020T6R8M 6.8 M 1.83 1.90 2.08 2.20 0.107 ANR5020T7R5M 7.5 M 1.78 1.90 1.88 2.00 0.116 ANR5020T8R2M 8.2 M 1.67 1.80 1.88 2.00 0.126 ANR5020T9R1M 9.1 M 1.57 1.70 1.73 1.80 0.142 ANR5020T100M 10 M 1.57 1.70 1.73 1.80 0.142 ANR5020T120M 12 M 1.42 1.50 1.52 1.60 0.18 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR5020 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR5020T150M 15 M ANR5020T180M 18 ANR5020T220M 22 ANR5020T330M 33 M ANR5020T470M 47 M ANR5020T560M 56 M ANR5020T680M 68 M ANR5020T820M 82 M 0.51 0.60 ANR5020T101M 100 M 0.54 0.58 ANR5020T121M 120 M 0.41 0.50 0.43 0.53 1.737 ANR5020T201M 200 M 0.41 0.45 0.30 0.33 2.574 ANR5020T561M 560 M 0.20 0.30 0.24 0.30 9.06 Irms Isat DCR 1.27 1.30 1.37 1.40 0.215 M 1.17 1.20 1.27 1.30 0.257 M 1.12 1.20 1.17 1.20 0.294 0.91 0.99 0.93 1.00 0.507 0.78 0.84 0.78 0.84 0.68 0.71 0.77 0.78 0.84 0.957 0.65 0.70 0.66 0.70 0.962 0.66 0.75 1.146 0.54 0.58 1.43 ● ANR5040 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR5040TR22□ 0.22 N/M 6.60 7.50 18.27 20.00 0.008 ANR5040TR24□ 0.24 N/M 6.50 7.40 15.94 18.00 0.008 ANR5040TR47□ 0.47 N/M 6.70 7.60 10.15 11.50 0.013 ANR5040T1R0□ 1 N/M 4.97 5.10 7.46 8.20 0.018 ANR5040T1R2□ 1.2 N/M 4.21 4.30 6.60 7.10 0.021 ANR5040T1R5□ 1.5 N/M 4.36 4.80 6.39 7.30 0.02 ANR5040T1R8□ 1.8 N/M 4.21 4.30 5.58 6.40 0.027 ANR5040T2R2□ 2.2 N/M 3.86 4.30 4.97 5.60 0.027 ANR5040T2R7□ 2.7 N/M 3.65 4.10 4.36 5.10 0.029 ANR5040T3R0□ 3 N/M 3.65 4.20 4.21 4.80 0.029 ANR5040T3R3□ 3.3 N/M 3.45 3.90 4.01 4.60 0.031 ANR5040T3R6□ 3.6 N/M 3.35 3.70 3.86 4.40 0.031 ANR5040T3R9□ 3.9 N/M 3.25 3.70 3.60 4.20 0.035 ANR5040T4R7□ 4.7 N/M 3.05 3.30 3.55 3.90 0.041 ANR5040T5R6M 5.6 M 2.84 3.10 3.05 4.10 0.046 ANR5040T6R8M 6.8 M 2.54 2.80 2.94 3.50 0.056 ANR5040T8R2M 8.2 M 2.33 2.60 2.74 3.00 0.074 ANR5040T100M 10 M 2.13 2.40 2.39 2.90 0.083 ANR5040T120M 12 M 2.03 2.10 2.23 2.50 0.099 ANR5040T150M 15 M 2.03 2.10 2.03 2.30 0.112 ANR5040T180M 18 M 1.47 1.65 1.73 2.00 0.153 ANR5040T220M 22 M 1.52 1.60 1.62 1.90 0.168 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR5040 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR5040T270M 27 M ANR5040T330M 33 ANR5040T470M 47 ANR5040T510M 51 M ANR5040T560M 56 M ANR5040T680M 68 M 0.81 0.90 0.91 1.10 0.52 ANR5040T750M 75 M 0.73 0.80 0.86 0.95 0.579 ANR5040T101M 100 M 0.71 0.80 0.76 0.90 0.728 ANR5040T151M 150 M 0.61 0.70 0.66 0.67 0.975 ANR5040T221M 220 M 0.41 0.50 0.49 0.55 1.82 ANR5040T301M 300 M 0.36 0.40 0.51 0.58 2.574 ANR5040T331M 330 M 0.41 0.50 0.43 0.47 2.703 ANR5040T471M 470 M 0.36 0.40 0.38 0.43 3.9 ANR5040T561M 560 M 0.31 0.35 0.31 0.36 4.914 ANR5040T681M 680 M 0.25 0.30 0.30 0.35 5.07 ANR5040T102M 1000 M 0.20 0.23 0.21 0.25 7.8 ANR5040T222M 2200 M 0.11 0.12 0.15 0.18 14.82 Irms Isat DCR 1.12 1.25 1.54 1.75 0.242 M 1.22 1.40 1.32 1.50 0.244 M 1.02 1.10 1.12 1.30 0.354 1.02 1.10 1.02 1.20 0.489 0.81 0.90 1.07 1.20 0.494 ● ANR5045 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR5045T2R2M 2.2 M 4.77 5.40 6.50 7.20 0.029 ANR5045T100M 10 M 2.54 2.90 3.25 3.70 0.078 ANR5045T220M 22 M 1.57 1.80 2.03 2.35 0.161 Symbol ● ANR6020 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Max. A L ANR6020TR50□ 0.5 N/M 4.06 5.00 ANR6020TR68□ 0.68 N/M 3.86 ANR6020TR82□ 0.82 N/M 3.86 ANR6020T1R0□ 1 N/M 3.55 ANR6020T1R2□ 1.2 N/M 3.25 ANR6020T1R5□ 1.5 N/M 3.25 Irms DC Resistance Typ. Ω Isat DCR 4.57 6.00 0.018 4.80 6.65 7.80 0.022 4.80 5.38 6.30 0.022 4.40 4.21 5.00 0.026 4.00 5.99 7.00 0.029 4.00 4.31 5.10 0.029 Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM Typ. A M=±20% N=±30% Symbol Saturation Current 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR6020 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Symbol L M=±20% N=±30% ANR6020T1R8□ 1.8 N/M 2.79 ANR6020T2R0□ 2 N/M ANR6020T2R2□ 2.2 N/M ANR6020T2R7□ 2.7 ANR6020T3R3□ 3.3 ANR6020T3R9□ ANR6020T4R3□ ANR6020T4R7□ ANR6020T5R6□ Typ. Ω A Irms DC Resistance Typ. Isat DCR 3.50 4.92 5.80 0.036 2.64 3.30 4.16 4.90 0.046 2.79 3.50 3.81 4.50 0.036 N/M 2.64 3.30 3.96 4.60 0.046 N/M 2.64 3.30 3.20 3.70 0.046 3.9 N/M 2.13 2.60 3.30 3.90 0.063 4.3 N/M 2.13 2.60 2.74 3.20 0.063 4.7 N/M 2.03 2.50 3.05 3.60 0.074 5.6 N/M 1.93 2.40 2.44 2.90 0.089 ANR6020T6R2□ 6.2 N/M 1.83 2.30 2.33 2.70 0.102 ANR6020T6R8□ 6.8 N/M 1.83 2.30 2.23 2.60 0.102 ANR6020T8R2□ 8.2 N/M 1.42 1.80 2.13 2.50 0.136 ANR6020T100M 10 M 1.42 1.80 1.78 2.10 0.136 ANR6020T120M 12 M 1.32 1.60 1.47 1.70 0.154 ANR6020T150M 15 M 1.22 1.50 1.22 1.40 0.187 ANR6020T180M 18 M 1.10 1.40 1.22 1.40 0.232 ANR6020T220M 22 M 1.02 1.30 1.07 1.20 0.262 ANR6020T330M 33 M 0.85 1.05 0.96 1.10 0.386 ANR6020T470M 47 M 0.81 0.90 0.71 0.90 0.553 ANR6020T331M 330 M 0.33 0.39 0.27 0.33 3.385 ANR6020T101M 100 M 0.50 0.58 0.64 0.84 1.2 ● ANR6028 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR6028TR82□ 0.82 N/M 5.28 6.00 6.60 9.00 0.016 ANR6028T1R0□ 1 N/M 5.28 5.70 5.84 7.00 0.018 ANR6028T1R2□ 1.2 N/M 4.65 5.00 6.50 7.50 0.017 ANR6028T1R5□ 1.5 N/M 4.65 5.00 6.09 6.60 0.017 ANR6028T2R2□ 2.2 N/M 3.81 4.10 5.18 5.60 0.026 ANR6028T2R7□ 2.7 N/M 3.81 4.10 3.86 4.10 0.033 ANR6028T3R3□ 3.3 N/M 3.53 3.80 4.21 4.50 0.033 ANR6028T4R7□ 4.7 N/M 3.13 3.40 3.05 3.30 0.039 ANR6028T5R1□ 5.1 N/M 2.64 2.80 3.25 3.50 0.055 ANR6028T6R2M 6.2 M 2.44 2.60 3.10 3.30 0.06 ANR6028T6R8M 6.8 M 2.44 2.60 2.64 3.00 0.06 ANR6028T8R2M 8.2 M 2.28 2.50 2.33 2.50 0.071 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR6028 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. Ω A Symbol L M=±20% N=±30% ANR6028T9R1M 9.1 M ANR6028T100M 10 ANR6028T120M 12 ANR6028T150M ANR6028T180M ANR6028T220M 22 M ANR6028T270M 27 M ANR6028T330M 33 M ANR6028T360M 36 M ANR6028T390M 39 ANR6028T470M 47 ANR6028T560M ANR6028T680M ANR6028T750M ANR6028T820M ANR6028T101M 100 M 0.71 0.77 ANR6028T151M 150 M 0.70 0.80 ANR6028T221M 220 M 0.50 0.57 ANR6028T401M 400 M 0.41 0.45 ANR6028T471M 470 M 0.33 ANR6028T102M 1000 M 0.23 Irms DC Resistance Typ. Isat DCR 2.18 2.40 2.59 2.80 0.095 M 1.98 2.40 2.07 2.50 0.093 M 1.88 2.00 1.83 2.00 0.103 15 M 1.47 1.60 1.78 1.90 0.161 18 M 1.47 1.60 1.54 1.80 0.154 1.42 1.60 1.47 1.80 0.18 1.34 1.40 1.52 1.60 0.2 1.24 1.30 1.37 1.50 0.239 1.15 1.20 1.27 1.40 0.277 M 1.12 1.20 1.27 1.40 0.29 M 1.08 1.10 1.17 1.30 0.406 56 M 0.90 1.00 1.07 1.20 0.445 68 M 0.87 0.95 0.81 0.95 0.463 75 M 0.82 0.90 0.91 0.99 0.528 82 M 0.71 0.77 0.81 0.88 0.644 0.66 0.71 0.774 0.80 0.88 0.78 0.40 0.50 1.729 0.30 0.33 2.78 0.37 0.28 0.32 3.505 0.26 0.18 0.22 7.54 ● ANR6040 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR Symbol L M=±20% N=±30% ANR6040T100M 10 M 2.45 2.80 3.20 3.50 0.062 ANR6040T150M 15 M 2.05 2.35 2.50 3.00 0.088 ● ANR6045 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR6045TR47□ 0.47 N/M 6.60 6.60 15.23 16.50 0.012 ANR6045TR56□ 0.56 N/M 6.60 6.60 14.21 15.00 0.012 ANR6045TR68□ 0.68 N/M 5.79 6.50 11.17 12.00 0.012 ANR6045TR82□ 0.82 N/M 5.99 6.50 10.51 11.00 0.013 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR6045 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR6045T1R0□ 1 N/M 5.22 5.60 10.00 10.00 0.014 ANR6045T1R2□ 1.2 N/M 5.48 5.90 8.48 9.10 0.016 ANR6045T1R3□ 1.3 N/M 5.48 5.90 8.48 9.10 0.013 ANR6045T1R5□ 1.5 N/M 5.02 5.40 8.93 9.70 0.016 ANR6045T1R8□ 1.8 N/M 5.02 5.40 7.71 8.40 0.016 ANR6045T2R2□ 2.2 N/M 4.67 5.00 6.85 7.40 0.023 ANR6045T2R3□ 2.3 N/M 3.55 3.80 6.09 6.60 0.027 ANR6045T2R7□ 2.7 N/M 4.36 4.70 5.84 6.30 0.02 ANR6045T3R0□ 3 N/M 3.86 4.20 5.68 6.20 0.026 ANR6045T3R3□ 3.3 N/M 3.76 4.00 5.99 6.20 0.027 ANR6045T3R6□ 3.6 N/M 3.76 4.00 5.33 5.70 0.027 ANR6045T4R3M 4.3 M 3.55 3.80 4.52 4.90 0.03 ANR6045T4R5M 4.5 M 3.35 3.60 5.04 5.50 0.034 ANR6045T4R7M 4.7 M 3.35 3.60 5.04 5.50 0.034 ANR6045T5R1M 5.1 M 3.35 3.60 4.47 4.80 0.034 ANR6045T5R6M 5.6 M 3.20 3.40 4.21 4.60 0.038 ANR6045T6R2M 6.2 M 3.05 3.30 4.50 4.80 0.04 ANR6045T6R3M 6.3 M 3.05 3.30 4.50 4.70 0.04 ANR6045T6R8M 6.8 M 3.05 3.30 3.96 4.30 0.04 ANR6045T7R5M 7.5 M 2.94 3.20 3.55 3.80 0.044 ANR6045T8R2M 8.2 M 2.64 2.80 3.96 4.30 0.06 ANR6045T9R1M 9.1 M 2.64 2.80 3.40 3.70 0.055 ANR6045T100M 10 M 2.49 2.70 3.25 3.50 0.062 ANR6045T120M 12 M 2.23 2.40 2.84 3.00 0.074 ANR6045T150M 15 M 2.08 2.20 2.54 2.70 0.088 ANR6045T180M 18 M 1.88 2.00 2.23 2.40 0.104 ANR6045T220M 22 M 1.83 2.00 2.08 2.20 0.116 ANR6045T270M 27 M 1.67 1.80 1.93 2.10 0.132 ANR6045T300M 30 M 1.52 1.60 1.73 1.80 0.17 ANR6045T330M 33 M 1.47 1.60 1.67 1.80 0.178 ANR6045T360M 36 M 1.42 1.50 1.64 1.80 0.223 ANR6045T390M 39 M 1.27 1.40 1.52 1.60 0.232 ANR6045T430M 43 M 1.22 1.30 1.65 1.80 0.257 ANR6045T470M 47 M 1.22 1.30 1.42 1.50 0.26 ANR6045T510M 51 M 1.17 1.20 1.37 1.50 0.266 ANR6045T560M 56 M 1.12 1.20 1.32 1.40 0.287 ANR6045T620M 62 M 1.12 1.20 1.27 1.40 0.303 ANR6045T680M 68 M 1.02 1.10 1.22 1.30 0.376 ANR6045T750M 75 M 0.96 1.00 1.17 1.20 0.393 ANR6045T820M 82 M 0.91 0.99 1.07 1.10 0.5 ANR6045T910M 91 M 0.86 0.94 1.02 1.10 0.462 Irms Isat Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM DCR 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR6045 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A L M=±20% N=±30% 100 M 0.81 0.88 0.96 ANR6045T121M 120 M 0.78 0.85 0.86 0.94 0.623 ANR6045T151M 150 M 0.71 0.77 0.81 0.88 0.754 ANR6045T221M 220 M 0.60 0.65 0.71 0.77 1.084 ANR6045T331M 330 M 0.58 0.63 0.58 0.63 1.651 ANR6045T471M 470 M 0.43 0.48 0.51 0.56 2.34 ANR6045T681M 680 M 0.33 0.38 0.43 0.46 3.25 ANR6045T102M 1000 M 0.30 0.35 0.30 0.35 5.85 ANR6045T152M 1500 M 0.21 0.24 0.24 0.29 8.1 Symbol ANR6045T101M Irms Isat DCR 1.00 0.563 ● ANR8040 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR8040TR82□ 0.82 N/M 6.39 6.90 14.01 16.00 0.01 ANR8040T1R0□ 1 N/M 6.39 6.90 10.00 14.00 0.01 ANR8040T1R2□ 1.2 N/M 5.73 6.20 10.15 14.00 0.013 ANR8040T1R5□ 1.5 N/M 5.73 6.20 8.27 11.00 0.013 ANR8040T2R0□ 2 N/M 5.23 5.60 9.39 10.00 0.016 ANR8040T2R2□ 2.2 N/M 5.23 5.60 7.21 8.00 0.016 ANR8040T3R0□ 3 N/M 4.77 5.20 6.19 7.00 0.018 ANR8040T3R3□ 3.3 N/M 4.47 4.80 6.60 7.00 0.022 ANR8040T3R6□ 3.6 N/M 4.42 4.80 7.63 8.50 0.022 ANR8040T3R9□ 3.9 N/M 4.42 4.80 5.84 6.50 0.022 ANR8040T4R7□ 4.7 N/M 4.16 4.50 5.99 6.50 0.025 ANR8040T5R1□ 5.1 N/M 4.11 4.40 4.77 5.40 0.025 ANR8040T5R6□ 5.6 N/M 3.91 4.20 6.09 6.90 0.027 ANR8040T6R2□ 6.2 N/M 3.91 4.20 4.52 5.10 0.027 ANR8040T6R8M 6.8 M 3.65 4.00 4.62 5.20 0.031 ANR8040T8R2M 8.2 M 3.50 3.80 4.26 4.80 0.034 ANR8040T100M 10 M 3.35 3.60 3.65 4.10 0.038 ANR8040T120M 12 M 2.84 3.00 3.55 4.00 0.052 ANR8040T150M 15 M 2.64 2.80 2.99 3.40 0.06 ANR8040T180M 18 M 2.44 2.60 2.74 3.10 0.068 ANR8040T220M 22 M 2.13 2.30 2.44 2.70 0.089 ANR8040T270M 27 M 2.03 2.20 2.18 2.50 0.1 ANR8040T330M 33 M 1.83 2.00 2.08 2.40 0.125 ANR8040T360M 36 M 1.78 1.90 2.03 2.30 0.132 ANR8040T390M 39 M 1.73 1.90 1.98 2.20 0.138 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR8040 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. A Typ. DC Resistance Typ. Ω A Symbol L M=±20% N=±30% ANR8040T430M 43 M 1.67 1.80 1.93 2.20 ANR8040T470M 47 M 1.57 1.70 1.78 2.00 0.175 ANR8040T510M 51 M 1.52 1.60 1.73 1.90 0.183 ANR8040T560M 56 M 1.47 1.60 1.57 1.70 0.19 ANR8040T620M 62 M 1.32 1.40 1.52 1.60 0.235 ANR8040T680M 68 M 1.27 1.40 1.47 1.60 0.252 ANR8040T750M 75 M 1.22 1.30 1.37 1.50 0.271 ANR8040T820M 82 M 1.17 1.20 1.32 1.40 0.29 ANR8040T910M 91 M 1.07 1.10 1.22 1.30 0.35 ANR8040T101M 100 M 1.02 1.10 1.17 1.30 0.373 ANR8040T121M 120 M 0.96 1.00 1.07 1.10 0.43 ANR8040T151M 150 M 0.86 0.94 1.12 1.20 0.528 ANR8040T181M 180 M 0.84 0.92 0.96 1.15 0.669 ANR8040T221M 220 M 0.81 0.88 0.86 0.94 0.771 ANR8040T331M 330 M 0.65 0.70 0.69 0.75 1.144 ANR8040T471M 470 M 0.51 0.60 0.61 0.70 1.609 ANR8040T681M 680 M 0.50 0.50 0.60 2.652 0.45 ANR8040T102M 1000 M 0.40 0.40 0.50 3.64 0.35 ANR8040T152M 1500 M 0.27 0.32 0.38 6.5 0.26 Irms Isat DCR 0.146 ● ANR8065 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR8065TR68M 0.68 M 7.61 8.50 24.36 26.00 0.008 ANR8065T1R0M 1 M 7.11 8.00 20.30 22.00 0.011 ANR8065T2R2M 2.2 M 5.28 4.50 14.01 12.00 0.016 ANR8065T3R3M 3.3 M 5.18 5.90 9.64 10.00 0.018 ANR8065T4R7M 4.7 M 4.77 5.40 8.63 9.50 0.022 ANR8065T5R6M 5.6 M 4.57 5.20 8.12 9.00 0.026 ANR8065T6R8M 6.8 M 4.57 5.20 7.61 8.00 0.026 ANR8065T8R2M 8.2 M 4.26 4.80 7.11 7.70 0.031 ANR8065T100M 10 M 3.25 3.70 8.12 8.90 0.044 ANR8065T150M 15 M 3.30 3.75 5.79 6.70 0.052 ANR8065T220M 22 M 2.74 3.10 4.36 4.80 0.071 ANR8065T470M 47 M 1.88 2.15 3.45 3.70 0.15 ANR8065T560M 56 M 1.37 1.55 3.25 3.70 0.196 ANR8065T680M 68 M 1.57 1.80 2.74 3.20 0.216 ANR8065T101M 100 M 1.37 1.45 2.03 2.40 0.277 Symbol Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ Electrical Characteristics ● ANR8065 Series Part Number Units Inductance Tolerance @100kHz,1V Inductance μH Heat Rating Current Max. Typ. Saturation Current Max. Typ. DC Resistance Typ. A A Ω Irms Isat DCR L M=±20% N=±30% ANR8065T151M 150 M 0.96 1.10 1.62 2.00 0.436 ANR8065T221M 220 M 0.81 0.90 1.22 1.50 0.649 ANR8065T331M 330 M 0.76 0.85 1.02 1.20 0.832 ANR8065T471M 470 M 0.56 0.65 1.02 1.20 1.544 ANR8065T681M 680 M 0.53 0.60 0.86 1.00 1.925 ANR8065T102M 1000 M 0.40 0.45 0.65 0.73 2.82 Symbol △ All test data is referenced to 20°C ambient; △ Rated current: Isat or Irms, whichever is smaller; △ The DC Resistance maximum from typical +25%; △ Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. ▉ TYPICAL ELECTRICAL CHARACTERISTICS ANR252010 Series ANR252012 Series Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS ANR3010 Series ANR3012 Series ANR3015 Series Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS ANR4010 Series ANR4012 Series ANR4018 Series ANR4020 Series Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS ANR4026 Series ANR4030 Series ANR5012 Series ANR5020 Series Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS ANR5040 Series ANR6020 Series ANR6028 Series ANR6045 Series Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25 Wire Wound SMD Power Inductors - ANR Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS ANR8040 Series ANR8065 Series Note: This series product is not applies in automotive or related products. Otherwise, we will shall not bear than the resulting all the problems of quality and responsibility. Please be sure to request approval specifications that provide further details of the products. Kindly not that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without APV approval. Specifications subject to change without notice. Please check our website for latest information. WWW.APVIND.COM 2023-08-25
ANR3015T220M 价格&库存
很抱歉,暂时无法提供与“ANR3015T220M”相匹配的价格&库存,您可以联系我们找货
ANR3015T220M
  • 1+0.21010
  • 50+0.12430
  • 2000+0.11110
库存:990
ANR3015T220M
  • 1+0.15470
  • 10+0.13720
  • 100+0.12560
  • 1000+0.11290
库存:35943
