APSWPA6045S471MTF
APSWPA6045S471MTF
    APV(爱普微)
    SMD,6x6mm
    470UH ±20% 500MA
APSWPA6045S471MTF 数据手册
Wire Wound SMD Power Inductors - APSWPA Series ▉ FEATURES ● Various high power inductors are superior to be high saturation ● Suitable for surface mounting equipment ● Closed magnetic circuit design reduces leakage flux and Electro Magnetic Interference (EMI) ● Takes up less PCB real estate and save more power ● Magnetic-resin shielded construction reduces buzz noise to ultra-low levels ● Operating Temperature: -40℃~+125℃ ▉ APPLICATIONS ● Smart phone, smart TV,set top box, notebook ● Car navigation systems, telecomm basestations ● VR, AR ● LED lighting ● RoHS, Halogen Free and REACH Compliance ▉ PART NUMBERING APS WPA 4018 S 4R7 M T F □□ ① Grade ② Series Name ③ Dimensions Code ④ Feature Type ⑤ Nominal inductance ⑥ Inductance tolerance ⑦ Packaging ⑧ HSF Products ⑨ Design Code ② Series Name ①Grade APS Grade Code ④Feature Type S Standard ⑦Packaging Taping ⑧HSF Products Hazardous Substance F Free Products ⑨Design Code Standard □□ product is blank WPA Wire Wound SMD Power Inductor ⑤Nominal inductance Code Nominal inductance[μH] (example) 2R2 2.2 100 10 101 100 ⑥Inductance tolerance Code Inductance tolerance (example) K ±10% M ±20% N ±30% ③Dimensions Code Code Dimensions(L×W×H)[mm] 252010 2.5×2.0×1.0 252012 2.5×2.0×1.2 3010 3.0×3.0×1.0 3012 3.0×3.0×1.2 3015 3.0×3.0×1.5 4010 4.0×4.0×1.0 4012 4.0×4.0×1.2 4018 4.0×4.0×1.8 4020 4.0×4.0×2.0 4026 4.0×4.0×2.6 4030 4.0×4.0×3.0 5012 5.0×5.0×1.2 5020 5.0×5.0×2.0 5040 5.0×5.0×4.0 5045 5.0×5.0×4.5 6020 6.0×6.0×2.0 6028 6.0×6.0×2.8 6040 6.0×6.0×4.0 6045 6.0×6.0×4.5 8040 8.0×8.0×4.0 8060 8.0×8.0×6.0 8065 8.0×8.0×6.5 Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Dimensions & Recommended Land Pattern Figure 1 Figure 2 C B Figure 3 Recommended Land Pattern Unit: mm Dimensions Recommended Land Pattern Series Shape A B C D E F a Typ. b Typ. c Typ. APSWPA252010 Figure1 2.5±0.1 2.0±0.1 1.0 Max. 2.0±0.2 0.80±0.2 0.80±0.2 0.8 0.85 2 APSWPA252012 Figure1 2.5±0.1 2.0±0.1 1.2 Max. 2.0±0.2 0.80±0.2 0.80±0.2 0.8 0.85 2 APSWPA3010 Figure2 3.0±0.2 3.0±0.2 1.0 Max. 2.5±0.2 0.75±0.2 1.5±0.2 1.5 0.8 2.7 APSWPA3012 Figure2 3.0±0.2 3.0±0.2 1.2 Max. 2.5±0.2 0.75±0.2 1.5±0.2 1.5 0.8 2.7 APSWPA3015 Figure2 3.0±0.2 3.0±0.2 1.5 Max. 2.5±0.2 0.75±0.2 1.5±0.2 1.5 0.8 2.7 APSWPA4010 Figure2 4.0±0.2 4.0±0.2 1.0 Max. 3.3±0.2 0.95±0.2 2.1±0.2 1.9 1.1 3.7 APSWPA4012 Figure2 4.0±0.2 4.0±0.2 1.2 Max. 3.3±0.2 0.95±0.2 2.1±0.2 1.9 1.1 3.7 APSWPA4018 Figure2 4.0±0.2 4.0±0.2 1.8 Max. 3.3±0.2 0.95±0.2 2.1±0.2 1.9 1.1 3.7 APSWPA4020 Figure2 4.0±0.2 4.0±0.2 2.0 Max. 3.3±0.2 0.95±0.2 2.1±0.2 1.9 1.1 3.7 APSWPA4026 Figure3 4.0±0.2 4.0±0.2 2.6 Max. 3.3±0.2 0.95±0.2 2.1±0.2 1.9 1.1 3.7 APSWPA4030 Figure2 4.0±0.2 4.0±0.2 3.0 Max. 3.3±0.2 0.95±0.2 2.1±0.2 1.9 1.1 3.7 APSWPA5012 Figure3 5.0±0.2 5.0±0.2 1.2 Max. 4.0±0.2 1.25±0.2 2.5±0.2 2.3 1.4 4.2 APSWPA5020 Figure3 5.0±0.2 5.0±0.2 2.0 Max. 4.0±0.2 1.25±0.2 2.5±0.2 2.3 1.4 4.2 APSWPA5040 Figure3 5.0±0.2 5.0±0.2 4.0 Max. 4.0±0.2 1.25±0.2 2.5±0.2 2.3 1.4 4.2 APSWPA5045 Figure3 5.0±0.2 5.0±0.2 4.5 Max. 4.0±0.2 1.30±0.2 2.5±0.2 2.3 1.4 4.2 APSWPA6020 Figure2 6.0±0.3 6.0±0.3 2.0 Max. 4.9±0.3 1.55±0.3 2.9±0.3 2.8 1.7 5.7 APSWPA6028 Figure2 6.0±0.3 6.0±0.3 2.8 Max. 4.9±0.3 1.55±0.3 2.9±0.3 2.8 1.7 5.7 APSWPA6040 Figure2 6.0±0.3 6.0±0.3 4.0 Max. 4.9±0.3 1.55±0.3 2.9±0.3 2.8 1.7 5.7 APSWPA6045 Figure2 6.0±0.3 6.0±0.3 4.5 Max. 4.9±0.3 1.55±0.3 2.9±0.3 2.8 1.7 5.7 APSWPA8040 Figure2 8.0±0.3 8.0±0.3 4.2 Max. 6.3±0.3 2.00±0.3 4.0±0.3 3.8 2.2 7.5 APSWPA8065 Figure3 8.0±0.3 8.0±0.3 6.5 Max. 6.3±0.3 2.00±0.3 4.0±0.3 3.8 2.2 7.5 ● All products are printed with Marking except the 252010, 252012, 3010, 3012 and 3015. ● The 3010,3012 and 3015 with Marking can be provided upon customer’s request. Please contact your local sales. Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWPA252010 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Irms Isat M=±20% N=±30% S.R.F DCR 0.47 2.35 2.56 2.50 3.35 206 0.056 N/M APSWPA252010SR56□TF 0.56 2.00 2.18 2.90 3.20 160 0.072 N/M APSWPA252010SR68□TF 0.68 2.00 2.18 2.20 2.75 129 0.074 N/M APSWPA252010SR47□TF L Inductance Tolerance APSWPA252010S1R0□TF 1 1.65 1.80 1.85 2.20 100 0.108 N/M APSWPA252010S1R5□TF 1.5 1.30 1.42 1.80 2.10 81 0.182 N/M APSWPA252010S2R2□TF 2.2 1.20 1.31 1.20 1.60 61 0.209 N/M APSWPA252010S3R3MTF 3.3 0.90 0.98 1.05 1.30 47 0.328 M APSWPA252010S4R7MTF 4.7 0.70 0.76 0.95 1.15 42 0.563 M APSWPA252010S5R6MTF 5.6 0.73 0.80 0.80 0.95 35 0.563 M APSWPA252010S6R8MTF 6.8 0.59 0.64 0.78 0.92 31 0.896 M APSWPA252010S100MTF 10 0.50 0.55 0.65 0.78 27 1.092 M Inductance Tolerance ● APSWPA252012 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms S.R.F DCR 2.34 3.82 4.27 160 0.061 N/M 1.95 2.13 3.28 3.68 140 0.074 N/M 1.93 2.10 2.59 2.90 110 0.090 N/M APSWPA252012SR47□TF 0.47 2.15 APSWPA252012SR68□TF 0.68 APSWPA252012S1R0□TF 1 Isat M=±20% N=±30% APSWPA252012S1R2□TF 1.2 1.46 1.59 2.38 2.67 100 0.129 N/M APSWPA252012S1R5□TF 1.5 1.40 1.53 2.24 2.51 97 0.147 N/M APSWPA252012S2R2□TF 2.2 1.15 1.25 1.85 2.07 69 0.216 N/M APSWPA252012S2R7MTF 2.7 1.09 1.19 1.72 1.92 63 0.239 M APSWPA252012S3R3MTF 3.3 1.04 1.13 1.61 1.80 62 0.264 M APSWPA252012S3R6MTF 3.6 0.90 0.98 1.46 1.64 53 0.348 M APSWPA252012S4R3MTF 4.3 0.87 0.95 1.37 1.53 51 0.377 M APSWPA252012S4R7MTF 4.7 0.84 0.92 1.12 1.25 47 0.377 M APSWPA252012S5R1MTF 5.1 0.75 0.82 1.23 1.37 44 0.500 M APSWPA252012S5R6MTF 5.6 0.73 0.80 1.11 1.25 38 0.538 M APSWPA252012S6R2MTF 6.2 0.73 0.80 1.03 1.16 38 0.542 M APSWPA252012S6R8MTF 6.8 0.69 0.75 0.98 1.09 38 0.581 M APSWPA252012S7R5MTF 7.5 0.68 0.74 0.97 1.09 35 0.611 M APSWPA252012S8R2MTF 8.2 0.65 0.71 0.98 1.10 36 0.658 M APSWPA252012S9R1MTF 9.1 0.62 0.68 0.91 1.02 34 0.690 M APSWPA252012S100MTF 10 0.62 0.68 0.79 0.88 34 0.690 M APSWPA252012S120MTF 12 0.51 0.56 0.78 0.88 28 1.075 M APSWPA252012S150MTF 15 0.42 0.46 0.68 0.77 25 1.591 M APSWPA252012S220MTF 22 0.38 0.41 0.53 0.59 20 1.976 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWPA3010 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA3010S1R0□TF 1 1.45 Irms 1.80 1.40 Isat 2.10 APSWPA3010S1R2□TF 1.2 1.45 1.80 1.25 APSWPA3010S1R5□TF 1.5 1.30 1.60 1.27 APSWPA3010S2R2□TF 2.2 1.09 1.40 APSWPA3010S2R7□TF 2.7 1.02 1.40 APSWPA3010S3R3□TF 3.3 0.96 1.20 APSWPA3010S3R6MTF 3.6 0.90 1.10 APSWPA3010S4R7MTF 4.7 0.77 1.10 0.75 APSWPA3010S5R6MTF 5.6 0.70 1.05 0.58 APSWPA3010S6R8MTF 6.8 0.66 0.96 0.55 0.72 APSWPA3010S8R2MTF 8.2 0.58 0.70 0.55 0.70 APSWPA3010S100MTF 10 0.58 0.70 0.55 APSWPA3010S120MTF 12 0.52 0.67 0.43 Inductance Tolerance M=±20% N=±30% S.R.F DCR 180 0.085 N/M 1.70 137 0.085 N/M 1.70 120 0.104 N/M 1.15 1.50 100 0.143 N/M 1.00 1.20 90 0.169 N/M 0.97 1.20 74 0.189 N/M 0.95 1.20 67 0.215 M 1.05 59 0.293 M 0.65 40 0.322 M 42 0.397 M 23 0.520 M 0.75 39 0.520 M 0.65 36 0.657 M APSWPA3010S150MTF 15 0.47 0.57 0.42 0.57 30 0.793 M APSWPA3010S220MTF 22 0.38 0.52 0.35 0.48 28 1.209 M APSWPA3010S270MTF 27 0.35 0.50 0.30 0.45 25 1.404 M APSWPA3010S330MTF 33 0.30 0.55 0.29 0.42 18 2.015 M APSWPA3010S390MTF 39 0.28 0.53 0.28 0.38 18 2.275 M APSWPA3010S430MTF 43 0.27 0.52 0.23 0.36 18 2.340 M APSWPA3010S470MTF 47 0.26 0.52 0.22 0.35 18 2.535 M APSWPA3010S510MTF 51 0.25 0.48 0.21 0.33 18 2.860 M APSWPA3010S560MTF 56 0.24 0.35 0.21 0.28 16 3.016 M Inductance Tolerance ● APSWPA3012 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms Isat M=±20% N=±30% S.R.F DCR APSWPA3012SR22□TF 0.22 3.00 3.30 5.30 6.00 321 0.022 N/M APSWPA3012SR82□TF 0.82 2.47 3.00 2.05 2.80 180 0.039 N/M APSWPA3012S1R0□TF 1 2.20 2.70 1.87 2.80 120 0.052 N/M APSWPA3012S1R2□TF 1.2 2.01 2.20 2.22 2.50 120 0.059 N/M APSWPA3012S1R5□TF 1.5 2.01 2.20 1.62 1.90 110 0.078 N/M APSWPA3012S1R8□TF 1.8 1.65 1.80 1.30 1.90 90 0.082 N/M APSWPA3012S2R2□TF 2.2 1.55 1.70 1.20 1.90 84 0.098 N/M APSWPA3012S2R4□TF 2.4 1.60 1.70 1.15 1.50 100 0.088 N/M APSWPA3012S2R7MTF 2.7 1.48 1.50 1.14 1.50 65 0.110 M APSWPA3012S3R3MTF 3.3 1.36 1.40 1.05 1.50 64 0.130 M APSWPA3012S3R6MTF 3.6 1.36 1.40 1.05 1.50 36 0.130 M APSWPA3012S3R9MTF 3.9 1.24 1.30 1.00 1.30 61 0.189 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWPA3012 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L APSWPA3012S4R7MTF 4.7 APSWPA3012S6R8MTF 6.8 APSWPA3012S100MTF 10 APSWPA3012S120MTF 12 APSWPA3012S150MTF 15 APSWPA3012S180MTF APSWPA3012S220MTF APSWPA3012S270MTF 27 APSWPA3012S330MTF 33 APSWPA3012S360MTF APSWPA3012S390MTF Irms 1.24 Isat Inductance Tolerance M=±20% N=±30% S.R.F DCR 61 0.156 M 61 0.247 M 42 0.345 M 32 0.449 M 27 0.468 M 25 0.709 M 23 0.839 M 21 1.131 M 18 1.138 M 18 1.235 M 18 1.729 M 0.35 14 1.885 M 0.33 9 1.794 M 0.24 0.29 7 2.171 M 0.17 0.27 7 3.302 M 0.21 0.23 5 3.718 M Inductance Tolerance 1.30 0.90 1.00 0.98 1.10 0.75 0.90 0.83 0.90 0.60 0.88 0.73 0.84 0.48 0.67 0.71 0.77 0.45 0.62 18 0.58 0.65 0.43 0.59 22 0.53 0.59 0.42 0.52 0.47 0.51 0.35 0.48 0.46 0.50 0.36 0.46 36 0.44 0.48 0.34 0.44 39 0.37 0.41 0.30 0.39 APSWPA3012S470MTF 47 0.35 0.40 0.27 APSWPA3012S560MTF 56 0.28 0.40 0.26 APSWPA3012S680MTF 68 0.33 0.37 APSWPA3012S820MTF 82 0.27 0.31 APSWPA3012S101MTF 100 0.25 0.29 ● APSWPA3015 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance S.R.F DCR 0.5 2.60 2.80 3.90 4.20 162 0.039 N/M APSWPA3015S1R0□TF 1 2.35 2.50 2.32 2.80 150 0.039 N/M APSWPA3015S1R2□TF 1.2 1.95 2.30 2.21 3.10 110 0.052 N/M APSWPA3015S1R5□TF 1.5 1.70 2.20 2.30 2.70 100 0.065 N/M APSWPA3015S1R8□TF 1.8 1.70 2.20 1.75 2.20 92 0.065 N/M APSWPA3015S2R2□TF 2.2 1.60 2.00 1.60 2.00 86 0.078 N/M APSWPA3015S2R7□TF 2.7 1.43 1.90 1.52 1.90 64 0.098 N/M APSWPA3015S3R3MTF 3.3 1.36 1.60 1.32 1.81 68 0.104 M APSWPA3015S3R6MTF 3.6 1.20 1.50 1.28 1.60 59 0.137 M APSWPA3015S3R9MTF 3.9 1.20 1.50 1.20 1.40 47 0.137 M APSWPA3015S4R3MTF 4.3 1.14 1.30 1.20 1.40 53 0.150 M APSWPA3015S4R7MTF 4.7 1.09 1.30 1.10 1.40 46 0.163 M APSWPA3015S5R1MTF 5.1 1.05 1.20 1.00 1.20 49 0.173 M APSWPA3015SR50□TF L Irms Isat M=±20% N=±30% APSWPA3015S6R2MTF 6.2 0.86 1.00 1.00 1.20 46 0.254 M APSWPA3015S6R8MTF 6.8 0.85 1.10 0.85 1.10 39 0.260 M APSWPA3015S100MTF 10 0.77 0.90 0.72 0.92 41 0.325 M APSWPA3015S120MTF 12 0.68 0.89 0.70 0.90 32 0.416 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWPA3015 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA3015S150MTF 15 0.65 Irms 0.72 Isat APSWPA3015S180MTF 18 0.59 0.72 APSWPA3015S220MTF 22 0.57 0.69 APSWPA3015S270MTF 27 0.45 0.56 0.48 APSWPA3015S330MTF 33 0.43 0.51 0.44 APSWPA3015S390MTF 39 0.39 0.44 0.41 APSWPA3015S430MTF 43 0.37 0.48 0.37 APSWPA3015S470MTF 47 0.35 0.44 0.35 0.43 APSWPA3015S560MTF 56 0.34 0.41 0.33 0.42 APSWPA3015S620MTF 62 0.30 0.41 0.30 APSWPA3015S680MTF 68 0.23 0.31 0.28 APSWPA3015S101MTF 100 0.21 0.25 0.23 APSWPA3015S151MTF 150 0.19 0.23 0.18 Inductance Tolerance M=±20% N=±30% S.R.F DCR 0.88 30 0.455 M 0.56 0.72 23 0.559 M 0.52 0.68 23 0.598 M 0.56 22 0.949 M 0.53 20 1.066 M 0.55 14 1.294 M 0.43 16 1.378 M 14 1.625 M 13 1.664 M 0.40 13 2.093 M 0.37 11 3.510 M 0.25 7.2 4.043 M 0.22 4.5 4.940 M Inductance Tolerance 0.66 ● APSWPA4010 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω L Irms Isat S.R.F DCR Inductance M=±20% N=±30% APSWPA4010S1R0□TF 1 1.90 2.40 2.00 2.30 104 0.067 N/M APSWPA4010S1R5□TF 1.5 1.70 2.00 1.68 2.00 71 0.084 N/M APSWPA4010S2R2MTF 2.2 1.50 2.00 1.20 1.50 52 0.102 M APSWPA4010S3R3MTF 3.3 1.40 1.80 1.10 1.40 42 0.120 M APSWPA4010S4R7MTF 4.7 1.20 1.50 0.95 1.10 30 0.168 M APSWPA4010S6R8MTF 6.8 1.00 1.20 0.80 0.95 26 0.240 M APSWPA4010S100MTF 10 0.75 1.00 0.62 0.75 19 0.360 M APSWPA4010S150MTF 15 0.60 0.85 0.54 0.61 17 0.516 M APSWPA4010S220MTF 22 0.50 0.75 0.45 0.52 11 0.684 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP4012 Series Part Number Units Symbol APSWPA4012SR82□TF @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L 0.82 Irms Isat 1.65 2.50 Inductance Tolerance M=±20% N=±30% S.R.F DCR 3.02 3.30 150 0.065 N/M APSWPA4012S1R0□TF 1 1.65 2.50 2.61 3.20 120 0.065 N/M APSWPA4012S1R5□TF 1.5 1.46 2.20 2.10 2.70 90 0.085 N/M APSWPA4012S1R8□TF 1.8 1.32 1.90 2.12 2.60 88 0.104 N/M APSWPA4012S2R2□TF 2.2 1.32 1.90 1.76 2.30 74 0.104 N/M APSWPA4012S2R7□TF 2.7 1.25 1.70 1.90 2.30 71 0.117 N/M APSWPA4012S3R3□TF 3.3 1.12 1.60 1.72 2.10 60 0.143 N/M APSWPA4012S3R6□TF 3.6 1.12 1.60 1.20 1.70 57 0.143 N/M APSWPA4012S4R3□TF 4.3 1.00 1.50 1.58 1.70 54 0.182 N/M APSWPA4012S4R7□TF 4.7 1.05 1.50 1.15 1.80 50 0.163 N/M APSWPA4012S5R1□TF 5.1 0.95 1.50 1.55 1.60 50 0.201 N/M APSWPA4012S5R6□TF 5.6 1.00 1.20 1.00 1.60 42 0.182 N/M APSWPA4012S6R8MTF 6.8 0.84 1.20 0.85 1.40 40 0.257 M APSWPA4012S100MTF 10 0.77 1.00 0.80 1.10 33 0.345 M APSWPA4012S120MTF 12 0.70 0.95 0.66 1.00 32 0.377 M APSWPA4012S150MTF 15 0.64 0.85 0.56 0.80 25 0.442 M APSWPA4012S180MTF 18 0.55 0.80 0.55 0.75 23 0.611 M APSWPA4012S220MTF 22 0.49 0.75 0.46 0.70 20 0.763 M APSWPA4012S270MTF 27 0.45 0.60 0.50 0.70 18 0.936 M APSWPA4012S330MTF 33 0.42 0.58 0.42 0.60 17 1.053 M APSWPA4012S360MTF 36 0.40 0.56 0.40 0.50 14 1.170 M APSWPA4012S390MTF 39 0.37 0.50 0.55 0.66 16 1.430 M APSWPA4012S470MTF 47 0.37 0.50 0.35 0.50 12 1.430 M APSWPA4012S560MTF 56 0.33 0.46 0.33 0.45 11 1.625 M APSWPA4012S680MTF 68 0.27 0.45 0.38 0.45 11 2.535 M APSWPA4012S820MTF 82 0.26 0.36 0.28 0.40 11 2.782 M APSWPA4012S101MTF 100 0.25 0.35 0.25 0.30 9.4 2.873 M Inductance Tolerance ● APSWP4018 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω L Irms Isat S.R.F DCR Inductance M=±20% N=±30% APSWPA4018SR47□TF 0.47 4.00 4.50 4.30 5.20 155 0.018 N/M APSWPA4018SR68□TF 0.68 3.30 3.80 4.90 5.60 128 0.026 N/M APSWPA4018S1R0□TF 1 2.00 3.30 4.80 5.20 80 0.033 N/M APSWPA4018S1R5□TF 1.5 1.80 3.20 3.35 4.00 65 0.039 N/M APSWPA4018S1R8□TF 1.8 2.00 2.80 3.00 3.40 54 0.044 N/M APSWPA4018S2R2□TF 2.2 1.65 2.60 2.70 3.20 52 0.059 N/M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP4018 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms Isat APSWPA4018S3R3MTF 3.3 1.23 2.10 APSWPA4018S4R7MTF 4.7 1.20 1.80 APSWPA4018S6R8MTF 6.8 1.06 1.50 APSWPA4018S100MTF 10 0.84 1.20 APSWPA4018S150MTF 15 0.65 1.00 Inductance Tolerance M=±20% N=±30% S.R.F DCR 2.90 44 0.091 M 1.70 2.20 34 0.117 M 1.45 2.00 29 0.143 M 1.30 1.60 24 0.234 M 0.94 1.10 19 0.325 M 2.45 APSWPA4018S220MTF 22 0.59 0.85 0.80 0.88 16 0.468 M APSWPA4018S330MTF 33 0.49 0.72 0.56 0.75 12 0.689 M APSWPA4018S470MTF 47 0.42 0.65 0.57 0.70 10 0.845 M APSWPA4018S680MTF 68 0.32 0.52 0.47 0.51 8.3 1.300 M APSWPA4018S101MTF 100 0.25 0.41 0.40 0.44 6.5 2.275 M APSWPA4018S151MTF 150 0.22 0.36 0.31 0.34 5.5 3.250 M APSWPA4018S221MTF 220 0.17 0.27 0.27 0.30 4 5.200 M Inductance Tolerance ● APSWP4020 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance S.R.F DCR 0.24 4.50 5.20 10.50 12.50 283 0.014 M APSWPA4020SR33□TF 0.33 3.30 4.90 7.50 8.50 223 0.016 N/M APSWPA4020SR47□TF 0.47 3.30 3.70 7.00 7.50 160 0.029 N/M APSWPA4020SR68□TF 0.68 2.80 3.30 6.40 6.60 120 0.036 N/M APSWPA4020S1R0□TF 1 2.15 3.20 4.78 5.20 75 0.038 N/M APSWPA4020S1R2□TF 1.2 2.15 3.20 5.10 5.60 72 0.038 N/M APSWPA4020S1R5□TF 1.5 1.98 3.00 4.45 4.90 71 0.046 N/M APSWPA4020SR24MTF L Irms Isat M=±20% N=±30% APSWPA4020S2R2□TF 2.2 1.85 2.80 3.40 3.70 49 0.052 N/M APSWPA4020S3R3□TF 3.3 1.40 2.50 3.20 3.50 44 0.091 N/M APSWPA4020S3R6□TF 3.6 1.54 2.50 2.80 3.00 49 0.072 N/M APSWPA4020S4R7□TF 4.7 1.34 2.00 2.35 2.50 42 0.098 N/M APSWPA4020S5R1MTF 5.1 1.27 1.80 2.30 2.50 42 0.111 M APSWPA4020S5R6MTF 5.6 1.22 1.80 2.20 2.40 30 0.117 M APSWPA4020S6R2MTF 6.2 1.08 1.60 2.15 2.30 36 0.150 M APSWPA4020S6R8MTF 6.8 1.04 1.60 2.20 2.40 33 0.163 M APSWPA4020S7R5MTF 7.5 1.08 1.50 1.85 2.00 30 0.150 M APSWPA4020S8R2MTF 8.2 1.04 1.40 1.75 1.90 27 0.163 M APSWPA4020S100MTF 10 0.90 1.20 1.60 1.70 26 0.215 M APSWPA4020S120MTF 12 0.88 1.20 1.50 1.60 26 0.228 M APSWPA4020S150MTF 15 0.77 1.10 1.35 1.50 24 0.299 M APSWPA4020S220MTF 22 0.62 0.87 1.05 1.10 15 0.455 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP4020 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA4020S270MTF 27 0.50 Irms 0.70 1.02 Isat APSWPA4020S330MTF 33 0.49 0.68 APSWPA4020S390MTF 39 0.46 0.64 APSWPA4020S430MTF 43 0.45 APSWPA4020S470MTF 47 0.44 APSWPA4020S510MTF 51 APSWPA4020S560MTF 56 APSWPA4020S620MTF 62 APSWPA4020S680MTF 68 Inductance Tolerance M=±20% N=±30% S.R.F DCR 1.10 14 0.709 M 0.85 0.93 11 0.715 M 0.82 0.90 11 0.845 M 0.63 0.77 0.85 10 0.858 M 0.61 0.74 0.81 10 0.923 M 0.42 0.59 0.70 0.77 10 0.975 M 0.41 0.57 0.66 0.72 10 1.040 M 0.39 0.52 0.65 0.71 9.6 1.170 M 0.36 0.50 0.61 0.67 7.7 1.380 M APSWPA4020S750MTF 75 0.35 0.49 0.70 0.77 7.7 1.510 M APSWPA4020S820MTF 82 0.34 0.47 0.50 0.55 7.2 1.520 M APSWPA4020S101MTF 100 0.31 0.43 0.48 0.53 6.3 2.020 M Inductance Tolerance ● APSWP4026 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA4026S1R0□TF 1 3.05 Irms 3.66 Isat APSWPA4026S1R2□TF 1.2 2.33 APSWPA4026S1R5□TF 1.5 2.33 APSWPA4026S2R2MTF 2.2 2.03 2.44 2.13 2.36 APSWPA4026S3R3MTF 3.3 1.73 2.08 1.83 2.03 APSWPA4026S4R7MTF 4.7 1.62 1.94 1.47 1.63 APSWPA4026S6R8MTF 6.8 1.52 1.82 1.32 1.47 APSWPA4026S100MTF 10 1.32 1.58 1.02 APSWPA4026S150MTF 15 1.12 1.34 0.91 APSWPA4026S220MTF 22 0.91 1.09 0.61 0.68 APSWPA4026S330MTF 33 0.71 0.85 0.56 0.62 APSWPA4026S470MTF 47 0.66 0.79 0.41 0.46 M=±20% N=±30% S.R.F DCR 151 0.031 N/M 3.50 120 0.039 N/M 2.71 100 0.039 N/M 96 0.051 M 58 0.064 M 46 0.071 M 33 0.084 M 1.13 26 0.109 M 1.01 19 0.142 M 13 0.212 M 9 0.347 M 6 0.386 M Inductance Tolerance 3.35 3.72 2.80 3.15 2.80 2.44 ● APSWP4030 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms Isat M=±20% N=±30% S.R.F DCR APSWPA4030SR68□TF 0.68 4.56 5.10 6.80 8.00 130 0.013 N/M APSWPA4030SR91□TF 0.91 4.15 4.70 6.25 6.80 100 0.017 N/M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP4030 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA4030S1R0□TF 1 Irms Isat 4.15 4.70 5.26 Inductance Tolerance M=±20% N=±30% S.R.F DCR 5.70 70 0.018 N/M APSWPA4030S1R2□TF 1.2 3.82 4.20 5.80 6.30 80 0.020 N/M APSWPA4030S1R5□TF 1.5 3.34 3.60 4.84 5.30 62 0.026 N/M APSWPA4030S1R8□TF 1.8 3.20 3.30 4.50 5.00 60 0.033 N/M APSWPA4030S2R2□TF 2.2 2.95 3.20 4.90 5.80 52 0.039 N/M APSWPA4030S3R3MTF 3.3 2.40 2.60 3.30 3.60 38 0.052 M APSWPA4030S3R9MTF 3.9 2.10 2.30 3.00 3.30 32 0.074 M APSWPA4030S4R3MTF 4.3 2.10 2.30 2.95 3.20 37 0.072 M APSWPA4030S4R7MTF 4.7 2.00 2.30 2.90 3.20 31 0.078 M APSWPA4030S5R6MTF 5.6 1.95 2.10 2.60 2.80 30 0.085 M APSWPA4030S6R8MTF 6.8 1.60 1.70 2.75 3.00 24 0.117 M APSWPA4030S7R5MTF 7.5 1.65 1.80 2.20 2.40 26 0.111 M APSWPA4030S8R2MTF 8.2 1.60 1.70 2.10 2.30 26 0.117 M APSWPA4030S100MTF 10 1.50 1.60 1.95 2.40 21 0.130 M APSWPA4030S120MTF 12 1.30 1.40 1.70 1.80 18 0.176 M APSWPA4030S150MTF 15 1.11 1.20 1.65 1.80 16 0.247 M APSWPA4030S180MTF 18 1.10 1.20 1.40 1.50 10 0.260 M APSWPA4030S220MTF 22 1.00 1.20 1.30 1.40 10 0.293 M APSWPA4030S330MTF 33 0.84 0.92 1.10 1.20 10 0.429 M APSWPA4030S360MTF 36 0.83 0.91 1.05 1.10 9.8 0.436 M APSWPA4030S390MTF 39 0.73 0.80 1.03 1.10 10 0.566 M APSWPA4030S470MTF 47 0.72 0.80 0.95 1.00 8.4 0.579 M APSWPA4030S510MTF 51 0.70 0.80 0.90 1.13 8.4 0.611 M APSWPA4030S560MTF 56 0.65 0.71 0.85 0.94 8.4 0.722 M APSWPA4030S620MTF 62 0.63 0.70 0.80 0.99 7 0.760 M APSWPA4030S680MTF 68 0.52 0.57 0.72 0.80 7 1.128 M APSWPA4030S750MTF 75 0.48 0.53 0.70 0.88 6.3 1.326 M APSWPA4030S820MTF 82 0.47 0.52 0.66 0.72 5.6 1.378 M APSWPA4030S910MTF 91 0.46 0.50 0.65 0.71 5.6 1.430 M APSWPA4030S101MTF 100 0.45 0.49 0.60 0.73 5.6 1.495 M APSWPA4030S121MTF 120 0.42 0.46 0.55 0.60 5.4 1.755 M APSWPA4030S151MTF 150 0.30 0.35 0.50 0.55 4 2.340 M APSWPA4030S221MTF 220 0.35 0.40 0.40 0.50 4.2 3.250 M APSWPA4030S331MTF 330 0.25 0.26 0.30 0.40 2.7 5.200 M APSWPA4030S471□TF 470 0.20 0.23 0.30 0.35 2 9.360 K/M APSWPA4030S501MTF 500 0.15 0.20 0.28 0.30 2 9.027 M APSWPA4030S681MTF 680 0.14 0.18 0.19 0.20 1.2 9.854 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP5012 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA5012S1R0□TF 1 2.00 Irms Isat APSWPA5012S1R5□TF 1.5 APSWPA5012S2R2□TF 2.2 APSWPA5012S3R3□TF 3.3 APSWPA5012S4R7□TF 4.7 APSWPA5012S6R8MTF 6.8 1.00 1.20 APSWPA5012S100MTF 10 0.85 1.00 APSWPA5012S150MTF 15 0.80 0.92 APSWPA5012S220MTF 22 0.60 0.68 Inductance Tolerance M=±20% N=±30% S.R.F DCR 103 0.068 N/M 3.80 68 0.086 N/M 3.20 50 0.108 N/M 2.40 2.60 34 0.151 N/M 2.20 2.30 31 0.197 N/M 1.70 1.90 22 0.294 M 1.40 1.50 17 0.413 M 1.20 1.30 13 0.523 M 0.88 0.98 16 0.858 M Inductance Tolerance 2.40 4.40 4.70 1.90 2.20 3.70 1.70 2.00 3.10 1.40 1.70 1.30 1.50 ● APSWP5020 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω L Irms Isat S.R.F DCR Inductance M=±20% N=±30% APSWPA5020SR22□TF 0.22 5.30 6.00 9.00 12.00 280 0.011 N/M APSWPA5020SR24□TF 0.24 5.30 6.00 8.00 10.00 248 0.011 N/M APSWPA5020SR47□TF 0.47 4.60 5.00 6.15 6.70 160 0.017 N/M APSWPA5020SR56□TF 0.56 3.80 4.20 8.50 9.60 137 0.022 N/M APSWPA5020SR68□TF 0.68 4.00 4.40 5.50 6.00 120 0.022 N/M APSWPA5020SR75□TF 0.75 4.00 4.40 5.50 6.00 117 0.022 N/M APSWPA5020S1R0□TF 1 3.80 4.10 4.10 5.00 114 0.026 N/M APSWPA5020S1R2□TF 1.2 3.55 3.90 4.50 4.90 83 0.029 N/M APSWPA5020S1R5□TF 1.5 3.20 3.50 4.10 4.50 68 0.034 N/M APSWPA5020S2R2□TF 2.2 2.90 3.10 3.20 4.00 57 0.042 N/M APSWPA5020S2R7□TF 2.7 2.70 2.90 2.90 3.50 52 0.049 N/M APSWPA5020S3R0□TF 3 2.70 2.90 2.55 2.80 49 0.049 N/M APSWPA5020S3R3□TF 3.3 2.50 2.70 2.55 3.00 46 0.056 N/M APSWPA5020S3R6□TF 3.6 2.50 2.70 2.80 3.00 43 0.056 N/M APSWPA5020S3R9□TF 3.9 2.50 2.70 2.30 2.80 40 0.056 N/M APSWPA5020S4R3MTF 4.3 2.20 2.40 2.50 3.00 37 0.074 M APSWPA5020S4R7MTF 4.7 2.20 2.40 2.50 2.70 37 0.074 M APSWPA5020S5R1MTF 5.1 2.05 2.20 2.25 2.60 32 0.083 M APSWPA5020S5R6MTF 5.6 2.05 2.20 2.30 2.50 32 0.083 M APSWPA5020S6R8MTF 6.8 1.80 1.90 2.05 2.20 30 0.108 M APSWPA5020S7R5MTF 7.5 1.75 1.90 1.85 2.00 26 0.117 M APSWPA5020S8R2MTF 8.2 1.65 1.80 1.85 2.00 26 0.127 M APSWPA5020S9R1MTF 9.1 1.55 1.70 1.70 1.80 24 0.143 M APSWPA5020S100MTF 10 1.55 1.70 1.70 1.80 24 0.143 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP5020 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Irms Isat Inductance Tolerance M=±20% N=±30% Symbol L S.R.F DCR APSWPA5020S120MTF 12 1.40 1.50 1.50 1.60 22 0.182 M APSWPA5020S150MTF 15 1.25 1.30 1.35 1.40 20 0.215 M APSWPA5020S180MTF 18 1.15 1.20 1.25 1.30 16 0.260 M APSWPA5020S220MTF 22 1.10 1.20 1.15 1.20 14 0.294 M APSWPA5020S330MTF 33 0.90 0.99 0.92 1.00 10 0.507 M APSWPA5020S470MTF 47 0.77 0.84 0.77 0.84 7 0.680 M APSWPA5020S560MTF 56 0.70 0.77 0.77 0.84 6 0.819 M APSWPA5020S680MTF 68 0.64 0.70 0.65 0.70 6 0.962 M APSWPA5020S820MTF 82 0.50 0.60 0.65 0.75 6 1.158 M APSWPA5020S101MTF 100 0.53 0.58 0.53 0.58 6 1.430 M APSWPA5020S121MTF 120 0.40 0.50 0.42 0.53 6 1.755 M APSWPA5020S201MTF 200 0.40 0.45 0.30 0.33 4.5 2.600 M Inductance Tolerance ● APSWP5040 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms Isat M=±20% N=±30% S.R.F DCR 18.00 20.00 289 0.008 M 7.40 15.70 18.00 251 0.008 N/M 7.60 10.00 11.50 171 0.013 M 5.10 7.35 8.20 117 0.018 N/M 4.30 6.50 7.10 110 0.021 N/M 7.30 86 0.020 N/M 6.40 55 0.021 M 5.60 50 0.027 N/M 5.10 37 0.029 N/M APSWPA5040SR22MTF 0.22 6.50 7.50 APSWPA5040SR24□TF 0.24 6.40 APSWPA5040SR47MTF 0.47 6.60 APSWPA5040S1R0□TF 1 4.90 APSWPA5040S1R2□TF 1.2 4.15 APSWPA5040S1R5□TF 1.5 4.30 4.80 6.30 APSWPA5040S1R8MTF 1.8 4.15 4.30 5.50 APSWPA5040S2R2□TF 2.2 3.80 4.30 4.90 APSWPA5040S2R7□TF 2.7 3.60 4.10 4.30 APSWPA5040S3R0□TF 3 3.60 4.20 4.15 4.80 37 0.029 N/M APSWPA5040S3R3□TF 3.3 3.40 3.90 3.95 4.60 32 0.031 N/M APSWPA5040S3R6MTF 3.6 3.30 3.70 3.80 4.40 30 0.031 M APSWPA5040S3R9□TF 3.9 3.20 3.70 3.55 4.20 29 0.035 N/M APSWPA5040S4R7□TF 4.7 3.00 3.30 3.50 3.90 28 0.041 N/M APSWPA5040S5R6MTF 5.6 2.80 3.10 3.00 4.10 27 0.046 M APSWPA5040S6R8MTF 6.8 2.50 2.80 2.90 3.50 21 0.056 M APSWPA5040S8R2MTF 8.2 2.30 2.60 2.70 3.00 20 0.062 M APSWPA5040S100MTF 10 2.10 2.40 2.35 2.90 18 0.083 M APSWPA5040S120MTF 12 2.00 2.10 2.20 2.50 14 0.100 M APSWPA5040S150MTF 15 2.00 2.10 2.00 2.30 13 0.112 M APSWPA5040S180MTF 18 1.45 1.65 1.70 2.00 12 0.155 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP5040 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA5040S220MTF 22 Irms 1.50 Isat 1.60 1.60 Inductance Tolerance M=±20% N=±30% S.R.F DCR 1.90 11 0.168 M APSWPA5040S270MTF 27 1.10 1.25 1.52 1.75 9.8 0.244 M APSWPA5040S330MTF 33 1.20 1.40 1.30 1.50 9 0.244 M APSWPA5040S470MTF 47 1.00 1.10 1.10 1.30 7 0.354 M APSWPA5040S510MTF 51 1.00 1.10 1.00 1.20 6 0.494 M APSWPA5040S560MTF 56 0.80 0.90 1.05 1.20 6 0.494 M APSWPA5040S680MTF 68 0.80 0.90 0.90 1.10 6 0.520 M APSWPA5040S750MTF 75 0.72 0.80 0.85 0.95 6 0.585 M APSWPA5040S101MTF 100 0.70 0.80 0.75 0.90 5 0.728 M APSWPA5040S151MTF 150 0.60 0.70 0.65 0.67 3.7 0.975 M APSWPA5040S221MTF 220 0.40 0.50 0.48 0.55 3 1.820 M APSWPA5040S301MTF 300 0.35 0.40 0.50 0.58 2.7 2.600 M APSWPA5040S331MTF 330 0.40 0.50 0.42 0.47 2.7 2.730 M APSWPA5040S471MTF 470 0.35 0.40 0.37 0.43 2.7 3.900 M APSWPA5040S561MTF 560 0.31 0.35 0.31 0.36 1.5 4.920 M APSWPA5040S681MTF 680 0.25 0.30 0.30 0.35 1.6 5.070 M APSWPA5040S102MTF 1000 0.20 0.23 0.21 0.25 1.3 7.800 M Inductance Tolerance ● APSWP5045 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω L Irms Isat S.R.F DCR Inductance M=±20% N=±30% APSWPA5045S2R2MTF 2.2 4.70 5.40 6.40 7.20 50 0.029 M APSWPA5045S100MTF 10 2.50 2.90 3.20 3.70 17 0.079 M APSWPA5045S220MTF 22 1.55 1.80 2.00 2.35 10 0.163 M Inductance Tolerance ● APSWP6020 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms S.R.F DCR 4.50 6.00 120 0.018 N/M 4.80 6.55 7.80 115 0.022 N/M 4.80 5.30 6.30 110 0.022 N/M 4.40 4.15 5.00 100 0.026 N/M 4.00 5.90 7.00 88 0.029 N/M 4.00 4.25 5.10 79 0.029 N/M APSWPA6020SR50□TF 0.5 4.00 5.00 APSWPA6020SR68□TF 0.68 3.80 APSWPA6020SR82□TF 0.82 3.80 APSWPA6020S1R0□TF 1 3.50 APSWPA6020S1R2□TF 1.2 3.20 APSWPA6020S1R5□TF 1.5 3.20 Isat M=±20% N=±30% Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP6020 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA6020S1R8□TF 1.8 2.75 Irms Isat APSWPA6020S2R0□TF 2 2.60 3.30 APSWPA6020S2R2□TF 2.2 2.75 3.50 APSWPA6020S2R7□TF 2.7 2.60 3.30 APSWPA6020S3R3□TF 3.3 2.60 3.30 APSWPA6020S3R9□TF 3.9 2.10 APSWPA6020S4R3□TF 4.3 2.10 APSWPA6020S4R7□TF 4.7 APSWPA6020S5R6□TF 5.6 APSWPA6020S6R2□TF APSWPA6020S6R8□TF APSWPA6020S8R2□TF APSWPA6020S100MTF Inductance Tolerance M=±20% N=±30% S.R.F DCR 5.80 68 0.036 N/M 4.10 4.90 65 0.046 N/M 3.75 4.50 61 0.036 N/M 3.90 4.60 56 0.046 N/M 3.15 3.70 51 0.046 N/M 2.60 3.25 3.90 45 0.064 N/M 2.60 2.70 3.20 44 0.064 N/M 2.00 2.50 3.00 3.60 41 0.075 N/M 1.90 2.40 2.40 2.90 36 0.075 N/M 6.2 1.80 2.30 2.30 2.70 31 0.103 N/M 6.8 1.80 2.30 2.20 2.60 31 0.103 N/M 8.2 1.40 1.80 2.10 2.50 27 0.137 N/M 10 1.40 1.80 1.75 2.10 27 0.137 M APSWPA6020S120MTF 12 1.30 1.60 1.45 1.70 25 0.156 M APSWPA6020S150MTF 15 1.20 1.50 1.20 1.40 21 0.189 M APSWPA6020S180MTF 18 1.08 1.40 1.20 1.40 18 0.234 M APSWPA6020S220MTF 22 1.00 1.30 1.05 1.20 16 0.265 M APSWPA6020S330MTF 33 0.84 1.05 0.95 1.10 11 0.390 M APSWPA6020S470MTF 47 0.80 0.90 0.70 0.90 10 0.559 M APSWPA6020S331MTF 330 0.33 0.39 0.27 0.33 3 3.419 M Inductance Tolerance 3.50 4.85 ● APSWP6028 Series Part Number Units Symbol APSWPA6028SR82□TF @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L 0.82 Irms 5.20 Isat 6.00 M=±20% N=±30% S.R.F DCR 6.50 9.00 97 0.016 N/M APSWPA6028S1R0□TF 1 5.20 5.70 5.75 7.00 70 0.013 N/M APSWPA6028S1R2□TF 1.2 4.58 5.00 6.40 7.50 69 0.017 N/M APSWPA6028S1R5□TF 1.5 4.58 5.00 6.00 6.60 65 0.017 N/M APSWPA6028S2R2□TF 2.2 3.75 4.10 5.10 5.60 48 0.026 N/M APSWPA6028S2R7□TF 2.7 3.75 4.10 3.80 4.10 48 0.026 N/M APSWPA6028S3R3□TF 3.3 3.48 3.80 4.15 4.50 41 0.033 N/M APSWPA6028S4R7□TF 4.7 3.08 3.40 3.00 3.30 35 0.039 N/M APSWPA6028S5R1□TF 5.1 2.60 2.80 3.20 3.50 32 0.056 N/M APSWPA6028S6R2MTF 6.2 2.40 2.60 3.05 3.30 30 0.061 M APSWPA6028S6R8MTF 6.8 2.40 2.60 2.60 3.00 27 0.061 M APSWPA6028S8R2MTF 8.2 2.25 2.50 2.30 2.50 24 0.072 M APSWPA6028S9R1MTF 9.1 2.15 2.40 2.55 2.80 24 0.096 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP6028 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Irms Isat Inductance Tolerance M=±20% N=±30% Symbol L S.R.F DCR APSWPA6028S100MTF 10 1.95 2.40 2.04 2.50 23 0.094 M APSWPA6028S120MTF 12 1.85 2.00 1.80 2.00 18 0.104 M APSWPA6028S150MTF 15 1.45 1.60 1.75 1.90 18 0.163 M APSWPA6028S180MTF 18 1.45 1.60 1.52 1.80 15 0.156 M APSWPA6028S220MTF 22 1.40 1.60 1.45 1.80 14 0.182 M APSWPA6028S270MTF 27 1.32 1.40 1.50 1.60 13 0.202 M APSWPA6028S330MTF 33 1.22 1.30 1.35 1.50 12 0.241 M APSWPA6028S360MTF 36 1.13 1.20 1.25 1.40 11 0.280 M APSWPA6028S390MTF 39 1.10 1.20 1.25 1.40 11 0.293 M APSWPA6028S470MTF 47 1.06 1.10 1.15 1.30 9.5 0.410 M APSWPA6028S560MTF 56 0.89 1.00 1.05 1.20 8.2 0.449 M APSWPA6028S680MTF 68 0.86 0.95 0.80 0.95 7.7 0.468 M APSWPA6028S750MTF 75 0.81 0.90 0.90 0.99 7.7 0.533 M APSWPA6028S820MTF 82 0.70 0.77 0.80 0.88 7.7 0.650 M APSWPA6028S101MTF 100 0.70 0.77 0.65 0.71 7.1 0.650 M APSWPA6028S401MTF 400 0.40 0.45 0.30 0.33 2.8 2.808 M APSWPA6028S102MTF 1000 0.23 0.26 0.18 0.22 1.5 7.540 M Inductance Tolerance ● APSWP6040 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Irms Isat M=±20% N=±30% Symbol L S.R.F DCR APSWPA6040S100MTF 10 2.45 2.80 3.20 3.50 16 0.062 M APSWPA6040S150MTF 15 2.05 2.35 2.50 3.00 13 0.088 M Inductance Tolerance ● APSWP6045 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω L Irms Isat S.R.F DCR Inductance M=±20% N=±30% APSWPA6045SR47□TF 0.47 6.50 6.60 15.00 16.50 155 0.008 N/M APSWPA6045SR56□TF 0.56 6.50 6.60 14.00 15.00 142 0.008 N/M APSWPA6045SR68□TF 0.68 5.70 6.50 11.00 12.00 99 0.008 N/M APSWPA6045SR82□TF 0.82 5.90 6.50 10.35 11.00 140 0.010 N/M APSWPA6045S1R0□TF 1 5.14 5.60 9.85 10.00 100 0.014 N/M APSWPA6045S1R2□TF 1.2 5.40 5.90 8.35 9.10 100 0.013 N/M APSWPA6045S1R3□TF 1.3 5.40 5.90 8.35 9.10 100 0.013 N/M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP6045 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Irms Isat Inductance Tolerance M=±20% N=±30% Symbol L S.R.F DCR APSWPA6045S1R5□TF 1.5 4.95 5.40 8.80 9.70 65 0.016 N/M APSWPA6045S1R8□TF 1.8 4.95 5.40 7.60 8.40 74 0.016 N/M APSWPA6045S2R2□TF 2.2 4.60 5.00 6.75 7.40 52 0.023 N/M APSWPA6045S2R3□TF 2.3 3.50 3.80 6.00 6.60 60 0.027 N/M APSWPA6045S2R7□TF 2.7 4.30 4.70 5.75 6.30 38 0.020 N/M APSWPA6045S3R0□TF 3 3.80 4.20 5.60 6.20 35 0.026 N/M APSWPA6045S3R3□TF 3.3 3.70 4.00 5.90 6.20 32 0.027 N/M APSWPA6045S3R6□TF 3.6 3.70 4.00 5.25 5.70 28 0.027 N/M APSWPA6045S4R3MTF 4.3 3.50 3.80 4.45 4.90 23 0.030 M APSWPA6045S4R5MTF 4.5 3.30 3.60 4.97 5.50 24 0.034 M APSWPA6045S4R7MTF 4.7 3.30 3.60 4.97 5.50 24 0.034 M APSWPA6045S5R1MTF 5.1 3.30 3.60 4.40 4.80 23 0.034 M APSWPA6045S5R6MTF 5.6 3.15 3.40 4.15 4.60 23 0.038 M APSWPA6045S6R2MTF 6.2 3.00 3.30 4.43 4.80 26 0.040 M APSWPA6045S6R3MTF 6.3 3.00 3.30 4.43 4.70 26 0.040 M APSWPA6045S6R8MTF 6.8 3.00 3.30 3.90 4.30 20 0.040 M APSWPA6045S7R5MTF 7.5 2.90 3.20 3.50 3.80 18 0.044 M APSWPA6045S8R2MTF 8.2 2.60 2.80 3.90 4.30 21 0.060 M APSWPA6045S9R1MTF 9.1 2.60 2.80 3.35 3.70 17 0.056 M APSWPA6045S100MTF 10 2.45 2.70 3.20 3.50 15 0.062 M APSWPA6045S120MTF 12 2.20 2.40 2.80 3.00 13 0.075 M APSWPA6045S150MTF 15 2.05 2.20 2.50 2.70 12 0.088 M APSWPA6045S180MTF 18 1.85 2.00 2.20 2.40 10 0.105 M APSWPA6045S220MTF 22 1.80 2.00 2.05 2.20 10 0.116 M APSWPA6045S270MTF 27 1.65 1.80 1.90 2.10 9.2 0.133 M APSWPA6045S300MTF 30 1.50 1.60 1.70 1.80 7.8 0.172 M APSWPA6045S330MTF 33 1.45 1.60 1.65 1.80 7.8 0.178 M APSWPA6045S360MTF 36 1.40 1.50 1.62 1.80 7.8 0.225 M APSWPA6045S390MTF 39 1.25 1.40 1.50 1.60 7.8 0.234 M APSWPA6045S430MTF 43 1.20 1.30 1.63 1.80 7.7 0.260 M APSWPA6045S470MTF 47 1.20 1.30 1.40 1.50 6.4 0.260 M APSWPA6045S510MTF 51 1.15 1.20 1.35 1.50 6.4 0.269 M APSWPA6045S560MTF 56 1.10 1.20 1.30 1.40 6.4 0.287 M APSWPA6045S620MTF 62 1.10 1.20 1.25 1.40 6.4 0.306 M APSWPA6045S680MTF 68 1.00 1.10 1.20 1.30 6.4 0.376 M APSWPA6045S750MTF 75 0.95 1.00 1.15 1.20 5 0.397 M APSWPA6045S820MTF 82 0.90 0.99 1.05 1.10 4.9 0.500 M APSWPA6045S910MTF 91 0.85 0.94 1.00 1.10 4.9 0.467 M APSWPA6045S101MTF 100 0.80 0.88 0.95 1.00 4.2 0.563 M APSWPA6045S121MTF 120 0.77 0.85 0.85 0.94 4.2 0.629 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP6045 Series Part Number Units Symbol APSWPA6045S151MTF @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms Isat Inductance Tolerance M=±20% N=±30% S.R.F DCR 0.88 4.2 0.754 M 0.70 0.77 3.5 1.084 M 0.57 0.63 2.8 1.651 M 0.56 2 2.340 M 0.46 1.7 3.250 M 1.3 5.850 M Inductance Tolerance 150 0.70 0.77 0.80 APSWPA6045S221MTF 220 0.59 0.65 APSWPA6045S331MTF 330 0.57 0.63 APSWPA6045S471MTF 470 0.42 0.48 0.50 APSWPA6045S681MTF 680 0.33 0.38 0.42 APSWPA6045S102MTF 1000 0.30 0.35 0.30 0.35 ● APSWP8040 Series Part Number Units Symbol APSWPA8040SR82□TF @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms Isat M=±20% N=±30% S.R.F DCR 13.80 16.00 94 0.010 N/M 6.90 9.85 14.00 89 0.010 N/M 6.20 10.00 14.00 59 0.013 N/M 11.00 67 0.013 N/M 10.00 43 0.016 N/M 41 0.016 N/M 32 0.018 N/M 27 0.022 N/M 30 0.022 N/M 26 0.022 N/M 24 0.025 N/M 22 0.025 N/M 24 0.027 N/M 20 0.027 N/M 20 0.031 M 4.80 17 0.034 M 4.10 15 0.038 M 3.50 4.00 13 0.053 M 2.95 3.40 12 0.061 M 11 0.069 M 9.5 0.090 M 9.2 0.101 M 7.8 0.126 M 7.8 0.133 M 7.8 0.139 M 2.20 7.8 0.147 M 2.00 6.4 0.177 M 0.82 6.30 6.90 APSWPA8040S1R0□TF 1 6.30 APSWPA8040S1R2□TF 1.2 5.65 APSWPA8040S1R5□TF 1.5 5.65 6.20 8.15 APSWPA8040S2R0□TF 2 5.15 5.60 9.25 APSWPA8040S2R2□TF 2.2 5.15 5.60 7.10 8.00 APSWPA8040S3R0□TF 3 4.70 5.20 6.10 7.00 APSWPA8040S3R3□TF 3.3 4.40 4.80 6.50 7.00 APSWPA8040S3R6□TF 3.6 4.35 4.80 7.52 8.50 APSWPA8040S3R9□TF 3.9 4.35 4.80 5.75 6.50 APSWPA8040S4R7□TF 4.7 4.10 4.50 5.90 6.50 APSWPA8040S5R1□TF 5.1 4.05 4.40 4.70 5.40 APSWPA8040S5R6□TF 5.6 3.85 4.20 6.00 6.90 APSWPA8040S6R2□TF 6.2 3.85 4.20 4.45 5.10 APSWPA8040S6R8MTF 6.8 3.60 4.00 4.55 5.20 APSWPA8040S8R2MTF 8.2 3.45 3.80 4.20 APSWPA8040S100MTF 10 3.30 3.60 3.60 APSWPA8040S120MTF 12 2.80 3.00 APSWPA8040S150MTF 15 2.60 2.80 APSWPA8040S180MTF 18 2.40 2.60 2.70 3.10 APSWPA8040S220MTF 22 2.10 2.30 2.40 2.70 APSWPA8040S270MTF 27 2.00 2.20 2.15 2.50 APSWPA8040S330MTF 33 1.80 2.00 2.05 2.40 APSWPA8040S360MTF 36 1.75 1.90 2.00 2.30 APSWPA8040S390MTF 39 1.70 1.90 1.95 2.20 APSWPA8040S430MTF 43 1.65 1.80 1.90 APSWPA8040S470MTF 47 1.55 1.70 1.75 Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP8040 Series Part Number Units @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance Symbol L APSWPA8040S510MTF 51 1.50 Irms APSWPA8040S560MTF 56 APSWPA8040S620MTF 62 APSWPA8040S680MTF APSWPA8040S750MTF APSWPA8040S820MTF APSWPA8040S910MTF APSWPA8040S101MTF 100 1.00 APSWPA8040S121MTF 120 0.95 APSWPA8040S151MTF 150 0.85 APSWPA8040S181MTF 180 0.83 APSWPA8040S221MTF 220 APSWPA8040S331MTF 330 APSWPA8040S471MTF 470 Isat Inductance Tolerance M=±20% N=±30% S.R.F DCR 1.60 1.70 1.90 6.4 0.185 M 1.45 1.60 1.55 1.70 6.4 0.192 M 1.30 1.40 1.50 1.60 6.4 0.237 M 68 1.25 1.40 1.45 1.60 4.9 0.255 M 75 1.20 1.30 1.35 1.50 4.9 0.274 M 82 1.15 1.20 1.30 1.40 5.9 0.293 M 91 1.05 1.10 1.20 1.30 4.9 0.354 M 1.10 1.15 1.30 4.2 0.377 M 1.00 1.05 1.10 3.5 0.434 M 0.94 1.10 1.20 3.5 0.533 M 0.92 0.95 1.15 3.5 0.676 M 0.80 0.88 0.85 0.94 3.5 0.779 M 0.64 0.70 0.68 0.75 2.8 1.156 M 0.50 0.60 0.60 0.70 2.1 1.625 M Inductance Tolerance ● APSWP8065 Series Part Number Units Symbol APSWPA8065SR68MTF @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms Isat M=±20% N=±30% S.R.F DCR 100 0.008 M 96 0.011 M 45 0.016 M 27 0.018 M 18 0.022 M 9.00 17 0.026 M 8.00 16 0.026 M 15 0.031 M 13 0.044 M 6.70 10 0.053 M 4.80 8 0.072 M 7 0.152 M 6 0.198 M 5 0.218 M 3.1 0.280 M 0.68 7.50 8.50 24.00 26.00 APSWPA8065S1R0MTF 1 7.00 8.00 20.00 22.00 APSWPA8065S2R2MTF 2.2 5.20 4.50 13.80 12.00 APSWPA8065S3R3MTF 3.3 5.10 5.90 9.50 10.00 APSWPA8065S4R7MTF 4.7 4.70 5.40 8.50 9.50 APSWPA8065S5R6MTF 5.6 4.50 5.20 8.00 APSWPA8065S6R8MTF 6.8 4.50 5.20 7.50 APSWPA8065S8R2MTF 8.2 4.20 4.80 7.00 7.70 APSWPA8065S100MTF 10 3.20 3.70 8.00 8.90 APSWPA8065S150MTF 15 3.25 3.75 5.70 APSWPA8065S220MTF 22 2.70 3.10 4.30 APSWPA8065S470MTF 47 1.85 2.15 3.40 3.70 APSWPA8065S560MTF 56 1.35 1.55 3.20 3.70 APSWPA8065S680MTF 68 1.55 1.80 2.70 3.20 APSWPA8065S101MTF 100 1.35 1.45 2.00 2.40 APSWPA8065S151MTF 150 0.95 1.10 1.60 2.00 2.5 0.440 M APSWPA8065S221MTF 220 0.80 0.90 1.20 1.50 2 0.656 M APSWPA8065S331MTF 330 0.75 0.85 1.00 1.20 1.7 0.840 M APSWPA8065S471MTF 470 0.55 0.65 1.00 1.20 1.4 1.560 M Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ Electrical Characteristics ● APSWP8065 Series Part Number Units Symbol @100kHz,1V Heat Rating Current Max. Typ. Saturation Current Max. Typ. Self-resonant Frequency Min. DC Resistance Max. μH A A MHz Ω Inductance L Irms Isat Inductance Tolerance M=±20% N=±30% S.R.F DCR APSWPA8065S681MTF 680 0.52 0.60 0.85 1.00 1 1.944 M APSWPA8065S102MTF 1000 0.40 0.45 0.65 0.73 1.1 2.820 M △1: All test data is referenced to 20°C ambient; △2: Rated current: Isat or Irms, whichever is smaller; △3: Irms: DC current that causes the temperature rise (△T =40°C) from 20°C ambient. ▉ TYPICAL ELECTRICAL CHARACTERISTICS APSWPA252010 Series Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS APSWPA252012 Series APSWPA3010 Series APSWPA3012 Series Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS APSWPA3015 Series APSWPA4010 Series APSWPA4012 Series Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS APSWPA4018 Series APSWPA4020 Series APSWPA4030 Series Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS APSWPA5012 Series APSWPA5020 Series APSWPA5040 Series Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS APSWPA6020 Series APSWPA6028 Series APSWPA6045 Series Specifications subject to change without notice. Please check our website for latest information. 2023/03/10 Wire Wound SMD Power Inductors - APSWPA Series ▉ TYPICAL ELECTRICAL CHARACTERISTICS APSWPA8040 Series APSWPA8065 Series Note: This series product is not applies in automotive or related products. Otherwise, we will shall not bear than the resulting all the problems of quality and responsibility. Please be sure to request approval specifications that provide further details of the products. Kindly not that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without APV approval. Specifications subject to change without notice. Please check our website for latest information. 2023/03/10
APSWPA6045S471MTF 价格&库存
很抱歉,暂时无法提供与“APSWPA6045S471MTF”相匹配的价格&库存,您可以联系我们找货
