Aluminum Electrolytic Capacitors
SSD Series
Customer :
Electric Characteristics:
KNSCHA
Part Number
Cap.
(120Hz)
(uF)
Cap.
Tol.
Rate
Volt.
(V-DC)
Surge
Volt.
(V-DC)
Oper.
Temp.
Nominal
Case Size
D*L(mm)
Leakage
Current
Max(uA)
D.F.
Max
RC
120HZ
(mArms)
ESR
100KHZ
(Ω)
Normal
servicelife
(Hours)
152EC0410
100
±20
50
62
-40∽105℃
6.3*12
50.0
0.10
317
0.480
3000
152EC0411
100
±20
35
43
-40∽105℃
6.3*11
35.0
0.12
367
0.300
2000
以下空白
D
SS
D
SS
Items 项 目
Characteristics
Capacitance Tolerance
静电 量误
性
± 20%(120Hz﹐20℃)
Operating Temperature Range
用温 范围
-40 ~ +105℃
-25 ~ +105℃
Rated Voltage Range
额 电压范围
6.3 ~ 400VDC
450VDC
Leakage Current
漏电
V ≦ 100V I ≦ 0.01CV or 3 ( μA) ( After 2 minutes application of DC rated voltage, at 20℃)
V>100V I ≦ 0.03CV +20 ( μA) ( After 5 minutes application of DC rated voltage, at 20℃)
Measurement Frequency: 120Hz. Temperature: 20℃
Dissipation Factor
散
( tan δ)
Rated Voltage(V)
6.3
10
16
25
35
50
63
100
160~250
400~450
tan δ(Max)
0.22
0.19
0.16
0.14
0.12
0.10
0.08
0.07
0.20
0.24
When nominal capacitance over 1000µF, tanδ shall be added 0.02 to the listed value with
increase of every 1000µF.
Low Temperature Stability
温 性
Impedance Ratio(Max)
阻
( 大值)
Rated Voltage(V)
6.3
10
16
25
35
50
63
100
160~250
400
450
Z(-25℃) ∕ Z(20℃)
4
3
2
2
2
2
2
2
3
5
6
Z(-40℃) ∕ Z(20℃)
8
6
4
3
3
3
3
3
6
10
12
2000hours,with application of rated voltage at 105℃£¨ φ ¡Ý8:3000hours£©
Load Life 负荷
Shelf Life
Standards
命
命
照标
Rated Voltage (V)
6.3 ~ 100
160 ~ 450
Capacitance Change
Within ± 20% of Initial Value
tan δ
200% or less of Initial Specified Value
Leakage Current
Initial Specified Value or less
The following specifications shall be satisfied when the capacitors are restored to 20℃ after
exposing them for 1,000 hours 105℃ without voltage applied. Before the measurement, the
capacitor shall be preconditioned by applying voltage according to them 4.1 of JIS C5101-4.
Capacitance Change
tan δ
Leakage Current
JIS C 5101-4 (IEC 60384)
Capacitance (μF)
Frequency (Hz)
50
120
1K
10K
100K
0.47 ~ 100
0.45
0.55
0.75
0.90
1.00
220 ~ 1000
0.60
0.70
0.85
0.95
1.00
1500 ~ 15000
0.70
0.80
0.95
0.98
1.00
2.2 ~ 330
0.55
0.65
0.80
0.90
1.00
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use , the rms ripple current has to be reduced.
ψD
P
ψd
5
2.0
0.5
6.3
2.5
0.5
8
3.5
0.5
10
5.0
0.6
13
5.0
0.6
16
7.5
0.8
18
7.5
0.8
α
(L < 16) 1.0
(L ≧ 16) 2.0
D×L(mm) ; R.C.(mA rms) at 105℃ 100KHz ; IMP (Ω max)at 20℃ 100KHz.
V
Cap (Code)
(μF)
Item
DxL
4.7
10
22
47
68
100
220
6.3x11.
330
6.3x11.
470
08x12
680
08x12
1000
10x13
1500
10x16
2200
10x25
3300
13x21
4700
13x25
6800
16x26
10000
16x32
15000
16x35
V
Cap (Code)
(μF)
Item
DxL
0.47
1
2.2
3.3
4.7
05x11
10
05x11
22
05x11
33
05x11
47
6.3x11.
68
08x12
100
08x12
220
10x13
330
10x16
470
10x20
680
13x21
1000
13x25
1500
16x26
2200
16x32
3300
18x35
4700
18x40
6.3
(0J)
R.C.
270
320
440
440
650
800
1350
1350
1820
2050
2550
2950
10
(1A)
16
(1C)
25
(1E)
IMP
DxL
R.C.
IMP
DxL
R.C.
IMP
0.300
0.300
0.200
0.100
0.100
0.075
0.055
0.055
0.035
0.030
0.027
0.025
05x11
05x11
05x11
6.3x11.
08x12
08x12
10x13
10x16
10x20
13x21
13x25
16x26
16x32
18x35
18x40
140
160
180
270
440
440
650
800
1050
1350
1650
2050
2550
2950
3300
0.650
0.650
0.650
0.300
0.200
0.200
0.100
0.075
0.058
0.055
0.043
0.030
0.027
0.025
0.023
05x11
05x11
6.3x11.
08x12
08x12
10x13
10x16
10x20
13x21
13x25
16x26
16x32
18x35
18x40
170
210
270
440
440
650
800
1050
1350
1650
2050
2550
2950
3300
0.650
0.550
0.300
0.200
0.200
0.100
0.075
0.058
0.055
0.043
0.030
0.027
0.025
0.023
35
(1V)
50
(1H)
R.C.
IMP
85
100
120
210
270
360
440
650
800
1050
1350
1650
2050
2550
2950
3300
2.000
1.200
1.000
0.430
0.300
0.300
0.200
0.100
0.075
0.058
0.055
0.043
0.030
0.027
0.025
0.023
DxL
05x11
05x11
05x11
05x11
05x11
05x11
05x11
6.3x11.
6.3x11.
08x12
08x12
10x16
10x20
13x21
13x25
16x26
16x32
18x35
R.C.
25
40
55
65
90
110
140
240
240
300
400
600
800
1050
1150
1550
1950
2250
※ 13mm may be replaced by 12.5mm upon customer’s request.
DxL
05x11
05x11
05x11
05x11
6.3x11.
6.3x11.
08x12
10x13
10x16
10x20
13x21
13x25
16x26
16x32
18x35
18x40
63
(1J)
IMP
7.500
5.300
4.500
3.900
2.300
1.400
1.200
0.480
0.480
0.300
0.250
0.170
0.150
0.090
0.070
0.048
0.043
0.040
R.C.
50
80
110
170
210
270
440
650
800
1050
1350
1850
2050
2550
2950
3300
IMP
1.500
1.500
0.800
0.650
0.550
0.300
0.200
0.100
0.075
0.058
0.055
0.040
0.030
0.027
0.025
0.023
100
(2A)
DxL
R.C.
IMP
05x11
05x11
6.3x11.
6.3x11.
08x12
10x13
10x13
10x20
13x21
13x25
16x26
16x32
18x35
18x40
65
110
200
250
320
380
450
780
950
1430
1780
1900
2150
2350
4.494
2.252
1.000
0.900
0.800
0.760
0.580
0.170
0.142
0.070
0.055
0.043
0.033
0.032
DxL
05x11
05x11
05x11
05x11
05x11
6.3x11.
08x12
10x13
10x16
10x20
13x21
16x26
16x32
16x36
18x35
18x40
R.C.
44
58
74
130
230
320
400
420
580
880
930
1230
1410
1520
IMP
15.00
15.00
9.800
6.600
4.600
1.805
1.360
0.460
0.390
0.288
0.208
0.104
0.088
0.072
0.064
0.047
V
Cap (Code)
(μF)
Item
2.2
3.3
4.7
10
22
33
47
68
100
220
330
V
Cap (Code)
(μF)
Item
2.2
3.3
4.7
10
22
33
47
68
100
160
(2C)
DxL
08x12
08x12
10x13
10x16
10x20
13x21
13x21
16x26
16x36
18x35
R.C.
104
112
180
250
570
730
850
1285
1450
1850
200
(2D)
IMP
11.0
6.50
4.30
3.00
1.90
1.20
0.86
0.50
0.29
0.26
DxL
08x12
08x12
10x13
10x20
10x25
13x21
13x25
16x26
18x32
R.C.
113
126
210
465
600
730
985
1285
1510
250
(2E)
IMP
DxL
R.C.
IMP
11.0
6.10
3.80
2.70
1.40
1.20
0.70
0.50
0.36
08x12
08x12
10x13
10x16
13x21
13x21
13x25
16x26
16x32
18x40
105
122
140
300
485
620
810
1010
1405
1490
13.0
11.0
4.30
3.50
2.80
2.13
1.60
1.07
0.62
0.38
400
(2G)
450
(2W)
DxL
R.C.
IMP
DxL
R.C.
IMP
6.3x12
8x12
8x12
10x13
8x12
10x16
10x16
10x20
13x21
13x25
13x21
13x25
13x25
16x26
16x26
16x32
18x26
18x35
50
80
90
110
90
160
170
195
290
350
400
480
530
720
750
820
850
950
27
13
16.5
8.2
9.5
4.8
6.1
3.0
4.0
1.95
3.00
1.50
1.25
0.61
1.10
0.55
1.00
0.48
8x12
10x13
8x12
10x16
8x14
10x20
10x16
13x21
13x21
16x26
13x25
16x26
16x26
16x32
60
90
80
126
95
170
160
280
280
580
420
610
650
850
28
23
23
6.2
7.5
3.7
7.0
3.5
3.6
1.6
1.9
0.85
18x32
940
0.71
18x35
18x40
1000
1100
1.00
0.43
很抱歉,暂时无法提供与“152EC0410”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.26031
- 200+0.20500
- 1000+0.17422
- 2000+0.15575
- 10000+0.13975
- 20000+0.13123
- 国内价格
- 10+0.22458
- 100+0.22121
- 200+0.17681
- 400+0.17416
- 1000+0.15029
