DIP Power Inductors
■ Features
● High rated current for circuit design.
● Design by special lead wire to prevent open circuit failure.
● Low cost with rugged reliability and performance fixed inductor.
● Operating temperature:-40℃ ~ +125℃.
■ Applications
● TVs and Audio equipment.
● Notebook,lnkjet printer,Copying machine,Display monitor,Cellular phone.
● Switching Power Supply.
● Excellent as DC/DC converter boost or buck inductor.
■ Product Identification
⑴ :Type
⑵ :Dimensions
⑶ :Inductance value
⑷:Inductance Tolerance:N=±30%,M=±20%,K=±10%,J=±5%
■ Shapes and Dimensions (Unit:mm)
TYPE
A Max.
B Max.
C
D
E
F
YDPK0612
15.0
8.0
3.5±0.5
3.5±0.5
3.0±0.5
0.65±0.1
深圳市益嘉源电子有限公司
http://www.yjycoin.com
-1-
DIP Power Inductors
■ Electrical specification
Part Number
Inductance
(uH)
Test
Frequency
Max.DCR
(Ω)
Isat
(mA)
YDPK0612-102M
1000±20%
1KHz/0.25V
2.8
200
※ Design as Customer’s Requested Specifications.
■ Reliability test
NO.
Items
Lead terminalstrength
1
Test Methods
A static pulling force of 5N in a
direction parallel tothe lead terminals
for 60±5 seconds.
Resistance
2
tosoldering
heattest
Fix the samples on a 1.6mm
thickness PCB,then dip thesample
leads into a soldering bath of
270±5℃ up tothe PCB for 5±1
Requirements
No terminal breakage
orloosening.
No significant abnormality
inappearance.Deviation relative
toinitial value:L:Within ±10%
seconds.
Solder abilitytest
Immerse the terminal in flux for 5
seconds. Then dipthe terminal into a
3
soldering bath of 245±5℃ for 2±0.5
At least 90% of terminalelectrode
is covered by newsolder.
seconds.
Humidity test
Temperature:40℃±2℃
Humidity :90%~95%RH
4
Duration:96±4 Hours
Hightemperaturestroage
5
test
Emperature:85℃±2℃
Duration :96±4 Hours
Lowtemperaturestorage
6
test
Temperature :-25℃±2℃
Time:96±4 Hours
Thermal shocktest
7
First -25±5℃ for 30±3 minutes,
last 85±5 ℃
30±3minutes as 1
cycles. Go through 10 cycles.
深圳市益嘉源电子有限公司
-2-
DIP Power Inductors
■ Soldering Conditions
Wave Soldering:
Note:
Never contact the ceramic with the iron tip
1.0mm tip diameter(max)
■ Material list
NO
ITEM
1
Core
2
Wire
3
TUBE
4
PIN
DESCRIPTION
SUPPLIER
RATING
UL FILE
H40 DR2W 6×12
HUICI
JINYAN
155℃
E238500
QUNAITAI
125℃
E227336
OR EQUIVALENT
QA-1 φ0.20mm
OR EQUIVALENT
T-2 φ6*14.5mm UL(Black)
OR EQUIVALENT
CP Ф0.6mm
BAICHUAN
REMARK:
深圳市益嘉源电子有限公司
-3-
DIP Power Inductors
■ Package specification
Type
YDPK0612
Quantity(pcs)
Bag
Inside box
Outer box
500
5000
10000
深圳市益嘉源电子有限公司
Remark
-4-
很抱歉,暂时无法提供与“YDPK0612-102M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.91725
- 50+0.73062
- 150+0.63731
