ZD35Q2GC-IB
ZD35Q2GC-IB
    ZETTA(澜智)
    WSON-8(6x8)
    2Gb 3.3V ,SPI NAND FLASH,WSON6*8
ZD35Q2GC-IB 数据手册
2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Features NAND Flash Memory Serial Peripheral Interface (SPI) Features • Security – Blocks 7:0 are valid when shipped from factory with ECC enabled – Software write protection with lock register – Hardware write protection to freeze BP bits – Lock tight to freeze BP bits during one power cycle • Permanent block lock protection – OTP Space: 10 pages one-time programmable NAND Flash memory area • Operating voltage range – VCC = 2.7–3.6V • Operating temperature – Industrial: –40°C to +85°C • Quality and reliability – Endurance:100,000PROGRAM/ERASEcycles – Data retention: JESD47H-compliant; see qualification report – Additional: Uncycled data retention: 10 years 24/7 @85°C • Package – 16-pin SOP, 300 mils – 8-pinWSON,6mmx8mm x0.8mm – 24-ball T-PBGA, 05/6mm x 8mm • Single-level cell (SLC) technology • 2Gb density • Organization – Page size x1: 2176 bytes (2048 + 128 bytes) – Block size: 64 pages (128K + 8K bytes) – Planesize:2Gb (2planes,1024blocks per plane) • Standard and extended SPI-compatible serial bus interface – Instruction, address on 1 pin; data out on 1, 2, or 4 pins – Instructionon1pin;address,dataouton2or4 pins – Instruction,addresson1pin;datainon1or4 pins • User-selectable internal ECC supported – 8 bits/sector • Array performance – 133 MHz clock frequency (MAX) – Page read: 25µs (MAX) with on-die ECC disabled; 70µs (MAX) with on-die ECC enabled – Page program: 200µs (TYP) with on-die ECC disabled; 220µs (TYP) with on-die ECC enabled – Block erase: 2ms (TYP) • Advanced features – Read page cache mode – Read unique ID – Read parameter page • Device initialization – Automatic device initialization after power-up 1 . 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Features Part Numbering Information Figure 1: Part Number Chart 2 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Features Contents GeneralDescription......................................................................................................................................................................7 Architecture.........................................................................................................................................................................................................8 PinAssignments............................................................................................................................................................................ 9 Pin Descriptions.......................................................................................................................................................................... 10 Memory Mapping........................................................................................................................................................................ 11 Array Organization......................................................................................................................................................................................... 11 BusOperation.............................................................................................................................................................................. 12 SPI Modes................................................................................................................................................................................. 12 SPI Protocols............................................................................................................................................................................ 12 SPI NAND Command Definitions............................................................................................................................................ 13 RESET Operation............................................................................................................................................................................................ 14 WRITEOperations...................................................................................................................................................................... 15 WRITE ENABLE (06h)...............................................................................................................................................................................15 WRITE DISABLE (04h)............................................................................................................................................................................. 15 READ Operations............................................................................................................................................................................................ 16 PAGEREAD(13h)....................................................................................................................................................................16 READ FROM CACHE x1 (03h or 0Bh)................................................................................................................................................. 18 READ FROM CACHE x2 (3Bh)...............................................................................................................................................................19 READ FROM CACHE x4 (6Bh)...............................................................................................................................................................20 READ FROM CACHE Dual I/O (BBh)................................................................................................................................................. 21 READ FROM CACHE Quad I/O (EBh)................................................................................................................................................ 22 READ PAGE CACHE RANDOM (30h)..................................................................................................................................................23 READ PAGE CACHE LAST (3Fh)...........................................................................................................................................................25 READ ID (9Fh)......................................................................................................................................................................... 25 ParameterPage............................................................................................................................................................................ 26 Parameter Page Data Structure Table...................................................................................................................................................... 26 Unique ID Page.............................................................................................................................................................................27 Program Operations....................................................................................................................................................................................... 29 PAGE PROGRAM........................................................................................................................................................................................ 29 PROGRAMLOADx1(02h).....................................................................................................................................................29 PROGRAM EXECUTE (10h)................................................................................................................................................................... 30 RANDOM DATAPROGRAM x1 (84h).................................................................................................................................. 32 PROGRAM LOAD x4 (32h) and PROGRAM LOAD RANDOM DATA x4 (34h)....................................................................... 33 INTERNAL DATAMOVE........................................................................................................................................................ 33 Block Erase Operations.................................................................................................................................................................................34 Features Operations.......................................................................................................................................................................................36 GET FEATURES (0Fh) and SET FEATURES (1Fh)..........................................................................................................................36 Feature Settings..........................................................................................................................................................................................37 Security – Volatile Block Protection.......................................................................................................................................................... 38 Security – Block Protection Bits................................................................................................................................................................. 38 Security – Hardware Write Protection......................................................................................................................................................39 Security – Device Lock Tight (LOT)...........................................................................................................................................39 Permanent Block Lock Protection.............................................................................................................................................................39 PROTECTION Command (2Ch) Details.............................................................................................................................................40 PermanentBlockLockProtectionDisableMode............................................................................................................. 40 Security– One Time Programmable (OTP)............................................................................................................................. 41 EnableOTPAccess................................................................................................................................................................. 41 OTP Configuration States....................................................................................................................................................................... 41 OTPProtection andProgramPrevention........................................................................................................................... 42 Exit OTP.................................................................................................................................................................................... 42 3 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Features Status Register........................................................................................................................................................................... 43 ECC Protection............................................................................................................................................................................44 Error Management.................................................................................................................................................................... 46 SPI NOR Read Configuration.................................................................................................................................................. 47 Power-Up and Power-Down......................................................................................................................................................50 Electrical Specifications...........................................................................................................................................................52 Package Dimensions................................................................................................................................................................. 57 Package Dimensions............................................................................................................................................................ 58 Package Dimensions............................................................................................................................................................ 59 Revision History..........................................................................................................................................................................60 Rev. C –2021/ 06/15........................................................................................................................................................... 60 4 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Features List of Figures Figure1: Part Number Chart......................................................................................................................................................2 Figure2: FunctionalBlock Diagram.........................................................................................................................................8 Figure 3: 8-Pin, U-PDFN (Top View)......................................................................................................................................... 9 Figure 4: 16-Pin, SOP2 (Top View).............................................................................................................................................9 Figure5: 24-BallT-PBGA,5 x 5 (Balls Down)...........................................................................................................................9 Figure 6: Memory Map.............................................................................................................................................................. 11 Figure7: ArrayOrganization....................................................................................................................................................11 Figure 8: SPI Modes Timing......................................................................................................................................................12 Figure9: RESET (FFh)Timing..................................................................................................................................................14 Figure10: WRITEENABLE (06h)Timing............................................................................................................................... 15 Figure11: WRITEDISABLE(04h)Timing.............................................................................................................................. 15 Figure12: PAGEREAD (13h)Timing...................................................................................................................................... 17 Figure13: READ FROMCACHE (03hor0Bh)Timing......................................................................................................... 18 Figure14: READFROMCACHE x2......................................................................................................................................... 19 Figure15: READFROMCACHE x4......................................................................................................................................... 20 Figure16: READFROMCACHEDualI/O............................................................................................................................. 21 Figure17: READFROMCACHEQuadI/O............................................................................................................................ 22 Figure 18: READ PAGE CACHE RANDOM Sequence....................................................................................................................... 24 Figure 19: READ ID (9Fh) Timing............................................................................................................................................ 25 Figure20: PROGRAM LOAD (02h)Timing............................................................................................................................ 30 Figure 21: PROGRAM EXECUTE (10h) Timing................................................................................................................................... 31 Figure22: PROGRAM LOAD RANDOM DATA(84h)Timing.............................................................................................. 32 Figure23: PROGRAMLOAD x4 (32h)Timing....................................................................................................................... 33 Figure 24: BLOCK ERASE (D8h) Timing................................................................................................................................................35 Figure 25: GET FEATURES (0Fh) Timing.............................................................................................................................................. 36 Figure 26: SET FEATURES (1Fh) Timing...............................................................................................................................................36 Figure27: PROTECTCommandCycle................................................................................................................................... 40 Figure 28: Read from Cache (03h)...........................................................................................................................................48 Figure29: FastRead from Cache (0Bh).................................................................................................................................. 49 Figure 30: SPI Power-Up............................................................................................................................................................50 Figure 31: SPI Power-UpTiming..............................................................................................................................................50 Figure32: Alternative SPI Power-UpTiming.........................................................................................................................51 Figure33: ACMeasurementI/OWaveform.......................................................................................................................... 52 Figure 34: WP# Timing...............................................................................................................................................................55 Figure35: Serial InputTiming................................................................................................................................................. 56 Figure36: SerialOutputTiming.............................................................................................................................................. 56 Figure37: 16-pinSOP (300 milsbodywidth) ........................................................................................................................57 Figure38: 8-pin WSON 6mm x 8mm .....................................................................................................................................58 Figure39: 24-PinT-PBGA(5 x5 Ball GridArray)6mm x8mm...........................................................................................59 5 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Features List of Tables Table 1: SPI Pin Descriptions ......................................................................................................................................... Table 2: SPI NAND Command Set .................................................................................................................................. Table 3: READ ID Table ................................................................................................................................................. Table 4: Parameter Table ............................................................................................................................................... Table 5: Feature Address Settings and Data Bits ........................................................................................................... Table 6: Block Lock Register Block Protect Bits ............................................................................................................. Table 7: Configuration Registers for Security ................................................................................................................. Table 8: Status Register Bit Descriptions ....................................................................................................................... Table 9: ECC Status Register Bit Descriptions ............................................................................................................... Table 10:ECC Protection ................................................................................................................................................. Table 11:Error Management Details ............................................................................................................................... Table 12:Absolute Maximum Ratings .............................................................................................................................. Table 13:Operating Conditions ....................................................................................................................................... Table 14:AC Measurement Conditions ............................................................................................................................ Table 15:Capacitance ................................................................................................................................................................ Table 16:DC Characteristics ........................................................................................................................................... Table 17:AC Characteristics ........................................................................................................................................... Table 18:PROGRAM/READ/ERASE Characteristics ....................................................................................................... 6 10 13 25 26 37 38 42 43 44 45 46 52 52 52 53 53 53 54 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory General Description General Description Serial peripheral interface (SPI) NAND is an SLC NAND Flash memory device that provides a cost-effective nonvolatile memory storage solution where pin count must be kept to a minimum. It is also an alternative solution to SPI NOR, offering superior write performance and cost per bit over SPI NOR. The hardware interface creates a low pin count device with a standard pin out that remains the same from one density to another and supports future upgrades to higher densities without board redesign. The serial electrical interface follows the industry-standard serial peripheral interface. New command protocols and registers are defined for SPI operation. The command set resembles common SPI-NOR command sets, modified to handle NAND specific functions and additional new features. New features include user-selectable internal ECC and first page auto-load on power- up.SPI NAND Flash devices have six signal lines plus VCC and ground (GND).The signal lines are SCK (serial clock), SI, SO (for command/response and data input/output), and control signals CS, HOLD#, WP#. This hardware interface creates a low pin-count device with a standard pinout that remains the same from one density to another, supporting future upgrades to higher densities without board redesign. Each block of the serial NAND Flash device is divided into 64 programmable pages, each page consisting of 2176 bytes. Each page is further divided into a 2048-byte data storage region and a 128-byte spare area. The 128-byte area is typically used for memory and error management functions. With internal ECC enabled as the default after poweron, ECC code is generated internally when a page is written to the memory core. The ECC code is stored in the spare area of each page.When a page is read to the cache register,the ECC code is calculated again and compared with the stored value. Errors are corrected if necessary. The device either outputs corrected data or returns an ECC error status. The internal ECC can be configured off after device initialization. Contact Zetta representative if ECC is required to be default off after power on. The first eight blocks are valid when shipped from factory. Security functions are also provided including software block protection: Lock tight and hardware protection modes avoid array data corruption. 7 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Architecture Architecture The devices use an industry-standard NAND Flash memory coreorganized by page/block. The standard parallel NAND Flash electrical interface and I/O logic are replaced by an SPI interface. The new command protocol set is a modification of the SPI NOR command set available in the industry. The modifications are specifically to handle functions related to NAND Flash architecture. The interface supports page and random read/write and internal data move functions. The device also includes an internal ECC feature. Data is transferred to or from the NAND Flash memory array,page-by-page, to a cache register and a data register. The cache register is closest to I/O control circuits and acts as a data buffer for the I/O data;the data register is closest to the memory array and acts as a data buffer for the NAND Flash memory array operation. The NAND Flash memory array is programmed and read in page-based operations; it is erased in block-based operations. The cache register functions as the buffer memory to enable random data READ/WRITE operations. These devices also use a new SPI status register that reports the status of device operation. Figure 2: Functional Block Diagram 8 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Pin Assignments Pin Assignments Figure 3: 8-Pin, WSON (Top View) CS# 1 8 VCC SO/IO1 2 7 HOLD#/IO3 WP#/IO2 3 6 SCK VSS 4 5 SI/IO0 Figure 4: 16-Pin, SOP2 (Top View) HOLD#/IO3 1 16 SCK VCC 2 15 SI/IO0 DNU 3 14 DNU DNU 4 13 DNU DNU 5 12 DNU DNU 6 11 DNU CS# 7 10 SO/IO1 VSS 8 9 WP#/IO2 Figure 5: 24-Ball T-PBGA, 5 x 5 (Balls Down) 1 2 3 4 5 DNU DNU DNU DNU DNU SCK VSS VCC DNU DNU CS# DNU WP#/IO2 DNU DNU S0/IO1 S1/IO0 HOLD#/IO3 DNU DNU DNU DNU DNU DNU A B C D E 9 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Pin Descriptions Pin Descriptions Table 1: SPI Pin Descriptions Symbol Type Description CS# Input Chip select: Places the device in active power mode when driven LOW. Deselects the device and places SO at High-Z when HIGH. After power-up, the device requires a falling edge on CS# before any command can be written. The device goes into standby mode when no PROGRAM, ERASE, or WRITE STATUS REGISTER operation is in progress. In the case of write-type instructions, CS# must be driven HIGH after a whole sequence is completed. Single command and address sequences and array-based operations are registered on CS#. SCK Input Serial clock: Provides serial interface timing. Latches commands, addresses, and data on SI on the rising edge of SCK. Triggers output on SO after the falling edge of SCK. While CS# is HIGH, keep SCK at VCC or GND (determined by mode 0 or mode 3). Do not toggle SCK until CS# is driven LOW. WP# Input Write protect: When LOW, prevents overwriting block lock bits (BP[3:0] and TB) if the block register write disable (BRWD) bit is set. WP# must not be driven by the host during a x4 READ operation. If the device is deselected, this pin defaults as an input pin. HOLD# Input Hold: Hold functionality is disabled by default except the special part numbers. Contact Zetta Sales representatives for details. When enabled, the external pull-up resistor is necessary to avoid accidental operation being placed on hold. HOLD# pauses any serial communication with the device without deselecting it. To start the HOLD condition, the device must be selected, with CS# driven LOW. During HOLD status (HOLD# driven LOW), SO is High-Z and all inputs at SI and SCK are ignored. Hold mode starts at the falling edge of HOLD#, provided SCK is also LOW. If SCK is HIGH when HOLD# goes LOW, hold mode is kicked off at the next falling edge of SCK. Similarly, hold mode is exited at the rising edge of HOLD#, provided SCK is also LOW. If SCK is HIGH, hold mode ends after the next falling edge of SCK. HOLD# must not be driven by the host during the x4 READ operation. SI/IO0, SO/IO1, IO2, IO3 I/O Serial I/O: The bidirectional I/O signals transfer address, data, and command information. The device latches commands, addresses, and data on the rising edge of SCK, and data is shifted out on the falling edge of the SCK. If the device is deselected, IO[0,2] defaults as an input pin and IO[1,3] defaults as an output pin. VCC Supply VCC: Supply voltage VSS Supply VSS: Ground DNU – Do not use: Must be left floating. NC – No Connect: Not internal connection; can be driven or floated. SI must not be driven by the host during x2 or x4 READ operations. 10 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Memory Mapping Memory Mapping Figure 6: Memory Map Blocks RA[16:6] 0 1 2 Pages RA[5:0] 0 1 ••• ••• Bytes CA[11:0] 0 1 2 Notes: • • • • • • • • • • • •• • •• • •• • • 2047 63 • • • • • • • • • • • • • • • • • • • • • • • •• • •• • •• • •• • •• • •• • • 2175 1. The 12-bit column address is capable of addressing from 0 to 4095 bytes; however, only bytes 0 through 2175 are valid. Bytes 2176 through 4095 of each page are “out of bounds,” do not exist in the device, and cannot be addressed. 2. Block RA6 controls the plane selection. Array Organization Figure 7: Array Organization 11 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Bus Operation Bus Operation SPI Modes The device can be driven by a micro controller with its SPI running in either of two modes depending on clock polarity (CPOL) and clock phase (CPHA) settings: • CPOL = 0, CPHA = 0 (Mode 0) • CPOL = 1, CPHA = 1 (Mode 3) Input data is latched in on the rising edge of SCK, and output data is available fromthe falling edge of SCK for both modes. Thedifference between the two modes,shown here,is the clock polarity when the bus master is in standby mode and not transferring data. • SCK remains at 0 for CPOL = 0, CPHA = 0 (Mode 0) • SCK remains at 1 for CPOL = 1, CPHA = 1 (Mode 3) Figure 8: SPI Modes Timing CPOL CPHA 0 0 SCK 1 1 SCK SI MSB LSB MSB SO LSB CS# Notes: 1. While CS# is HIGH, keep SCK at VCC or GND (determined by mode 0 or mode 3). Do not begin toggling SCK until after CS# is driven LOW. 2. All timing diagrams shown in this data sheet are mode 0. SPI Protocols Standard SPI: Command, address, and data are transmitted on a single data line. Input on SI is latched in on the rising edge of SCK. Output on SO is available on the falling edge of SCK. Extended SPI: An extension of the standard SPI protocol. Command and address are transmitted on a single data line through SI. Data are transmitted on two or four data lines, IO[3:0], depending on the command. 12 2Gb 3.3V x1, x2, x4: SPI NAND Flash Memory SPI NAND Command Definitions SPI NAND Command Definitions Table 2: SPI NAND Command Set Command Op Code Address Dummy Bytes Bytes Data Bytes Comments RESET FFh 0 0 0 Reset the device GET FEATURES 0Fh 1 0 1 Get features SET FEATURES 1Fh 1 0 1 Set features READ ID 9Fh 0 1 2 Read device ID PAGE READ 13h 3 0 0 Array read READ PAGE CACHE RANDOM 30h 3 0 0 Cache read READ PAGE CACHE LAST 3Fh 0 0 0 Ending of cache read READ FROM CACHE x1 03h, 0Bh 2 1 1 to 2176 Output cache data at column address READ FROM CACHE x2 3Bh 2 1 1 to 2176 Output cache data on IO[1:0] READ FROM CACHE x4 6Bh 2 1 1 to 2176 Output cache data on IO[3:0] READ FROM CACHE Dual IO BBh 2 1 1 to 2176 Input address/Output cache data on IO[1:0] READ FROM CACHE Quad IO EBh 2 2 1 to 2176 Input address/Output cache data on IO[3:0] WRITE ENABLE 06h 0 0 0 Sets the WEL bit in the status register to 1; required to enable operations that change the content of the memory array WRITE DISABLE 04h 0 0 0 Clears the WEL bit in the status register to 0; required to disable operations that change the content of the memory array BLOCK ERASE D8h 3 0 0 Block erase PROGRAM EXECUTE 10h 3 0 0 Array program PROGRAM LOAD x1 02h 2 0 1 to 2176 Load program data into cache register on SI PROGRAM LOAD x4 32h 2 0 1 to 2176 Load program data into cache register on SO[3:0] PROGRAM LOAD RANDOM DATA x1 84h 2 0 1 to 2176 Overwrite cache register with input data on SI PROGRAM LOAD RANDOM DATA x4 34h 2 0 1 to 2176 Overwrite cache register with input data on SO[3:0] PERMANENT BLOCK LOCK PROTECTION 2Ch 3 0 0 13 Permanently protect a specific group of blocks 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory RESET Operation RESET Operation The RESET command (FFh) is used to put the memory device into a known condition and to abort the command sequence in progress. READ, PROGRAM, and ERASE commands can be aborted while the device is in the busy state.Once the RESETcommand is issued to the device, it will take tPOR to reset. During this period, the GET FEATURE command could be issued to monitor the status (OIP) except for 4Gb stacked device. For 4Gb stacked device, no command should be issued until tPOR.The contents of the memory location being programmed or the block being erased are no longer valid.The first page data of the first block is auto-loaded to the cache register. All other status register bits will be cleared. The ECC status register bits will be updated after a reset. The configuration register bits CFG[2:0] will be cleared after a reset. All the other configuration register bits will not be reset.The block lock register bits will not be cleared after reset until the device is power cycled or is written to by SET FEATURE command. Figure 9: RESET (FFh) Timing 0 1 2 3 SCK Command (FFh) CS# SI SO High-Z 14 4 5 6 7 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory WRITE Operations WRITE Operations WRITE ENABLE (06h) The WRITE ENABLE (06h) command sets the WEL bit in the status register to 1. Write enable is required in the following operations that change the contents of the memory array: • PAGE PROGRAM • OTP AREA PROGRAM • BLOCK ERASE Figure 10: WRITE ENABLE (06h) Timing 0 1 2 3 4 5 6 7 SCK CS# Command (06h) SI WRITE DISABLE (04h) The WRITE DISABLE (04h) command clears the WEL bit in the status register to 0, disabling the following operations: • PAGE PROGRAM • OTP AREA PROGRAM • BLOCK ERASE Figure 11: WRITE DISABLE (04h) Timing 0 1 2 3 4 5 SCK CS# Command (04h) SI 15 6 7 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations READ Operations PAGE READ (13h) The PAGE READ (13h) command transfers data from the NAND Flash array to the cache register. It requires a 24-bit address consisting of 7 dummy bits and a 17-bit block/page address (8 dummy bits followed by an 16-bit block/page address for 1Gb). After the block/page addressis registered, the device starts the transfer from the main array to the cache register. During this data transfer busy time of tRD, the GET FEATURES command can be issued to monitor the operation. Following successful completion of PAGE READ,the READ FROM CACHE command must be issued to read data out of cache.The command sequence is as follows to transfer data from array to output: • • • • • • • 13h (PAGE READ command to cache) 0Fh (GET FEATURES command to read the status) 03h or 0Bh (READ FROM CACHE) 3Bh (READ FROM CACHE x2) 6Bh (READ FROM CACHE x4) BBh (READ FROM CACHE Dual I/O) EBh (READ FROM CACHE Quad I/O) 16 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations Figure 12: PAGE READ (13h) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SCK CS# Command (13h) Address bits SI 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 High-Z SO 1 23 24 25 26 27 28 29 30 0 31 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 1 0 SCK CS# tCS Address bits SI 8 7 6 5 4 3 2 1 GET FEATURES (0Fh) Status register address (C0h) 7 0 6 5 4 3 2 MSB High-Z SO 1 13 14 2 15 16 17 18 19 20 21 22 23 SCK CS# SI 2 1 0 Status register data out Status register data out 7 SO MSB 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 MSB 2 Don’t Care 17 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations READ FROM CACHE x1 (03h or 0Bh) The READ FROM CACHE x1 command enables sequentially reading one or more data bytes from the cache buffer. The command is initiated by driving CS# LOW, shifting in command opcode 03h/0Bh, followed by a 16 bit column address and 8-bit dummy clocks. Both the commands run at fast mode. Data is returned from the addressed cache buffer,MSB first,on SO at the falling edge of SCK.The address is automatically incremented to the next higher address after each byte of data is shifted out,enabling a continuous stream of data.This command is completed by driving CS# HIGH. Figure 13: READ FROM CACHE (03h or 0Bh) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SCK CS# Command (03h or 0Bh) 3 dummy bits 0 SI 0 12-bit column address 0 12 11 10 9 8 7 6 5 1 dummy byte 4 3 2 1 0 MSB Plane select High-Z SO 1 SCK 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 17431... 17439 CS# 1 dummy byte SI High-Z 0 Data out 1 SO High-Z 7 6 5 4 3 Data out 2176 2 1 0 MSB 7 6 5 4 3 2 1 0 MSB 1 Don’t Care Note: 1. Plane select is a dummy bit for 1Gb devices. 18 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations READ FROM CACHE x2 (3Bh) The READ FROM CACHE x2 (3Bh) command is similar to READ FROM CACHE x1 (03h or0Bh) except that data is output on the following two pins, enabling data transfer at twice the rate: IO0(SI) and IO1(SO). Figure 14: READ FROM CACHE x2 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SCK CS# Command (3Bh) 3 dummy bits 0 SI 0 12-bit column address 0 12 Plane select 10 11 9 8 7 6 5 4 1 dummy byte 3 2 1 0 MSB High-Z SO 1 SCK 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 8727... 8735 CS# 1 dummy byte SI High-Z SO High-Z SI switches from input to output 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 Data out 1 1 Note: Data out 2 1. Plane select is a dummy bit for 1Gb devices. 19 Data out 2175 Data out 2176 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations READ FROM CACHE x4 (6Bh) The READ FROM CACHE x4 (6Bh) command is similar to READ FROM CACHE x1 command, but with the capability to output data across four data lines. Figure 15: READ FROM CACHE x4 0 SCK 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 CS# Command 3 dummy bits SI/ IO0 0 0 12-bit column address 0 12 11 High-Z WP#/ IO2 High-Z HOLD#/ IO3 High-Z 9 8 7 6 5 4 3 2 1 0 MSB Plane select SO/ IO1 10 1 dummy byte 1 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 SCK CS# 1 dummy byte SI/ IO0 High-Z SO/ IO1 High-Z WP#/ IO2 High-Z HOLD#/ IO3 High-Z SI switches from input to output 4 0 4 0 4 0 4 0 4 5 1 5 1 5 1 5 1 5 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 Byte 1 1 Note: Byte 2 Byte 3 Byte 4 1. Plane select is a dummy bit for 1Gb devices. 20 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations READ FROM CACHE Dual I/O (BBh) The READ FROM CACHE Dual IO (BBh) command enables improved random access while maintaining two IO pins, IO0 and IO1. It is similar to the READ FROM CACHE x2 (3Bh) command but with capability to input either the column address or the dummy clocks two bits per clock, thereby reducing command overhead. Refer to the Electrical Specifications for the supported frequency. Figure 16: READ FROM CACHE Dual I/O 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 SCK Command (BBh) CS# Plane select SI IO0 4 dummy cycles 12 SO IO1 3 23 SCK CS# 24 data out 1 25 26 27 28 data out 2 29 30 dummy bits 31 32 data out 3 data out 1 10 8 6 4 2 0 6 4 11 9 7 5 3 1 7 5 12-bit column address 33 34 35 36 data out 4 37 38 . . . . . . 8716 data out x 8717 8718 8719 8720 data out 2175 8721 8723 8722 8724 data out 2176 SI IO0 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 SO IO1 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 Don’t Care Note: 1. Plane select is a dummy bit for 1Gb devices. 21 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations READ FROM CACHE Quad I/O (EBh) The READ FROM CACHE Quad I/O (EBh) command is similar to the READ FROM CACHE Dual I/O (BBh) command except that address and data bits are input and output through four pins: IO0, IO1, IO2, and IO3. The quad IO dramatically reduces command overhead, enabling faster random access to the cache buffer. Refer to the Electrical Specifications for the supported frequency. Figure 17: READ FROM CACHE Quad I/O 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 SCK Command CS# Plane select S1 IO0 12 4 dummy cycles data out 1 data out 2 data out 3 data out 4 8 4 0 4 0 4 0 4 0 4 S0 IO1 9 5 1 5 1 5 1 5 1 5 WP# IO2 10 6 2 6 2 6 2 6 2 6 HOLD# IO3 11 7 3 7 3 7 3 7 3 7 3 dummy bits 12-bit column address 23 24 25 26 27 . . . . 4363 4364 4365 4366 4367 SCK data out 4 data out 5 data out 5 Data out x CS# data out 2175 data out 2176 SI IO0 0 4 0 4 0 4 0 4 0 4 0 4 SO IO1 1 5 1 5 1 5 1 5 1 5 1 5 WP# IO2 2 6 2 6 2 6 2 6 2 6 2 6 HOLD# IO3 3 7 3 7 3 7 3 7 3 7 3 7 Note: 1. Plane select is a dummy bit for 1Gb devices. 22 Don’t Care 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations READ PAGE CACHE RANDOM (30h) The READ PAGE CACHE RANDOM(30h) command reads the specified block and page into the data register while the previous page is output from the cache register. This command is accepted by the die when it is ready (OIP =0, CRBSY =0). This command is used to improve the read through put as follows: 1. 13h – PAGE READ to cache 2. 0Fh – GET FEATURE command to the read status until OIP status bit is changed from 1 to 0 3. 30h – READ PAGE CACHE RANDOM command to transfer data from data register to cache register and kick off the next page transfer from array to data register 4. 0Fh – GET FEATURE command to read the status until OIP status bit is changed from 1 to 0 5. 03h, 0Bh, 3Bh, 6Bh, BBh, or EBh – READ FROM CACHE TO OUTPUT command 6. 0Fh – GET FEATURE command to read the status until CRBSY = 0 7. Repeat step 3 to step 6 to read out all expected pages until last page 8. 3Fh – READ PAGE CACHE LAST command to end the read page cache sequence and copy a last page from the data register to the cache register 9. 0Fh – GET FEATURE command to read the status until OIP status bit is changed from 1 to 0 10. 03h, 0Bh, 3Bh, 6Bh, BBh, or EBh – READ FROM CACHE TO OUTPUT command to read out last page from cache register to output The READ PAGE CACHE RANDOM command requires a 24 bit address consisting of 8 dummy bits followed by a 16-bit block/page address for 1Gb device or 7 dummy bits followed by a 17-bit block/page address for 2Gb or higher devices. After the block/page addresses are registered,the device starts to transfer data from data register to cache register for tRCBSY. After tRCBSY, OIP bit (through GET FEATURE command to check this status bit) goes to 0 from1, indicating that the cache register is available and that the specified page in the READ PAGE CACHE RANDOM command is copying from the the Flash array to the data register. At this point, data can be output from the cache register beginning at the column address specified by READ FROM CACHE commands. The status register CRBSY bit value remains at 1, indicating that the specified page in READ PAGE CACHE RANDOM command is copying from the Flash array to the data register; CRBSY returns to 0 to indicating the copying from array is completed. During tRCBSY, the error check and correction is also performed. Note:With an on-die ECC-enabled die,ECC is executed after data is transferred from the data register to the cache register; therefore, tRCBSY includes this ECC time, which must be factored in when checking the OIP status. 23 Figure 18: READ PAGE CACHE RANDOM Sequence 0 1 2 3 4 5 6 7 8 9 10 23 22 21 11 12 13 14 15 28 29 3 2 30 31 SCK CS# tRD Page x SI 13h 20 19 18 17 16 1 0 SO 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 28 29 30 31 0 1 2 3 4 5 6 7 8 9 10 11 12 22 23 1 0 24 25 30 31 32 SCK CS# t RCBSY Page y SI 23 30h 22 21 20 19 18 Dummy byte 17 16 3 2 1 0 11 03h MSB SO Page x data 1 6 7 5 4 3 2 MSB 1 0 7 1 1 2 3 4 5 6 7 8 9 10 11 12 26 27 28 29 30 31 0 1 6 7 8 29 30 31 24 CS# Page Z SI MSB SO 23 30h Page x data 2 7 6 5 4 3 2 MSB 1 0 7 t 22 21 20 19 4 3 2 1 RCBSY 0 03h Page x data n 6 5 4 3 2 1 0 7 6 1 0 2 1 0 1 2 3 4 5 6 7 0 1 6 7 8 29 30 31 SCK CS# Read page cache last 3Fh SI MSB SO MSB Page Y data 2 7 6 5 4 3 2 1 0 7 tRCBSY 03h MSB 6 5 4 3 2 1 0 7 Page Z data n Page Z data 1 Page Z data 2 6 0 7 0 7 6 0 7 6 0 2 Don’t Care 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations 0 SCK 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory READ Operations READ PAGE CACHE LAST (3Fh) The READ PAGECACHELAST(3Fh) command ends the READ PAGE CACHE RANDOM Sequence and copies a page from the data register to the cache register. This command is accepted by the die when it is ready (OIP = 0, CRBSY = 0). After this command is issued, the status register bit OIP goes HIGH and the device is busy (CRBSY =0, OIP = 1) for tRCBSY. Address is not applied in this command sequence. When data is completely copied to cache register,OIP goes LOW and READ FROM CACHE commands could be issued to output data. READ ID (9Fh) READ ID reads the 2-byte identifier code programmed into the device, which includes ID and device configuration data as shown in the table below. Table 3: READ ID Table Byte Description 7 6 5 4 3 2 1 0 Value Byte 0 Manufacturer ID 0 0 1 0 1 1 0 0 2Ch Byte 1 2Gb 3.3V Device ID 0 0 1 0 0 1 0 0 24h Figure 19: READ ID (9Fh) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SCK CS# Command (9Fh) Dummy byte 0 SI 0 0 0 0 0 0 0 Manufacturer ID High-Z SO Device ID 7 6 MSB 23 24 25 26 27 28 29 30 1 31 SCK CS# SI Device ID SO 7 6 5 4 3 2 1 0 MSB Don’t Care 1 25 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Parameter Page Parameter Page The following command flow must be issued by the memory controller to access the parameter page contained within Zetta SPI devices: 1. 1Fh – SET FEATURES command with a feature address of B0h and data value for CFG[2:0] = 010b ( to access OTP/Parameter/UniqueID pages). 2. 13h – PAGE READ command with a block/page address of 0x01h, and then check the status of the read completion using the GET FEATUR ES (0Fh) command with a feature address of C0h. 3. 03h – READ FROM CACHE command with an address of 0x00h to read the data outof the NAND device(see the following Parameter Page Data Structure table for a description of the contents of the parameter page.) 4. 1Fh – SET FEATURES command with a feature address of B0h and data value of 00h to exit the parameter page reading. Parameter Page Data Structure Table Table 4: Parameter Table Byte Description Value (hex) 0-3 Parameter page signature 4Fh, 4Eh, 46h, 49h 4-5 Revision number 00h 6-7 Feature support 00h 8-9 Optional commands support 06h, 00h 10-31 Reserved 00h 32-43 Device manufacturer 4Dh, 49h, 43h, 52h, 4Fh, 4Eh, 20h, 20h, 20h, 20h, 20h, 20h 44-63 Device model 4Dh, 54h, 32h, 39h, 46h, 32h, 47h, 30h, 31h, 41h, 42h, 41h, 47h, 44h, 53h, 46h, 20h, 20h, 20h, 20h 44-63 Device model 4Dh, 54h, 32h, 39h, 46h, 32h, 47h, 30h, 31h, 41h, 42h, 41h, 47h, 44h, 31h, 32h, 20h, 20h, 20h, 20h 44-63 Device model 4Dh, 54h, 32h, 39h, 46h, 32h, 47h, 30h, 31h, 41h, 42h, 41h, 47h, 44h, 57h, 42h, 20h, 20h, 20h, 20h 64 Manufacturer ID 2Ch 65-66 Date code 00h 67-79 Reserved 00h 80-83 Number of data bytes per page 00h, 08h, 00h, 00h 84-85 Number of spare bytes per page 80h, 00h 86-89 Number of data bytes per partial page 00h, 02h, 00h, 00h 90-91 Number of spare bytes per partial page 20h, 00h 92-95 Number of pages per block 40h, 00h, 00h, 00h 96-99 Number of blocks per unit 00h, 08h, 00h, 00h 100 Number of logical units 01h 101 Number of address cycles 00h 102 Number of bits per cell 01h 103-104 Bad blocks maximum per unit 28h, 00h 26 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Unique ID Page Table 4: Parameter Table (Continued) Byte Description Value (hex) 105-106 Block endurance 01h, 05h 107 Guaranteed valid blocks at beginning of target 08h 108-109 Block endurance for guaranteed valid blocks 00h 110 Number of programs per page 04h 111 Partial programming attributes 00h 112 Number of ECC bits 00h 113 Number of interleaved address bits 00h 114 Interleaved operation attributes 00h 115-127 Reserved 00h 128 I/O pin capacitance 08h 129-130 Timing mode support 00h 131-132 Program cache timing 00h 133-134 tPROG 58h, 02h 135-136 tERS 137-138 tR 139-140 tCCS 141-163 Reserved 00h 164-165 Vendor-specific revision number 00h 166-179 Vendor specific 01h, 00h, 00h, 00h, 00h, 00h, 00h, 00h, 00h, 02h, 02h, B0h, 0Ah, B0h 180-247 Reserved 00h 248 ECC maximum correct ability 08h 249 Die select feature 00h 250-253 Reserved 00h 254-255 Integrity CRC Set at Test 256-512 2nd copy of the parameter table 513-768 3rd copy of the parameter table 769-2048 Additional redundant parameter pages maximum page program time maximum block erase time maximum page read time minimum 10h, 27h 46h, 00h 00h Unique ID Page The following command flow must be issued by the memory controller to access the unique ID page contained within the device: 1. Issue a SET FEATURES (1Fh) command on a feature address of B0h and data value of 40h (Access to OTP, Parameter, Unique ID pages, ECC disable). 2. Issue a PAGE READ (13h) command on a block/page address of 0x00h, and then poll the status register OIP bit until device ready using the GET FEATURES (0Fh) command issued on a feature address of C0h. 27 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Unique ID Page 3. Issue a READ FROM CACHE (03h) command on an address of 0x00h to read the unique ID data out of the NAND device. 4. To exit reading the unique ID page, issue a SET FEATURES (1Fh) command with a feature address of B0h and data value of 10h or 00h (main array READ, ECC enable/disable). The device stores 16 copies of the unique ID data. Each copy is 32 bytes: the first 16 bytes are unique data, and the second 16 bytes are the complement of the first 16 bytes. The host should XOR the first 16 bytes with the second 16 bytes. If the result is 16 bytes of FFh, that copy of the unique ID data is correct. If a non-FFh result is returned, the host can repeat the XOR operation on a subsequent copy of the unique ID data. 28 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Program Operations Program Operations PAGE PROGRAM A PAGE PROGRAM operation sequence enables the host to input 1 byte to 2176 bytes of data within a page to a cacheregister,and moves the data from the cache register to the specified block and page address in the array.Only four partialpage programs are allowed on a single page.If more than 2176 bytes areloaded, then those additional bytes are ignored by the cache register. The page program sequence is as follows: • • • • 06h (WRITE ENABLE command) 02h (PROGRAM LOAD command) 10h (PROGRAM EXECUTE command) 0Fh (GET FEATURES command to read the status) PROGRAM LOAD x1 (02h) Prior to performing the PROGRAM LOAD operation, a WRITE ENABLE (06h) command mustbe issued.As withany command that changes thememory contents,the WRITE ENABLE command must be executed in order to set the WELbit.WRITE ENABLE is followed by a PROGRAM LOAD (02h) command. The PROGRAM LOAD command consists of an 8-bit op code, followed by 3 dummy bits, followed by a plane select (if available) and a 12-bit column address, and then the data bytes to be programmed. The data bytes are loaded into a cache register that is 2176 bytes long. Only four partial-page programs are allowed on a single page.If more than 2176 bytes are loaded,those additional bytes are ignored by the cache register. The command sequence ends when CS# goes from LOW to HIGH. 29 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Program Operations Figure 20: PROGRAM LOAD (02h) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SCK CS# 3 dummy bits Command (02h) SI 0 0 0 12-bit column address 12 10 11 9 8 7 6 5 4 Data byte 1 3 2 1 0 7 6 MSB Plane select 1 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 17424… 17431 SCK CS# Data byte 1 SI 7 6 5 4 3 Data byte 2 2 1 0 7 6 5 4 3 Data byte 2176 2 1 0 7 6 5 4 3 2 1 0 Don’t Care 1 Note: 1. Plane select is a dummy bit in 1Gb device. PROGRAM EXECUTE (10h) The PROGRAM EXECUTE command consists of an 8-bit op code, followed by a 24bit address. After the page/block address is registered, the device starts the transfer from the cache register to the main array and is busy for tPROG time. During this busy time, the status register can be polled to monitor the status of the operation (refer to the status register section). When the operation completes successfully, the next series of data can be loaded with the PROGRAM LOAD command. 30 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Program Operations Figure 21: PROGRAM EXECUTE (10h) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SCK CS# Command (10h) Address bits SI 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 High-Z SO 1 SCK 23 24 25 26 27 28 29 0 30 31 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 CS# Get Feature (0Fh) Address bits SI 7 6 5 4 3 2 1 Status register address (C0h) 0 7 6 5 4 3 2 1 MSB SO High-Z 2 1 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 1 0 SCK CS# Status register address SI 2 1 0 Status register data out Status register data out SO High-Z 7 2 6 5 4 3 2 1 0 7 MSB 6 5 4 3 2 MSB Don’t Care 31 0 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Program Operations RANDOM DATA PROGRAM x1 (84h) TheRANDOM DATA PROGRAM operation programs or replaces data in a page with existing data. The random data program sequence is as follows: • • • • 06h (WRITE ENABLE command) 84h (PROGRAM LOAD RANDOM DATA command) 10h (PROGRAM EXECUTE command) 0Fh (GET FEATURES command to read the status) The PROGRAM LOAD RANDOM DATA x1 (84h) operation is similar to PROGRAM LOAD x1 (02h). The difference is that PROGRAM LOAD X1command will reset the cache buffer to an all FFh value, while PROGRAM LOAD RANDOM DATA X1 command will only update the data bytes that are specified by the command input sequence, and the rest of data in the cache buffer will remain unchanged. If the random data is not sequential, then another PROGRAM LOAD RANDOM DATA x1 (84h) command must be issued with a new column address. After the data is loaded, a PROGRAM EXECUTE (10h) command can be issued to start the programming operation. Figure 22: PROGRAM LOAD RANDOM DATA (84h) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SCK CS# Command (84h) 3 dummy bits 0 SI 0 0 12-bit column address 12 11 10 9 8 7 6 5 4 Data byte 1 3 2 1 0 7 6 MSB Plane select 23 24 25 26 27 28 29 30 31 32 33 34 35 1 36 37 38 39 17424… 17431 SCK CS# Data byte 1 SI 7 6 5 4 3 Data byte 2 2 1 0 7 6 5 4 3 Data byte 2176 2 1 0 1 7 6 5 4 3 2 1 0 Don’t Care Note: 1. Plane select is a dummy bit in 1Gb device. 32 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Program Operations PROGRAM LOAD x4 (32h) and PROGRAM LOAD RANDOM DATA x4 (34h) The PROGRAM LOAD x4 (32h) and RANDOM DATAx4 (34h) is similar to PROGRAM LOADx1(02h) command and RANDOM DATA x1(84h),but with the capability to input the data across four data lines. Figure 23: PROGRAM LOAD x4 (32h) Timing 0 1 2 3 4 5 6 7 8 9 10 20 21 22 23 24 25 26 27 28 29 43 44 45 46 47 SCK CS# Dummy bits and plane select 1 Command (32h) column address bits A[11:0] 15 4 0 4 0 4 0 0 4 0 4 0 0 4 0 4 0 IO1 5 1 5 1 5 1 1 5 1 5 1 1 5 1 5 1 IO2 6 2 6 2 6 2 2 6 2 6 2 2 6 2 6 2 IO3 7 3 7 3 7 3 3 7 3 7 3 3 7 3 7 3 IO0 14 13 3 2 1 0 Byte 1 Byte 2 Byte 11 Byte 12 Byte 2175 Byte 2176 Don’t Care Note: 1. Number of dummy bits are different for the different densities, and plane select is not available in 1Gb. Plane select is a dummy bit in 1Gb device. INTERNAL DATA MOVE The INTERNAL DATA MOVE command programs or replaces data in a page with existing data. The internal data move command sequence is as follows: • • • • • 13h (PAGE READ command to cache) 06h (WRITE ENABLE command) 84h (PROGRAM LOAD RANDOM DATA command) 10h (PROGRAM EXECUTE command) 0Fh (GET FEATURES command to read the status) Note: If the random data is not sequential, another PROGRAM LOAD RANDOM DATA (84h) command must be issued with the new column address. 33 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Block Erase Operations Block Erase Operations The BLOCK ERASE (D8h) command is used to erase at the block level. The blocks are organized as 64 pages per block, 2176 bytes per page (2048 + 128 bytes). Each block is 136KB. The BLOCK ERASE command (D8h) operates on one block at a time. The command sequence for the BLOCK ERASE operation is as follows: • 06h (WRITE ENABLE command) • D8h (BLOCK ERASE command) • 0Fh (GET FEATURES command to read the status register) Prior to performing the BLOCK ERASE operation, a WRITE ENABLE (06h) command must be issued. As with any command that changes the memory contents, the WRITE ENABLE command must be executed in order to set the WEL bit. If the WRITE ENABLE command is not issued, then the rest of the erase sequence is ignored. A WRITE ENABLE command must be followed by a BLOCK ERASE (D8h) command. This command requires a 24bit address consisting of dummy bits followed by a valid block address. After the address is registered, the control logic automatically controls timing and ERASE and VERIFY operations. The device is busy for tERS time during the BLOCK ERASE operation. The GET FEATURES (0Fh) command can be used to monitor the status of the operation. (See the following figure.) 34 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Block Erase Operations Figure 24: BLOCK ERASE (D8h) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SCK CS# Command (D8h) Address bits SI 23 SO 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 High-Z 1 23 24 25 26 27 28 29 30 0 31 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SCK CS# Address bits SI 7 6 5 4 3 GET FEATURES (0Fh) 2 1 Status register address (C0h) 0 6 7 5 4 3 2 1 0 MSB SO High-Z 2 1 12 13 14 15 16 17 18 19 20 21 22 23 SCK CS# SI 2 1 0 Status register data out Status register data out SO High-Z 7 6 5 4 3 2 1 0 7 MSB 6 5 4 3 2 1 0 MSB 2 Don’t Care 35 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Features Operations Features Operations GET FEATURES (0Fh) and SET FEATURES (1Fh) The GET FEATURES (0Fh) and SET FEATURES (1Fh) commands either monitor the device status or alter the device configuration from the default at power-on. These commands use a 1-byte feature address to determine which feature is to be read or modified. Features such as OTP protect, block locking, SPI NOR like protocol configuration, and ECC correction can be managed by setting specific bits in feature addresses. Typically, the status register at feature address C0h is read to check the device status, except WEL, which is a writable bit with the WRITE ENABLE (06h) command. When a feature is set, it remains active until the device is power cycled or the feature is written to.Unless specified otherwise,when the device is set,it remains set even if a RESET (FFh) command is issued. CFG[2:0] will be cleared to 000 after a reset and the device is back to normal operation. Figure 25: GET FEATURES (0Fh) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 2 1 15 16 17 18 19 20 21 22 23 2 1 0 SCK CS# 1 byte address Command (0Fh) 7 SI 5 6 4 3 0 MSB SO Data byte High-Z 7 6 5 4 3 MSB Don’t Care Figure 26: SET FEATURES (1Fh) Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 SCK CS# 1 byte address Command (1Fh) SI 7 6 5 4 3 MSB Data byte 2 1 0 7 6 5 4 3 2 1 0 MSB Don’t Care 36 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Features Operations Feature Settings Table 5: Feature Address Settings and Data Bits Register Feature Data Bits Feature Address 7 6 5 4 3 2 1 0 Notes Block lock Address = A0h; Access = R/W BRWD BP3 BP2 BP1 BP0 TB WP#/HOLD# Disable – 1, 2 Configuration Address = B0h; Access = R/W CFG2 CFG1 LOT_EN ECC_EN – – CFG0 – 1 Status Address = C0h; Access = R CRBSY ECCS2 ECCS1 ECCS0 P_Fail E_Fail WEL OIP 1 Die select Address = D0h; Access = R/W – DS0 – – – – – – 1 Notes: 1. See the corresponding register bit description in Security Features, ECC Protection, Status Register, and Read Protocol – Similar to SPI NOR sections. 2. When the WP#/HOLD# disable bit is at the default value of 0, and with BRWD set to 1 and WP# LOW, block lock registers [7:2] cannot be changed. 37 2Gb 3.3V x1, x2, x4: SPI NAND Flash Memory Security – Volatile Block Protection Security – Volatile Block Protection The block lock feature protects the entire device or ranges of device blocks from the PROGRAM and ERASE operations. The SET FEATURE command must be issued to alter the state of block protection. After power-up,the device is in the locked state by default; block lock register bits BP[3:0] and TB are 1 . Reset will notmodify the block protection state. When a PROGRAM/ERASE command is issued to a locked block, a status register P_Fail bit or E_Fail bit will be set to indicate the operation failure. The following command sequence unlocks all blocks after power-up:The SET FEATURES register write (1Fh) operation is issued, followed by the feature address (A0h). Then, 00h is issued on data bits to unlock all blocks. Security – Block Protection Bits Table 6: Block Lock Register Block Protect Bits BP3 BP2 BP1 BP0 0 0 0 0 0 None—all unlocked 0 0 0 0 1 Upper 1/1024 locked 2046:2047 0 0 0 1 0 Upper 1/512 locked 2044:2047 0 0 0 1 1 Upper 1/256 locked 2040:2047 0 0 1 0 0 Upper 1/128 locked 2032:2047 0 0 1 0 1 Upper 1/64 locked 2016:2047 0 0 1 1 0 Upper 1/32 locked 1984:2047 0 0 1 1 1 Upper 1/16 locked 1920:2047 0 1 0 0 0 Upper 1/8 locked 1792:2047 0 1 0 0 1 Upper 1/4 locked 1536:2047 0 1 0 1 0 Upper 1/2 locked 1024:2047 1 0 0 0 0 All unlocked None All locked 0:2047 1 0 0 0 1 Lower 1/1024 locked 0:1 1 0 0 1 0 Lower 1/512 locked 0:3 1 0 0 1 1 Lower 1/256 locked 0:7 1 0 1 0 0 Lower 1/128 locked 0:15 1 0 1 0 1 Lower 1/64 locked 0:31 1 0 1 1 0 Lower 1/32 locked 0:63 1 0 1 1 1 Lower 1/16 locked 0:127 1 1 0 0 0 Upper 1/8 locked 0:255 1 1 0 0 1 Lower 1/4 locked 0:511 1 1 0 1 0 Lower 1/2 locked 0:1023 1 1 1 1 1 All locked (default) 0:2047 All others 38 Protected Portion Protected Blocks TB None 2Gb 3.3V x1, x2, x4: SPI NAND Flash Memory Security – Hardware Write Protection Security – Hardware Write Protection Hardware write protection prevents the block protection state from hardware modifications. The following command sequence enables hardware write protection: The SET FEATURE command is issued on feature address A0h. Then, the WP#/Hold# disable bit state is set to 0 as the default after power up. The BRWD bit is operated in conjunction with WP#/Hold# disable bit. When BRWD is set to 1 and WP# is LOW,none of the other block lock register bits [7:2] can be set.The block lock state can not be changed, regardless of what is unlocked or locked. Also, when the WP#/Hold# disable bit is set to 1, the hardware protected mode is disabled. The default value of BRWD and WP#/ Hold# disable bits = 0 after power up. Security – Device Lock Tight (LOT) The lock tight mode prevents the block protection state from software modifications. After it is enabled,this mode can not be disabled by a software command.Also,BP,TB, and BRWD bits are protected from further software changes. Only another power cycle can disable the lock tight mode. The following command sequence enables the lock tight mode: The SET FEATURES register write (1Fh) operation is issued, followed by the feature address (B0h). Then, data bits are set to enable LOT (LOT_EN bit = 1). When the hardware write protection mode is disabled during quad or x4 mode,lock tight can be used to prevent a block protection state change. Permanent Block Lock Protection 48 blocks per die (0 to 47) can be permanently locked using PROTECT command. The PROTECT command provides nonvolatile, irreversible protection of up to twelve groups (48 blocks). Implementation of the protection is group-based, which means that a mini- mum of one group (4 blocks) is protected when the PROTECT command is issued. Because block protection is nonvolatile, a power-on or power-off sequence does not affect the block status after the PROTECT command is issued. The device is shipped from the factory with no blocks protected so that users can program or erase the blocks before is suing the PROTECT command. Block protection is also irreversible in that when protection is enabled by issuing the PROTECT command,the protected blocks can no longer be programmed or erased. If permanent lock is disabled, PROTECT command would be ignored. As with any command that changes the memory contents, the WRITE ENABLE must be executed. If this command is not issued, then the protection command is ignored.WRITE ENABLE must be followed by a PROTECTION command (2Ch). The following PROTECT sequence is used: • • • • 06h (WRITE ENABLE) 2Ch (permanent block lock protection) 24-bit address (see the PROTECTION Command Details) After tPROG time, use GET FEATURE command (0Fh) with feature address C0h to verify P_Fail bit 39 2Gb 3.3V x1, x2, x4: SPI NAND Flash Memory Permanent Block Lock Protection Figure 27: PROTECT Command Cycle 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 28 29 30 31 SCK CS# tPROG Page Y SI 2Ch 23 22 21 20 19 18 17 16 3 2 1 0 SO PROTECTION Command (2Ch) Details To enable protection,the PROTECTION command consists of an 8-bit commandcode, followed by a 24-bit address (8 dummy bits and an 16-bit page/block address for 1Gb or 7 dummy bits and an 17-bit page/ block address for 2Gb die). Row address bits 11, 10, 9, 8 (namedasY) input the targeted block group information.Where Ydefines the group of blocks to be protected. There are 12 Groups Y where Y = 0000b-1011b: • • • • Y = 0000 protects Group0 = blks 0, 1, 2, 3. Y = 0001 protects Group1 = blks 4, 5, 6, 7. ...... Y = 1011 protects Group11 = blks 44, 45, 46, 47. After tPROG, the targeted block groups are protected. Upon PROTECT operation failure, the status register reports a value of 0Ch(P_FAIL=1and WEL=1).UponPROTECT operation success, the status register reports a value of 00h. Note: There is no status register to check the PROTECT status of a block or a group.A permanent blocks table should be maintained and updated after a group is protected. Permanent Block Lock Protection Disable Mode This mode disables the ability to accept the PROTECTION command. Running this command sequence ensures no more groups can ever be permanently locked. The following disable PROTECT sequence is used • SET FEATURE command (1Fh) with B0h mode and data value C2h • 06h (WRITE ENABLE) • 10h (Execute with block/page address as '0') • After tPROG time, use GET FEATURE command (0Fh) with feature address C0h to verify P_Fail bit 40 2Gb 3.3V x1, x2, x4: SPI NAND Flash Memory Security – One Time Programmable (OTP) Security – One Time Programmable (OTP) This device offers a protected, one-time programmable NAND Flash memory area. Ten full pages (10 x 2176 bytes per page) per die are available, and the entire range is guaranteed. Customers can choose how to use the OTP area, such as programming serial numbers or other data for permanent storage. The OTP area can't be erased. When ECC is enabled, data written in the OTP area is ECC protected. Besides some additional configuration bits are described in this section. Enable OTP Access OTP access needs to be enabled in order to read and write to the OTP region.When the dieisin OTP operation mode,all subsequent page program or pageread commands are applied to the OTP area. SET FEATURES command (1Fh) with feature address B0h and data 50h (OTP operation mode with ECC enabled ) or 40h (OTP operation mode with ECC disabled ) are used to enable the OTP access. After OTP accessis enabled,the following sequence is used to program one or morepages WRITE ENABLE command (06h) • PROGRAM EXECUTE command (10h) with the row address of page (OTP page address range 02h-0Bh) • Verify until OIP bit not busy using GET FEATURE command (0Fh) with feature address C0h • Using GET FEATURE command (0Fh) with feature address C0h, verify if P_FAIL bit is 0 for the successful operation. After OTP access is enabled, the following sequence is used to read one or more pages • PAGE READ command (13h) with the page address (02h-0Bh) • Verify until OIP bit is not busy using GET FEATURE command (0Fh) with feature address C0h • Page data using READ FROM CACHE command (03h). OTP Configuration States To check the status of OTP data protect,SPI NOR read enable,or permanent block Lock protection, the following sequence is used • SET FEATURES command (1Fh) with feature address B0h and data (C0h for OTP data protect bit, 82h for NOR read protocol enable bit, C2h for permanent block lock disable bit) • PAGE READ command (13h) with address 0 • Verify until OIP bit not busy using GET FEATURE command (0Fh) with feature address C0h • READ FROM CACHE command (03h) with address 0 • Expect the read from cache data all 1 for the mode disabled or all "0" for enabled. Note: Configuration status of CFG[2:0] can be read using GET FEATURE command (0Fh) with feature address B0h. 41 2Gb 3.3V x1, x2, x4: SPI NAND Flash Memory Security – One Time Programmable (OTP) OTP Protection and Program Prevention This mode is used to prevent further programming of the pages in the OTP area. To protect and prevent programming the OTP area, the following sequence is used SET FEATURES command (1Fh) with feature address B0h and data C0h (CFG[2:0] = 110b) WRITE ENABLE command (06h) PROGRAM EXECUTE command (10h) with the row address 00h Verify until OIP bit not busy and P_FAIL bit 0 using GET FEATURE command (0Fh) with status register address C0h. Exit OTP To exit from OTP operation mode and return the device to normal array operation mode, the SET FEATURES command (1Fh) is issued. This is followed by setting the feature address = B0h and data CFG[2:0] = 000b. Last, the RESET (FFh) command is issued. Table 7: Configuration Registers for Security CFG2 CFG1 CFG0 0 0 0 State Normal operation 0 1 0 Access OTP area/Parameter/Unique ID 1 1 0 Access to OTP data protection bit to lock OTP area 1 0 1 Access to SPI NOR read protocol enable mode 1 1 1 Access to permanent block lock protection disable mode 42 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Status Register Status Register The device has an 8-bit status register that software can read during the device operation. All bits are read-only register except WEL, which could be changed by WRITE DISABLE (04h) and WRITE ENABLE (06h) commands. None of bits can be changed by SET FEATURE command (1Fh).The status register can be read by issuing the GET FEATURES (0Fh) command, followed by the feature address (C0h). The status register will output the status of the operation. Table 8: Status Register Bit Descriptions Bit 7 Bit Name Description Cache read busy (CRBSY) This bit is set (CRBSY = 1) when READ PAGE CACHE RANDOM command is executing; this bit remains a 1 until the page specified at READ PAGE CACHE RANDOM command is transferred from array to data register. When the bit is 0, the device is in the ready state and background read page cache operation is completed. RESET command is acceptable during CRBSY = 1 and could halt background read page cache operation and download first page at block 0 into cache register at default. 6 ECC status register (ECCS2) 5 ECC status register (ECCS1) 4 ECC status register (ECCS0) 3 Program fail (P_Fail) See ECC Protection for the ECC status definition. ECC status is set to 000b either following a RESET or at the beginning of the READ. It is then updated after the device completes a valid READ operation. ECC status is invalid if ECC is disabled (via a SET FEATURES command to get access the configuration register). After a power-up RESET, ECC status is set to reflect the contents of block 0, page 0. Indicates that a program failure has occurred (P_Fail = 1). This bit will also be set if the user attempts to program an invalid address or a locked or protected region, including the OTP area. This bit is cleared during the PROGRAM EXECUTE command sequence or a RESET command (P_Fail = 0). 2 Erase fail (E_Fail) Indicates that an erase failure has occurred (E_Fail = 1). This bit will also be set if the user attempts to erase a locked region or if the ERASE operation fails. This bit is cleared (E_Fail = 0) at the start of the BLOCK ERASE command sequence or a RESET command. 1 Write enable latch (WEL) Indicates the current status of the write enable latch (WEL) and must be set (WEL = 1) prior to issuing a PROGRAM EXECUTE or BLOCK ERASE command. It is set by issuing the WRITE ENABLE command. WEL can also be cleared (WEL = 0) by issuing the WRITE DISABLE command or a successful PROGRAM/ERASE operation. 0 Operation in progress (OIP) This bit is set (OIP = 1 ) when a PROGRAM EXECUTE, PAGE READ, READ PAGE CACHE LAST, BLOCK ERASE, READ PAGE CACHE RANDOM (within tRCBSY to wait for cache register readiness) or RESET command or a power-up initialization is executing; the device is busy. When the bit is 0, the interface is in the ready state. 43 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory ECC Protection ECC Protection The device offers an 8-bit data corruption protection by offering internal ECC to obtain the data integrity.The internal ECC can be enabled or disabled by setting the ECC_EN bit in the configuration register.ECC is enabled after device power-up by default.The READ and PROGRAM commands operate with internal ECC by default. Reset will not change the existing configuration. To enable/disable ECC after power on, perform the following command sequence: • Issue the SET FEATURES command (1Fh) • Issue configuration register address (B0h) • Then:To enable ECC,set bit4(ECCenable) to1;To disable ECC,clear bit4( ECC enable) to 0 During a PROGRAM operation, the device calculates an expected ECC code on the ECCprotected bytes in the cache register, before the page is written to the NAND Flash array. The ECC code is stored in the spare area of the page. During a READ operation, the page data is read from the array to the cache register, where the ECC code is calculated and compared with the expected ECC code value read from the array.If a1–8-biterror is detected,the error is corrected in the cache register. Only corrected data is output on the I/O bus.The ECC status register bit indicates whether or not the error correction is successful.The table below describes the ECC protection scheme used throughout a page. Note: The unique ID and parameter page are not ECC protected areas. Multiple copies are provided for parameter page to obtain the data integrity.XOR method is provided for unique ID to verify the data. With internal ECC, users must accommodate the following (details provided in table be- low): • Spare area definitions • WRITEs are supported for main and spare areas (user meta data I and II). WRITEs to the ECC area are prohibited When using partial-page programming, the following conditions must both be met: • In the main user area and user meta data area I, single partial-page programming operations must be used • Within a page, a maximum of four partial-page programming operations can be performed Table 9: ECC Status Register Bit Descriptions Bit 2 Bit 1 Bit 0 0 0 0 No errors 0 0 1 1-3 bit errors detected and corrected 0 1 0 Bit errors greater than 8 bits detected and not corrected 0 1 1 4-6 bit errors detected and corrected. Indicates data refreshment might be taken 1 0 1 7-8 bit errors detected and corrected. Indicates data refreshment must be taken to guarantee data retention Others Description Reserved 44 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory ECC Protection Table 10: ECC Protection Max Byte Address Min Byte Address ECC Protected Area 1FFh 000h Yes Main 0 User Main data 0 3FFh 200h Yes Main 1 User Main data 1 5FFh 400h Yes Main 2 User Main data 2 7FFh 600h Yes Main 3 User Main data 3 803h 800h No Spare 0 Reserved (bad block data) 807h 804h No Spare 1 User meta data II 80Bh 808h No Spare 2 User meta data II 80Fh 80Ch No Spare 3 User meta data II 813h 810h No Spare 0 User meta data II 817h 814h No Spare 1 81Bh 818h No Spare 2 81Fh 81Ch No Spare 3 827h 820h Yes Spare 0 82Fh 828h Yes Spare 1 837h 830h Yes Spare 2 83Fh 838h Yes Spare 3 84Fh 840h Yes Spare 0 ECC for Main/Spare 0 85Fh 850h Yes Spare 1 ECC for Main/Spare 1 86Fh 860h Yes Spare 2 ECC for Main/Spare 2 87Fh 870h Yes Spare 3 ECC for Main/Spare 3 45 Description User meta data I 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Error Management Error Management This NAND Flash device is specified to have the minimum number of valid blocks (NVB) of the total available blocks per die shown in the table below.This means the devices may have blocks that are invalid when shipped from the factory.An invalid block is one that contains at least one page that has more bad bits than can be corrected by the minimum required ECC. Additional bad blocks may develop with use. However,the total number of available blocks will not fall below NVB during the endurance life of the product. Although NAND Flash memory devices may contain bad blocks, they can be used reliably in systems that provide bad-block management and errorcorrection algorithms. This ensures data integrity. Internal circuitry isolates each block from other blocks, so the presence of a bad block does not affect the operation of the rest of the NAND Flash array. NAND Flash devices are shipped from the factory erased.The factory identifies invalid blocks before shipping by attempting to program the bad-block mark into every location in the first page of each invalid block. It may not be possible to program every location in an invalid block with the bad-block mark.However,the first spare area location in each bad block is guaranteed to contain the bad-block mark.This method is compliant with ONFI factory defect mapping requirements. See the following table for the bad-block mark. System software should initially check the first spare area location for non-FFh data on the first page of each block prior to performing any program or erase operations on the NAND Flash device. A bad-block table can then be created, enabling system software to map around these areas. Factory testing is performed under worst case conditions. Because invalid blocks may be marginal, it may not be possible to recover the bad-block marking if the block is erased. Table 11: Error Management Details Description Requirement Minimum number of valid blocks per die (NVB) 2008 Total available blocks per die 2048 First spare area location in the first page of each block Byte 2048 Value programmed for bad block at the first byte of spare area 00h Minimum required ECC 8-bit ECC per sector (544) bytes of data Minimum ECC with internal ECC enabled 8-bit ECC per 512 bytes (user data) + 8 bytes (Spare) + 16 bytes (ECC data) 46 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory SPI NOR Read Configuration SPI NOR Read Configuration Some chip set vendors may have already designed in SPI NOR IP to support system boot; address allocation on clock cycle in SPI NAND read from cache protocol will cause incompatibility. To be drop-in compatible to SPI NOR read protocol, this device offers an alternative solution to implement 03h/0Bh commands,as are done with SPINOR. Refer to the Electrical Specifications for detail timing requirement. This solution would be enabled using the following command sequence: • SET FEATURE command (1Fh) with feature address B0h and CFG bits[2:0] = 101b (access SPI NOR read protocol enable mode) • WRITE ENABLE command (06h) • PROGRAM EXECUTE command (10h) with block/page address all 0 • GET FEATURE command (0Fh) with status register address C0h to check until device is ready (OIP bit clear) and verify that P_FAIL bit is not set • SET FEATURE command (1Fh) with feature address B0h and CFG bits[2:0] = 000b (re- turn to normal operation mode) • GET FEATURE command (0Fh) at address B0h and CFG bits[2:0] = 101b to verify all 0; all 1 indicates SPI NOR mode not enabled. • It is a nonvolatile configuration setting and power cycle will not recover it back to SPI NAND default mode. The rest of the SPI NAND commands still work in this configuration. 47 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory SPI NOR Read Configuration Figure 28: Read from Cache (03h) 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 SCK 11 dummy bits 12-bit column address Plane select (bit 12) Command (03h) CS# 12 SI 11 10 9 SO 1 23 SCK CS# SI 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 2 1 39 16,919 16,927 12-bit column address 7 8 7 6 5 4 3 2 1 0 data out 1 SO 7 6 5 4 3 data out 2176 0 7 6 5 4 3 2 1 0 7 6 1 Don’t Care Note: 1. SPI NOR compatible. Plane select bit not available in 1Gb device and can be used as a dummy bit. 48 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory SPI NOR Read Configuration Figure 29: Fast Read from Cache (0Bh) 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 SCK 11 dummy bits 12-bit column address Plane select (bit 12) Command (0Bh) CS# 12 SI 11 10 9 SO 1 23 SCK CS# SI 24 25 26 27 28 29 30 31 12-bit column address 7 8 7 6 5 4 3 32 33 34 35 36 37 38 39 40 41 42 1 dummy byte 2 1 43 44 45 46 47 48 0 7 data out 1 0 SO 7 1 6 5 4 3 2 1 6 Don’t Care Note: 1. SPI NOR compatible. Plane select bit not available in 1Gb device and can be used as a dummy bit. 49 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Power-Up and Power-Down Power-Up and Power-Down At power-up and power-down, the device must not be selected;that is,CS# must follow the voltage applied on V CC until V CC reaches the correct values: V CC, min at powerup and VSS at power-down. Zetta NAND Flash devices are designed to prevent data corruption during power transitions.VCC is internally monitored and when VCC reaches the write inhibit voltage V WI, a minimum of 250μs must elapse before issuing a RESET (FFh) command. After issuing the RESET command, 1.25ms must elapse before issuing any other command. GET FEATURE command could be issued to poll the status register (OIP) before the first access. Normal precautions must be taken for supply line decoupling to stabilize the VCC supply.Each device in a system should have the VCC line decoupled by a suitable capacitor (typically 100nF) close to the package pins. Note:For power cycle testing,the system must not initiate the powerup sequence until VCC drops down to 0V. Figure 30: SPI Power-Up VCC VCC,max Chip selection not allowed VCC,min Chip reset VWI tPOR Polling allowed Device fully accessible Status register OIP bit 0 Time Figure 31: SPI Power-Up Timing Zetta has developed an alternative SPI NAND sequence that does not require issuing an explicit RESET(FFh) command upon power-up.This is default device initialization setting. When device V CC has reached the write inhibit voltage, the device automatically kicks off the initialization. At default setting, first page data would be automatically loaded into cache register. During the initialization, GET FEATURE command could be issued to poll the status register (OIP) before the first access; Or, the first access can occur 1.25ms after VCC reaches VCC,min. 50 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Power-Up and Power-Down Figure 32: Alternative SPI Power-Up Timing Mode 3 SCK Mode 0 VCC,min = 2.7V VCC WP# Power-up: 1st page autoload = 1.25ms1 CS# SI SO Read from cache (03h, 3Bh, or 6Bh) High-Z Don’t Care Note: 1. Poll status register OIP bit is allowed during device initialization. 51 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Electrical Specifications Electrical Specifications Stresses greater than those listed can cause permanent damage to the device. These are stress ratings only,and functional operation of the device at these or any other conditions above values in this specification is not guaranteed. Exposure to absolute maximum rating conditions for extended periods can affect reliability. Table 12: Absolute Maximum Ratings Parameter Symbol Min Max Unit Supply voltage (SPI) VCC –0.6 4.6 V I/O voltage VCC –0.6 4.6 V Operating temperature (ambient) TA –40 85 °C Storage temperature TS –65 150 °C Note: 1. During infrequent, nonperiodic transitions and for periods less than 20ns, voltage potential between VSS and VCC may undershoot to –2.0V or overshoot to VCC_MAX + 2.0V. Table 13: Operating Conditions Parameter Symbol Min Typ Max Unit VCC 2.7 3.3 3.6 V TA –40 25 85 °C Supply voltage Ambient operating temperature (industrial) Table 14: AC Measurement Conditions Parameter Symbol Min Max 30/10 Unit Load Capacitance CL Input rise and fall time – – 5 pF ns Input rise and fall time (>100 MHz) – – 1.5 ns voltage1 – 0.2 VCC 0.8 VCC V Input timing reference voltages – 0.3 VCC 0.7 VCC V Output timing reference voltages – Input pulse Note: VCC/2 1. These are Min/Max specifications for dual/quad operations. Figure 33: AC Measurement I/O Waveform I/O timing reference levels Input levels 0.8 VCC 0.7 0.5 0.3 0.2 VCC 52 VCC VCC VCC V 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Electrical Specifications Table 15: Capacitance Symbol Test Conditions Min Max Unit Input/output capacitance (IO0, IO1, IO2, IO3) CIN VOUT = 0V – 9 pF Input capacitance (other pins) CIN VIN = 0V – 9 pF Description Notes: 1. These parameters are verified in device characterization and are not 100% tested. 2. The value includes the silicon and package together. Table 16: DC Characteristics Parameter Symbol Conditions Min Typ Max Unit VIH – 0.7 × VCC – VCC + 0.4 V Input low voltage VIL – –0.5 – 0.3 × VCC V Output high voltage VOH IOH = –100µA VCC - 0.2 – – V Output low voltage VOL IOL = 1.6mA – – 0.4 V ILI – – – ±10 µA Output leakage current ILO – – – ±10 µA Page read current ICC3 – – 25 35 mA Program current ICC4 – – 20 25 mA Erase current ICC5 – – 20 25 mA Standby current ICC1 CE# = VCC; VIN = VSS or VCC – 15 50 µA Input high voltage Input leakage current Notes: 1. Typical values are given for TA = 25 °C. 2. These parameters are verified in device characterization and are not 100% tested. Table 17: AC Characteristics Parameter Symbol Min Max Unit fC – 133 MHz Clock LOW time tWL 3.375 – ns Clock HIGH time tWH 3.375 – ns Clock LOW time (SPI NOR read 03h mode at 20 MHz) tWL 22.5 – ns Clock HIGH time (SPI NOR read 03h mode at 20 MHz) tWH 22.5 – ns Clock rise time tCRT 1.3 – V/ns Clock fall time tCFT 1.3 Clock frequency1, 2 V/ns tCS 30 – ns tCSS/ tCSH 3.375 – ns Chip select# non-active setup/hold time relative to SCK tCSH 2.5 – ns Output disable time tDIS Command deselect time Chip select# active setup/hold time relative to SCK – 6 ns Data input setup time tSUDAT 2.5 – ns Data input hold time tHDDAT 1.75 – ns tV – 6 ns Clock LOW to output valid (30pF) 53 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Electrical Specifications Table 17: AC Characteristics (Continued) Parameter Symbol Min Max Unit Clock LOW to output valid (10pF) tV – 5 ns Clock LOW to output valid (similar to SPI NOR 20 MHz read 30pF) tV – 30 ns Clock LOW to output valid (similar to SPI NOR 20 MHz read 10pF) tV – 28 ns Output hold time (30pF) tHO 2 – ns Output hold time (10pF) tHO 1.5 – ns Output hold time (SPI NOR similar to 20 MHz read 30pF) tHO 0 – ns Output hold time (SPI NOR similar to 20 MHz read 10pF) tHO 0 – ns WP# hold time tWPH 100 – ns WP# setup time tWPS 20 – ns Notes: 1. Read from Cache Dual I/O (BBh) and Quad I/O (EBh) can run up to 108 MHz. 2. When read protocol similar to SPI NOR is enabled, Read from Cache 03h command can run up to 20 MHz, while read from Cache 0Bh command can run up to 133 MHz. Table 18: PROGRAM/READ/ERASE Characteristics Parameter BLOCK ERASE operation time (128KB) PROGRAM PAGE operation time (ECC disabled) Symbol Typ Max Unit tERS 2 10 ms tPROG 200 600 µs 220 600 – 25 46 70 – 5 PROGRAM PAGE operation time (ECC enabled) tRD Page read time (ECC disabled) Page read time (ECC enabled) Data transfer time from data register to cache register (internal ECC disabled) tRCBSY Data transfer time from data register to cache register (internal ECC enabled) Power-on reset time (device initialization) from VCC MIN Write inhibit voltage Reset time for READ, PROGRAM, and ERASE operations (internal ECC disabled) Notes: µs 40 50 µs tPOR – 1.25 ms VWI – 2.5 V tRST1 – 30/35/525 µs – 75/80/570 µs – 4 – Reset time for READ, PROGRAM, and ERASE operations (internal ECC enabled) Number of partial-page programming operations supported µs NOP2 1. For first RESET condition after power-up, tRST will be 1.25ms maximum. For stacked die, no command should be issued during this time. 2. In the main user area and in user meta data area I, single partial-page programming operations must be used. Within a page, the user can perform a maximum of four partialpage programming operations. 54 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Electrical Specifications Figure 34: WP# Timing 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 SCK CS# Command (1Fh) Address (A0h) 7 SI 6 5 MSB tWPS 4 3 Data byte 2 1 0 7 6 5 4 MSB WP# 1 17 18 19 20 21 22 23 SCK CS# Data byte SI 6 5 4 3 2 1 0 tWPH WP# 1 Don’t Care 55 3 2 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Electrical Specifications t Figure 35: Serial Input Timing Figure 36: Serial Output Timing tWL tWH SCK CS# t HO SO tV t HO High-Z tDIS LSB OUT Don’t Care 56 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Package Dimensions Package Dimensions Figure 37: 16-pin SOP (300 mils body width) 0.5 ±0.25 X 45° 10.3 ±0.2 2.5 ±0.15 16X 0.2 ±0.1 0.1 A 0.275 ±0.045 16X 0.42 ±0.09 See Detail A 1.27 TYP 16 9 Plating material composition: PPF (0.003µm–0.015µm Au, 0.02µm–0.15µm Pd, 0.5µm–2.0µm Ni). Plastic package material: epoxy novolac. 10.3 ±0.2 7.5 ±0.1 Pin 1 ID 1 Package width and length do not include mold protrusion. Allowable protrusion is 0.25 per side. 8 0.25 gage plane Seating plane 0.2 ±0.1 (for reference only) Note: 1. All dimensions are in millimeters. 57 0.83 ±0.44 Detail A 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Package Dimensions Package Dimensions Figure 38: 8-pin WSON 6mm x 8mm x0.8mm 58 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Package Dimensions Package Dimensions Figure 39: 24-Pin T-PBGA (5 x 5 Ball Grid Array) 6mm x 8mm Seating plane A 24X Ø0.4 Dimensions apply to solder balls postreflow on Ø0.35 SMD ball pads. 0.1 A Ball A1 ID 5 4 3 2 Ball A1 ID 1 A B 4 CTR C 8 ±0.1 D 1 TYP E 1.1 ±0.1 1 TYP 4 CTR 0.25 MIN 6 ±0.1 Note: 1. All dimensions are in millimeters. 59 2Gb 3.3V x1, x2, x4: SPI NAND FlashMemory Revision History Revision History Rev. Date Description 1.0 2021-06-15 Initial Release 1.1 2021-10-08 Modify Package Information 60
ZD35Q2GC-IB 价格&库存
很抱歉,暂时无法提供与“ZD35Q2GC-IB”相匹配的价格&库存,您可以联系我们找货
