EKYA350ELL470ME11D
EKYA350ELL470ME11D
    NCC(贵弥功)
    AEC-D5X11MM_TM
    47UF ±20% 35V
EKYA350ELL470ME11D 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS KYA Series Low impedance, 105℃ KYA ・Downsized from KY series ・Newly innovative electrolyte is employed to minimize impedance ・Endurance with ripple current : 4,000 to 10,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant Downsized KY ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 6.3 to 100Vdc (at 20℃, 120Hz) ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V tanδ (Max.) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.08 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V Z(-25℃)/Z(+20℃) 4 3 2 2 2 2 2 2 8 6 4 3 3 3 3 3 (at 120Hz) Z(-40℃)/Z(+20℃) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃. Time 6.3 to 10Vdc φ5 & 6.3 : 4,000hours φ8 & 10 : 6,000hours φ12.5 to 16 : 8,000hours 16 to 100Vdc φ5 & 6.3 : 5,000hours φ8 & 10 : 7,000hours φ12.5 to 16 : 10,000hours Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] φd Sleeve (PET : Brown) F±0.5 Code : E F±0.5 ●Terminal φD φd φD' F φD' L' Vent (Exceptφ5 &φ6.3) 15min. 4min. (φ5 to φ10) (φ12.5 to φ16) L' 5 0.5 2.0 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max. L+1.5max. 16 0.8 7.5 Gas escape end seal ◆PART NUMBERING SYSTEM 1 2 3 4 E KYA 5 6 7 8 E 9 10 11 12 13 14 M 15 16 17 18 Supplement code Size code Capacitance tolerance code Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3,50V:500) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KYASeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 6.3 10 16 25 100 180 220 330 470 820 1,200 1,200 1,500 1,800 2,700 3,300 3,900 4,700 5,600 10,000 12,000 15,000 100 120 330 560 820 820 1,000 1,200 1,200 1,800 2,200 3,300 3,900 6,800 10,000 12,000 47 100 220 270 470 680 680 820 1,000 1,500 1,800 2,200 3,300 4,700 5,600 6,800 8,200 10,000 33 47 68 150 330 390 470 560 680 1,000 1,200 1,500 2,200 5×11 5×11 5×11 6.3×11 6.3×11 8×11.5 10×12.5 8×15 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×25 16×25 16×31.5 16×35.5 5×11 5×11 6.3×11 8×11.5 8×15 10×12.5 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 16×25 16×31.5 16×35.5 5×11 5×11 6.3×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 16×25 16×25 16×31.5 16×31.5 16×35.5 5×11 5×11 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.90 0.40 0.40 0.22 0.22 0.13 0.080 0.087 0.069 0.060 0.046 0.042 0.035 0.027 0.027 0.021 0.017 0.015 0.90 0.40 0.22 0.13 0.087 0.080 0.080 0.069 0.060 0.046 0.042 0.035 0.027 0.021 0.017 0.015 0.40 0.40 0.22 0.22 0.13 0.087 0.080 0.069 0.060 0.046 0.042 0.035 0.027 0.021 0.021 0.017 0.017 0.015 0.40 0.40 0.40 0.22 0.13 0.087 0.080 0.069 0.060 0.046 0.042 0.035 0.027 3.6 1.6 1.6 0.87 0.87 0.52 0.32 0.35 0.27 0.24 0.18 0.17 0.12 0.089 0.089 0.060 0.050 0.044 3.6 1.6 0.87 0.52 0.35 0.32 0.32 0.27 0.24 0.18 0.17 0.12 0.089 0.060 0.050 0.044 1.6 1.6 0.87 0.87 0.52 0.35 0.32 0.27 0.24 0.18 0.17 0.12 0.089 0.060 0.060 0.050 0.050 0.044 1.6 1.6 1.6 0.87 0.52 0.35 0.32 0.27 0.24 0.18 0.17 0.12 0.089 150 250 250 400 400 640 865 840 1,050 1,300 1,400 1,650 1,900 2,230 2,230 2,930 3,450 3,610 150 250 400 640 840 865 865 1,050 1,300 1,400 1,650 1,900 2,230 2,930 3,450 3,610 250 250 400 400 640 840 865 1,050 1,300 1,400 1,650 1,900 2,230 2,930 2,930 3,450 3,450 3,610 250 250 250 400 640 840 865 1,050 1,300 1,400 1,650 1,900 2,230 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ EKYA6R3E□□101ME11D EKYA6R3E□□181ME11D 25 EKYA6R3E□□221ME11D EKYA6R3E□□331MF11D EKYA6R3E□□471MF11D EKYA6R3E□□821MHB5D EKYA6R3E□□122MJC5S EKYA6R3E□□122MH15D EKYA6R3E□□152MH20D EKYA6R3E□□182MJ16S EKYA6R3E□□272MJ20S EKYA6R3E□□332MJ25S 35 EKYA6R3E□□392MK20S EKYA6R3E□□472MK25S EKYA6R3E□□562MK25S EKYA6R3E□□103ML25S EKYA6R3E□□123MLN3S EKYA6R3E□□153MLP1S EKYA100E□□101ME11D EKYA100E□□121ME11D EKYA100E□□331MF11D EKYA100E□□561MHB5D EKYA100E□□821MH15D EKYA100E□□821MJC5S EKYA100E□□102MJC5S EKYA100E□□122MH20D EKYA100E□□122MJ16S EKYA100E□□182MJ20S EKYA100E□□222MJ25S EKYA100E□□332MK20S EKYA100E□□392MK25S EKYA100E□□682ML25S 50 EKYA100E□□103MLN3S EKYA100E□□123MLP1S EKYA160E□□470ME11D EKYA160E□□101ME11D EKYA160E□□221MF11D EKYA160E□□271MF11D EKYA160E□□471MHB5D EKYA160E□□681MH15D EKYA160E□□681MJC5S EKYA160E□□821MH20D EKYA160E□□102MJ16S EKYA160E□□152MJ20S EKYA160E□□182MJ25S EKYA160E□□222MK20S EKYA160E□□332MK25S EKYA160E□□472ML25S EKYA160E□□562ML25S EKYA160E□□682MLN3S EKYA160E□□822MLN3S EKYA160E□□103MLP1S 63 EKYA250E□□330ME11D EKYA250E□□470ME11D EKYA250E□□680ME11D EKYA250E□□151MF11D EKYA250E□□331MHB5D EKYA250E□□391MH15D EKYA250E□□471MJC5S EKYA250E□□561MH20D EKYA250E□□681MJ16S EKYA250E□□102MJ20S EKYA250E□□122MJ25S 100 EKYA250E□□152MK20S EKYA250E□□222MK25S 3,300 3,900 4,700 5,600 33 47 100 220 270 330 390 470 680 820 1,000 1,500 2,200 2,700 3,300 3,900 1.0 2.2 3.3 4.7 10 22 27 47 56 100 150 180 180 220 330 470 470 560 820 1,000 1,200 1,800 2,200 10 15 33 56 82 100 120 120 220 330 330 390 470 560 1,000 1,200 1,500 1.0 2.2 3.3 4.7 6.8 16×25 16×25 16×31.5 16×35.5 5×11 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 16×25 16×25 16×31.5 16×35.5 5×11 5×11 5×11 5×11 5×11 5×11 5×11 6.3×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×20 12.5×25 16×25 16×25 16×31.5 16×35.5 5×11 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×20 12.5×25 12.5×25 16×25 16×31.5 16×35.5 5×11 5×11 5×11 5×11 5×11 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.021 0.021 0.017 0.015 0.40 0.40 0.22 0.13 0.087 0.080 0.069 0.060 0.046 0.042 0.035 0.027 0.021 0.021 0.017 0.015 4.0 2.5 2.2 1.9 1.5 0.70 0.70 0.30 0.30 0.17 0.12 0.12 0.091 0.084 0.060 0.055 0.045 0.045 0.034 0.025 0.025 0.022 0.019 0.88 0.88 0.35 0.22 0.16 0.11 0.12 0.076 0.056 0.046 0.041 0.041 0.031 0.031 0.025 0.021 0.019 4.5 3.0 2.7 2.5 1.4 0.060 0.060 0.050 0.044 1.6 1.6 0.87 0.52 0.35 0.32 0.27 0.24 0.18 0.17 0.12 0.089 0.060 0.060 0.050 0.044 16 10 8.8 7.6 6.0 2.8 2.8 1.2 1.2 0.68 0.48 0.48 0.36 0.34 0.24 0.22 0.15 0.15 0.11 0.075 0.075 0.066 0.057 3.5 3.5 1.4 0.88 0.64 0.44 0.48 0.31 0.23 0.19 0.13 0.13 0.093 0.093 0.075 0.063 0.057 15 13 11 10 5.6 2,930 2,930 3,450 3,610 250 250 400 640 840 865 1,050 1,300 1,400 1,650 1,900 2,230 2,930 2,930 3,450 3,610 30 43 53 88 100 180 250 295 295 555 730 760 910 1,050 1,220 1,440 1,660 1,660 1,950 2,555 2,555 3,010 3,150 173 173 278 500 665 725 820 950 1,200 1,350 1,570 1,570 1,990 1,990 2,730 2,850 2,900 20 30 40 65 125 Part No. EKYA250E□□332ML25S EKYA250E□□392ML25S EKYA250E□□472MLN3S EKYA250E□□562MLP1S EKYA350E□□330ME11D EKYA350E□□470ME11D EKYA350E□□101MF11D EKYA350E□□221MHB5D EKYA350E□□271MH15D EKYA350E□□331MJC5S EKYA350E□□391MH20D EKYA350E□□471MJ16S EKYA350E□□681MJ20S EKYA350E□□821MJ25S EKYA350E□□102MK20S EKYA350E□□152MK25S EKYA350E□□222ML25S EKYA350E□□272ML25S EKYA350E□□332MLN3S EKYA350E□□392MLP1S EKYA500E□□1R0ME11D EKYA500E□□2R2ME11D EKYA500E□□3R3ME11D EKYA500E□□4R7ME11D EKYA500E□□100ME11D EKYA500E□□220ME11D EKYA500E□□270ME11D EKYA500E□□470MF11D EKYA500E□□560MF11D EKYA500E□□101MHB5D EKYA500E□□151MH15D EKYA500E□□181MJC5S EKYA500E□□181MH20D EKYA500E□□221MJ16S EKYA500E□□331MJ20S EKYA500E□□471MJ25S EKYA500E□□471MK20S EKYA500E□□561MK20S EKYA500E□□821MK25S EKYA500E□□102ML25S EKYA500E□□122ML25S EKYA500E□□182MLN3S EKYA500E□□222MLP1S EKYA630E□□100ME11D EKYA630E□□150ME11D EKYA630E□□330MF11D EKYA630E□□560MHB5D EKYA630E□□820MH15D EKYA630E□□101MJC5S EKYA630E□□121MH20D EKYA630E□□121MJ16S EKYA630E□□221MJ20S EKYA630E□□331MJ25S EKYA630E□□331MK20S EKYA630E□□391MK20S EKYA630E□□471MK25S EKYA630E□□561MK25S EKYA630E□□102ML25S EKYA630E□□122MLN3S EKYA630E□□152MLP1S EKYA101E□□1R0ME11D EKYA101E□□2R2ME11D EKYA101E□□3R3ME11D EKYA101E□□4R7ME11D EKYA101E□□6R8ME11D □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KYASeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 100 10 6.3×11 15 6.3×11 27 8×11.5 39 8×15 47 10×12.5 56 8×20 68 10×16 100 10×20 150 10×25 180 12.5×20 220 12.5×25 330 16×25 470 16×31.5 560 16×35.5 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.57 0.57 0.36 0.25 0.17 0.19 0.11 0.084 0.069 0.062 0.047 0.038 0.032 0.029 2.3 2.3 1.4 1.0 0.66 0.76 0.47 0.34 0.28 0.18 0.14 0.12 0.095 0.086 205 205 355 450 480 565 600 800 900 1,100 1,250 1,700 1,850 2,000 Part No. EKYA101E□□100MF11D EKYA101E□□150MF11D EKYA101E□□270MHB5D EKYA101E□□390MH15D EKYA101E□□470MJC5S EKYA101E□□560MH20D EKYA101E□□680MJ16S EKYA101E□□101MJ20S EKYA101E□□151MJ25S EKYA101E□□181MK20S EKYA101E□□221MK25S EKYA101E□□331ML25S EKYA101E□□471MLN3S EKYA101E□□561MLP1S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Capacitance(µF) 1.0 220 680 2,200 4,700 to to to to to 180 560 1,800 3,900 120 0.40 0.50 0.60 0.75 0.85 1k 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EKYA350ELL470ME11D 价格&库存
很抱歉,暂时无法提供与“EKYA350ELL470ME11D”相匹配的价格&库存,您可以联系我们找货
