深圳市首韩科技有限公司
SHENZHEN SHOUHAN TECHNOLOGYCO.,LTD
Tel: 0755-27597601 Fax: 0755-27597491
承
认
书
产品名称 Project:
电感
CYA0650-33UH
韩
科
规格型号 Part No:
有
户 Customer:
技
客
限
公
司
SPECIFICATION FOR APPROVAL
首
贵公司承认印 Approal slgnatures
签
章/Signatures
深
圳
市
料 号/Part No.
日期 Date:
拟制/Drawn
李春风
审核/Check
钟华华
批准/Approved
罗孝金
深圳市首韩科技有限公司
1.Features
公
2.Applications area
司
①. H igh performance (Isat) realize by metal dust core .
②. Low profile: Thickness max.2.0~5.0mm.
③. Low loss and low resistance.
④. Capable of corresponding high frequency 1MHz~5MHz.
⑤ Ultra low buzz noise, due to composite construction.
⑥. The products contain no lead and also support lead-free soldering.
Externl Dimensions (unit : mm )
有
3.
限
Ideally used in NB/Desktop/server/Graphic card, LCD TV/Projector, etc as DC-DC Converter.
技
UNIT: mm
A:6 .6±0 .2
B:7 .2±0 .2
C:5.0MAX
D:1 .5±0 .5
E:3 .0±0 .2
市
首
韩
科
1R5
4. Product Code
0650
深
圳
CYA
Code 代码
330
M
TOLERANCE 公差
INDUCTANCE VALUE 电感值
DIMENSIONS 尺寸
SERIAL CODE 系列代码
• 电感值Inductance Value
(1R0:1.0uH; 100: 10uH; 101:100uH)
Tolerance 公差
J
±5%
K
±10%
L
±15%
M
±20%
P
±25%
N
±30%
深圳市首韩科技有限公司
5. Electrical
Characteristics
CYA0650 Series
Electrical Characteristics
Max.
Current DC
Amps . Idc
(A)
CYA0650-R22M
0.22±20%
1.1
1.3
30.0
CYA0650-R36M
0.36±20%
2.7
3.1
21.0
CYA0650-R39M
0.39±20%
3.2
3.5
20.0
CYA0650-R47M
0.47±20%
3.3
3.8
CYA0650-R56M
0.56±20%
3.4
3.6
CYA0650-R68M
0.68±20%
3.9
4.2
CYA0650-R82M
0.82±20%
4.6
4.9
CYA0650-1R0M
1.00±20%
5.6
CYA0650-1R5M
1.50±20%
CYA0650-2R2M
Saturation
Current DC
Amps. Isat
(A)
TEST FREQ
(KHZ)
司
Typ.
Heat Rating
科
C.Y
PART NO
Rdc (mΩ) @25°C
35.0
公
L0(uH)
Inductance
(uH)@(0A)
100KHZ/1.0v
23.0
100KHZ/1.0v
20.0
21.0
100KHZ/1.0v
20.0
18.0
100KHZ/1.0v
18.0
16.0
100KHZ/1.0v
16.5
17.0
100KHZ/1.0v
6.5
12.0
13.0
100KHZ/1.0v
7.0
8.5
10.0
12.5
100KHZ/1.0v
2.20±20%
11.2
12.5
9.5
10.0
100KHZ/1.0v
CYA0650-3R3M
3.30±20%
19.9
20.9
8.5
9.0
100KHZ/1.0v
CYA0650-4R7M
4.70±20%
26.0
29.0
6.0
8.0
100KHZ/1.0v
CYA0650-5R6M
5.60±20%
31.5
34.4
6.0
7.0
100KHZ/1.0v
CYA0650-6R8M
6.80±20%
35.0
40.0
5.5
7.0
100KHZ/1.0v
CYA0650-8R2M
8.20±20%
40.0
43.0
5.5
6.5
100KHZ/1.0v
CYA0650-100M
10.00±20%
48.0
55.0
4.5
6.0
100KHZ/1.0v
CYA0650-120M
12.00±20%
58.0
65.0
4.0
5.0
100KHZ/1.0v
CYA0650-150M
15.00±20%
78.0
85.0
3.1
4.0
100KHZ/1.0v
CYA0650-180M
18.00±20%
83.0
105.0
3.0
3.5
100KHZ/1.0v
CYA0650-220M
22.00±20%
110.0
130.0
2.6
3.5
100KHZ/1.0v
CYA0650-330M
33.00±20%
160.0
200.0
2.3
3.0
100KHZ/1.0v
CYA0650-470M
47.00±20%
250.0
290.0
2.0
2.8
100KHZ/1.0v
首
市
圳
深
技
有
限
100KHZ/1.0v
韩
25.0
深圳市首韩科技有限公司
• Notes
司
1.All test data is reference to 25℃ ambient.
2.Idc: DC current (A) that will cause an approximate △T of 40℃
3. Isat :DC current (A) that will cause L0 to drop approximately 30%
4.Operating Temperature Range -55℃ to +125℃
5.The part temperature (ambient + temp rise ) should not exceed 125 ℃ under worse case operating
conditions. Circuit design, component. PWB trace size and thickness airflow and other cooling provisions all affect
the part temperature. Part temperature should be verified in the den application.
公
6.The rated current as listde is either the saturation current or the heating current depending on which value is lower.
6.Minimum Packaging and storage
限
• 包装Packing
首
韩
科
技
有
Tape Dimension
Reel Dimensions(mm)
A
330
+2/-0
CYA0530
330
深
CYA0618
CYA0624
CYA0630
CYA0650
CYA1040
CYA1250
CYA1260
+2/-0
W
C
100
12.4
13.2
+2/-0
+2/-0
±0.2
100
12.4
13.2
+2/-0
+2/-0
±0.2
圳
CYA0420
N
市
Type
330
100
16.4
13.2
+2/-0
+2/-0
+2/-0
±0.2
330
100
16.4
13.2
+2/-0
+2/-0
+2/-0
±0.2
330
100
16.4
13.2
+2/-0
+2/-0
+2/-0
±0.2
330
100
16.4
13.2
+2/-0
+2/-0
+2/-0
±0.2
330
100
24.4
13.2
+2/-0
+2/-0
+2/-0
±0.2
330
100
24.4
13.2
+2/-0
+2/-0
+2/-0
±0.2
330
100
24.4
13.2
+2/-0
+2/-0
+2/-0
±0.2
Tape Dimensions(mm)
W
P
P0
A0
B0
H
T
12±0.3
8±0.1
4±0.1
4.4±0.1
4.9±0.1
2.3±0.05
0.35±0.05
12±0.3
8±0.1
4±0.1
5.4±0.1
5.9±0.1
3.3±0.05
0.35±0.05
16±0.3
12±0.1
4±0.1
6.9±0.1
7.5±0.1
2.1±0.05
0.35±0.05
16±0.3
12±0.1
4±0.1
6.9±0.1
7.5±0.1
2.7±0.05
0.35±0.05
16±0.3
12±0.1
4±0.1
6.9±0.1
7.5±0.1
3.3±0.05
0.35±0.05
16±0.3
12±0.1
4±0.1
6.9±0.1
7.5±0.1
5.2±0.1
0.4±0.05
24±0.3
16±0.1
4±0.1
10.4±0.1
11.5±0.1
4.3±0.1
0.35±0.05
24±0.3
16±0.1
4±0.1
13.2±0.1
14.4±0.1
5.3±0.1
0.4±0.05
24±0.3
16±0.1
4±0.1
13.2±0.1
14.4±0.1
6.3±0.1
0.5±0.05
深圳市首韩科技有限公司
• Tape Carrier Packaging:
Standard Quantity
(pcs/reel)
Type
Standard Quantity
(pcs/reel)
Type
3000
CYA1250
400
CYA5030
2000
CYA1265
400
CYA6030
1000
CYA1040
1000
公
司
CYA0420
技
有
限
• Tearing Off Force
The force for tearing off cover tape is 15 to 60 grams in the arrow direction under the following conditions
Room Humidity
860~1060
Tearing Speed
mm/min
300
首
• Application Notice
韩
45~85
5~35
Room atm
(hPa)
科
Room
Temp. ( )℃
Storage Conditions To maintain the solderability of terminal electrodes:
市
1. Temperature and humidity conditions: Less than 30℃ and 70% RH.
2. Recommended products should be used within 6 months form the time of delivery.
圳
3. The packaging material should be kept where no chlorine or sulfur exists in the air.
Transportation
1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils .
深
2. The use of tweezers or vacuum pick up is strongly recommended for individual components. Bulk handling
should ensure that abrasion and mechanical shock are minimized.
很抱歉,暂时无法提供与“CYA0650-33UH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.82228
- 50+1.44995
- 150+1.29030
- 1000+1.04693
- 2000+0.95819
- 5000+0.90504
