OT2EL89CJI-111YLC-12M
    YXC(扬兴科技)
    SMD3225_4P
    YSO110TR 12MHZ 1.8V-3.3V ±10PPM -40~85℃ (±20PPM) CMOS
OT2EL89CJI-111YLC-12M 数据手册
Crystal Oscillator YSO110TR Applications ‧Consumer Electronics Industrial Control IOT WideVoltage Features ‧Frequency range: 1MHz-125MHz. ‧Package Size: 1.6*1.2, 2.0*1.6 ‧Ultra Small SMD seam sealed crystal 2.5*2.0, 3.2*2.5, 5.0*3.2, 7.0*5.0mm oscillator units. Specifications(规格参数) Item Symbol Specifications Supply Voltage(电源电压) f₀ 1MHz to 125MHz, or specify Vcc 1.8V~3.3V Frequency Tolerance(频率偏差) (at 25℃ ) - CMOS f_tol ±10ppm, ±20ppm, or specify L_cmos 15pF T_use -40~+85℃, or specify Frequency Versus Temperature Characteristics(频率-温度特性) T_stg -55~+125℃ f_tem ±20ppm, ±30ppm, ±50ppm, or specify Start-up Time(启动时间) SYM 45~55% t_str 3ms Max. tr/tf 4ns Max tpj 0.7ps max f_age ±3ppm/year Max. Frequency Range(额定频率范围) Output Type(输出方式) Output Load(输出负载) Operating Temperature(工作温度) Storage Temperature(储存温度) Duty Cycle(占空比) Rise Time/Fall Time(上升沿/下降沿) Phase Jitter [12 kHz ~ 20 MHz](相位抖动) Frequency Aging(老化)(at 25℃ ) Current Consumption(消耗电流) Power Dissipation Vcc=1.8~3.3V 15pF only 1.000~40.000MHZ Supply Voltage (V) 7050/5032/3225 1.8V 4mA max 2.5V 3.3V 4.5mA max 5mA max 41.000~125.000MHZ 2520/2016/1612 7050/5032/3225/2520 2016/1612 9mA max 4mA max 10mA max 12mA max 10mA max Pin Dimension(脚位尺寸) Pin #1 #2 #3 #4 FUNCTION Tri-state GND OUTPUT VDD *The picture on the right is only for PIN function description. www.yxc.hk 1 Crystal Oscillator YSO110TR WideVoltage Dimensions and Recommended land pattern(外观尺寸及推荐焊盘) Package Size - Dimensions(Unit:mm) Recommended Land Pattern(Unit:mm) www.yxc.hk 2 Crystal Oscillator YSO110TR WideVoltage Notes: 1.A capacitor value-0.01uf~0.1uf or higher between Vdd and GND is required. Test Circuit(测试电路) CMOS www.yxc.hk 3
OT2EL89CJI-111YLC-12M 价格&库存
很抱歉,暂时无法提供与“OT2EL89CJI-111YLC-12M”相匹配的价格&库存,您可以联系我们找货
  • 1+2.66304
  • 10+2.05200
  • 30+1.78752
  • 1+3.36960
  • 10+2.64600
  • 30+2.34360
  • 100+1.95480
  • 500+1.70640
  • 1000+1.60920
库存:18343
