ESP8684H2
ESP8684H2
    ESPRESSIF(乐鑫)
    QFN-24_4X4MM-EP
ESP8684H2 数据手册
ESP8684 Series Datasheet Ultra­Low­Power SoC with RISC­V Single­Core CPU Supporting IEEE 802.11b/g/n (2.4 GHz Wi­Fi) and Bluetooth 5 (LE) 1 MB, 2 MB or 4 MB flash in the 4×4 mm QFN package Including: ESP8684H1 ESP8684H2 ESP8684H4 Version v1.2 Espressif Systems Copyright © 2022 www.espressif.com Product Overview ESP8684 series of SoCs is an ultra-low-power and highly-integrated MCU-based SoC solution that supports 2.4 GHz Wi-Fi and Bluetooth® Low Energy (Bluetooth LE). The block diagram of ESP8684 series is shown below. Espressif’s ESP8684 Wi-Fi + Bluetooth® Low Energy SoC Wireless MAC and Baseband Core System RF Cache SRAM Bluetooth LE Link Controller JTAG ROM Bluetooth LE Baseband 2.4 GHz Transmitter Wi-Fi MAC 2.4 GHz Receiver Wi-Fi Baseband Peripherals RTC SPI0/1 I2C Master GPIO RTC GPIO SPI2 GDMA UART RTC Watchdog Timer DIG ADC Controller SiP Flash PMU Security RTC Super Watchdog Timer Temperature Sensor Main System Watchdog Timer General-purpose Timer RF Synthesizer 2.4 GHz Balun + Switch RISC-V 32-bit Microprocessor eFuse Controller Brownout System Timer LED PWM RNG ECC Secure Boot SHA Flash Encryption Modules having power in specific power modes: Active Active, Modem-sleep, and Light-sleep; All modes Figure 1: Functional block diagram of ESP8684 Solution Highlights • A complete Wi­Fi subsystem that complies • Storage capacity ensured by 272 KB of SRAM with IEEE 802.11b/g/n protocol and supports (16 KB for cache) and 576 KB of ROM on the Station mode, SoftAP mode, SoftAP + Station chip. mode, and promiscuous mode • Reliable security features ensured by • A Bluetooth LE subsystem that supports – Cryptographic hardware accelerators that features of Bluetooth 5, central role and support ECC, Hash and secure boot peripheral role – Random number generator • State­of­the­art power and RF performance – External memory encryption and decryption • 32­bit RISC­V single­core processor with a • Rich set of peripheral interfaces and GPIOs, four-stage pipeline that operates at up to 120 ideal for various scenarios and complex MHz Espressif Systems applications 1 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) Features – 1 core at 120 MHz: 305.42 CoreMark; 2.55 Wi­Fi CoreMark/MHz • IEEE 802.11 b/g/n-compliant • 576 KB ROM • Supports 20 MHz bandwidth in 2.4 GHz band • 272 KB SRAM (16 KB for cache) • 1T1R mode with data rate up to 72.2 Mbps • SiP flash (see details in Chapter 1 ESP8684 • Wi-Fi Multimedia (WMM) Series Comparison) • TX/RX A-MPDU, TX/RX A-MSDU • Access to flash accelerated by cache • Immediate Block ACK • Supports flash in-Circuit Programming (ICP) • Fragmentation and defragmentation Advanced Peripheral Interfaces • Transmit opportunity (TXOP) • 14 × programmable GPIOs • Automatic Beacon monitoring (hardware TSF) • Digital interfaces: • 3 × virtual Wi-Fi interfaces – 3 × SPI • Simultaneous support for Infrastructure BSS in Station mode, SoftAP mode, Station + SoftAP – 2 × UART mode, and promiscuous mode – 1 × I2C Master Note that when ESP8684 series scans in Station – LED PWM controller, with up to 6 channels mode, the SoftAP channel will change along with the Station channel – General DMA controller (GDMA), with 1 transmit channel and 1 receive channel • Antenna diversity • Analog interfaces: Bluetooth – 1 × 12-bit SAR ADC, up to 5 channels – 1 × temperature sensor • Bluetooth LE: Bluetooth 5 • Timers: • High power mode�20 dBm� • Speed: 125 kbps, 500 kbps, 1 Mbps, 2 Mbps – 1 × 54-bit general-purpose timer • Advertising extensions – 2 × watchdog timers • Multiple advertisement sets – 1 × 52-bit system timer • Channel selection algorithm #2 Low Power Management • Internal co-existence mechanism between Wi-Fi • Power Management Unit with four power modes and Bluetooth to share the same antenna Security CPU and Memory • Secure boot • 32-bit RISC-V single-core processor, up to 120 MHz • Flash encryption • CoreMark® score: Espressif Systems • 1024-bit OTP, up to 256 bits for use 2 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) – SHA Accelerator (FIPS PUB 180-4) • Cryptographic hardware acceleration: – ECC • Random Number Generator (RNG) Applications (A Non­exhaustive List) With ultra-low power consumption, ESP8684 is an ideal choice for IoT devices in the following areas: • Smart Home • Health Care – Light control – Health monitor – Smart button – Baby monitor – Smart plug • Smart Agriculture – Indoor positioning – Smart greenhouse – Smart irrigation • Industrial Automation – Industrial robot – Agriculture robot – Industrial field bus • Retail and Catering – POS machines • Consumer Electronics – Smart watch and bracelet – Service robot – Over-the-top (OTT) devices • Generic Low-power IoT Sensor Hubs – Logger toys and proximity sensing toys • Generic Low-power IoT Data Loggers Espressif Systems 3 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) Contents Contents Product Overview 1 Solution Highlights 1 Features 2 Applications 3 1 ESP8684 Series Comparison 8 1.1 ESP8684 Series Nomenclature 8 1.2 Comparison 8 2 Pin Definition 9 2.1 Pin Layout 9 2.2 Pin Description 9 2.3 Power Scheme 10 2.4 Strapping Pins 12 3 Functional Description 14 3.1 Radio and Wi-Fi 14 3.1.1 2.4 GHz Receiver 14 3.1.2 2.4 GHz Transmitter 14 3.1.3 Clock Generator 14 3.1.4 Wi-Fi Radio and Baseband 15 3.1.5 Wi-Fi MAC 15 3.1.6 Networking Features 15 3.2 3.3 3.4 3.5 3.6 Bluetooth LE 15 3.2.1 Bluetooth LE Radio and PHY 16 3.2.2 Bluetooth LE Link Layer Controller 16 CPU and Memory 16 3.3.1 CPU 16 3.3.2 Internal Memory 17 3.3.3 Address Mapping Structure 17 3.3.4 Cache 17 System Clocks 18 3.4.1 CPU Clock 18 3.4.2 RTC Clock 18 Digital Peripherals 18 3.5.1 General Purpose Input / Output Interface (GPIO) 18 3.5.2 Serial Peripheral Interface (SPI) 20 3.5.3 Universal Asynchronous Receiver Transmitter (UART) 20 3.5.4 I2C Interface 20 3.5.5 LED PWM Controller 21 3.5.6 General DMA Controller 21 Analog Peripherals 21 3.6.1 21 Analog-to-Digital Converter (ADC) Espressif Systems 4 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) Contents 3.6.2 3.7 Temperature Sensor 21 Timers 21 3.7.1 General Purpose Timer 21 3.7.2 System Timer 22 3.7.3 Watchdog Timers 22 3.8 Low Power Management 22 3.9 Cryptographic Hardware Accelerators 23 3.10 Physical Security Features 23 3.11 Peripheral Pin Configurations 23 4 Electrical Characteristics 25 4.1 Absolute Maximum Ratings 25 4.2 Recommended Operating Conditions 25 4.3 DC Characteristics (3.3 V, 25 °C) 25 4.4 ADC Characteristics 26 4.5 Current Consumption 27 4.5.1 RF Current Consumption in Active Mode 27 4.5.2 Current Consumption in Other Modes 27 4.6 Reliability 27 4.7 Wi-Fi Radio 28 4.7.1 Wi-Fi RF Transmitter (TX) Specifications 28 4.7.2 Wi-Fi RF Receiver (RX) Specifications 29 4.8 Bluetooth LE Radio 30 4.8.1 Bluetooth LE RF Transmitter (TX) Specifications 30 4.8.2 Bluetooth LE RF Receiver (RX) Specifications 32 5 Package Information 35 6 Related Documentation and Resources 36 Revision History Espressif Systems 37 5 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) List of Tables List of Tables 1 ESP8684 Series Member Comparison 8 2 Pin Description 9 3 Description of ESP8684 Series Power-up and Reset Timing Parameters 12 4 Strapping Pins 12 5 Parameter Descriptions of Setup and Hold Times for the Strapping Pins 13 6 IO MUX Pin Functions 19 7 Power-Up Glitches on Pins 20 8 Peripheral Pin Configurations 23 9 Absolute Maximum Ratings 25 10 Recommended Operating Conditions 25 11 DC Characteristics (3.3 V, 25 °C) 25 12 ADC Characteristics 26 13 ADC Calibration Results 26 14 Current Consumption Depending on RF Modes 27 15 Current Consumption in Low-Power Modes 27 16 Current Consumption in Modem-sleep Mode 27 17 Reliability Qualifications 28 18 Wi-Fi Frequency 28 19 TX Power with Spectral Mask and EVM Meeting 802.11 Standards 28 20 TX EVM Test 29 21 RX Sensitivity 29 22 Maximum RX Level 29 23 RX Adjacent Channel Rejection 30 24 Bluetooth LE Frequency 30 25 Transmitter General Characteristics 30 26 Transmitter Characteristics - Bluetooth LE 1 Mbps 30 27 Transmitter Characteristics - Bluetooth LE 2 Mbps 31 28 Transmitter Characteristics - Bluetooth LE 125 Kbps 31 29 Transmitter Characteristics - Bluetooth LE 500 Kbps 31 30 Receiver Characteristics - Bluetooth LE 1 Mbps 32 31 Receiver Characteristics - Bluetooth LE 2 Mbps 32 32 Receiver Characteristics - Bluetooth LE 125 Kbps 33 33 Receiver Characteristics - Bluetooth LE 500 Kbps 33 Espressif Systems 6 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) List of Figures List of Figures 1 Functional block diagram of ESP8684 1 2 ESP8684 Series Nomenclature 8 3 ESP8684 Pin Layout (Top View) 9 4 ESP8684 Series Power Scheme 11 5 ESP8684 Series Power-up and Reset Timing 11 6 Setup and Hold Times for the Strapping Pins 13 7 Address Mapping Structure 17 8 QFN24 (4×4 mm) Package 35 Espressif Systems 7 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 1 ESP8684 Series Comparison 1 ESP8684 Series Comparison 1.1 ESP8684 Series Nomenclature ESP8684 H x Flash Flash temperature H: High temperature Chip series Figure 2: ESP8684 Series Nomenclature 1.2 Comparison Table 1: ESP8684 Series Member Comparison Ordering Code SiP Flash Ambient Temperature (°C) Package (mm) ESP8684H1 1 MB –40 ∼ 105 QFN24 (4*4) ESP8684H2 2 MB –40 ∼ 105 QFN24 (4*4) 4 MB –40 ∼ 105 QFN24 (4*4) 1 1 ESP8684H4 1 The ESP8684H1 and ESP8684H4 chips are still in sample status. Espressif Systems 8 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 2 Pin Definition 2 Pin Definition 19 U0RXD 20 U0TXD 21 VDDA 22 XTAL_N 23 XTAL_P 24 VDDA 2.1 Pin Layout ANT 1 18 GPIO18 VDDA3P3 2 17 VDD3P3_CPU VDDA3P3 3 16 GPIO10 GPIO0 4 15 GPIO9 GPIO1 5 ESP8684 14 GPIO8 25 GND MTCK 12 VDD3P3_RTC 11 9 MTMS MTDI 10 8 GPIO3 13 MTDO 7 6 CHIP_EN GPIO2 Figure 3: ESP8684 Pin Layout (Top View) 2.2 Pin Description Table 2: Pin Description Name No. Type Power Domain Function ANT 1 I/O — RF input and output VDDA3P3 2 PA — Analog power supply VDDA3P3 3 PA — Analog power supply GPIO0 4 I/O/T VDD3P3_RTC GPIO0, ADC1_CH0 GPIO1 5 I/O/T VDD3P3_RTC GPIO1, ADC1_CH1 GPIO2 6 I/O/T VDD3P3_RTC GPIO2, ADC1_CH2, FSPIQ High: on, enables the chip. CHIP_EN 7 I VDD3P3_RTC Low: off, the chip powers off. Note: Do not leave the CHIP_EN pin floating. GPIO3 8 I/O/T VDD3P3_RTC GPIO3, ADC1_CH3 MTMS 9 I/O/T VDD3P3_RTC MTMS, GPIO4, ADC1_CH4, FSPIHD MTDI 10 I/O/T VDD3P3_RTC MTDI, GPIO5, FSPIWP Espressif Systems 9 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 2 Pin Definition Name No. Type Power Domain Function VDD3P3_RTC 11 PD — MTCK 12 I/O/T VDD3P3_CPU MTCK, GPIO6, FSPICLK MTDO 13 I/O/T VDD3P3_CPU MTDO, GPIO7, FSPID GPIO8 14 I/O/T VDD3P3_CPU GPIO8 GPIO9 15 I/O/T VDD3P3_CPU GPIO9 GPIO10 16 I/O/T VDD3P3_CPU GPIO10, FSPICS0 VDD3P3_CPU 17 PD — GPIO18 18 I/O/T VDD3P3_CPU GPIO18 U0RXD 19 I/O/T VDD3P3_CPU U0RXD, GPIO19 U0TXD 20 I/O/T VDD3P3_CPU U0TXD, VDDA 21 PA — Analog power supply XTAL_N 22 — — External crystal output XTAL_P 23 — — External crystal input VDDA 24 PA — Analog power supply GND 25 G — Ground Input power supply for RTC Input power supply for digital IO GPIO20 1 PA : analog power supply; PD : power supply for digital IO; I: input; O: output; T: high impedance. 2 Pin functions in bold font are the default pin functions. 3 The pin function in this table refers only to some fixed settings and do not cover all cases for signals that can be input and output through the GPIO matrix. For more information on the GPIO matrix, please refer to Chapter IO MUX and GPIO Matrix (GPIO, IO_MUX) in ESP8684 Technical Reference Manual. 2.3 Power Scheme Digital pins of ESP8684 are divided into two different power domains: • VDD3P3_CPU • VDD3P3_RTC VDD3P3_CPU is the input power supply for digital IO and digital system. VDD3P3_RTC is the input power supply for RTC, RTC IO, and digital system. The power scheme diagram is shown in Figure 4. Espressif Systems 10 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 2 Pin Definition Figure 4: ESP8684 Series Power Scheme Notes on CHIP_EN: Figure 5 shows the power-up and reset timing of ESP8684 series. Details about the parameters are listed in Table 3. t0 t1 2.8 V VDDA, VDDA3P3, VDD3P3_RTC, VDD3P3_CPU CHIP_EN VIL_nRST Figure 5: ESP8684 Series Power­up and Reset Timing Espressif Systems 11 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 2 Pin Definition Table 3: Description of ESP8684 Series Power­up and Reset Timing Parameters Min Parameter Description (µs) Time between bringing up the VDDA, VDDA3P3, VDD3P3_RTC, and t0 VDD3P3_CPU rails, and activating CHIP_EN Duration of CHIP_EN signal level < VIL_nRST (refer to its value in t1 Table 11) to reset the chip 50 50 2.4 Strapping Pins ESP8684 series has two strapping pins: • GPIO8 • GPIO9 Software can read the values of GPIO8 and GPIO9 from GPIO_STRAPPING field in GPIO_STRAP_REG register. For register description, please refer to Section GPIO Matrix Register Summary in ESP8684 Technical Reference Manual. During the chip’s power-on reset, RTC watchdog reset, and brownout reset, the latches of the strapping pins sample the voltage level as strapping bits of ”0” or ”1”, and hold these bits until the chip is powered down or shut down. By default, GPIO9 is connected to the internal weak pull-up resistor. If GPIO9 is not connected or connected to an external high-impedance circuit, the latched bit value will be ”1”. To change the strapping bit values, you can apply the external pull-down/pull-up resistances, or use the host MCU’s GPIOs to control the voltage level of these pins when powering on ESP8684. After reset, the strapping pins work as normal-function pins. Table 4 lists detailed booting configurations of the strapping pins. Table 4: Strapping Pins Booting Mode 1 Pin Default SPI Boot Download Boot GPIO8 N/A Don’t care 1 1 0 GPIO9 Internal weak pull-up Enabling/Disabling ROM Messages Print During Booting Pin Default Functionality When the value of eFuse field EFUSE_UART_PRINT_CONTROL is 0 (default), print is enabled and not controlled by GPIO8. GPIO8 N/A 1, if GPIO8 is 0, print is enabled; if GPIO8 is 1, it is disabled. 2, if GPIO8 is 0, print is disabled; if GPIO8 is 1, it is enabled. 3, print is disabled and not controlled by GPIO8. 1 The strapping combination of GPIO8 = 0 and GPIO9 = 0 is invalid and will trigger unexpected behavior. Espressif Systems 12 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 2 Pin Definition Figure 6 shows the setup and hold times for the strapping pins before and after the CHIP_EN signal goes high. Details about the parameters are listed in Table 5. t0 CHIP_EN t1 VIL_nRST VIH Strapping pin Figure 6: Setup and Hold Times for the Strapping Pins Table 5: Parameter Descriptions of Setup and Hold Times for the Strapping Pins Min Parameter Description t0 Setup time before CHIP_EN goes from low to high 0 t1 Hold time after CHIP_EN goes high 3 Espressif Systems (ms) 13 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description 3 Functional Description This chapter describes the functions of ESP8684. 3.1 Radio and Wi­Fi The ESP8684 series radio consists of the following blocks: • 2.4 GHz receiver • 2.4 GHz transmitter • bias and regulators • balun and transmit-receive switch • clock generator 3.1.1 2.4 GHz Receiver The 2.4 GHz receiver demodulates the 2.4 GHz RF signal to quadrature baseband signals and converts them to the digital domain with two high-resolution, high-speed ADCs. To adapt to varying signal channel conditions, ESP8684 series integrates RF filters, Automatic Gain Control (AGC), DC offset cancelation circuits, and baseband filters. 3.1.2 2.4 GHz Transmitter The 2.4 GHz transmitter modulates the quadrature baseband signals to the 2.4 GHz RF signal, and drives the antenna with a high-powered CMOS power amplifier. The use of digital calibration further improves the linearity of the power amplifier. Additional calibrations are integrated to cancel any radio imperfections, such as: • carrier leakage • I/Q amplitude/phase matching • baseband nonlinearities • RF nonlinearities • antenna matching These built-in calibration routines reduce the cost, time, and specialized equipment required for product testing. 3.1.3 Clock Generator The clock generator produces quadrature clock signals of 2.4 GHz for both the receiver and the transmitter. All components of the clock generator are integrated into the chip, including inductors, varactors, filters, regulators and dividers. The clock generator has built-in calibration and self-test circuits. Quadrature clock phases and phase noise are optimized on chip with patented calibration algorithms which ensure the best performance of the receiver and the transmitter. Espressif Systems 14 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description 3.1.4 Wi­Fi Radio and Baseband The ESP8684 series Wi-Fi radio and baseband support the following features: • 802.11b/g/n • 802.11n MCS0-7 that supports 20 MHz bandwidth • 802.11n 0.4 µs guard interval • data rate up to 72.2 Mbps • RX STBC (single spatial stream) • adjustable transmitting power • antenna diversity ESP8684 series supports antenna diversity with an external RF switch. This switch is controlled by one or more GPIOs, and used to select the best antenna to minimize the effects of channel imperfections. 3.1.5 Wi­Fi MAC ESP8684 series implements the full 802.11 b/g/n Wi-Fi MAC protocol. It supports the Basic Service Set (BSS) STA and SoftAP operations under the Distributed Control Function (DCF). Power management is handled automatically with minimal host interaction to minimize the active duty period. The ESP8684 series Wi-Fi MAC applies the following low-level protocol functions automatically: • 3 × virtual Wi-Fi interfaces • infrastructure BSS in Station mode, SoftAP mode, Station + SoftAP mode, and promiscuous mode • RTS protection, CTS protection, Immediate Block ACK • fragmentation and defragmentation • TX/RX A-MPDU, TX/RX A-MSDU • transmit opportunity (TXOP) • Wi-Fi multimedia (WMM) • CCMP, TKIP, WEP, BIP, WPA2-PSK/WPA2-Enterprise, and WPA3-PSK/WPA3-Enterprise • automatic beacon monitoring (hardware TSF) 3.1.6 Networking Features Espressif provides libraries for TCP/IP networking and other networking protocols over Wi-Fi. TLS 1.2 (default) and 1.3 are also supported. 3.2 Bluetooth LE ESP8684 series includes a Bluetooth Low Energy subsystem that integrates a hardware link layer controller, an RF/modem block and a feature-rich software protocol stack. It supports the core features of Bluetooth 5. Espressif Systems 15 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description 3.2.1 Bluetooth LE Radio and PHY Bluetooth Low Energy radio and PHY in ESP8684 series support: • 1 Mbps PHY • 2 Mbps PHY for higher data rates • coded PHY for longer range (125 Kbps and 500 Kbps) • HW listen before talk (LBT) 3.2.2 Bluetooth LE Link Layer Controller Bluetooth Low Energy Link Layer Controller in ESP8684 series supports: • LE advertising extensions, to enhance broadcasting capacity and broadcast more intelligent data • multiple advertisement sets • simultaneous advertising and scanning • adaptive frequency hopping and channel assessment • LE channel selection algorithm #2 • connection parameter update • high duty cycle non-connectable advertising • LE privacy 1.2 • LE data packet length extension • link layer extended scanner filter policies • low duty cycle directed advertising • link layer encryption • LE Ping 3.3 CPU and Memory 3.3.1 CPU ESP8684 series has a low-power 32-bit RISC-V single-core microprocessor with the following features: • four-stage pipeline that supports a clock frequency of up to 120 MHz • RV32IMC ISA • 32-bit multiplier and 32-bit divider • up to 32 vectored interrupts at seven priority levels • up to 2 hardware breakpoints/watchpoints • JTAG for debugging Espressif Systems 16 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description 3.3.2 Internal Memory ESP8684’s internal memory includes: • 576 KB of ROM: for booting and core functions. • 272 KB of on­chip SRAM: for data and instructions. Of the 272 KB SRAM, 16 KB is configured for cache. • 1 Kbit of eFuse: 256 bits are reserved for your data, such as encryption key and device ID. • SiP flash : See details in Chapter 1 ESP8684 Series Comparison. 3.3.3 Address Mapping Structure Figure 7: Address Mapping Structure Note: The memory space with gray background is not available for use. 3.3.4 Cache ESP8684 series has an four-way set associative cache. This cache is read-only and has the following features: • size: 16 KB • block size: 32 bytes Espressif Systems 17 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description • critical word first and early restart 3.4 System Clocks 3.4.1 CPU Clock The CPU clock has three possible sources: • external main crystal clock • fast RC oscillator (typically about 17.5 MHz, and adjustable) • PLL clock The application can select the clock source from the three clocks above. The selected clock source drives the CPU clock directly, or after division, depending on the application. Once the CPU is reset, the default clock source would be the external main crystal clock divided by 2. Note: ESP8684 is unable to operate without an external main crystal clock. 3.4.2 RTC Clock The RTC slow clock is used for RTC counter, RTC watchdog and low-power controller. It has three possible sources: • internal slow RC oscillator (typically about 136 kHz, and adjustable) • internal fast RC oscillator divided clock (derived from the fast RC oscillator divided by 256) • external slow clock (clock signal input through GPIO0, and typically about 32.768 kHz) The RTC fast clock is used for RTC peripherals and sensor controllers. It has two possible sources: • external main crystal clock divided by 2 • internal fast RC oscillator clock (typically about 17.5 MHz, and adjustable) 3.5 Digital Peripherals 3.5.1 General Purpose Input / Output Interface (GPIO) ESP8684 has 14 GPIO pins which can be assigned various functions by configuring corresponding registers. Besides digital signals, some GPIOs can be also used for analog functions, such as ADC. All GPIOs have selectable internal pull-up or pull-down, or can be set to high impedance. When these GPIOs are configured as an input, the input value can be read by software through the register. Input GPIOs can also be set to generate edge-triggered or level-triggered CPU interrupts. All digital IO pins are bi-directional, non-inverting and tristate, including input and output buffers with tristate control. These pins can be multiplexed with other functions, such as the UART, SPI, etc. For low-power operations, the GPIOs can be set to holding state. The IO MUX and the GPIO matrix are used to route signals from peripherals to GPIO pins. Together they provide highly configurable I/O. Using GPIO Matrix, peripheral input signals can be configured from any IO pins while peripheral output signals can be configured to any IO pins. Table 6 shows the IO MUX functions of each pin. For Espressif Systems 18 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description more information about IO MUX and GPIO matrix, please refer to Chapter IO MUX and GPIO Matrix (GPIO, IO_MUX) in ESP8684 Technical Reference Manual. Table 6: IO MUX Pin Functions Name No. Function 0 Function 1 Function 2 Reset Notes GPIO0 4 GPIO0 GPIO0 — 0 R, G GPIO1 5 GPIO1 GPIO1 — 0 R, G GPIO2 6 GPIO2 GPIO2 FSPIQ 1 R GPIO3 8 GPIO3 GPIO3 — 1 R, G MTMS 9 MTMS GPIO4 FSPIHD 1 R MTDI 10 MTDI GPIO5 FSPIWP 1 R, G MTCK 12 MTCK GPIO6 FSPICLK 1* — MTDO 13 MTDO GPIO7 FSPID 1 — GPIO8 14 GPIO8 GPIO8 — 1 — GPIO9 15 GPIO9 GPIO9 — 3 — GPIO10 16 GPIO10 GPIO10 FSPICS0 1 — GPIO18 18 GPIO18 GPIO18 — 0 — U0RXD 19 U0RXD GPIO19 — 3 — U0TXD 20 U0TXD GPIO20 — 4 — Reset The default configuration of each pin after reset: • 0 - input disabled, in high impedance state (IE = 0) • 1 - input enabled, in high impedance state (IE = 1) • 2 - input enabled, pull-down resistor enabled (IE = 1, WPD = 1) • 3 - input enabled, pull-up resistor enabled (IE = 1, WPU = 1) • 4 - output enabled, pull-up resistor enabled (OE = 1, WPU = 1) • 1* - When the value of eFuse bit EFUSE_DIS_PAD_JTAG is 0, input enabled, pull-up resistor enabled (IE = 1, WPU = 1) 1, input enabled, in high impedance state (IE = 1) We recommend pulling high or low GPIO pins in high impedance state to avoid unnecessary power consumption. You may add pull-up and pull-down resistors in your PCB design referring to Table 11, or enable internal pull-up and pull-down resistors during software initialization. Notes • R - These pins have analog functions. • G - These pins have glitches during power-up. See details in Table 7. Espressif Systems 19 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description Table 7: Power­Up Glitches on Pins Typical Time Period Pin Glitch1 GPIO0 Low-level glitch 40 GPIO1 Low-level glitch 60 GPIO3 Low-level glitch 40 MTDI Low-level glitch 60 1 (µs) Low-level glitch: the pin is at a low level during the time period; 3.5.2 Serial Peripheral Interface (SPI) ESP8684 series features three SPI interfaces (SPI0, SPI1, and SPI2). SPI0 and SPI1 can be configured to operate in SPI memory mode and SPI2 can be configured to operate in general-purpose SPI mode. • SPI Memory mode In SPI memory mode, SPI0 and SPI1 interface with SiP flash. Data is transferred in bytes. Up to four-line STR reads and writes are supported. The clock frequency is configurable to a maximum of 60 MHz in STR mode. • SPI2 General­purpose SPI (GP­SPI) mode When SPI2 acts as a general-purpose SPI, it can operate in master and slave modes. SPI2 supports two-line full-duplex communication and single-/two-/four-line half-duplex communication in both master and slave modes. The host’s clock frequency of SPI2 is configurable. Data is transferred in bytes. The clock polarity (CPOL) and phase (CPHA) are also configurable. The SPI2 interface can connect to GDMA. In master or slave mode, the clock frequency is 40 MHz at most, and the four modes of SPI transfer format are supported. 3.5.3 Universal Asynchronous Receiver Transmitter (UART) ESP8684 series has two UART interfaces, i.e. UART0 and UART1, which support IrDA and asynchronous communication (RS232 and RS485) at a speed of up to 2.5 Mbps. The UART controller provides hardware flow control (CTS and RTS signals) and software flow control (XON and XOFF). 3.5.4 I2C Interface ESP8684 series has an I2C bus master interface. The I2C interface supports: • standard mode (100 Kbit/s) • fast mode (400 Kbit/s) • up to 800 Kbit/s (constrained by SCL and SDA pull-up strength) • 7-bit and 10-bit addressing mode • double addressing mode • 7-bit broadcast address You can configure instruction registers to control the I2C interface for more flexibility. Espressif Systems 20 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description 3.5.5 LED PWM Controller The LED PWM controller has the following features: • Six identical, independent PWM generators (i.e. channels) that generate digital waveforms • Configurable waveform periods and duty cycle • Maximum PWM resolution: 18 bits • PWM signal output in low-power mode (Light-sleep mode) • Automatic duty cycle fading - gradual increase/decrease of PWM duty cycle, which is useful for the LED RGB color-gradient generator. 3.5.6 General DMA Controller ESP8684 series has a general DMA controller (GDMA) with two independent channels, i.e. one transmit channel and one receive channel. These two channels are shared by peripherals with DMA feature. The GDMA controller implements a fixed-priority scheme among these channels, whose priority can be configured. The GDMA controller controls data transfer using linked lists. It allows peripheral-to-memory and memory-to-memory data transfer at a high speed. All channels can access internal RAM. Peripherals on ESP8684 series with DMA feature are SPI2 and SHA. 3.6 Analog Peripherals 3.6.1 Analog­to­Digital Converter (ADC) ESP8684 series integrates a 12-bit SAR ADC, which supports measurements on 5 channels. For ADC characteristics, please refer to Table 12. 3.6.2 Temperature Sensor The temperature sensor generates a voltage that varies with temperature. The voltage is internally converted via an ADC into a digital value. The temperature sensor has a range of –40 °C to 125 °C. It is designed primarily to sense the temperature changes inside the chip. The temperature value depends on factors like microcontroller clock frequency or I/O load. Generally, the chip’s internal temperature is higher than the operating ambient temperature. 3.7 Timers 3.7.1 General Purpose Timer ESP8684 series is embedded with a 54-bit general-purpose timer, which is based on a 16-bit prescaler and a 54-bit auto-reload-capable up/down-timer. The timers’ features are summarized as follows: • a 16-bit clock prescaler, from 2 to 65536 • a 54-bit time-base counter programmable to be incrementing or decrementing Espressif Systems 21 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description • able to read real-time value of the time-base counter • halting and resuming the time-base counter • programmable alarm generation • level interrupt generation 3.7.2 System Timer ESP8684 series integrates a 52-bit system timer, which has two 52-bit counters and three comparators. The system timer has the following features: • counters with a fixed clock frequency of 16 MHz • three types of independent interrupts generated according to alarm value • two alarm modes: target mode and period mode • 52-bit target alarm value and 26-bit periodic alarm value • automatic reload of counter value • counters can be stalled if the CPU is stalled or in OCD mode 3.7.3 Watchdog Timers The ESP8684 series contains two watchdog timers: one in general-purpose timer group (called Main System Watchdog Timer, or MWDT) and one in the RTC module (called the RTC Watchdog Timer, or RWDT). During the flash boot process, RWDT and MWDT are enabled automatically in order to detect and recover from booting errors. Watchdog timers have the following features: • four stages, each with a programmable timeout value. Each stage can be configured, enabled and disabled separately • interrupt, CPU reset, or core reset for MWDT upon expiry of each stage; interrupt, CPU reset, core reset, or system reset for RWDT upon expiry of each stage • 32-bit expiry counter • write protection, to prevent RWDT and MWDT configuration from being altered inadvertently • flash boot protection If the boot process from an SPI flash does not complete within a predetermined period of time, the watchdog will reboot the entire main system. 3.8 Low Power Management With the use of advanced power-management technologies, ESP8684 series can switch between different power modes. • Active mode: CPU and chip radio are powered on. The chip can receive, transmit, or listen. • Modem-sleep mode: The CPU is operational and the clock speed can be reduced. Wireless base band, and radio are disabled, but wireless connection can remain active. Espressif Systems 22 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description • Light-sleep mode: The CPU is paused. Any wake-up events (MAC, host, RTC timer, or external interrupts) will wake up the chip. Wireless connection can remain active. • Deep-sleep mode: CPU and most peripherals are powered down. Only the PMU in RTC power management unit is powered on. For more details, please refer to Figure 1. For power consumption in different power modes, please refer to Current Consumption. 3.9 Cryptographic Hardware Accelerators ESP8684 series is equipped with hardware accelerators of general algorithms, such as: • SHA1/SHA224/SHA256 (FIPS PUB 180-4) • ECC 3.10 Physical Security Features • SiP flash encryption (AES-XTS algorithm) with software inaccessible key prevents unauthorized readout of your application code or data. • Secure boot feature uses a hardware root of trust to ensure only signed firmware can be booted. 3.11 Peripheral Pin Configurations Table 8: Peripheral Pin Configurations Interface Signal Pin Function ADC ADC1_CH0 GPIO0 One 12-bit SAR ADC ADC1_CH1 GPIO1 ADC1_CH2 GPIO2 ADC1_CH3 GPIO3 ADC1_CH4 MTMS MTDI MTDI MTCK MTCK MTMS MTMS MTDO MTDO U0RXD_in Any GPIO pins JTAG UART JTAG for software debugging Two UART channels with hardware flow control U0CTS_in U0DSR_in U0TXD_out U0RTS_out U0DTR_out U1RXD_in U1CTS_in U1DSR_in U1TXD_out U1RTS_out U1DTR_out Espressif Systems 23 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 3 Functional Description Interface Signal Pin Function I2C I2CEXT0_SCL_in Any GPIO pins One I2C channel in slave or master mode Six independent PWM channels • Master mode and slave mode of SPI, Dual I2CEXT0_SDA_in I2CEXT0_SCL_out I2CEXT0_SDA_out LED PWM ledc_ls_sig_out0~5 Any GPIO pins SPI2 FSPICLK_in/_out_mux Any GPIO pins SPI, Quad SPI, and QPI FSPICS0_in/_out • Connection to external flash, RAM, and FSPICS1~5_out other SPI devices FSPID_in/_out FSPIQ_in/_out • Four modes of SPI transfer format FSPIWP_in/_out • Configurable SPI frequency FSPIHD_in/_out • 64-byte FIFO or GDMA buffer Espressif Systems 24 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 4 Electrical Characteristics 4 Electrical Characteristics 4.1 Absolute Maximum Ratings Stresses beyond the absolute maximum ratings listed in the table below may cause permanent damage to the device. These are stress ratings only, and do not refer to the functional operation of the device. Table 9: Absolute Maximum Ratings Symbol Parameter VDDA3P3, VDDA, VDD3P3_RTC, Voltage applied to power supply pins VDD3P3_CPU per power domain Ioutput 1 Cumulative IO output current TST ORE 1 Min Storage temperature Max Unit –0.3 3.6 V — 730 mA –40 150 °C The chip worked properly after a 24-hour test in ambient temperature at 25 °C, and the IOs in two domains (VDD3P3_RTC, VDD3P3_CPU) output high logic level to ground. 4.2 Recommended Operating Conditions Table 10: Recommended Operating Conditions Symbol Parameter Min Typ Max Unit VDDA3P3, VDDA, VDD3P3_RTC, Voltage applied to power supply pin 3.0 3.3 3.6 V IV DD 2 Current delivered by external power supply 0.5 — — A TA Operating ambient temperature -40 — 105 °C VDD3P3_CPU 1 1 To write eFuse, VDD3P3_CPU should not be higher than 3.3 V. 2 If you use a single power supply, the recommended output current is 500 mA or more. 4.3 DC Characteristics (3.3 V, 25 °C) Table 11: DC Characteristics (3.3 V, 25 °C) Symbol Parameter CIN Pin capacitance VIH Min Typ — High-level input voltage 0.75 × VDD 1 Max 2 — Unit — pF 1 VDD + 0.3 V 1 VIL Low-level input voltage –0.3 — 0.25 × VDD IIH High-level input current — — 50 nA Low-level input current — — 50 nA — — V IIL VOH VOL 2 2 High-level output voltage 0.8 × VDD Low-level output voltage 1 — — 0.1 × VDD — 40 — 1 V V 1 IOH High-level source current (VDD = 3.3 V, VOH >= 2.64 V, PAD_DRIVER = 3) Espressif Systems 25 Submit Documentation Feedback mA ESP8684 Datasheet (Version v1.2) 4 Electrical Characteristics Low-level sink current (VDD1= 3.3 V, VOL = IOL 0.495 V, PAD_DRIVER = 3) — 28 — mA — kΩ — kΩ RP U Pull-up resistor — 45 RP D Pull-down resistor — 45 VIH_nRST VIL_nRST Chip reset release voltage 0.75 × VDD Chip reset voltage 1 –0.3 1 VDD is the I/O voltage for a particular power domain of pins. 2 VOH and VOL are measured using high-impedance load. 1 — VDD + 0.3 — 0.25 × VDD V 1 V 4.4 ADC Characteristics Table 12: ADC Characteristics Symbol Parameter Min ADC connected to an external DNL (Differential nonlinearity)1 100 nF capacitor; DC signal input; ambient temperature at 25 °C; INL (Integral nonlinearity) Wi-Fi off Sampling rate — Max Unit –1 3 LSB –4 8 LSB — 100 kSPS 2 1 To get better DNL results, you can sample multiple times and apply a filter, or calculate the average value. 2 kSPS means kilo samples-per-second. ESP-IDF provides a couple of calibration methods for ADC. Results after calibration using hardware + software calibration are shown in Table 13. For higher accuracy, users may apply other calibration methods provided in ESP-IDF, or implement their own. Table 13: ADC Calibration Results Parameter Total error Espressif Systems Description Min Max Unit ATTEN0, effective measurement range of 0 ~ 950 -5 5 mV ATTEN3, effective measurement range of 0 ~ 2800 -10 10 mV 26 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 4 Electrical Characteristics 4.5 Current Consumption 4.5.1 RF Current Consumption in Active Mode The current consumption measurements are taken with a 3.3 V supply at 25 °C of ambient temperature at the RF port. All transmitters’ measurements are based on a 100% duty cycle. Table 14: Current Consumption Depending on RF Modes Work mode Peak Description (mA) TX Active (RF working) RX 802.11b, 1 Mbps, @22 dBm 370 802.11g, 54 Mbps, @20 dBm 320 802.11n, HT20, MCS7, @19 dBm 300 802.11b/g/n, HT20 65 4.5.2 Current Consumption in Other Modes Table 15: Current Consumption in Low­Power Modes Work mode Description Typ Unit Light-sleep — 140 µA Deep-sleep Only RTC timer is powered on 5 µA Power off CHIP_EN is set to low level, and the chip is powered off 1 µA Table 16: Current Consumption in Modem­sleep Mode Frequency Work mode Description (MHz) 80 Modem-sleep3 120 Typ1 Typ2 (mA) (mA) WFI (Wait-for-Interrupt) 9.4 10.3 CPU run at full speed 12.1 13.0 WFI (Wait-for-Interrupt) 10.7 11.5 CPU run at full speed 14.7 15.6 1 Current consumption when all peripheral clocks are disabled. 2 Current consumption when all peripheral clocks are enabled. In practice, the current consumption might be different depending on which peripherals are enabled. 3 In Modem-sleep mode, Wi-Fi is clock gated, and the current consumption might be higher when accessing flash. For a flash rated at 80 Mbit/s, in SPI 2-line mode the consumption is 10 mA. 4.6 Reliability Espressif Systems 27 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 4 Electrical Characteristics Table 17: Reliability Qualifications Test Item HTOL (High Temperature Operating Life) Test Conditions Test Standard 125 °C, 1000 hours JESD22-A108 HBM (Human Body Mode)1± 2000 V ESD (Electro-Static Discharge Sensitivity) JS-001 2 CDM (Charge Device Mode) ± 1000 V JS-002 Current trigger ± 200 mA Latch up JESD78 Voltage trigger 1.5 × VDDmax Bake 24 hours @125 °C Preconditioning J-STD-020, JESD47, Moisture soak (level 3: 192 hours @30 °C, 60% RH) IR reflow solder: 260 + 0 °C, 20 seconds, three times TCT (Temperature Cycling Test) JESD22-A113 –65 °C / 150 °C, 500 cycles JESD22-A104 130 °C, 85% RH, 96 hours JESD22-A118 150 °C, 1000 hours JESD22-A103 –40 °C, 1000 hours JESD22-A119 uHAST (Highly Accelerated Stress Test, unbiased) HTSL (High Temperature Storage Life) LTSL (Low Temperature Storage Life) 1 JEDEC document JEP155 states that 500 V HBM allows safe manufacturing with a standard ESD control process. 2 JEDEC document JEP157 states that 250 V CDM allows safe manufacturing with a standard ESD control process. 4.7 Wi­Fi Radio Table 18: Wi­Fi Frequency Parameter Center frequency of operating channel Min Typ Max (MHz) (MHz) (MHz) 2412 — 2484 4.7.1 Wi­Fi RF Transmitter (TX) Specifications Table 19: TX Power with Spectral Mask and EVM Meeting 802.11 Standards Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps — 21.5 — 802.11b, 11 Mbps — 21.5 — 802.11g, 6 Mbps — 21.5 — 802.11g, 54 Mbps — 19.5 — 802.11n, HT20, MCS0 — 21.0 — 802.11n, HT20, MCS7 — 19.0 — Rate Espressif Systems 28 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 4 Electrical Characteristics Table 20: TX EVM Test Rate Min Typ SL1 (dB) (dB) (dB) 802.11b, 1 Mbps, @21.5 dBm — –25.2 –10 802.11b, 11 Mbps, @21.5 dBm — –25.2 –10 802.11g, 6 Mbps, @21.5 dBm — –20.4 –5 802.11g, 54 Mbps, @19.5 dBm — –26.8 –25 802.11n, HT20, MCS0, @21 dBm — –21.0 –5 802.11n, HT20, MCS7, @19 dBm — –29.0 –27 1 SL stands for standard limit value. 4.7.2 Wi­Fi RF Receiver (RX) Specifications Table 21: RX Sensitivity Rate Min Typ Max (dBm) (dBm) (dBm) 802.11b, 1 Mbps — –99.0 — 802.11b, 2 Mbps — –96.5 — 802.11b, 5.5 Mbps — –94.0 — 802.11b, 11 Mbps — –90.0 — 802.11g, 6 Mbps — –94.0 — 802.11g, 9 Mbps — –92.0 — 802.11g, 12 Mbps — –91.0 — 802.11g, 18 Mbps — –89.0 — 802.11g, 24 Mbps — –86.0 — 802.11g, 36 Mbps — –83.0 — 802.11g, 48 Mbps — –78.5 — 802.11g, 54 Mbps — –77.0 — 802.11n, HT20, MCS0 — –92.5 — 802.11n, HT20, MCS1 — –90.5 — 802.11n, HT20, MCS2 — –87.5 — 802.11n, HT20, MCS3 — –84.5 — 802.11n, HT20, MCS4 — –81.5 — 802.11n, HT20, MCS5 — –77.5 — 802.11n, HT20, MCS6 — –75.5 — 802.11n, HT20, MCS7 — –74.0 — Table 22: Maximum RX Level Rate 802.11b, 1 Mbps Min Typ Max (dBm) (dBm) (dBm) — 5 — Cont’d on next page Espressif Systems 29 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 4 Electrical Characteristics Table 22 – cont’d from previous page Min Typ Max (dBm) (dBm) (dBm) 802.11b, 11 Mbps — 5 — 802.11g, 6 Mbps — 5 — 802.11g, 54 Mbps — 0 — 802.11n, HT20, MCS0 — 5 — 802.11n, HT20, MCS7 — -1 — Rate Table 23: RX Adjacent Channel Rejection Rate Min Typ Max (dB) (dB) (dB) 802.11b, 1 Mbps — 35 — 802.11b, 11 Mbps — 35 — 802.11g, 6 Mbps — 31 — 802.11g, 54 Mbps — 20 — 802.11n, HT20, MCS0 — 31 — 802.11n, HT20, MCS7 — 16 — 4.8 Bluetooth LE Radio Table 24: Bluetooth LE Frequency Parameter Center frequency of operating channel Min Typ Max (MHz) (MHz) (MHz) 2402 — 2480 4.8.1 Bluetooth LE RF Transmitter (TX) Specifications Table 25: Transmitter General Characteristics Parameter RF transmit power 1 1 Description Min RF power control range –24.0 Typ Max — 21.0 Unit dBm Target center frequency range and transmit power are configurable by software. See ESP RF Test Tool and Test Guide for more details. Table 26: Transmitter Characteristics ­ Bluetooth LE 1 Mbps Parameter Carrier frequency offset and drift Description Min Typ Max Unit Max |fn |n=0, 1, 2, ..k — 1.0 — kHz Max |f0 − fn | — 2.3 — kHz Max |fn − fn−5 | — 1.4 — kHz Cont’d on next page Espressif Systems 30 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 4 Electrical Characteristics Table 26 – cont’d from previous page Parameter Description Modulation characteristics In-band spurious emissions Min Typ Max Unit |f1 − f0 | — 1.5 — kHz ∆ f 1avg — 250.2 — kHz — 234.4 — kHz ∆ f 2avg /∆ f 1avg — 1.0 — — ± 2 MHz offset — –32 — dBm ± 3 MHz offset — –38 — dBm > ± 3 MHz offset — –41 — dBm Min ∆ f 2max (for at least 99.9% of all ∆ f 2max ) Table 27: Transmitter Characteristics ­ Bluetooth LE 2 Mbps Parameter Description Carrier frequency offset and drift Modulation characteristics In-band spurious emissions Min Typ Max Unit Max |fn |n=0, 1, 2, ..k — 3.7 — kHz Max |f0 − fn | — 1.8 — kHz Max |fn − fn−5 | — 1.5 — kHz |f1 − f0 | — 1.1 — kHz ∆ f 1avg — 500.0 — kHz — 460.7 — kHz ∆ f 2avg /∆ f 1avg — 1.0 — — ± 4 MHz offset — –40 — dBm ± 5 MHz offset — –43 — dBm > ± 5 MHz offset — –44 — dBm Min ∆ f 2max (for at least 99.9% of all ∆ f 2max ) Table 28: Transmitter Characteristics ­ Bluetooth LE 125 Kbps Parameter Description Carrier frequency offset and drift Modulation characteristics Min Max Unit Max |fn |n=0, 1, 2, ..k — 0.6 — kHz Max |f0 − fn | — 0.7 — kHz |fn − fn−3 | — 0.4 — kHz |f0 − f3 | — 0.7 — kHz ∆ f 1avg — 250.0 — kHz — 241.0 — kHz ± 2 MHz offset — –32 — dBm ± 3 MHz offset — –38 — dBm > ± 3 MHz offset — –41 — dBm Min ∆ f 1max (for at least 99.9% of all∆ f 2max ) In-band spurious emissions Typ Table 29: Transmitter Characteristics ­ Bluetooth LE 500 Kbps Parameter Description Min Max |fn |n=0, 1, 2, ..k Max 0.5 — Unit kHz Cont’d on next page Carrier frequency offset and drift Espressif Systems — Typ 31 Submit Documentation Feedback ESP8684 Datasheet (Version v1.2) 4 Electrical Characteristics Table 29 – cont’d from previous page Parameter Description Modulation characteristics Min Max Unit Max |f0 − fn | — 0.6 — kHz |fn − fn−3 | — 0.2 — kHz |f0 − f3 | — 0.8 — kHz ∆ f 2avg — 251.3 — kHz — 234.5 — kHz ± 2 MHz offset — –32 — dBm ± 3 MHz offset — –38 — dBm > ± 3 MHz offset — –41 — dBm Min ∆ f 2max (for at least 99.9% of all ∆ f 2max ) In-band spurious emissions Typ 4.8.2 Bluetooth LE RF Receiver (RX) Specifications Table 30: Receiver Characteristics ­ Bluetooth LE 1 Mbps Parameter Description Sensitivity @30.8% PER — — –98.0 — dBm Maximum received signal @30.8% PER — — 8 — dBm Co-channel C/I F = F0 MHz — 8 — dB F = F0 + 1 MHz — -1 — dB F = F0 – 1 MHz — -3 — dB F = F0 + 2 MHz — –26 — dB F = F0 – 2 MHz — –28 — dB F = F0 + 3 MHz — –34 — dB F = F0 – 3 MHz — –33 — dB F >= F0 + 4 MHz — –33 — dB F = F0 + 8 MHz — –39 — dB F = F0 + 4 MHz — –41 — dB F = F0 + 4 MHz — –34 — dB F
ESP8684H2 价格&库存
很抱歉,暂时无法提供与“ESP8684H2”相匹配的价格&库存,您可以联系我们找货
