| 11'1 II~ Ir!'t .'I~):I'':].川UM ELECTROLYTIC CAPACITORS
AiSH~
RS series
噩噩
• High performance , high reliability
. l口w
impadanca , high rippla currant , long lifa
• Endurance: +1 05'C 4 ,000-1 0 ,000 hours
• RoHS Compliant
SPECIFICATIONS
lωm.
ca脑gory Temperature
Charactørlatlcs
Ra nge
-40同时 05'C
RatedVol恒ge Range
6.3-120Vd.
CapacilanωTolaranω
士 20%(M)
laa阳ga
1.:50.01 CVor 3μA , whiche内,er is greater.
Whe障, 1:Max.leakage current (IIA), C:Nominal capacitance
Currant
(at20'C ,120Hz)
阳
R
atadVol
口创It同
匈
a
伊@叫(Vd
g
由eφ)
叫
[阳
叫
M
6町{叫
Oissipetion Faclor (饱nð)
1佣
o 河16
6.3
部
25
阴
5o
Rated voltage (V)
臼
63
(at 20'C after2 minute8)
8ωo 河1 ∞ :河120
:旦
阳一芒…
M
巨2 一0.19 …
0 16二 L~:.叫1 ~.;0.12
川二 0.10川9 口斗口8' 口 η
wh
惘
en noml阳
na
副Ic俑泊p
阳
挝c蚓lt
a
忧tancωe excωee
时
ds
钊1 ,0
阳
IIF,
Rated Voltage(Vdc)
low Tamperature
臼
35
(~F),V:
8.3
10
16
25
add 0.02 tωo the value above for each 1, 000 1l F Increase.
35
50
83
80
100
(at 20'C ,120Hz)
120 :
Characteris苗。s
(Max.lmp创ance
Ratio)
Z( -2S'C)/Z( +20'C)
4
Z( -4 0'C)/Z(+20'C)
8
3
i
6
2
4
i
3
3
6
i
Tha spacifications listød ba low sha 11 ba mat whan tha 臼pacitors ara rastorad to 20'C aftar OC voltaga plus 帽tad rippla
cu寸ant is appl iad for a spaci币4月riod ofti …--tip-ic.;……………丁
Loadll白(hou古} ……!
Ola
Capacltan饵 Cha叼e
量:t 20% ofthe Inltlal value (6.3 , 10V: 孟:t 30%)
[.. _._. .....;..~,~::-.1_O_v: .. j 贷-120V i
ØD";8.3 : 4 ,000
5 , 000
D.F. (tanð)
:5: 200% ofthe initialspecified v回 lue
ØO=8& 10
6 ,000
7 , 000
LaakagaCur晴 nt
~Tha initial spacifiad valua
;iõ
., ....S.:Õ'OÕ..... ,.. '1(
Endurance
'''øo
The following specifications shall be satisfiad when the
105' C for 1, 000 hours.
Shelf Life
c回pacitors
ú'.s'
i:ooo'"
are rastored to 20'。回fter leaving tham under no load at
γ ……………………………...………………,…… 「
Capacitance Changø
量土 20%
ofthø initial valua (6.3 , 10咿:仕 30%)
D.F. (tanð)
量200%
oftha initialspecifiad valuø
Leakage Cur阳nt
~200%
ofthe initialspaci而edvalue
DIMENSIONS[mm]
@ah
←-里冒"但
(at 120Hz)
时::tO.5
(Ø5 -ø 18)
4mln.
PART NUMBERING SYSTEM
E
RS 1H
Tt
t
81田ve Cod e: 'C' for 阿生主旦旦I
Tenmlnal code
Siza ∞de
capaci饱n面目>da
capacl回n国 tolaran曲目>da
vo阳啕e ∞de
Ser1es∞de
E些塑旦旦旦旦
RATED RIPPLE CURRENT MULTIP Ll ERS
Frequency correction factor for ri pple current
ι证时?
120
1k
10k
100k
Cap.
很抱歉,暂时无法提供与“ERS1JM121F12OT”相匹配的价格&库存,您可以联系我们找货
