EKZM500ETD221MJ16S
EKZM500ETD221MJ16S
    NCC(贵弥功)
    插件,D10xL16mm
EKZM500ETD221MJ16S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS KZM Low impedance, 105℃ KZN Series Higher ripple ・Long-Life version of KZH series ・Endurance with ripple current : 6,000 to 10,000 hours at 105℃ ・Newly innovative electrolyte is employed to minimize ESR ・Rated voltage range : 6.3 to 50Vdc, Nominal capacitance range : 27 to 10,000µF ・Non solvent resistant type ・RoHS2 Compliant KZM Longer life KZH ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 6.3 to 50Vdc ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V tanδ (Max.) 0.22 0.19 0.16 0.14 0.12 0.10 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. Z (-25℃) / Z (+20℃) 2max. Z (-40℃) / Z (+20℃) 3max. Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃. Time φ5 &φ6.3 : 6,000hours φ8 : 8,000hours φ10 to φ18 : 10,000hours Capacitance change ≦±25% of the initial value (6.3, 10Vdc : ≦± 30%) D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±25% of the initial value (6.3, 10Vdc : ≦±30%) D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] F±0.5 Code : E φD' φd Sleeve(PET : Brown) F±0.5 ●Terminal L' 15min. 4min. (φ5 to φ10) (φ12.5 to φ18) φD 5 φd 0.5 2.0 F φD' L' 6.3 0.5 2.5 10 12.5 16 8 0.6 0.6 0.6 0.8 3.5 5.0 5.0 7.5 φD+0.5max. L+1.5max. 18 0.8 7.5 Gas escape end seal Vent (Exceptφ5 &φ6.3) ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KZM AAA E AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 100µF:101, 1,000µF:102) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3, 10V:100) Series code Category Please refer to "Product code guide (radial lead type)" ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Capacitance(µF) 27 220 680 2,200 4,700 to to to to to 180 560 1,800 3,900 10,000 120 0.40 0.50 0.60 0.75 0.85 1k 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 Note : The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KZMSeries ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 Cap (µF) Case size φD×L(mm) tanδ 220 470 820 1,200 1,200 1,500 1,800 2,200 2,700 3,900 4,700 5,600 6,800 6,800 8,200 10,000 150 330 680 1,000 1,000 1,500 1,500 1,800 2,200 3,300 3,900 4,700 4,700 5,600 6,800 8,200 100 220 470 680 680 1,000 1,000 1,500 1,800 2,200 2,700 3,300 3,300 3,900 4,700 5,600 5× 11 6.3×11 8×11.5 8×15 10 ×12.5 8×20 10 ×16 10× 20 10× 25 12.5× 20 12.5× 25 12.5× 30 12.5× 35 16 × 20 16 × 25 18 × 25 5× 11 6.3×11 8× 11.5 8× 15 10 ×12.5 8× 20 10 ×16 10 ×20 10 ×25 12.5× 20 12.5× 25 12.5× 30 16 ×20 12.5× 35 16 ×25 18 ×25 5× 11 6.3×11 8×11.5 8×15 10× 12.5 8× 20 10× 16 10 × 20 10 × 25 12.5× 20 12.5× 25 12.5× 30 16 ×20 12.5×35 16 ×25 18 ×25 0.22 0.22 0.22 0.22 0.22 0.22 0.22 0.24 0.24 0.26 0.28 0.30 0.32 0.32 0.36 0.40 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.19 0.21 0.23 0.23 0.25 0.25 0.27 0.29 0.33 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.16 0.18 0.18 0.20 0.20 0.20 0.22 0.24 Impedance (Ω max./100kHz) 20℃ -10℃ 0.22 0.094 0.056 0.045 0.039 0.029 0.028 0.020 0.018 0.017 0.015 0.013 0.012 0.015 0.013 0.012 0.22 0.094 0.056 0.045 0.039 0.029 0.028 0.020 0.018 0.017 0.015 0.013 0.015 0.012 0.013 0.012 0.22 0.094 0.056 0.045 0.039 0.029 0.028 0.020 0.018 0.017 0.015 0.013 0.015 0.012 0.013 0.012 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.031 0.038 0.035 0.031 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.038 0.031 0.035 0.031 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.038 0.031 0.035 0.031 Rated ripple current (mArms/105℃, 100kHz) Part No. 345 540 945 1,250 1,330 1,500 1,760 1,960 2,250 2,480 2,900 3,450 3,570 3,250 3,630 3,650 345 540 945 1,250 1,330 1,500 1,760 1,960 2,250 2,480 2,900 3,450 3,250 3,570 3,630 3,650 345 540 945 1,250 1,330 1,500 1,760 1,960 2,250 2,480 2,900 3,450 3,250 3,570 3,630 3,650 EKZM6R3E□□221ME11D EKZM6R3E□□471MF11D EKZM6R3E□□821MHB5D EKZM6R3E□□122MH15D EKZM6R3E□□122MJC5S EKZM6R3E□□152MH20D EKZM6R3E□□182MJ16S EKZM6R3E□□222MJ20S EKZM6R3E□□272MJ25S EKZM6R3E□□392MK20S EKZM6R3E□□472MK25S EKZM6R3E□□562MK30S EKZM6R3E□□682MK35S EKZM6R3E□□682ML20S EKZM6R3E□□822ML25S EKZM6R3E□□103MM25S EKZM100E□□151ME11D EKZM100E□□331MF11D EKZM100E□□681MHB5D EKZM100E□□102MH15D EKZM100E□□102MJC5S EKZM100E□□152MH20D EKZM100E□□152MJ16S EKZM100E□□182MJ20S EKZM100E□□222MJ25S EKZM100E□□332MK20S EKZM100E□□392MK25S EKZM100E□□472MK30S EKZM100E□□472ML20S EKZM100E□□562MK35S EKZM100E□□682ML25S EKZM100E□□822MM25S EKZM160E□□101ME11D EKZM160E□□221MF11D EKZM160E□□471MHB5D EKZM160E□□681MH15D EKZM160E□□681MJC5S EKZM160E□□102MH20D EKZM160E□□102MJ16S EKZM160E□□152MJ20S EKZM160E□□182MJ25S EKZM160E□□222MK20S EKZM160E□□272MK25S EKZM160E□□332MK30S EKZM160E□□332ML20S EKZM160E□□392MK35S EKZM160E□□472ML25S EKZM160E□□562MM25S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KZMSeries ◆STANDARD RATINGS WV (Vdc) 25 35 50 Cap (µF) Case size φD×L(mm) tanδ 68 150 330 390 470 560 680 820 1,000 1,500 1,800 2,200 2,200 2,700 3,300 3,900 47 100 220 270 330 390 470 560 680 1,000 1,200 1,500 1,500 1,800 2,200 2,700 27 56 100 120 150 180 220 270 330 470 560 680 820 820 1,000 1,500 5× 11 6.3× 11 8×11.5 8×15 10× 12.5 8×20 10× 16 10× 20 10× 25 12.5 ×20 12.5 ×25 12.5 ×30 16× 20 12.5 ×35 16× 25 18× 25 5×11 6.3 ×11 8×11.5 8×15 10 ×12.5 8×20 10 ×16 10 ×20 10 ×25 12.5 ×20 12.5 ×25 12.5 ×30 16 ×20 12.5 ×35 16 ×25 18 ×25 5×11 6.3×11 8×11.5 8×15 10× 12.5 8× 20 10 × 16 10 × 20 10 ×25 12.5×20 12.5×25 12.5×30 12.5×35 16 ×20 16 ×25 18 ×25 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.16 0.16 0.16 0.18 0.18 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.14 0.14 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 Impedance (Ω max./100kHz) 20℃ -10℃ 0.22 0.094 0.056 0.045 0.039 0.029 0.028 0.020 0.018 0.017 0.015 0.013 0.015 0.012 0.013 0.012 0.22 0.094 0.056 0.045 0.039 0.029 0.028 0.020 0.018 0.017 0.015 0.013 0.015 0.012 0.013 0.012 0.34 0.14 0.074 0.061 0.061 0.046 0.042 0.030 0.028 0.027 0.023 0.021 0.019 0.023 0.021 0.019 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.038 0.031 0.035 0.031 0.80 0.35 0.19 0.15 0.14 0.11 0.10 0.060 0.054 0.043 0.038 0.033 0.038 0.031 0.035 0.031 1.18 0.50 0.22 0.18 0.18 0.14 0.12 0.090 0.085 0.068 0.059 0.052 0.051 0.059 0.056 0.051 Rated ripple current (mArms/105℃, 100kHz) Part No. 345 540 945 1,250 1,330 1,500 1,760 1,960 2,250 2,480 2,900 3,450 3,250 3,570 3,630 3,650 345 540 945 1,250 1,330 1,500 1,760 1,960 2,250 2,480 2,900 3,450 3,250 3,570 3,630 3,650 238 385 724 950 979 1,190 1,370 1,580 1,870 2,050 2,410 2,860 2,960 2,730 3,010 3,290 EKZM250E□□680ME11D EKZM250E□□151MF11D EKZM250E□□331MHB5D EKZM250E□□391MH15D EKZM250E□□471MJC5S EKZM250E□□561MH20D EKZM250E□□681MJ16S EKZM250E□□821MJ20S EKZM250E□□102MJ25S EKZM250E□□152MK20S EKZM250E□□182MK25S EKZM250E□□222MK30S EKZM250E□□222ML20S EKZM250E□□272MK35S EKZM250E□□332ML25S EKZM250E□□392MM25S EKZM350E□□470ME11D EKZM350E□□101MF11D EKZM350E□□221MHB5D EKZM350E□□271MH15D EKZM350E□□331MJC5S EKZM350E□□391MH20D EKZM350E□□471MJ16S EKZM350E□□561MJ20S EKZM350E□□681MJ25S EKZM350E□□102MK20S EKZM350E□□122MK25S EKZM350E□□152MK30S EKZM350E□□152ML20S EKZM350E□□182MK35S EKZM350E□□222ML25S EKZM350E□□272MM25S EKZM500E□□270ME11D EKZM500E□□560MF11D EKZM500E□□101MHB5D EKZM500E□□121MH15D EKZM500E□□151MJC5S EKZM500E□□181MH20D EKZM500E□□221MJ16S EKZM500E□□271MJ20S EKZM500E□□331MJ25S EKZM500E□□471MK20S EKZM500E□□561MK25S EKZM500E□□681MK30S EKZM500E□□821MK35S EKZM500E□□821ML20S EKZM500E□□102ML25S EKZM500E□□152MM25S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EKZM500ETD221MJ16S 价格&库存
很抱歉,暂时无法提供与“EKZM500ETD221MJ16S”相匹配的价格&库存,您可以联系我们找货
